version 3.2.007: Crash on boot
Hi folks, Well, the module updated to 3.2.007 last night. I just checked on it, and it appears that it didn't exactly survive. Crashed while running the autoconfig script. Log with two cycles attached. I tried renaming the /store/events directory to /store/was_events since it seems like Duktape was getting in the way, but that didn't resolve the crash. I manually enabled wifi so I could manage the module, and moved it back to 3.2.005 from the other partition. Seems stable again. The car is going into the Service Center tomorrow (the perennial issue with 1146 alerts), so I need to have the module stable so that I can keep an eye on it. Going to leave it on 3.2.005 for now, unless someone has a quick fix in the next few hours... Otherwise, any ideas for troubleshooting after I get the car back back (hopefully end of day)? Greg
Mark, Greg uses your build, the crash point seems to be consistent, can you post the a2l on this? Regards, Michael PS: Greg, would you mind switching to EAP to beta test future releases? Am 11.12.19 um 04:33 schrieb Greg D.:
Hi folks,
Greg
Can’t get a2l working at the moment. The addr2line gives: addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551 That is: void canbus::LogInfo(CAN_log_type_t type, const char* text) { MyCan.LogInfo(this, type, text); <—— HERE } ELF is at: http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf <http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf> Regards, Mark.
On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter@expeedo.de> wrote:
Mark,
Regards, Michael
Hi folks,
Greg
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Mark, good example why not to use addr2line: I think that result is wrong. a2l uses gdb which gives: balzer@leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> a2l tmp/3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 Using elf file: tmp/3.2.007.ovms3.elf 0x400d5e4c is in CAN_rxtask(void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:730). 725 me->IncomingFrame(&msg.body.frame); 726 } while (loop); 727 break; 728 } 729 case CAN_txcallback: 730 msg.body.bus->TxCallback(&msg.body.frame, true); 731 break; 732 case CAN_txfailedcallback: 733 msg.body.bus->TxCallback(&msg.body.frame, false); 734 msg.body.bus->LogStatus(CAN_LogStatus_Error); …and that actually makes sense and matches the register dump. If I read the gdb disassembly correctly, A10 = msg.body.bus, so Greg's got a CAN_txcallback msg without a bus. Hardening the rxtask against null here would probably avoid the crash, but I don't see yet how that could be possible. Both esp32can and mcp2515 set the bus field to their object addresses, which cannot be null. Regards, Michael Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson:
That is:
ELF is at:
On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Mark,
Regards, Michael
Hi folks,
Greg
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Odd. Wonder which bus it was that it didn't have? I might try disabling the auto start of the obd2ecu task, and see if that changes things. But that task doesn't transmit until it receives something from the device first. Perhaps the first test would be to unplug the obdii dongle that's connected to the CAN3 bus, since it's the wildcard here, then work back from there. The car is at Tesla right now, with them trying to determine once and for all the source of the 1146 alerts. ETA Friday... Fingers crossed... Greg On December 11, 2019 10:29:19 AM PST, Michael Balzer <dexter@expeedo.de> wrote:
Mark,
Regards, Michael
That is:
ELF is at:
Mark,
Regards, Michael
releases?
Hi folks,
it,
Greg
-- This space for rent...
Greg, I suspect the obd2ecu is a victim of the changes to can drivers related to swcan support. A temporary workaround of disabling obd2ecu would help confirm that. Regards, Mark.
On 12 Dec 2019, at 2:57 AM, Greg D <gregd2350@gmail.com> wrote:
Odd.
Fingers crossed...
Greg
On December 11, 2019 10:29:19 AM PST, Michael Balzer <dexter@expeedo.de> wrote: Mark,
balzer@leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3 <mailto:balzer@leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3>> a2l tmp/3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 Using elf file: tmp/3.2.007.ovms3.elf 0x400d5e4c is in CAN_rxtask(void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:730). 725 me->IncomingFrame(&msg.body.frame); 726 } while (loop); 727 break; 728 } 729 case CAN_txcallback: 730 msg.body.bus->TxCallback(&msg.body.frame, true); 731 break; 732 case CAN_txfailedcallback: 733 msg.body.bus->TxCallback(&msg.body.frame, false); 734 msg.body.bus->LogStatus(CAN_LogStatus_Error);
Regards, Michael
That is:
ELF is at:
Mark,
Regards, Michael
Hi folks,
Greg
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
-- This space for rent... _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Two issues: 1] A2L My a2l is this: #!/bin/bash elf=3.2.007.ovms3.elf for adr in $* ; do if [[ "$adr" =~ "elf" ]] ; then elf="$adr" else cmd+=" -ex 'l *$adr'" fi done cmd+=" -ex 'q'" echo "Using elf file: $elf" echo "xtensa-esp32-elf-gdb -batch $elf $cmd" eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null #| grep "^0x.* is in " When I run it, I get: $ a2l 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 Using elf file: 3.2.007.ovms3.elf xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex ‘q' And a manual run gives: $ xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex 'q' Junk at end of line specification. $ xtensa-esp32-elf-gdb 3.2.007.ovms3.elf GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 7.10 (gdb) l *0x400d5e4c:0x3ffc5c40 Junk at end of line specification. (gdb) l *0x7ffffffd:0x3ffc5c90 (gdb) quit 2] Frame origin Regarding the CAN_txcallback, I think you are correct. And both generators of that message set the frame correctly. So my initial thought was that it is either a memory corruption, or somewhere else sending a frame with garbage data. I do see this technique used in both the mcp2515 and esp32can drivers: msg.body.bus = me; msg.body.frame = me->tx_frame; I don’t normally just copy structures over like that. I memcpy() them, but I guess it must work. However, as our CAN_queue_msg_t is a union of CAN_frame_t (frame, with first member of the structure a canbus*) and 'canbus* bus’, that is a little worrying. It seems that the msg.body.bus will get overwritten with whatever is in msg.body.frame.origin. I can’t see anywhere that tx_frame.origin is set - which is scary because that would mean it is always random junk. Maybe it works if tx_frame.origin is set to the bus before anything else, but not in Greg’s circumstances where something else arrives first. Perhaps related to obd2ecu? I only see tx_frame set in can.cpp canbus::Write. I don’t really understand the tx_frame approach at all, and why the frame is just not passed on the queue. // CAN Frame // Note: Take care changing this structure, as it is a union with // CAN_log_message_t and position of 'origin' is fixed. struct CAN_frame_t { canbus* origin; // Origin of the frame CanFrameCallback * callback; // Frame-specific callback. Is called when this frame is successfully sent (or sending failed) CAN_FIR_t FIR; // Frame information record uint32_t MsgID; // Message ID union { uint8_t u8[8]; // Payload byte access uint32_t u32[2]; // Payload u32 access (Att: little endian!) uint64_t u64; // Payload u64 access (Att: little endian!) } data; esp_err_t Write(canbus* bus=NULL, TickType_t maxqueuewait=0); // bus: NULL=origin }; // CAN message typedef struct { CAN_queue_type_t type; union { CAN_frame_t frame; // CAN_frame canbus* bus; } body; } CAN_queue_msg_t; This approach seems to date back to the swcan support merge (f94ae5a1b). Should we swap around, and set the msg.body.bus after msg.body.frame? Or am I missing something… Regards, Mark.
On 12 Dec 2019, at 2:29 AM, Michael Balzer <dexter@expeedo.de> wrote:
Mark,
Regards, Michael
That is:
ELF is at:
Mark,
Regards, Michael
Hi folks,
Greg
Mark, 1) maybe I missed posting my later version of a2l, which automatically strips the stack pointers from the ":" address syntax so you can copy&paste the USB output. Here it is: #!/bin/bash elf=~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf for adr in $* ; do if [[ "$adr" =~ "elf" ]] ; then elf="$adr" else cmd+=" -ex 'l *${adr/:*/}'" fi done cmd+=" -ex 'q'" echo "Using elf file: $elf" 2) You're right, the bug is tx_frame with null origin overwriting body.bus in the union. I didn't notice that when checking Marko's submission. tx_frame is a copy of the last frame given to the bus for transmission. The queue msg is gone when the TX done IRQ comes in, and Marko needed a copy of the frame the TX IRQ relates to. I asked him (see PR discussion), he checked and confirmed that all TX is done sequentially, so a single buffer is sufficient. Swapping the lines would work. The frame.origin also shouldn't be null, but the handler should tolerate that. …oops, tx_frame also doesn't get initialized in the canbus constructor, so there's also potentially garbage in tx_frame if due to some bug a TX IRQ is generated or processed without a previous tx. I'll do the fixes… and also rename tx_frame to m_tx_frame for consistency. Regards, Michael Am 12.12.19 um 01:20 schrieb Mark Webb-Johnson:
Two issues:
_*1] A2L*_
My a2l is this:
_*2] Frame origin*_
On 12 Dec 2019, at 2:29 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Mark,
Regards, Michael
That is:
ELF is at:
Mark,
Regards, Michael
Hi folks,
Greg
Last line of a2l was missing: #!/bin/bash elf=~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf for adr in $* ; do if [[ "$adr" =~ "elf" ]] ; then elf="$adr" else cmd+=" -ex 'l *${adr/:*/}'" fi done cmd+=" -ex 'q'" echo "Using elf file: $elf" eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null Am 12.12.19 um 11:12 schrieb Michael Balzer:
Mark,
Regards, Michael
Two issues:
_*1] A2L*_
My a2l is this:
_*2] Frame origin*_
Mark,
Regards, Michael
That is:
ELF is at:
Mark,
Regards, Michael
Hi folks,
Greg
Fix commit is https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/8fef... Greg, please test. New build with SPIRAM fix: https://ovms.dexters-web.de/firmware/ota/v3.1/edge/ Regards, Michael Am 12.12.19 um 11:17 schrieb Michael Balzer:
Mark,
Regards, Michael
Two issues:
_*1] A2L*_
My a2l is this:
_*2] Frame origin*_
Mark,
Regards, Michael
That is:
ELF is at:
Mark,
Regards, Michael
Am 11.12.19 um 04:33 schrieb Greg D.: > Hi folks, > > Well, the module updated to 3.2.007 last night. I just checked on it, > and it appears that it didn't exactly survive. Crashed while running > the autoconfig script. Log with two cycles attached. > > I tried renaming the /store/events directory to /store/was_events since > it seems like Duktape was getting in the way, but that didn't resolve > the crash. I manually enabled wifi so I could manage the module, and > moved it back to 3.2.005 from the other partition. Seems stable again. > > The car is going into the Service Center tomorrow (the perennial issue > with 1146 alerts), so I need to have the module stable so that I can > keep an eye on it. Going to leave it on 3.2.005 for now, unless someone > has a quick fix in the next few hours... > > Otherwise, any ideas for troubleshooting after I get the car back back > (hopefully end of day)? > > Greg > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Greg, Mark, the new crash happened here: balzer@leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> a2l 0x3ffcfda0:0x3ffc87a0 0x400da762:0x3ffc87d0 0x400da95b:0x3ffc87f0 0x400da901:0x3ffc8810 Using elf file: /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf 0x400da762 is in can::ExecuteCallbacks(CAN_frame_t const*, bool, bool) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:866). 861 { 862 if (tx) 863 { 864 if (frame->callback) 865 { 866 (*(frame->callback))(frame, success); // invoke frame-specific callback function 867 } 868 for (auto entry : m_txcallbacks) { // invoke generic tx callbacks 869 entry->m_callback(frame, success); 870 } 0x400da95b is in canbus::TxCallback(CAN_frame_t*, bool) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:1018). 1013 } 1014 else 1015 { 1016 LogFrame(CAN_LogFrame_TX_Fail, p_frame); 1017 } 1018 MyCan.ExecuteCallbacks(p_frame, true, success); 1019 } 1020 1021 /** 1022 * canbus::Write -- main TX API 0x400da901 is in CAN_rxtask(void*) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:730). 725 me->IncomingFrame(&msg.body.frame); 726 } while (loop); 727 break; 728 } 729 case CAN_txcallback: 730 msg.body.bus->TxCallback(&msg.body.frame, true); 731 break; 732 case CAN_txfailedcallback: 733 msg.body.bus->TxCallback(&msg.body.frame, false); 734 msg.body.bus->LogStatus(CAN_LogStatus_Error); As the frame callback invocation is secured against null, it must have been a missing initialization of frame.callback. So I checked our source tree for uses of CAN_frame_t without memset or zero initialization and found one in obd2ecu::IncomingFrame() -- causing this crash I assume -- and two more in the can rx/tx shell commands. Fix is in commit https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/3430... …and build in https://ovms.dexters-web.de/firmware/ota/v3.1/edge/ Greg, please test again. Regards, Michael Am 13.12.19 um 07:09 schrieb Greg D.:
Hi Michael,
Ok, so I believe I loaded your Edge build, and the issue remains. To verify, this is the string reported by the web Status page:
3.2.007-102-g07440970/ota_1/main (build idf v3.3-beta3-774-g6652269e1 Dec 12 2019 11:59:14)
Following my earlier email, I left the configuration as-is, including launching the obd2ecu task, but with the attached OBDII module removed, and the crash was resolved. Rebooting the module had it come up running normally. I then plugged in the OBDII module into the OVMSv3, and OVMS crashed the instant the first it started polling. The device is a SyncUp Drive, which is a telematics and WiFi hotspot. Connecting the OBDII device with 12v power off, as expected, did nothing. Power it on, wait a few seconds to boot, and OVMS crashes immediately.
New console log, attached. It shows the module booting normally (OBDII device not present), followed by the device being attached (indicated in the log), and the subsequent crash. I removed the device right after the boot started, so as to let the OVMS boot normally.
So, clearly the obd2ecu task it is receiving frames on CAN3 just fine, but transmits back out on that same bus aren't working. Is this something I need to address within obd2ecu, or is it in the core code? I've not changed obd2ecu in quite some time.
Greg
Greg, please test.
Regards, Michael
Mark,
Regards, Michael
Two issues:
_*1] A2L*_
My a2l is this:
_*2] Frame origin*_
Mark,
Regards, Michael
Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson: > Can’t get a2l working at the moment. The addr2line gives: > > addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 > /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551 > > > That is: > > void canbus::LogInfo(CAN_log_type_t type, const char* text) > { > MyCan.LogInfo(this, type, text); <—— HERE > } > > > ELF is at: > > http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf > > > Regards, Mark. > >> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >> >> Mark, >> >> Greg uses your build, the crash point seems to be consistent, can you post the a2l on this? >> >> Regards, >> Michael >> >> PS: Greg, would you mind switching to EAP to beta test future releases? >> >> >> Am 11.12.19 um 04:33 schrieb Greg D.: >>> Hi folks, >>> >>> Well, the module updated to 3.2.007 last night. I just checked on it, >>> and it appears that it didn't exactly survive. Crashed while running >>> the autoconfig script. Log with two cycles attached. >>> >>> I tried renaming the /store/events directory to /store/was_events since >>> it seems like Duktape was getting in the way, but that didn't resolve >>> the crash. I manually enabled wifi so I could manage the module, and >>> moved it back to 3.2.005 from the other partition. Seems stable again. >>> >>> The car is going into the Service Center tomorrow (the perennial issue >>> with 1146 alerts), so I need to have the module stable so that I can >>> keep an eye on it. Going to leave it on 3.2.005 for now, unless someone >>> has a quick fix in the next few hours... >>> >>> Otherwise, any ideas for troubleshooting after I get the car back back >>> (hopefully end of day)? >>> >>> Greg >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> >> -- >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Just saw the can shell commands actually do an explicit init of frame.callback, so that added zero init is superfluous now. I'll keep it because doing the init is good style to allow future extensions without hassle. The obd2ecu frame use was definitely broken. Am 13.12.19 um 10:15 schrieb Michael Balzer:
Greg, Mark,
Regards, Michael
Hi Michael,
Greg
Greg, please test.
Regards, Michael
Mark,
Regards, Michael
Two issues:
_*1] A2L*_
My a2l is this:
_*2] Frame origin*_
> On 12 Dec 2019, at 2:29 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: > > Mark, > > good example why not to use addr2line: I think that result is wrong. a2l uses gdb which gives: > > balzer@leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> a2l tmp/3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 > Using elf file: tmp/3.2.007.ovms3.elf > 0x400d5e4c is in CAN_rxtask(void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:730). > 725 me->IncomingFrame(&msg.body.frame); > 726 } while (loop); > 727 break; > 728 } > 729 case CAN_txcallback: > 730 msg.body.bus->TxCallback(&msg.body.frame, true); > 731 break; > 732 case CAN_txfailedcallback: > 733 msg.body.bus->TxCallback(&msg.body.frame, false); > 734 msg.body.bus->LogStatus(CAN_LogStatus_Error); > > …and that actually makes sense and matches the register dump. > > If I read the gdb disassembly correctly, A10 = msg.body.bus, so Greg's got a CAN_txcallback msg without a bus. > > Hardening the rxtask against null here would probably avoid the crash, but I don't see yet how that could be possible. > Both esp32can and mcp2515 set the bus field to their object addresses, which cannot be null. > > Regards, > Michael > > > Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson: >> Can’t get a2l working at the moment. The addr2line gives: >> >> addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 >> /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551 >> >> >> That is: >> >> void canbus::LogInfo(CAN_log_type_t type, const char* text) >> { >> MyCan.LogInfo(this, type, text); <—— HERE >> } >> >> >> ELF is at: >> >> http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf >> >> >> Regards, Mark. >> >>> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>> >>> Mark, >>> >>> Greg uses your build, the crash point seems to be consistent, can you post the a2l on this? >>> >>> Regards, >>> Michael >>> >>> PS: Greg, would you mind switching to EAP to beta test future releases? >>> >>> >>> Am 11.12.19 um 04:33 schrieb Greg D.: >>>> Hi folks, >>>> >>>> Well, the module updated to 3.2.007 last night. I just checked on it, >>>> and it appears that it didn't exactly survive. Crashed while running >>>> the autoconfig script. Log with two cycles attached. >>>> >>>> I tried renaming the /store/events directory to /store/was_events since >>>> it seems like Duktape was getting in the way, but that didn't resolve >>>> the crash. I manually enabled wifi so I could manage the module, and >>>> moved it back to 3.2.005 from the other partition. Seems stable again. >>>> >>>> The car is going into the Service Center tomorrow (the perennial issue >>>> with 1146 alerts), so I need to have the module stable so that I can >>>> keep an eye on it. Going to leave it on 3.2.005 for now, unless someone >>>> has a quick fix in the next few hours... >>>> >>>> Otherwise, any ideas for troubleshooting after I get the car back back >>>> (hopefully end of day)? >>>> >>>> Greg >>>> >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> >>> -- >>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > -- > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
My code crashed with same error as it described. plus one error: in esp32can.cpp:448 The files can access my dropbox folder: https://www.dropbox.com/sh/mowc7hc7zrzszmm/AACO4MAmM1yF3yoXsGoZO6R_a?dl=0 Michael Balzer <dexter@expeedo.de> ezt írta (időpont: 2019. dec. 13., P, 10:16):
Greg, Mark,
Regards, Michael
Hi Michael,
Greg
Greg, please test.
Regards, Michael
Mark,
Regards, Michael
Two issues:
*1] A2L*
My a2l is this:
*2] Frame origin*
Mark,
Regards, Michael
That is:
ELF is at:
Mark,
Regards, Michael
Hi folks,
Greg
_______________________________________________ OvmsDev mailing listOvmsDev@lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
-- Üdvözlettel: Kovács Tamás
Tamás, I'm confused, and your dropbox files don't help… did you merge the fix and still get the crash? Is your version just off because your repository lacks tags (if so: why?), or are you on a local spin-off branch of 3.2.005? I've got the impression your git repository is messed up. Maybe you should try a new clone? Regards, Michael Am 15.12.19 um 20:13 schrieb Tamás Kovács:
Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> ezt írta (időpont: 2019. dec. 13., P, 10:16):
Greg, Mark,
balzer@leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3 <mailto:balzer@leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3>> a2l 0x3ffcfda0:0x3ffc87a0 0x400da762:0x3ffc87d0 0x400da95b:0x3ffc87f0 0x400da901:0x3ffc8810 Using elf file: /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf 0x400da762 is in can::ExecuteCallbacks(CAN_frame_t const*, bool, bool) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:866). 861 { 862 if (tx) 863 { 864 if (frame->callback) 865 { 866 (*(frame->callback))(frame, success); // invoke frame-specific callback function 867 } 868 for (auto entry : m_txcallbacks) { // invoke generic tx callbacks 869 entry->m_callback(frame, success); 870 } 0x400da95b is in canbus::TxCallback(CAN_frame_t*, bool) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:1018). 1013 } 1014 else 1015 { 1016 LogFrame(CAN_LogFrame_TX_Fail, p_frame); 1017 } 1018 MyCan.ExecuteCallbacks(p_frame, true, success); 1019 } 1020 1021 /** 1022 * canbus::Write -- main TX API 0x400da901 is in CAN_rxtask(void*) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:730). 725 me->IncomingFrame(&msg.body.frame); 726 } while (loop); 727 break; 728 } 729 case CAN_txcallback: 730 msg.body.bus->TxCallback(&msg.body.frame, true); 731 break; 732 case CAN_txfailedcallback: 733 msg.body.bus->TxCallback(&msg.body.frame, false); 734 msg.body.bus->LogStatus(CAN_LogStatus_Error);
Regards, Michael
Hi Michael,
Greg
Greg, please test.
Regards, Michael
Mark,
Regards, Michael
Two issues:
_*1] A2L*_
My a2l is this:
_*2] Frame origin*_
> On 12 Dec 2019, at 2:29 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: > > Mark, > > good example why not to use addr2line: I think that result is wrong. a2l uses gdb which gives: > > balzer@leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3 <mailto:balzer@leela:%7E/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3>> > a2l tmp/3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 > Using elf file: tmp/3.2.007.ovms3.elf > 0x400d5e4c is in CAN_rxtask(void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:730). > 725 me->IncomingFrame(&msg.body.frame); > 726 } while (loop); > 727 break; > 728 } > 729 case CAN_txcallback: > 730 msg.body.bus->TxCallback(&msg.body.frame, true); > 731 break; > 732 case CAN_txfailedcallback: > 733 msg.body.bus->TxCallback(&msg.body.frame, false); > 734 msg.body.bus->LogStatus(CAN_LogStatus_Error); > > …and that actually makes sense and matches the register dump. > > If I read the gdb disassembly correctly, A10 = msg.body.bus, so Greg's got a CAN_txcallback msg without a bus. > > Hardening the rxtask against null here would probably avoid the crash, but I don't see yet how that could be possible. > Both esp32can and mcp2515 set the bus field to their object addresses, which cannot be null. > > Regards, > Michael > > > Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson: >> Can’t get a2l working at the moment. The addr2line gives: >> >> addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 >> /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551 >> >> >> That is: >> >> void canbus::LogInfo(CAN_log_type_t type, const char* text) >> { >> MyCan.LogInfo(this, type, text); <—— HERE >> } >> >> >> ELF is at: >> >> http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf >> >> >> Regards, Mark. >> >>> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>> >>> Mark, >>> >>> Greg uses your build, the crash point seems to be consistent, can you post the a2l on this? >>> >>> Regards, >>> Michael >>> >>> PS: Greg, would you mind switching to EAP to beta test future releases? >>> >>> >>> Am 11.12.19 um 04:33 schrieb Greg D.: >>>> Hi folks, >>>> >>>> Well, the module updated to 3.2.007 last night. I just checked on it, >>>> and it appears that it didn't exactly survive. Crashed while running >>>> the autoconfig script. Log with two cycles attached. >>>> >>>> I tried renaming the /store/events directory to /store/was_events since >>>> it seems like Duktape was getting in the way, but that didn't resolve >>>> the crash. I manually enabled wifi so I could manage the module, and >>>> moved it back to 3.2.005 from the other partition. Seems stable again. >>>> >>>> The car is going into the Service Center tomorrow (the perennial issue >>>> with 1146 alerts), so I need to have the module stable so that I can >>>> keep an eye on it. Going to leave it on 3.2.005 for now, unless someone >>>> has a quick fix in the next few hours... >>>> >>>> Otherwise, any ideas for troubleshooting after I get the car back back >>>> (hopefully end of day)? >>>> >>>> Greg >>>> >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> >>> -- >>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > -- > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Yes I merged the fix. I don't understand why my version is 3.2.005. Now I try to new clone I think. I don't know what's this: "or are you on a local spin-off branch of 3.2.005". I always create modification on my code then I upload it to my git repo and then create a compare with the main open vehicles repo then I update my local code in atom with a fetch. Michael Balzer <dexter@expeedo.de> ezt írta (időpont: 2019. dec. 16., H, 18:54):
Tamás,
Regards, Michael
Greg, Mark,
Regards, Michael
Hi Michael,
Greg
Greg, please test.
Regards, Michael
Mark,
Regards, Michael
Two issues:
*1] A2L*
My a2l is this:
*2] Frame origin*
Mark,
Regards, Michael
That is:
ELF is at:
Mark,
Regards, Michael
Hi folks,
Greg
I deleted my fork from my github repo, create a new fork from Open-Vehicle-Monitoring-System-3, now version tagging is fixed. The crash is my fault I think, missing two row from my code. In ticker60 I added the following row: CAN_frame_t frame; memset(&frame,0,sizeof(frame)); now can't get crash about 24 hour, now testing. Tamás Kovács <kommykt@gmail.com> ezt írta (időpont: 2019. dec. 16., H, 19:57):
Tamás,
Regards, Michael
Greg, Mark,
Regards, Michael
Hi Michael,
Greg
Greg, please test.
Regards, Michael
#!/bin/bash
Mark,
#!/bin/bash
Regards, Michael
Two issues:
*1] A2L*
My a2l is this:
*2] Frame origin*
Mark,
Regards, Michael
That is:
ELF is at:
Mark,
Regards, Michael
Hi folks,
Greg
Michael, It all looks good. I have tagged this as 3.2.008, and sent it to EAP. Plan is to send to MAIN this weekend. The rush is to avoid another of the new 8MB PSRAM users updating OTA and messed up their module. Any objections? Regards, Mark.
Regards, Michael
Two issues:
1] A2L
My a2l is this:
2] Frame origin
Mark,
Regards, Michael
That is:
ELF is at:
Mark,
Regards, Michael
Hi folks,
Greg
Mark, having a look at Greg's new report now, which differs from the first. Please wait for my results. Regards, Michael Am 13.12.19 um 06:05 schrieb Mark Webb-Johnson:
Michael,
It all looks good.
On 12 Dec 2019, at 6:12 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Regards, Michael
Two issues:
_*1] A2L*_
My a2l is this:
_*2] Frame origin*_
Mark,
Regards, Michael
That is:
ELF is at:
Mark,
Regards, Michael
Mark, I also recommend merging the SPIRAM fix into master now and building the factory release on that base as well (see my post Re: [Ovmsdev] Time for 3.2.006?). I've been releasing all builds on my server including the fix since June, so there is no need for further tests. Regards, Michael Am 13.12.19 um 09:35 schrieb Michael Balzer:
Mark,
Regards, Michael
Michael,
It all looks good.
Regards, Michael
Two issues:
_*1] A2L*_
My a2l is this:
_*2] Frame origin*_
Mark,
Regards, Michael
That is:
ELF is at:
> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: > > Mark, > > Greg uses your build, the crash point seems to be consistent, can you post the a2l on this? > > Regards, > Michael > > PS: Greg, would you mind switching to EAP to beta test future releases? > > > Am 11.12.19 um 04:33 schrieb Greg D.: >> Hi folks, >> >> Well, the module updated to 3.2.007 last night. I just checked on it, >> and it appears that it didn't exactly survive. Crashed while running >> the autoconfig script. Log with two cycles attached. >> >> I tried renaming the /store/events directory to /store/was_events since >> it seems like Duktape was getting in the way, but that didn't resolve >> the crash. I manually enabled wifi so I could manage the module, and >> moved it back to 3.2.005 from the other partition. Seems stable again. >> >> The car is going into the Service Center tomorrow (the perennial issue >> with 1146 alerts), so I need to have the module stable so that I can >> keep an eye on it. Going to leave it on 3.2.005 for now, unless someone >> has a quick fix in the next few hours... >> >> Otherwise, any ideas for troubleshooting after I get the car back back >> (hopefully end of day)? >> >> Greg >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > -- > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
My concern for this is that once we do it ALL developers have to also run that version of toolchain. Can we wait for Espressif to formally release this (as that seems to be happening soon)? Regards, Mark.
On 13 Dec 2019, at 8:32 PM, Michael Balzer <dexter@expeedo.de> wrote:
Mark,
Regards, Michael
Mark,
Regards, Michael
Michael,
It all looks good.
Regards, Michael
Two issues:
1] A2L
My a2l is this:
2] Frame origin
Mark,
Regards, Michael
Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson: > Can’t get a2l working at the moment. The addr2line gives: > > addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 > /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551 > > That is: > > void canbus::LogInfo(CAN_log_type_t type, const char* text) > { > MyCan.LogInfo(this, type, text); <—— HERE > } > > ELF is at: > > http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf <http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf> > > Regards, Mark. > >> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >> >> Mark, >> >> Greg uses your build, the crash point seems to be consistent, can you post the a2l on this? >> >> Regards, >> Michael >> >> PS: Greg, would you mind switching to EAP to beta test future releases? >> >> >> Am 11.12.19 um 04:33 schrieb Greg D.: >>> Hi folks, >>> >>> Well, the module updated to 3.2.007 last night. I just checked on it, >>> and it appears that it didn't exactly survive. Crashed while running >>> the autoconfig script. Log with two cycles attached. >>> >>> I tried renaming the /store/events directory to /store/was_events since >>> it seems like Duktape was getting in the way, but that didn't resolve >>> the crash. I manually enabled wifi so I could manage the module, and >>> moved it back to 3.2.005 from the other partition. Seems stable again. >>> >>> The car is going into the Service Center tomorrow (the perennial issue >>> with 1146 alerts), so I need to have the module stable so that I can >>> keep an eye on it. Going to leave it on 3.2.005 for now, unless someone >>> has a quick fix in the next few hours... >>> >>> Otherwise, any ideas for troubleshooting after I get the car back back >>> (hopefully end of day)? >>> >>> Greg >>> >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev> >> >> >> -- >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev> > > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
My concern is data corruption and crashes produced by the bug. How about keeping it unmerged until the release but doing your factory and OTA builds with the fix until then? Regards, Michael Am 15.12.19 um 13:34 schrieb Mark Webb-Johnson:
On 13 Dec 2019, at 8:32 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Mark,
Regards, Michael
Mark,
Regards, Michael
Michael,
It all looks good.
Regards, Michael
Two issues:
_*1] A2L*_
My a2l is this:
_*2] Frame origin*_
The next one bricked his new module OTA (see forum)… should be able to recover using esptool. I've released the current 3.2.008 build to my "main" directory to prevent more of this. Regards, Michael Am 15.12.19 um 14:13 schrieb Michael Balzer:
Regards, Michael
Mark,
Regards, Michael
Mark,
Regards, Michael
Michael,
It all looks good.
Regards, Michael
Am 12.12.19 um 01:20 schrieb Mark Webb-Johnson: > Two issues: > > _*1] A2L*_ > > My a2l is this: > > #!/bin/bash > elf=3.2.007.ovms3.elf > for adr in $* ; do > if [[ "$adr" =~ "elf" ]] ; then > elf="$adr" > else > cmd+=" -ex 'l *$adr'" > fi > done > cmd+=" -ex 'q'" > echo "Using elf file: $elf" > echo "xtensa-esp32-elf-gdb -batch $elf $cmd" > eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null #| grep "^0x.* is in " > > > When I run it, I get: > > $ a2l 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 > Using elf file: 3.2.007.ovms3.elf > xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex ‘q' > > > And a manual run gives: > > $ xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex 'q' > Junk at end of line specification. > > $ xtensa-esp32-elf-gdb 3.2.007.ovms3.elf > GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 7.10 > (gdb) l *0x400d5e4c:0x3ffc5c40 > Junk at end of line specification. > (gdb) l *0x7ffffffd:0x3ffc5c90 > (gdb) quit > > > _*2] Frame origin*_ > > Regarding the CAN_txcallback, I think you are correct. And both generators of that message set the frame correctly. So my initial thought was that it is > either a memory corruption, or somewhere else sending a frame with garbage data. > > I do see this technique used in both the mcp2515 and esp32can drivers: > > msg.body.bus = me; > msg.body.frame = me->tx_frame; > > > I don’t normally just copy structures over like that. I memcpy() them, but I guess it must work. However, as our CAN_queue_msg_t is a union of > CAN_frame_t (frame, with first member of the structure a canbus*) and 'canbus* bus’, that is a little worrying. It seems that the msg.body.bus will get > overwritten with whatever is in msg.body.frame.origin. I can’t see anywhere that tx_frame.origin is set - which is scary because that would mean it is > always random junk. > > Maybe it works if tx_frame.origin is set to the bus before anything else, but not in Greg’s circumstances where something else arrives first. Perhaps > related to obd2ecu? I only see tx_frame set in can.cpp canbus::Write. I don’t really understand the tx_frame approach at all, and why the frame is just > not passed on the queue. > > // CAN Frame > // Note: Take care changing this structure, as it is a union with > // CAN_log_message_t and position of 'origin' is fixed. > struct CAN_frame_t > { > canbus* origin; // Origin of the frame > CanFrameCallback * callback; // Frame-specific callback. Is called when this frame is successfully sent (or sending failed) > CAN_FIR_t FIR; // Frame information record > uint32_t MsgID; // Message ID > union > { > uint8_t u8[8]; // Payload byte access > uint32_t u32[2]; // Payload u32 access (Att: little endian!) > uint64_t u64; // Payload u64 access (Att: little endian!) > } data; > > esp_err_t Write(canbus* bus=NULL, TickType_t maxqueuewait=0); // bus: NULL=origin > }; > > // CAN message > typedef struct > { > CAN_queue_type_t type; > union > { > CAN_frame_t frame; // CAN_frame > canbus* bus; > } body; > } CAN_queue_msg_t; > > > This approach seems to date back to the swcan support merge (f94ae5a1b). > > Should we swap around, and set the msg.body.bus after msg.body.frame? Or am I missing something… > > Regards, Mark. > >> On 12 Dec 2019, at 2:29 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >> >> Mark, >> >> good example why not to use addr2line: I think that result is wrong. a2l uses gdb which gives: >> >> balzer@leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> a2l tmp/3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 >> Using elf file: tmp/3.2.007.ovms3.elf >> 0x400d5e4c is in CAN_rxtask(void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:730). >> 725 me->IncomingFrame(&msg.body.frame); >> 726 } while (loop); >> 727 break; >> 728 } >> 729 case CAN_txcallback: >> 730 msg.body.bus->TxCallback(&msg.body.frame, true); >> 731 break; >> 732 case CAN_txfailedcallback: >> 733 msg.body.bus->TxCallback(&msg.body.frame, false); >> 734 msg.body.bus->LogStatus(CAN_LogStatus_Error); >> >> …and that actually makes sense and matches the register dump. >> >> If I read the gdb disassembly correctly, A10 = msg.body.bus, so Greg's got a CAN_txcallback msg without a bus. >> >> Hardening the rxtask against null here would probably avoid the crash, but I don't see yet how that could be possible. >> Both esp32can and mcp2515 set the bus field to their object addresses, which cannot be null. >> >> Regards, >> Michael >> >> >> Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson: >>> Can’t get a2l working at the moment. The addr2line gives: >>> >>> addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 >>> /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551 >>> >>> >>> That is: >>> >>> void canbus::LogInfo(CAN_log_type_t type, const char* text) >>> { >>> MyCan.LogInfo(this, type, text); <—— HERE >>> } >>> >>> >>> ELF is at: >>> >>> http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf >>> >>> >>> Regards, Mark. >>> >>>> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>>> >>>> Mark, >>>> >>>> Greg uses your build, the crash point seems to be consistent, can you post the a2l on this? >>>> >>>> Regards, >>>> Michael >>>> >>>> PS: Greg, would you mind switching to EAP to beta test future releases? >>>> >>>> >>>> Am 11.12.19 um 04:33 schrieb Greg D.: >>>>> Hi folks, >>>>> >>>>> Well, the module updated to 3.2.007 last night. I just checked on it, >>>>> and it appears that it didn't exactly survive. Crashed while running >>>>> the autoconfig script. Log with two cycles attached. >>>>> >>>>> I tried renaming the /store/events directory to /store/was_events since >>>>> it seems like Duktape was getting in the way, but that didn't resolve >>>>> the crash. I manually enabled wifi so I could manage the module, and >>>>> moved it back to 3.2.005 from the other partition. Seems stable again. >>>>> >>>>> The car is going into the Service Center tomorrow (the perennial issue >>>>> with 1146 alerts), so I need to have the module stable so that I can >>>>> keep an eye on it. Going to leave it on 3.2.005 for now, unless someone >>>>> has a quick fix in the next few hours... >>>>> >>>>> Otherwise, any ideas for troubleshooting after I get the car back back >>>>> (hopefully end of day)? >>>>> >>>>> Greg >>>>> >>>>> >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> >>>> -- >>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> -- >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
This (new?) script probably wants to have execute permission: ice 126 % ls -l support/a2l -rw-r--r-- 1 leres wheel 304 Dec 13 09:45 support/a2l Craig
Agreed. Done.
Craig
participants (6)
Craig Leres -
Greg D -
Greg D. -
Mark Webb-Johnson -
Michael Balzer -
Tamás Kovács
