Hi! I would like to create a dtc reading on i-miEV/ Peugeot iOn. But if is send the following command: OVMS# obd can1 request device 761 762 19020f 761[762] 19020f: request failed with response error code 80 I now use hobdrive app to read dtc code with OBDlink LX
Tamás, a) are you sure the DTC is in device 761/762? There are three more devices in the i-MiEV source. b) maybe you need to give another status mask, e.g. 1902ae or just all DTCs by 1902ff -- did you try that? c) you can also try the other DTC retrieval subfunctions, e.g. 1901<mask> to get just the number of DTCs (see ISO spec for more) Regards, Michael Am 19.06.21 um 18:13 schrieb Tamás Kovács:
Hi!
I would like to create a dtc reading on i-miEV/ Peugeot iOn. But if is send the following command: OVMS#obd can1 request device 761 762 19020f 761[762] 19020f: request failed with response error code 80
a) a test with another two device b) nothing working c) if i use 19 Poll type and vehicle set to trio no response, if vehicle empty set get 80-error code If i connect simultaneously another device can i capture the DTC code reading with ovms using a Y OBD cable? My car always have a U1113 DTC error because not have a EV-REMOTE ECU. I have a log file created with ovms when i read and clean the dtc codes with hobdrive. Another error codes: P1A39 (BMU), P1A33 (BMU), P1A7E (CMU) Log file: https://drive.google.com/file/d/1zcIcMsBYLEoubafO1P6JW_GchZXI7WLD/view?usp=s... Michael Balzer <dexter@expeedo.de> ezt írta (időpont: 2021. jún. 19., Szo, 18:55):
Tamás,
Regards, Michael
Hi!
-- Üdvözlettel: Kovács Tamás
That log file is missing too many frames to be readable, and the logger should have told you that. Maybe your OVMS has an SD speed issue? Have you tried raising the optimization hints? https://docs.openvehicles.com/en/latest/crtd/can_logging.html#optimizing-the... Anyway, it seems your tool queries at least the four ECUs defined in the source. It uses diag session 0x92 (i.e. request 1092), and then request 1800ff00 to retrieve the DTCs. 18 is not a standard UDS command, but some VW ECUs (especially the TP2.0 ones) also use this (but there it's 1802ff00). You can try other subfunctions, i.e. 1801, 1802, etc. to see if you get something else than "subfunction not supported". To clear the DTCs, the tool seems to use the standard command 14, but with non-standard parameters: the log has a request 14ff00 to 771 (but the response is missing). Due to the missing frames, your DTCs are not readable in the log. Try to get a log without dropped frames. Regards, Michael Am 20.06.21 um 09:02 schrieb Tamás Kovács:
My car always have a U1113 DTC error because not have a EV-REMOTE ECU. I have a log file created with ovms when i read and clean the dtc codes with hobdrive. Another error codes: P1A39 (BMU), P1A33 (BMU), P1A7E (CMU) Log file: https://drive.google.com/file/d/1zcIcMsBYLEoubafO1P6JW_GchZXI7WLD/view?usp=s... <https://drive.google.com/file/d/1zcIcMsBYLEoubafO1P6JW_GchZXI7WLD/view?usp=sharing>
Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> ezt írta (időpont: 2021. jún. 19., Szo, 18:55):
Tamás,
Regards, Michael
Hi!
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
Now i create a new log file without dropped frame, with filter. https://drive.google.com/file/d/1o477jmllYyntpmLJca_3aTmL2NvYZfsZ/view?usp=s... Only active error code is U1113. This is a U1113 Error? 1624253728.207555 1R11 751 04 18 00 ff 00 00 00 00 1624253728.213037 1R11 752 05 58 01 d1 13 e0 00 8e OVMS# obd can1 request device 751 752 1800ff00 751[752] 1800ff00: Response: 01 d1 13 e0 | .... if i decode this d1 = 11010001 bit 6-7 = 11 -» U bit 4-5 = 01 -» 1 bit 0-3 = 0001 -» 1 so the error code is: U1113 OVMS# obd can1 request device 751 752 1801ff00 751[752] 1801ff00: Response: df 05 62 00 00 b4 00 00 b3 00 21 23 00 21 22 00 | ..b.......!#.!". 1a 00 00 21 28 00 21 27 00 1a 01 00 21 38 00 05 | ...!(.!'....!8.. 58 00 05 57 00 1b 31 00 1a f0 00 1b 19 00 1b 1a | X..W..1......... 00 1b 1b 00 28 05 00 07 05 00 1a 02 00 1a 03 00 | ....(........... 1a 04 00 1a 2c 00 1a 06 00 1a 07 00 1a 08 00 1a | ....,........... 09 00 1a 0a 00 1a 0b 00 1a 0c 00 1a 0d 00 1a 0e | ................ 00 1a 0f 00 0c 73 00 0c 74 00 0a 05 00 1b 2b 00 | .....s..t.....+. 06 91 00 06 92 00 06 93 00 06 94 00 0a 01 00 1a | ................ 10 00 1a 11 00 1a 12 00 06 46 00 06 47 00 d8 01 | .........F..G... 00 d8 02 00 d8 03 00 d8 04 00 d8 05 00 d8 06 00 | ................ 1a 14 00 1b 0a 00 0a e6 00 0a e7 00 0a e2 00 0a | ................ db 00 0a a1 00 0a df 00 0a a4 00 0a 0a 00 1a 15 | ................ 00 1a 16 00 1a 17 00 0a 09 00 0a 10 00 1b 29 00 | ..............). 1b 2a 00 1a 18 00 1a 19 00 06 0b 00 06 05 00 06 | .*.............. 04 00 06 0c 00 16 02 00 06 2f 00 d1 90 00 d0 73 | ........./.....s 00 1b 09 00 d1 1b 00 d1 1c 00 d1 1d 00 d1 10 00 | ................ d1 02 00 d1 04 00 1b 35 00 d1 08 00 d1 09 00 d1 | .......5........ 05 00 1b 36 00 d1 13 e0 d1 06 00 d1 6a 00 d1 6b | ...6........j..k 00 d9 10 00 d9 00 00 d9 11 00 d9 01 00 1a 1a 00 | ................ 1a f1 00 1a f2 00 1a f3 00 05 60 00 1a 1b 00 1a | ..........`..... 1c 00 1a 22 00 1a 1e 00 d0 80 00 d1 60 00 d9 20 | ..."........`.. 00 0a ba 00 1a 1f 00 0a 2a 00 0a 3d 00 0a ed 00 | ........*..=.... 0a 51 00 1a 20 00 1a 21 00 1a 23 00 1a 24 00 1a | .Q.. ..!..#..$.. 25 00 1a 26 00 1a 27 00 1a 28 00 1a 29 00 1a 2a | %..&..'..(..)..* 00 0a 90 00 0a 78 00 1a 2b 00 1a 3d 00 1a 3e 00 | .....x..+..=..>. 1a 3f 00 1b 1c 00 1b 1d 00 0a bf 00 1a 44 00 1a | .?...........D.. 45 00 1a 2d 00 1a 2e 00 1a 2f 00 1a 30 00 1a 31 | E..-...../..0..1 00 1a 32 00 1b 33 00 1a 33 00 1a 34 00 1b 34 00 | ..2..3..3..4..4. 1a 35 00 1a e6 00 d0 81 00 d1 61 00 d0 90 00 1a | .5........a..... 38 00 d9 21 00 d9 24 00 1a f4 00 1a f5 00 1a 39 | 8..!..$........9 00 1b 1e 00 1b 1f 00 1a c5 00 1b 2f 00 1b 21 00 | .........../..!. 1a f6 00 1a f7 00 1a f8 00 1a f9 00 1a fa 00 1a | ................ fb 00 1a fc 00 1a fd 00 1a fe 00 1a ff 00 1b 00 | ................ 00 1b 01 00 1b 02 00 1b 03 00 1b 04 00 1b 05 00 | ................ 1b 06 00 1b 07 00 1b 08 00 1b 0c 00 1b 0d 00 1b | ................ 0b 00 1b 22 00 1b 23 00 1b 24 00 1b 25 00 1b 26 | ..."..#..$..%..& 00 1b 27 00 1b 28 00 1b 2c 00 1b 30 00 1b 2d 00 | ..'..(..,..0..-. 1b 32 00 d1 17 00 05 13 00 12 31 00 1b 37 00 91 | .2........1..7.. 78 00 60 05 00 60 06 00 60 07 00 60 0a 00 60 0e | x.`..`..`..`..`. 00 60 0f 00 60 10 00 60 11 00 60 16 00 60 18 00 | .`..`..`..`..`.. 60 19 00 60 1a 00 60 20 00 60 21 00 60 22 00 60 | `..`..` .`!.`".` 2a 00 60 2b 00 60 2c 00 60 2d 00 60 2e 00 | *.`+.`,.`-.`.. OVMS# obd can1 request device 751 752 1802ff00 751[752] 1802ff: ERROR: request failed with response error code 12 subFunctionNotSupported This is clear of dtc codes? 1624253725.617633 1R11 751 03 14 ff 00 00 00 00 00 1624253725.618253 1R11 752 03 54 ff 00 13 e0 00 8e Michael Balzer <dexter@expeedo.de> ezt írta (időpont: 2021. jún. 20., V, 13:54):
Regards, Michael
Tamás,
Regards, Michael
Hi!
_______________________________________________ OvmsDev mailing listOvmsDev@lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
Tamás, your interpretation is correct. The DTC status byte e0 also decodes to… warningIndicatorRequested + testNotCompletedThisOperationCycle + testFailedSinceLastClear …and lacks confirmedDTC, so the fault condition did not occur often enough to be stored in long term memory. I would assume 1801ff00 returns all DTC codes supported by the ECU, which are 0xdf = 223 codes of 3 bytes each (containing d1 13 e0). All other DTCs seem to have status 00, so only this DTC occured since the last clear.
OVMS#obd can1 request device 751 752 1802ff00 751[752] 1802ff: ERROR: request failed with response error code 12 subFunctionNotSupported
You should try some further subfunctions, 02 returning subFunctionNotSupported doesn't mean all higher ones are unsupported as well. Best would be a loop through all 256 to be sure. That's pretty simple using the new Duktape binding: (function(){ var cmd = new Uint8Array([0x18, 0x00]); var req = { txid: 0x751, rxid: 0x752, request: cmd }; var res, subfn; for (subfn = 0; subfn <= 255; subfn++) { cmd[1] = subfn; res = OvmsVehicle.ObdRequest(req); if (res.error != 0x12) print(subfn.toString(16) + ": " + res.errordesc + res.response_hex + "\n"); } })() Whereever you get something else than code 12 subFunctionNotSupported is worth investigating with parameters. Some ECUs store snapshots or extended records for DTCs, see the UDS command scheme for 19 -- maybe something similar can be found here using command 18.
Yes, 14ff00, the response is an ACK/OK to that. Regards, Michael Am 21.06.21 um 08:41 schrieb Tamás Kovács:
Now i create a new log file without dropped frame, with filter. https://drive.google.com/file/d/1o477jmllYyntpmLJca_3aTmL2NvYZfsZ/view?usp=s... <https://drive.google.com/file/d/1o477jmllYyntpmLJca_3aTmL2NvYZfsZ/view?usp=sharing>
OVMS#obd can1 request device 751 752 1800ff00 751[752] 1800ff00: Response: 01 d1 13 e0 | .... if i decode this d1 = 11010001 bit 6-7 = 11 -» U bit 4-5 = 01 -» 1 bit 0-3 = 0001 -» 1 so the error code is: U1113
OVMS# obd can1 request device 751 752 1801ff00 751[752] 1801ff00: Response: df 05 62 00 00 b4 00 00 b3 00 21 23 00 21 22 00 | ..b.......!#.!". 1a 00 00 21 28 00 21 27 00 1a 01 00 21 38 00 05 | ...!(.!'....!8.. 58 00 05 57 00 1b 31 00 1a f0 00 1b 19 00 1b 1a | X..W..1......... 00 1b 1b 00 28 05 00 07 05 00 1a 02 00 1a 03 00 | ....(........... 1a 04 00 1a 2c 00 1a 06 00 1a 07 00 1a 08 00 1a | ....,........... 09 00 1a 0a 00 1a 0b 00 1a 0c 00 1a 0d 00 1a 0e | ................ 00 1a 0f 00 0c 73 00 0c 74 00 0a 05 00 1b 2b 00 | .....s..t.....+. 06 91 00 06 92 00 06 93 00 06 94 00 0a 01 00 1a | ................ 10 00 1a 11 00 1a 12 00 06 46 00 06 47 00 d8 01 | .........F..G... 00 d8 02 00 d8 03 00 d8 04 00 d8 05 00 d8 06 00 | ................ 1a 14 00 1b 0a 00 0a e6 00 0a e7 00 0a e2 00 0a | ................ db 00 0a a1 00 0a df 00 0a a4 00 0a 0a 00 1a 15 | ................ 00 1a 16 00 1a 17 00 0a 09 00 0a 10 00 1b 29 00 | ..............). 1b 2a 00 1a 18 00 1a 19 00 06 0b 00 06 05 00 06 | .*.............. 04 00 06 0c 00 16 02 00 06 2f 00 d1 90 00 d0 73 | ........./.....s 00 1b 09 00 d1 1b 00 d1 1c 00 d1 1d 00 d1 10 00 | ................ d1 02 00 d1 04 00 1b 35 00 d1 08 00 d1 09 00 d1 | .......5........ 05 00 1b 36 00 d1 13 e0 d1 06 00 d1 6a 00 d1 6b | ...6........j..k 00 d9 10 00 d9 00 00 d9 11 00 d9 01 00 1a 1a 00 | ................ 1a f1 00 1a f2 00 1a f3 00 05 60 00 1a 1b 00 1a | ..........`..... 1c 00 1a 22 00 1a 1e 00 d0 80 00 d1 60 00 d9 20 | ..."........`.. 00 0a ba 00 1a 1f 00 0a 2a 00 0a 3d 00 0a ed 00 | ........*..=.... 0a 51 00 1a 20 00 1a 21 00 1a 23 00 1a 24 00 1a | .Q.. ..!..#..$.. 25 00 1a 26 00 1a 27 00 1a 28 00 1a 29 00 1a 2a | %..&..'..(..)..* 00 0a 90 00 0a 78 00 1a 2b 00 1a 3d 00 1a 3e 00 | .....x..+..=..>. 1a 3f 00 1b 1c 00 1b 1d 00 0a bf 00 1a 44 00 1a | .?...........D.. 45 00 1a 2d 00 1a 2e 00 1a 2f 00 1a 30 00 1a 31 | E..-...../..0..1 00 1a 32 00 1b 33 00 1a 33 00 1a 34 00 1b 34 00 | ..2..3..3..4..4. 1a 35 00 1a e6 00 d0 81 00 d1 61 00 d0 90 00 1a | .5........a..... 38 00 d9 21 00 d9 24 00 1a f4 00 1a f5 00 1a 39 | 8..!..$........9 00 1b 1e 00 1b 1f 00 1a c5 00 1b 2f 00 1b 21 00 | .........../..!. 1a f6 00 1a f7 00 1a f8 00 1a f9 00 1a fa 00 1a | ................ fb 00 1a fc 00 1a fd 00 1a fe 00 1a ff 00 1b 00 | ................ 00 1b 01 00 1b 02 00 1b 03 00 1b 04 00 1b 05 00 | ................ 1b 06 00 1b 07 00 1b 08 00 1b 0c 00 1b 0d 00 1b | ................ 0b 00 1b 22 00 1b 23 00 1b 24 00 1b 25 00 1b 26 | ..."..#..$..%..& 00 1b 27 00 1b 28 00 1b 2c 00 1b 30 00 1b 2d 00 | ..'..(..,..0..-. 1b 32 00 d1 17 00 05 13 00 12 31 00 1b 37 00 91 | .2........1..7.. 78 00 60 05 00 60 06 00 60 07 00 60 0a 00 60 0e | x.`..`..`..`..`. 00 60 0f 00 60 10 00 60 11 00 60 16 00 60 18 00 | .`..`..`..`..`.. 60 19 00 60 1a 00 60 20 00 60 21 00 60 22 00 60 | `..`..` .`!.`".` 2a 00 60 2b 00 60 2c 00 60 2d 00 60 2e 00 | *.`+.`,.`-.`.. OVMS#obd can1 request device 751 752 1802ff00 751[752] 1802ff: ERROR: request failed with response error code 12 subFunctionNotSupported This is clear of dtc codes?
Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> ezt írta (időpont: 2021. jún. 20., V, 13:54):
Maybe your OVMS has an SD speed issue? Have you tried raising the optimization hints? https://docs.openvehicles.com/en/latest/crtd/can_logging.html#optimizing-the... <https://docs.openvehicles.com/en/latest/crtd/can_logging.html#optimizing-the-performance>
Regards, Michael
Tamás,
Regards, Michael
Hi!
Michael Balzer -
Tamás Kovács
