=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.12.12 21:49:33 =~=~=~=~=~=~=~=~=~=~=~= OVMS# OVMS# module reset I (480636) script: Duktape: Compacting DukTape memory OVMS# module reset Resetting system... OVMS# I (481876) boot: Shutting down for restart... I (481886) esp32wifi: Stopping WIFI station I (481886) wifi: state: run -> init (0) I (481886) wifi: pm stop, total sleep time: 435723370 us / 476801654 us I (481886) wifi: new:<6,0>, old:<6,0>, ap:<6,2>, sta:<6,0>, prof:6 I (481896) ovms-server-v2: Status: Disconnected E (481896) event: system_event_ap_stop_handle_default 223 esp_wifi_internal_reg_rxcb ret=0x3014 I (481906) wifi: flush txq I (481906) wifi: stop sw txq I (481906) wifi: lmac stop hw txq I (481916) esp32wifi: Powering down WIFI driver I (481916) wifi: Deinit lldesc rx mblock:16 I (481936) sdcard: Unmounting SDCARD for reset I (481936) simcom: State: Enter PoweringOff state I (481936) gsm-ppp: Shutting down (soft)... I (481946) gsm-ppp: PPP is shutdown I (481946) gsm-nmea: Shutdown (direct) I (481956) simcom: Power Cycle OVMS#  I (482966) netmanager: WIFI client stop I (482966) netmanager: Interface priority is pp3 (0.0.0.0/255.255.255.255 gateway 0.0.0.0) I (482966) netmanager: Set DNS#0 9.9.9.9 I (482966) netmanager: Set DNS#1 8.8.8.8 I (482966) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority I (482986) esp32wifi: STA disconnected with reason 8 = ASSOC_LEAVE I (483016) netmanager: WIFI access point is down I (483016) esp32wifi: AP stopped I (483026) sdcard: unmount done I (483026) netmanager: MODEM down (with WIFI client down): network connectivity has been lost I (483036) ovms-server-v2: Status: Server is ready to start I (483056) time: Network was reconfigured: restarting SNTP client I (483056) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds I (483056) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds I (483086) time: Stopping SNTP client I (483146) webserver: Stopping Web Server I (483146) ssh: Stopping SSH Server OVMS#  I (483626) ovms-server-v2: Status: Server is ready to start OVMS#  I (486626) boot: Restart in 55 seconds (1 pending)... OVMS#  I (491626) simcom: State timeout, transition to 1 I (491626) simcom: State: Enter CheckPowerOff state I (491626) boot: Restart in 50 seconds (1 pending)... OVMS#  I (493946) gsm-ppp: StatusCallBack: User Interrupt I (493946) gsm-ppp: PPP connection has been closed OVMS#  I (496626) boot: Restart in 45 seconds (1 pending)... OVMS#  I (501626) boot: Restart in 40 seconds (1 pending)... OVMS#  I (506626) simcom: State timeout, transition to 13 I (506626) simcom: State: Enter PoweredOff state I (506626) gsm-mux: Stop MUX I (506626) boot: Restart now OVMS# ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x3b (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:4796 load:0x40078000,len:0 load:0x40078000,len:14896 entry 0x40078d74 I (920) psram: This chip is ESP32-D0WD I (920) spiram: Found 32MBit SPI RAM device I (920) spiram: SPI RAM mode: flash 40m sram 40m I (923) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (930) cpu_start: Pro cpu up. I (934) cpu_start: Application information: I (939) cpu_start: Project name: ovms3 I (943) cpu_start: App version: 3.2.007-102-g07440970 I (950) cpu_start: Compile time: Dec 12 2019 11:58:47 I (956) cpu_start: ELF file SHA256: d151e36378c6be55... I (962) cpu_start: ESP-IDF: v3.3-beta3-774-g6652269e1 I (968) cpu_start: Starting app cpu, entry point is 0x40081820 I (960) cpu_start: App cpu up. I (1853) spiram: SPI SRAM memory test OK I (1854) heap_init: Initializing. RAM available for dynamic allocation: I (1854) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (1861) heap_init: At 3FFBED50 len 000212B0 (132 KiB): DRAM I (1866) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (1873) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (1880) heap_init: At 4009918C len 00006E74 (27 KiB): IRAM I (1886) cpu_start: Pro cpu start user code I (1890) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (19) ovms_main: Set default logging level for * to INFO I (20) command: Initialising COMMAND (1000) I (21) boot: Initialising BOOT (1100) I (24) boot: Boot #50 reasons for CPU0=12 and CPU1=12 I (29) boot: Reset reason Exception/panic (4) I (35) boot: Soft reset by user I (38) events: Initialising EVENTS (1200) I (43) config: Initialising CONFIG (1400) I (48) time: Initialising TIME (1500) I (53) script: Initialising SCRIPTS (1600) I (57) script: Using DUKTAPE javascript engine I (63) metrics: Initialising METRICS (1810) I (67) metrics: Expanding DUKTAPE javascript engine I (77) notify: Initialising NOTIFICATIONS (1820) I (79) notify: Registered notification type info I (83) notify: Registered notification type error I (88) notify: Registered notification type alert I (94) notify: Registered notification type data I (99) notify: Registered notification type stream I (104) notify: Expanding DUKTAPE javascript engine I (110) location: Initialising LOCATIONS (1900) I (117) location: Expanding DUKTAPE javascript engine I (121) vehicle: Initialising VEHICLE Factory (2000) I (128) pcp: Initialising POWER (4000) I (131) max7317: Initialising MAX7317 EGPIO (4200) I (137) sdcard: Initialising SD CARD (4400) I (142) ota: Initialising OTA (4400) I (146) canformat: Initialising CAN Format Factory (4500) I (152) canformat-crtd: Registering CAN Format: CRTD (4505) I (158) canformat-gvret: Registering CAN Format: GVRET (4505) I (164) canformat-lawricel: Registering CAN Format: LAWRICEL (4505) I (171) canformat-pcap: Registering CAN Format: PCAP (4505) I (178) canformat-raw: Registering CAN Format: RAW (4505) I (184) can: Initialising CAN (4510) I (191) dbc-app: Initialising DBC (4520) I (194) canlog: Initialising CAN logging (4550) I (198) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (205) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (213) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (220) canlog-vfs: Initialising CAN logging to VFS (4560) I (226) canplay: Initialising CAN play framework (4570) I (231) canplay-vfs: Initialising CAN playing from VFS (4580) I (238) simcom: Initialising SIMCOM (4600) I (243) test: Initialising TEST (5000) I (247) module: Initialising MODULE (5100) I (252) vfs: Initialising VFS (5200) I (256) ovms-server: Initialising OVMS Server (6000) I (262) ovms-server-v2: Initialising OVMS V2 Server (6100) I (268) ovms-server-v3: Initialising OVMS V3 Server (6200) I (274) obd2ecu: Initialising OBD2ECU (7000) I (279) canopen: Initialising CANopen (7000) I (285) esp32wifi: Initialising ESP32WIFI (8000) I (289) ovms-mdns: Initialising MDNS (8100) I (294) webserver: Initialising WEBSERVER (8200) I (302) ssh: Initialising SSH (8300) I (304) powermgmt: Initialising POWERMGMT (8500) I (309) re: Initialising RE Tools (8800) I (315) pushover: Initialising Pushover client (8800) I (320) netmanager: Initialising NETMANAGER (8999) I (328) v-zeva: Registering Vehicle: ZEVA (9000) I (330) v-voltampera: Registering Vehicle: Volt/Ampera (9000) I (336) v-track: Registering Vehicle: TRACK (9000) I (342) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (348) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (355) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (362) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (368) v-smarteq: Registering Vehicle: SMART EQ (9000) I (374) v-smarted: Registering Vehicle: SMART ED (9000) I (380) v-zoe: Registering Vehicle: Renault Zoe (9000) I (386) v-twizy: Registering Vehicle: Renault Twizy (9000) I (392) v-obdii: Registering Vehicle: OBDII (9000) I (398) v-none: Registering Vehicle: NONE (9000) I (403) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (409) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (419) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (425) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (433) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (439) v-demo: Registering Vehicle: DEMO (9000) I (444) vehicle_dbc: Registering Vehicle: DBC based vehicle (9000) I (451) version: Initialising Versioning (9900) I (460) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (0) script: Duktape: Scripting task is running I (546) ovms_main: Executing on CPU core 0 I (546) ovms_main: Mounting CONFIG... I (596) ovms_main: Configure logging... W (606) webserver: UpdateGlobalAuthFile: no password set => no auth for web console I (606) ovms_main: Registering default configs... I (606) ovms_main: Starting HOUSEKEEPING... I (616) housekeeping: Initialising HOUSEKEEPING Framework... I (616) housekeeping: Executing on CPU core 1 I (626) housekeeping: reset_reason: cpu0=12, cpu1=12 I (626) housekeeping: Initialising WATCHDOG... I (636) housekeeping: Starting PERIPHERALS... I (636) peripherals: Initialising OVMS Peripherals... I (646) peripherals: TCP/IP Adaptor I (646) peripherals: ESP32 system I (656) peripherals: SPI bus I (656) peripherals: MAX7317 I/O Expander I (666) peripherals: ESP32 CAN I (666) peripherals: ESP32 WIFI E (666) can: can1: intr=1 rxpkt=0 txpkt=0 errflags=0x40caa rxerr=1 txerr=0 rxovr=0 txovr=0 txdelay=0 wdgreset=0 errreset=0 I (676) peripherals: ESP32 ADC I (686) peripherals: MCP2515 CAN 1/2 I (686) mcp2515: can2: SetPowerMode off I (776) peripherals: MCP2515 CAN 2/2 I (776) mcp2515: can3: SetPowerMode off I (856) peripherals: SD CARD I (856) peripherals: SIMCOM MODEM I (856) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0  I (866) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0  I (876) uart: queue free spaces: 50 I (876) ext12v: Powering off external 12V devices I (886) housekeeping: Auto init max7317 (free: 182492 bytes) I (886) housekeeping: Auto init ext12v (free: 182492 bytes) I (896) ext12v: Powering on external 12V devices I (896) housekeeping: Auto init dbc (free: 182492 bytes) I (906) housekeeping: Auto init wifi (free: 182492 bytes) I (916) esp32wifi: Powering up WIFI driver I (946) wifi: wifi driver task: 3ffd44fc, prio:23, stack:3584, core=0 I (946) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (956) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (976) wifi: wifi firmware version: aeed694 I (976) wifi: config NVS flash: enabled I (976) wifi: config nano formating: disabled I (976) wifi: Init dynamic tx buffer num: 16 I (986) wifi: Init data frame dynamic rx buffer num: 16 I (986) wifi: Init management frame dynamic rx buffer num: 16 I (996) wifi: Init management short buffer num: 32 I (996) wifi: Init static rx buffer size: 2212 I (1006) wifi: Init static rx buffer num: 16 I (1006) wifi: Init dynamic rx buffer num: 16 I (1816) phy: phy_version: 4102, 2fa7a43, Jul 15 2019, 13:06:06, 0, 0 I (1816) wifi: mode : sta (30:ae:a4:43:92:88) + softAP (30:ae:a4:43:92:89) I (1826) wifi: Total power save buffer number: 8 I (1826) wifi: Init max length of beacon: 752/752 I (1836) wifi: Init max length of beacon: 752/752 I (1836) housekeeping: Auto init modem (free: 131860 bytes) I (1846) simcom: State: Enter PoweringOn state I (1846) simcom: Power Cycle I (2846) housekeeping: Auto init vehicle (free: 131068 bytes) I (2846) v-teslaroadster: Tesla Roadster v1.x, v2.x and v3.0 vehicle module I (2856) housekeeping: Auto init obd2ecu (free: 120368 bytes) I (2956) mcp2515: can3: SetPowerMode on E (2966) can: can1: intr=7 rxpkt=6 txpkt=0 errflags=0x80c00 rxerr=0 txerr=0 rxovr=0 txovr=0 txdelay=0 wdgreset=0 errreset=0 I (3056) housekeeping: Auto init server v2 (free: 113148 bytes) I (3056) ovms-server-v2: OVMS Server V2 registered metric modifier is #1 I (3066) ovms-server-v2: Status: Server has been started I (3066) ovms-server-v2: OVMS Server v2 running I (3076) housekeeping: Auto init server v3 (free: 113040 bytes) I (3076) housekeeping: Auto init javascript (free: 113040 bytes) I (3086) housekeeping: Auto init done (free: 113040 bytes) I (3096) housekeeping: Starting USB console... I (3096) uart: queue free spaces: 100 Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console Firmware: 3.2.007-102-g07440970/ota_1/main Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 OVMS# I (3116) script: Duktape: Creating heap I (3116) script: Duktape: Initialising module system E (3206) events: SignalEvent: queue overflow, event 'notify.info.charge.done' dropped E (3206) events: SignalEvent: queue overflow, event 'vehicle.charge.mode' dropped E (3236) events: SignalEvent: queue overflow, event 'vehicle.charge.prepare' dropped E (3236) events: SignalEvent: queue overflow, event 'vehicle.charge.pilot.on' dropped OVMS#  I (3436) netmanager: WIFI access point is up I (3436) esp32wifi: AP started with SSID: OVMS, MAC: 30:ae:a4:43:92:89, IP: 192.168.4.1 I (3496) ovms-mdns: Starting MDNS I (3526) webserver: Launching Web Server I (3526) ssh: Launching SSH Server OVMS#  I (4286) wifi: ap channel adjust o:1,1 n:6,2 I (4286) wifi: new:<6,0>, old:<1,0>, ap:<6,2>, sta:<6,0>, prof:1 OVMS#  I (5006) wifi: state: init -> auth (b0) I (5006) wifi: state: auth -> assoc (0) I (5016) wifi: state: assoc -> run (10) I (5046) wifi: connected with gregnet, channel 6, HT20, bssid = 40:b0:76:32:ea:70 I (5046) wifi: pm start, type: 1 I (5056) esp32wifi: STA connected with SSID: gregnet, BSSID: 40:b0:76:32:ea:70, Channel: 6, Auth: WPA2 I (5056) event: sta ip: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1 I (5066) netmanager: WIFI client got IP I (5076) esp32wifi: STA got IP with SSID 'gregnet' AP 40:b0:76:32:ea:70: MAC: 30:ae:a4:43:92:88, IP: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1 OVMS#  I (5626) sdcard: SD CARD has been inserted I (5716) sdcard: mount done OVMS#  I (8626) netmanager: WIFI client has good signal quality (-85.0 dBm); connect I (8626) netmanager: Interface priority is st1 (10.30.1.105/255.255.255.0 gateway 10.30.1.1) I (8626) simcom: State: Enter PoweredOn state I (8636) netmanager: Set DNS#0 9.9.9.9 I (8636) netmanager: Set DNS#1 8.8.8.8 I (8636) netmanager: WIFI client up (with MODEM down): starting network with WIFI client I (8666) time: Starting SNTP client I (8676) ovms-server-v2: Status: Network is up, so attempt network connection OVMS#  I (10626) ovms-server-v2: Connection is api.openvehicles.com:6867 ROADSTER834B I (10626) ovms-server-v2: Status: Connecting... OVMS#  I (10976) housekeeping: System considered stable (RAM: 8b=71304-71432 32b=27560) OVMS#  I (11276) ovms-server-v2: Connection successful I (11276) ovms-server-v2: Status: Logging in... I (11276) ovms-server-v2: Sending server login: MP-C 0 v1t3wM96P8dMQuxap8ztnc HryerO1CXBZ9fRTgydB05w== ROADSTER834B OVMS#  I (11586) ovms-server-v2: Got server response: MP-S 0 2ljIfUTLHiFXAfCMeaDRB+ KPfCHSPZqweGw3SGo1AqFQ== I (11586) ovms-server-v2: Server token is 2ljIfUTLHiFXAfCMeaDRB+ and digest is KPfCHSPZqweGw3SGo1AqFQ== I (11586) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (11586) ovms-server-v2: Shared secret key is 2ljIfUTLHiFXAfCMeaDRB+v1t3wM96P8dMQuxap8ztnc (44 bytes) I (11586) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (11606) ovms-server-v2: Incoming Msg: MP-0 Z0 I (11636) ovms-server-v2: Send MP-0 S93.0,M,1,0,done,standard,157,139,24,0,0,180,0,4,0,0,0,0,0.00,0,0,0,0,0,0,0,0,0,0,0,0,0.00,0.00,0 I (11636) ovms-server-v2: Send MP-0 D78,0,5,27,23,24,8067,529655,0,11,18,2,0,0,12.97,0,12.6,0,27,0,0 I (11646) ovms-server-v2: Send MP-0 L28.538242,-130.302567,251,0,0,0,0,8067,0,0.398,0,0 I (11646) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0 I (11646) ovms-server-v2: Send MP-0 F3.2.007-102-g07440970/ota_1/main (build idf v3.3-beta3-774-g6652269e1 Dec 12 2019 11:59:14),5YJRE1A16A1000834,17,1,TR2N,gregnet I (11656) ovms-server-v2: Send MP-0 PINot charging|SOC: -|ODO: 52965.5M OVMS#  I (28626) simcom: State: Enter MuxStart state I (28636) gsm-mux: Start MUX I (28636) gsm-mux: Channel #0 is open I (28646) gsm-mux: Channel #1 is open I (28646) gsm-mux: Channel #2 is open I (28656) gsm-mux: Channel #3 is open I (28656) gsm-mux: Channel #4 is open OVMS#  I (29626) simcom: State: Enter NetWait state OVMS#  I (39706) simcom: CREG Network Registration: RegisteredRoaming OVMS#  I (40626) simcom: State: Enter NetStart state OVMS#  I (41656) simcom: PPP Connection is ready to start OVMS#  I (42626) simcom: State: Enter NetMode state I (42626) gsm-ppp: Initialising... OVMS#  I (45186) gsm-ppp: StatusCallBack: None I (45186) gsm-ppp: status_cb: Connected I (45186) gsm-ppp: our_ipaddr = 10.52.33.103 I (45186) gsm-ppp: his_ipaddr = 10.64.64.64 I (45186) gsm-ppp: netmask = 255.255.255.255 I (45186) gsm-ppp: DNS#0 = 212.9.0.135 I (45186) gsm-ppp: DNS#1 = 212.9.0.136 I (45186) gsm-ppp: our6_ipaddr = :: I (45226) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority OVMS#  I (60636) script: Duktape: Compacting DukTape memory OVMS#  OVMS# OVMS# <----------- OBDII module attached at this time. Removed after crash / Reboot OVMS# OVMS# OVMS# Guru Meditation Error: Core 0 panic'ed (InstrFetchProhibited). Exception was unhandled. Core 0 register dump: PC : 0x3ffcfda0 PS : 0x00060b30 A0 : 0x800da765 A1 : 0x3ffc87a0 A2 : 0x3ffdf764 A3 : 0x3ffc8818 A4 : 0x00000001 A5 : 0x3ffc8818 A6 : 0x18004106 A7 : 0x55010019 A8 : 0x800da749 A9 : 0x3ffc8780 A10 : 0x3ffdf764 A11 : 0x3ffc87a0 A12 : 0x3ffc87a4 A13 : 0x3f40c391 A14 : 0x18004106 A15 : 0x55010019 SAR : 0x00000003 EXCCAUSE: 0x00000014 EXCVADDR: 0x3ffcfda0 LBEG : 0x400908e0 LEND : 0x4009090e LCOUNT : 0x00000000 ELF file SHA256: d151e36378c6be55a27f666546ffda83f5bb9782230cd43031c731f46d49d0b2 Backtrace: 0x3ffcfda0:0x3ffc87a0 0x400da762:0x3ffc87d0 0x400da95b:0x3ffc87f0 0x400da901:0x3ffc8810 Rebooting... ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x3b (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:4796 load:0x40078000,len:0 load:0x40078000,len:14896 entry 0x40078d74 I (919) psram: This chip is ESP32-D0WD I (920) spiram: Found 32MBit SPI RAM device I (920) spiram: SPI RAM mode: flash 40m sram 40m I (923) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (930) cpu_start: Pro cpu up. I (934) cpu_start: Application information: I (938) cpu_start: Project name: ovms3 I (943) cpu_start: App version: 3.2.007-102-g07440970 I (949) cpu_start: Compile time: Dec 12 2019 11:58:47 I (956) cpu_start: ELF file SHA256: d151e36378c6be55... I (961) cpu_start: ESP-IDF: v3.3-beta3-774-g6652269e1 I (968) cpu_start: Starting app cpu, entry point is 0x40081820 I (960) cpu_start: App cpu up. I (1853) spiram: SPI SRAM memory test OK I (1853) heap_init: Initializing. RAM available for dynamic allocation: I (1854) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (1860) heap_init: At 3FFBED50 len 000212B0 (132 KiB): DRAM I (1866) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (1873) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (1880) heap_init: At 4009918C len 00006E74 (27 KiB): IRAM I (1885) cpu_start: Pro cpu start user code I (1890) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (19) ovms_main: Set default logging level for * to INFO I (20) command: Initialising COMMAND (1000) I (21) boot: Initialising BOOT (1100) I (24) boot: Boot #51 reasons for CPU0=12 and CPU1=12 I (29) boot: Reset reason Exception/panic (4) E (34) boot: Crash #1 detected I (38) events: Initialising EVENTS (1200) I (43) config: Initialising CONFIG (1400) I (48) time: Initialising TIME (1500) I (53) script: Initialising SCRIPTS (1600) I (57) script: Using DUKTAPE javascript engine I (63) metrics: Initialising METRICS (1810) I (67) metrics: Expanding DUKTAPE javascript engine I (77) notify: Initialising NOTIFICATIONS (1820) I (78) notify: Registered notification type info I (83) notify: Registered notification type error I (88) notify: Registered notification type alert I (93) notify: Registered notification type data I (99) notify: Registered notification type stream I (104) notify: Expanding DUKTAPE javascript engine I (110) location: Initialising LOCATIONS (1900) I (117) location: Expanding DUKTAPE javascript engine I (121) vehicle: Initialising VEHICLE Factory (2000) I (128) pcp: Initialising POWER (4000) I (131) max7317: Initialising MAX7317 EGPIO (4200) I (137) sdcard: Initialising SD CARD (4400) I (141) ota: Initialising OTA (4400) I (146) canformat: Initialising CAN Format Factory (4500) I (151) canformat-crtd: Registering CAN Format: CRTD (4505) I (158) canformat-gvret: Registering CAN Format: GVRET (4505) I (164) canformat-lawricel: Registering CAN Format: LAWRICEL (4505) I (171) canformat-pcap: Registering CAN Format: PCAP (4505) I (177) canformat-raw: Registering CAN Format: RAW (4505) I (183) can: Initialising CAN (4510) I (190) dbc-app: Initialising DBC (4520) I (194) canlog: Initialising CAN logging (4550) I (198) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (205) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (213) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (220) canlog-vfs: Initialising CAN logging to VFS (4560) I (225) canplay: Initialising CAN play framework (4570) I (231) canplay-vfs: Initialising CAN playing from VFS (4580) I (238) simcom: Initialising SIMCOM (4600) I (243) test: Initialising TEST (5000) I (247) module: Initialising MODULE (5100) I (252) vfs: Initialising VFS (5200) I (256) ovms-server: Initialising OVMS Server (6000) I (261) ovms-server-v2: Initialising OVMS V2 Server (6100) I (268) ovms-server-v3: Initialising OVMS V3 Server (6200) I (274) obd2ecu: Initialising OBD2ECU (7000) I (279) canopen: Initialising CANopen (7000) I (285) esp32wifi: Initialising ESP32WIFI (8000) I (289) ovms-mdns: Initialising MDNS (8100) I (294) webserver: Initialising WEBSERVER (8200) I (302) ssh: Initialising SSH (8300) I (304) powermgmt: Initialising POWERMGMT (8500) I (309) re: Initialising RE Tools (8800) I (314) pushover: Initialising Pushover client (8800) I (320) netmanager: Initialising NETMANAGER (8999) I (328) v-zeva: Registering Vehicle: ZEVA (9000) I (330) v-voltampera: Registering Vehicle: Volt/Ampera (9000) I (336) v-track: Registering Vehicle: TRACK (9000) I (341) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (348) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (355) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (361) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (368) v-smarteq: Registering Vehicle: SMART EQ (9000) I (374) v-smarted: Registering Vehicle: SMART ED (9000) I (380) v-zoe: Registering Vehicle: Renault Zoe (9000) I (386) v-twizy: Registering Vehicle: Renault Twizy (9000) I (392) v-obdii: Registering Vehicle: OBDII (9000) I (397) v-none: Registering Vehicle: NONE (9000) I (403) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (409) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (418) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (425) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (432) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (438) v-demo: Registering Vehicle: DEMO (9000) I (444) vehicle_dbc: Registering Vehicle: DBC based vehicle (9000) I (451) version: Initialising Versioning (9900) I (460) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (0) script: Duktape: Scripting task is running I (546) ovms_main: Executing on CPU core 0 I (546) ovms_main: Mounting CONFIG... I (596) ovms_main: Configure logging... W (606) webserver: UpdateGlobalAuthFile: no password set => no auth for web console I (606) ovms_main: Registering default configs... I (606) ovms_main: Starting HOUSEKEEPING... I (616) housekeeping: Initialising HOUSEKEEPING Framework... I (616) housekeeping: Executing on CPU core 1 I (626) housekeeping: reset_reason: cpu0=12, cpu1=12 I (626) housekeeping: Initialising WATCHDOG... I (636) housekeeping: Starting PERIPHERALS... I (636) peripherals: Initialising OVMS Peripherals... I (646) peripherals: TCP/IP Adaptor I (646) peripherals: ESP32 system I (656) peripherals: SPI bus I (656) peripherals: MAX7317 I/O Expander I (666) peripherals: ESP32 CAN I (666) peripherals: ESP32 WIFI I (676) peripherals: ESP32 ADC I (676) peripherals: MCP2515 CAN 1/2 I (676) mcp2515: can2: SetPowerMode off I (766) peripherals: MCP2515 CAN 2/2 I (766) mcp2515: can3: SetPowerMode off I (846) peripherals: SD CARD I (846) peripherals: SIMCOM MODEM I (846) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0  I (856) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0  I (866) uart: queue free spaces: 50 I (866) ext12v: Powering off external 12V devices I (876) housekeeping: Auto init max7317 (free: 182492 bytes) I (876) housekeeping: Auto init ext12v (free: 182492 bytes) I (886) ext12v: Powering on external 12V devices I (886) housekeeping: Auto init dbc (free: 182492 bytes) I (896) housekeeping: Auto init wifi (free: 182492 bytes) I (906) esp32wifi: Powering up WIFI driver I (936) wifi: wifi driver task: 3ffd44fc, prio:23, stack:3584, core=0 I (936) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (936) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (966) wifi: wifi firmware version: aeed694 I (966) wifi: config NVS flash: enabled I (966) wifi: config nano formating: disabled I (966) wifi: Init dynamic tx buffer num: 16 I (976) wifi: Init data frame dynamic rx buffer num: 16 I (976) wifi: Init management frame dynamic rx buffer num: 16 I (986) wifi: Init management short buffer num: 32 I (986) wifi: Init static rx buffer size: 2212 I (996) wifi: Init static rx buffer num: 16 I (996) wifi: Init dynamic rx buffer num: 16 I (1806) phy: phy_version: 4102, 2fa7a43, Jul 15 2019, 13:06:06, 0, 0 I (1816) wifi: mode : sta (30:ae:a4:43:92:88) + softAP (30:ae:a4:43:92:89) I (1816) wifi: Total power save buffer number: 8 I (1816) wifi: Init max length of beacon: 752/752 I (1826) wifi: Init max length of beacon: 752/752 I (1826) housekeeping: Auto init modem (free: 131860 bytes) I (1836) simcom: State: Enter PoweringOn state I (1836) simcom: Power Cycle I (2506) simcom: State: Enter PoweredOn state I (2846) housekeeping: Auto init vehicle (free: 131068 bytes) I (2846) v-teslaroadster: Tesla Roadster v1.x, v2.x and v3.0 vehicle module I (2856) housekeeping: Auto init obd2ecu (free: 120368 bytes) I (2956) mcp2515: can3: SetPowerMode on I (3056) housekeeping: Auto init server v2 (free: 113148 bytes) I (3056) ovms-server-v2: OVMS Server V2 registered metric modifier is #1 I (3066) ovms-server-v2: Status: Server has been started I (3066) ovms-server-v2: OVMS Server v2 running I (3076) housekeeping: Auto init server v3 (free: 113040 bytes) E (3076) can: can1: intr=6 rxpkt=5 txpkt=0 errflags=0x80c00 rxerr=0 txerr=0 rxovr=0 txovr=0 txdelay=0 wdgreset=0 errreset=0 I (3076) housekeeping: Auto init javascript (free: 113040 bytes) I (3096) housekeeping: Auto init done (free: 113040 bytes) I (3106) housekeeping: Starting USB console... I (3106) uart: queue free spaces: 100 Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console Firmware: 3.2.007-102-g07440970/ota_1/main Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 OVMS# I (3126) script: Duktape: Creating heap I (3126) script: Duktape: Initialising module system OVMS#  I (3426) netmanager: WIFI access point is up I (3426) esp32wifi: AP started with SSID: OVMS, MAC: 30:ae:a4:43:92:89, IP: 192.168.4.1 I (3486) ovms-mdns: Starting MDNS I (3516) webserver: Launching Web Server I (3516) ssh: Launching SSH Server OVMS#  I (4276) wifi: ap channel adjust o:1,1 n:6,2 I (4276) wifi: new:<6,0>, old:<1,0>, ap:<6,2>, sta:<6,0>, prof:1 OVMS#  I (4996) wifi: state: init -> auth (b0) I (5006) wifi: state: auth -> assoc (0) I (5016) wifi: state: assoc -> run (10) I (5036) wifi: connected with gregnet, channel 6, HT20, bssid = 40:b0:76:32:ea:70 I (5036) wifi: pm start, type: 1 I (5046) esp32wifi: STA connected with SSID: gregnet, BSSID: 40:b0:76:32:ea:70, Channel: 6, Auth: WPA2 I (5056) event: sta ip: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1 I (5066) netmanager: WIFI client got IP I (5066) esp32wifi: STA got IP with SSID 'gregnet' AP 40:b0:76:32:ea:70: MAC: 30:ae:a4:43:92:88, IP: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1 OVMS#  I (5626) sdcard: SD CARD has been inserted I (5716) sdcard: mount done OVMS#  I (7626) netmanager: WIFI client has good signal quality (-86.4 dBm); connect I (7626) netmanager: Interface priority is st1 (10.30.1.105/255.255.255.0 gateway 10.30.1.1) I (7636) netmanager: Set DNS#0 9.9.9.9 I (7636) netmanager: Set DNS#1 8.8.8.8 I (7636) netmanager: WIFI client up (with MODEM down): starting network with WIFI client I (7676) time: Starting SNTP client I (7686) ovms-server-v2: Status: Network is up, so attempt network connection OVMS#  I (9626) ovms-server-v2: Connection is api.openvehicles.com:6867 ROADSTER834B I (9626) ovms-server-v2: Status: Connecting... OVMS#  I (10096) ovms-server-v2: Connection successful I (10106) ovms-server-v2: Status: Logging in... I (10106) ovms-server-v2: Sending server login: MP-C 0 GVOcBBICxKcLy+SD4s/fD5 YfmEjLfGzvoXXZGuw01D6Q== ROADSTER834B OVMS#  I (10406) ovms-server-v2: Got server response: MP-S 0 qWTLyMqCU4TMRzDXBGb24H GWKItB3ws/s2NJAM2v959A== I (10406) ovms-server-v2: Server token is qWTLyMqCU4TMRzDXBGb24H and digest is GWKItB3ws/s2NJAM2v959A== I (10416) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (10416) ovms-server-v2: Shared secret key is qWTLyMqCU4TMRzDXBGb24HGVOcBBICxKcLy+SD4s/fD5 (44 bytes) I (10416) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (10436) ovms-server-v2: Incoming Msg: MP-0 Z0 I (10626) ovms-server-v2: Send MP-0 S93.0,M,1,0,done,standard,157,139,24,0,0,180,0,4,0,0,0,0,0.00,0,0,0,0,0,0,0,0,0,0,0,0,0.00,0.00,0 I (10636) ovms-server-v2: Send MP-0 D78,0,5,0,0,0,8067,529655,0,10,0,2,0,0,13.01,0,12.6,0,0,0,0 I (10636) ovms-server-v2: Send MP-0 L28.538242,-130.302567,251,0,0,0,0,8067,0,0.398,0,0 I (10636) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0 I (10646) ovms-server-v2: Send MP-0 F3.2.007-102-g07440970/ota_1/main (build idf v3.3-beta3-774-g6652269e1 Dec 12 2019 11:59:14),5YJRE1A16A1000834,17,1,TR2N,gregnet I (10646) ovms-server-v2: Send MP-0 PINot charging|SOC: - I (10676) housekeeping: System considered stable (RAM: 8b=71432-71868 32b=27560) OVMS#  I (11626) ovms-server-v2: Send MP-0 h1,0,*-OVM-DebugCrash,0,2592000,3.2.007-102-g07440970/ota_1/main (build idf v3.3-beta3-774-g6652269e1 Dec 12 2019 11:59:14),51,Crash,12,12,1,0,InstrFetchProhibited,0,0x3ffcfda0 0x00060b30 0x800da765 0x3ffc87a0 0x3ffdf764 0x3ffc8818 0x00000001 0x3ffc8818 0x18004106 0x55010019 0x800da749 0x3ffc8780 0x3ffdf764 0x3ffc87a0 0x3ffc87a4 0x3f40c391 0x18004106 0x55010019 0x00000003 0x00000014 0x3ffcfda0 0x400908e0 0x4009090e 0x00000000 ,0x3ffcfda0 0x400da762 0x400da95b 0x400da901 ,4,Exception/panic OVMS#  I (11946) ovms-server-v2: Incoming Msg: MP-0 h1 OVMS#  I (20626) simcom: State timeout, transition to 2 I (20626) simcom: State: Enter PoweringOn state I (20626) simcom: Power Cycle OVMS#  I (27416) simcom: State: Enter PoweredOn state OVMS#
