=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.12.10 18:57:40 =~=~=~=~=~=~=~=~=~=~=~= OVMS# module reset Resetting system... OVMS# I (228844) boot: Shutting down for restart... I (228854) esp32wifi: Powering down WIFI driver I (228854) sdcard: Unmounting SDCARD for reset I (228854) sdcard: unmount done OVMS#  I (232834) boot: Restart now OVMS# ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x3b (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:4796 load:0x40078000,len:0 load:0x40078000,len:14896 entry 0x40078d74 I (895) psram: This chip is ESP32-D0WD I (896) spiram: Found 32MBit SPI RAM device I (896) spiram: SPI RAM mode: flash 40m sram 40m I (899) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (906) cpu_start: Pro cpu up. I (910) cpu_start: Application information: I (915) cpu_start: Project name: ovms3 I (919) cpu_start: App version: 3.2.007 I (924) cpu_start: Compile time: Dec 9 2019 20:19:55 I (930) cpu_start: ELF file SHA256: 14822bd8e0d2c843... I (936) cpu_start: ESP-IDF: v3.3-beta3-772-gc3465e0 I (943) cpu_start: Starting app cpu, entry point is 0x40081668 I (935) cpu_start: App cpu up. I (1828) spiram: SPI SRAM memory test OK I (1828) heap_init: Initializing. RAM available for dynamic allocation: I (1828) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (1835) heap_init: At 3FFBC540 len 00023AC0 (142 KiB): DRAM I (1841) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (1847) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (1854) heap_init: At 40099C20 len 000063E0 (24 KiB): IRAM I (1860) cpu_start: Pro cpu start user code I (1865) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (217) ovms_main: Set default logging level for * to INFO I (218) ovms_main: Pre-allocated 2MB of SPIRAM at 0x3f800028 (workaround ESP32 bug) I (221) command: Initialising COMMAND (1000) I (227) boot: Initialising BOOT (1100) I (230) boot: Boot #13 reasons for CPU0=12 and CPU1=12 I (236) boot: Reset reason Exception/panic (4) I (241) boot: Soft reset by user I (245) events: Initialising EVENTS (1200) I (250) config: Initialising CONFIG (1400) I (255) time: Initialising TIME (1500) I (260) script: Initialising SCRIPTS (1600) I (264) script: Using DUKTAPE javascript engine I (270) metrics: Initialising METRICS (1810) I (274) metrics: Expanding DUKTAPE javascript engine I (285) notify: Initialising NOTIFICATIONS (1820) I (286) notify: Registered notification type info I (291) notify: Registered notification type error I (296) notify: Registered notification type alert I (302) notify: Registered notification type data I (307) notify: Registered notification type stream I (312) notify: Expanding DUKTAPE javascript engine I (318) location: Initialising LOCATIONS (1900) I (325) location: Expanding DUKTAPE javascript engine I (329) vehicle: Initialising VEHICLE Factory (2000) I (336) pcp: Initialising POWER (4000) I (339) max7317: Initialising MAX7317 EGPIO (4200) I (345) sdcard: Initialising SD CARD (4400) I (350) ota: Initialising OTA (4400) I (354) canformat: Initialising CAN Format Factory (4500) I (360) canformat-crtd: Registering CAN Format: CRTD (4505) I (366) canformat-pcap: Registering CAN Format: PCAP (4505) I (372) canformat-gvret: Registering CAN Format: GVRET (4505) I (379) canformat-lawricel: Registering CAN Format: LAWRICEL (4505) I (386) canformat-raw: Registering CAN Format: RAW (4505) I (392) can: Initialising CAN (4510) I (398) dbc-app: Initialising DBC (4520) I (402) canlog: Initialising CAN logging (4550) I (406) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (414) canlog-vfs: Initialising CAN logging to VFS (4560) I (419) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (426) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (434) canplay: Initialising CAN play framework (4570) I (439) canplay-vfs: Initialising CAN playing from VFS (4580) I (446) simcom: Initialising SIMCOM (4600) I (451) test: Initialising TEST (5000) I (455) module: Initialising MODULE (5100) I (460) vfs: Initialising VFS (5200) I (464) ovms-server: Initialising OVMS Server (6000) I (469) ovms-server-v2: Initialising OVMS V2 Server (6100) I (476) ovms-server-v3: Initialising OVMS V3 Server (6200) I (482) obd2ecu: Initialising OBD2ECU (7000) I (487) canopen: Initialising CANopen (7000) I (493) esp32wifi: Initialising ESP32WIFI (8000) I (497) ovms-mdns: Initialising MDNS (8100) I (502) webserver: Initialising WEBSERVER (8200) I (510) ssh: Initialising SSH (8300) I (512) powermgmt: Initialising POWERMGMT (8500) I (517) re: Initialising RE Tools (8800) I (522) pushover: Initialising Pushover client (8800) I (528) netmanager: Initialising NETMANAGER (8999) I (536) v-zeva: Registering Vehicle: ZEVA (9000) I (538) v-voltampera: Registering Vehicle: Volt/Ampera (9000) I (544) v-track: Registering Vehicle: TRACK (9000) I (550) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (556) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (563) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (570) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (576) v-smarteq: Registering Vehicle: SMART EQ (9000) I (582) v-smarted: Registering Vehicle: SMART ED (9000) I (588) v-zoe: Registering Vehicle: Renault Zoe (9000) I (594) v-twizy: Registering Vehicle: Renault Twizy (9000) I (600) v-obdii: Registering Vehicle: OBDII (9000) I (606) v-none: Registering Vehicle: NONE (9000) I (611) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (617) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (627) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (633) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (641) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (647) v-demo: Registering Vehicle: DEMO (9000) I (652) vehicle_dbc: Registering Vehicle: DBC based vehicle (9000) I (659) version: Initialising Versioning (9900) I (667) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (0) script: Duktape: Scripting task is running I (754) ovms_main: Executing on CPU core 0 I (754) ovms_main: Mounting CONFIG... I (804) ovms_main: Configure logging... W (804) webserver: UpdateGlobalAuthFile: no password set => no auth for web console I (804) ovms_main: Registering default configs... I (814) ovms_main: Starting HOUSEKEEPING... I (814) housekeeping: Initialising HOUSEKEEPING Framework... I (824) housekeeping: Executing on CPU core 1 I (824) housekeeping: reset_reason: cpu0=12, cpu1=12 I (834) housekeeping: Initialising WATCHDOG... I (834) housekeeping: Starting PERIPHERALS... I (844) peripherals: Initialising OVMS Peripherals... I (844) peripherals: TCP/IP Adaptor I (854) peripherals: ESP32 system I (854) peripherals: SPI bus I (864) peripherals: MAX7317 I/O Expander I (864) peripherals: ESP32 CAN I (874) peripherals: ESP32 WIFI I (874) peripherals: ESP32 ADC I (874) peripherals: MCP2515 CAN 1/2 I (884) mcp2515: can2: SetPowerMode off I (964) peripherals: MCP2515 CAN 2/2 I (964) mcp2515: can3: SetPowerMode off I (1044) peripherals: SD CARD I (1044) peripherals: SIMCOM MODEM I (1044) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0  I (1054) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0  I (1064) uart: queue free spaces: 50 I (1064) ext12v: Powering off external 12V devices I (1074) housekeeping: Auto init max7317 (free: 193708 bytes) I (1074) housekeeping: Auto init ext12v (free: 193708 bytes) I (1084) ext12v: Powering on external 12V devices I (1084) housekeeping: Auto init dbc (free: 193708 bytes) I (1094) housekeeping: Auto init wifi (free: 193708 bytes) I (1104) esp32wifi: Powering up WIFI driver I (1134) wifi: wifi driver task: 3ffd192c, prio:23, stack:3584, core=0 I (1134) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1144) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1164) wifi: wifi firmware version: aeed694 I (1164) wifi: config NVS flash: enabled I (1164) wifi: config nano formating: disabled I (1164) wifi: Init dynamic tx buffer num: 16 I (1174) wifi: Init data frame dynamic rx buffer num: 16 I (1174) wifi: Init management frame dynamic rx buffer num: 16 I (1184) wifi: Init management short buffer num: 32 I (1184) wifi: Init static rx buffer size: 2212 I (1194) wifi: Init static rx buffer num: 16OVMS Developers I (1194) wifi: Init dynamic rx buffer num: 16 I (1974) phy: phy_version: 4102, 2fa7a43, Jul 15 2019, 13:06:06, 0, 0 I (1974) wifi: mode : sta (30:ae:a4:43:92:88) + softAP (30:ae:a4:43:92:89) I (1974) wifi: Total power save buffer number: 8 I (1984) wifi: Init max length of beacon: 752/752 I (1984) wifi: Init max length of beacon: 752/752 I (1994) housekeeping: Auto init modem (free: 148328 bytes) I (1994) simcom: State: Enter PoweringOn state I (2004) simcom: Power Cycle I (3004) housekeeping: Auto init vehicle (free: 147532 bytes) I (3004) v-teslaroadster: Tesla Roadster v1.x, v2.x and v3.0 vehicle module I (3014) housekeeping: Auto init obd2ecu (free: 139360 bytes) I (3114) mcp2515: can3: SetPowerMode on I (3214) housekeeping: Auto init server v2 (free: 132140 bytes) I (3214) ovms-server-v2: OVMS Server V2 registered metric modifier is #1 I (3224) ovms-server-v2: Status: Server has been started I (3224) ovms-server-v2: OVMS Server v2 running I (3234) housekeeping: Auto init server v3 (free: 132032 bytes) I (3234) housekeeping: Auto init javascript (free: 132032 bytes) I (3244) housekeeping: Auto init done (free: 132032 bytes) E (3244) can: can1: intr=7 rxpkt=6 txpkt=0 errflags=0x80c00 rxerr=0 txerr=0 rxovr=0 txovr=0 txdelay=0 wdgreset=0 errreset=0 I (3254) housekeeping: Starting USB console... I (3264) uart: queue free spaces: 100 Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console Firmware: 3.2.007/ota_1/main Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 OVMS# I (3254) script: Duktape: Creating heap I (3294) script: Duktape: Initialising module system E (3474) events: SignalEvent: queue overflow, event 'vehicle.charge.state' dropped E (3474) events: SignalEvent: queue overflow, event 'vehicle.charge.mode' dropped I (3644) netmanager: WIFI access point is up I (3644) esp32wifi: AP started with SSID: OVMS, MAC: 30:ae:a4:43:92:89, IP: 192.168.4.1 I (3734) ovms-mdns: Starting MDNS I (3784) webserver: Launching Web Server I (3784) ssh: Launching SSH Server OVMS#  I (4434) wifi: ap channel adjust o:1,1 n:6,2 I (4434) wifi: new:<6,0>, old:<1,0>, ap:<6,2>, sta:<6,0>, prof:1 OVMS#  I (5124) wifi: state: init -> auth (b0) I (5124) wifi: state: auth -> assoc (0) I (5134) wifi: state: assoc -> run (10) I (5154) wifi: connected with gregnet, channel 6, HT20, bssid = 40:b0:76:32:ea:70 I (5154) wifi: pm start, type: 1 I (5164) esp32wifi: STA connected with SSID: gregnet, BSSID: 40:b0:76:32:ea:70, Channel: 6, Auth: WPA2 I (5174) event: sta ip: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1 I (5184) netmanager: WIFI client got IP I (5184) esp32wifi: STA got IP with SSID 'gregnet' AP 40:b0:76:32:ea:70: MAC: 30:ae:a4:43:92:88, IP: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1 OVMS#  I (5834) sdcard: SD CARD has been inserted I (5924) sdcard: mount done OVMS#  I (6834) netmanager: WIFI client has good signal quality (-86.6 dBm); connect I (6844) netmanager: Interface priority is st1 (10.30.1.105/255.255.255.0 gateway 10.30.1.1) I (6844) netmanager: Set DNS#0 9.9.9.9 I (6844) netmanager: Set DNS#1 8.8.8.8 I (6844) netmanager: WIFI client up (with MODEM down): starting network with WIFI client I (6874) time: Starting SNTP client I (6884) ovms-server-v2: Status: Network is up, so attempt network connection OVMS# Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled. Core 0 register dump: PC : 0x400d5e4c PS : 0x00060030 A0 : 0x00000000 A1 : 0x3ffc5c40 A2 : 0x3ffb3eec A3 : 0x400d5e46 A4 : 0x00000000 A5 : 0x00000000 A6 : 0x00000000 A7 : 0x00000000 A8 : 0x3f400928 A9 : 0x3ffc5c00 A10 : 0x00000000 A11 : 0x3ffc5c48 A12 : 0x00000001 A13 : 0x00000000 A14 : 0x3ffc4bec A15 : 0x00000000 SAR : 0x00000003 EXCCAUSE: 0x0000001c EXCVADDR: 0x00000000 LBEG : 0x4008f33c LEND : 0x4008f36a LCOUNT : 0x00000000 ELF file SHA256: 14822bd8e0d2c843b0e5641a469ba2e865a09b94726cb281c70dbbe7bffe8a88 Backtrace: 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 Rebooting... ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x3b (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:4796 load:0x40078000,len:0 load:0x40078000,len:14896 entry 0x40078d74 I (895) psram: This chip is ESP32-D0WD I (896) spiram: Found 32MBit SPI RAM device I (896) spiram: SPI RAM mode: flash 40m sram 40m I (899) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (906) cpu_start: Pro cpu up. I (910) cpu_start: Application information: I (914) cpu_start: Project name: ovms3 I (919) cpu_start: App version: 3.2.007 I (924) cpu_start: Compile time: Dec 9 2019 20:19:55 I (930) cpu_start: ELF file SHA256: 14822bd8e0d2c843... I (936) cpu_start: ESP-IDF: v3.3-beta3-772-gc3465e0 I (943) cpu_start: Starting app cpu, entry point is 0x40081668 I (935) cpu_start: App cpu up. I (1827) spiram: SPI SRAM memory test OK I (1828) heap_init: Initializing. RAM available for dynamic allocation: I (1828) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (1835) heap_init: At 3FFBC540 len 00023AC0 (142 KiB): DRAM I (1841) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (1847) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (1854) heap_init: At 40099C20 len 000063E0 (24 KiB): IRAM I (1860) cpu_start: Pro cpu start user code I (1865) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (217) ovms_main: Set default logging level for * to INFO I (218) ovms_main: Pre-allocated 2MB of SPIRAM at 0x3f800028 (workaround ESP32 bug) I (221) command: Initialising COMMAND (1000) I (227) boot: Initialising BOOT (1100) I (230) boot: Boot #14 reasons for CPU0=12 and CPU1=12 I (236) boot: Reset reason Exception/panic (4) E (241) boot: Early crash #1 detected I (246) events: Initialising EVENTS (1200) I (251) config: Initialising CONFIG (1400) I (256) time: Initialising TIME (1500) I (260) script: Initialising SCRIPTS (1600) I (264) script: Using DUKTAPE javascript engine I (270) metrics: Initialising METRICS (1810) I (275) metrics: Expanding DUKTAPE javascript engine I (285) notify: Initialising NOTIFICATIONS (1820) I (286) notify: Registered notification type info I (291) notify: Registered notification type error I (296) notify: Registered notification type alert I (302) notify: Registered notification type data I (307) notify: Registered notification type stream I (313) notify: Expanding DUKTAPE javascript engine I (318) location: Initialising LOCATIONS (1900) I (325) location: Expanding DUKTAPE javascript engine I (329) vehicle: Initialising VEHICLE Factory (2000) I (336) pcp: Initialising POWER (4000) I (340) max7317: Initialising MAX7317 EGPIO (4200) I (345) sdcard: Initialising SD CARD (4400) I (350) ota: Initialising OTA (4400) I (355) canformat: Initialising CAN Format Factory (4500) I (360) canformat-crtd: Registering CAN Format: CRTD (4505) I (366) canformat-pcap: Registering CAN Format: PCAP (4505) I (373) canformat-gvret: Registering CAN Format: GVRET (4505) I (379) canformat-lawricel: Registering CAN Format: LAWRICEL (4505) I (386) canformat-raw: Registering CAN Format: RAW (4505) I (392) can: Initialising CAN (4510) I (399) dbc-app: Initialising DBC (4520) I (402) canlog: Initialising CAN logging (4550) I (406) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (415) canlog-vfs: Initialising CAN logging to VFS (4560) I (420) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (427) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (435) canplay: Initialising CAN play framework (4570) I (440) canplay-vfs: Initialising CAN playing from VFS (4580) I (446) simcom: Initialising SIMCOM (4600) I (452) test: Initialising TEST (5000) I (456) module: Initialising MODULE (5100) I (461) vfs: Initialising VFS (5200) I (465) ovms-server: Initialising OVMS Server (6000) I (470) ovms-server-v2: Initialising OVMS V2 Server (6100) I (476) ovms-server-v3: Initialising OVMS V3 Server (6200) I (483) obd2ecu: Initialising OBD2ECU (7000) I (488) canopen: Initialising CANopen (7000) I (494) esp32wifi: Initialising ESP32WIFI (8000) I (498) ovms-mdns: Initialising MDNS (8100) I (503) webserver: Initialising WEBSERVER (8200) I (510) ssh: Initialising SSH (8300) I (512) powermgmt: Initialising POWERMGMT (8500) I (518) re: Initialising RE Tools (8800) I (523) pushover: Initialising Pushover client (8800) I (528) netmanager: Initialising NETMANAGER (8999) I (536) v-zeva: Registering Vehicle: ZEVA (9000) I (538) v-voltampera: Registering Vehicle: Volt/Ampera (9000) I (545) v-track: Registering Vehicle: TRACK (9000) I (550) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (556) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (563) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (570) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (577) v-smarteq: Registering Vehicle: SMART EQ (9000) I (583) v-smarted: Registering Vehicle: SMART ED (9000) I (588) v-zoe: Registering Vehicle: Renault Zoe (9000) I (594) v-twizy: Registering Vehicle: Renault Twizy (9000) I (600) v-obdii: Registering Vehicle: OBDII (9000) I (606) v-none: Registering Vehicle: NONE (9000) I (611) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (618) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (627) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (633) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (641) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (647) v-demo: Registering Vehicle: DEMO (9000) I (652) vehicle_dbc: Registering Vehicle: DBC based vehicle (9000) I (659) version: Initialising Versioning (9900) I (668) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (0) script: Duktape: Scripting task is running I (754) ovms_main: Executing on CPU core 0 I (754) ovms_main: Mounting CONFIG... I (804) ovms_main: Configure logging... W (804) webserver: UpdateGlobalAuthFile: no password set => no auth for web console I (804) ovms_main: Registering default configs... I (814) ovms_main: Starting HOUSEKEEPING... I (814) housekeeping: Initialising HOUSEKEEPING Framework... I (824) housekeeping: Executing on CPU core 1 I (824) housekeeping: reset_reason: cpu0=12, cpu1=12 I (834) housekeeping: Initialising WATCHDOG... I (834) housekeeping: Starting PERIPHERALS... I (844) peripherals: Initialising OVMS Peripherals... I (844) peripherals: TCP/IP Adaptor I (854) peripherals: ESP32 system I (854) peripherals: SPI bus I (864) peripherals: MAX7317 I/O Expander I (864) peripherals: ESP32 CAN I (874) peripherals: ESP32 WIFI I (874) peripherals: ESP32 ADC I (874) peripherals: MCP2515 CAN 1/2 I (884) mcp2515: can2: SetPowerMode off I (964) peripherals: MCP2515 CAN 2/2 I (964) mcp2515: can3: SetPowerMode off I (1044) peripherals: SD CARD I (1044) peripherals: SIMCOM MODEM I (1044) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0  I (1054) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0  I (1064) uart: queue free spaces: 50 I (1064) ext12v: Powering off external 12V devices I (1074) housekeeping: Auto init max7317 (free: 193708 bytes) I (1074) housekeeping: Auto init ext12v (free: 193708 bytes) I (1084) ext12v: Powering on external 12V devices I (1084) housekeeping: Auto init dbc (free: 193708 bytes) I (1094) housekeeping: Auto init wifi (free: 193708 bytes) I (1104) esp32wifi: Powering up WIFI driver I (1134) wifi: wifi driver task: 3ffd192c, prio:23, stack:3584, core=0 I (1134) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1144) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1164) wifi: wifi firmware version: aeed694 I (1164) wifi: config NVS flash: enabled I (1164) wifi: config nano formating: disabled I (1164) wifi: Init dynamic tx buffer num: 16 I (1174) wifi: Init data frame dynamic rx buffer num: 16 I (1174) wifi: Init management frame dynamic rx buffer num: 16 I (1184) wifi: Init management short buffer num: 32 I (1184) wifi: Init static rx buffer size: 2212 I (1194) wifi: Init static rx buffer num: 16 I (1194) wifi: Init dynamic rx buffer num: 16 I (1974) phy: phy_version: 4102, 2fa7a43, Jul 15 2019, 13:06:06, 0, 0 I (1974) wifi: mode : sta (30:ae:a4:43:92:88) + softAP (30:ae:a4:43:92:89) I (1974) wifi: Total power save buffer number: 8 I (1984) wifi: Init max length of beacon: 752/752 I (1984) wifi: Init max length of beacon: 752/752 I (1994) housekeeping: Auto init modem (free: 148328 bytes) I (1994) simcom: State: Enter PoweringOn state I (2004) simcom: Power Cycle I (2804) simcom: State: Enter PoweredOn state I (3004) housekeeping: Auto init vehicle (free: 147532 bytes) I (3004) v-teslaroadster: Tesla Roadster v1.x, v2.x and v3.0 vehicle module I (3014) housekeeping: Auto init obd2ecu (free: 139360 bytes) I (3114) mcp2515: can3: SetPowerMode on I (3214) housekeeping: Auto init server v2 (free: 132140 bytes) I (3214) ovms-server-v2: OVMS Server V2 registered metric modifier is #1 I (3214) ovms-server-v2: Status: Server has been started I (3224) ovms-server-v2: OVMS Server v2 running I (3234) housekeeping: Auto init server v3 (free: 132032 bytes) I (3234) housekeeping: Auto init javascript (free: 132032 bytes) I (3244) housekeeping: Auto init done (free: 132032 bytes) I (3254) housekGuru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled. Core 0 register dump: PC : 0x400d5e4c PS : 0x00060d30 A0 : 0x00000000 A1 : 0x3ffc5c40 A2 : 0x3ffb3eec A3 : 0x400d5e46 A4 : 0x00000000 A5 : 0x00000000 A6 : 0x00000000 A7 : 0x00000000 A8 : 0x3f400928 A9 : 0x3ffc5c00 A10 : 0x00000000 A11 : 0x3ffc5c48 A12 : 0x00000001 A13 : 0x00000000 A14 : 0x3ffc498c A15 : 0x00000000 SAR : 0x00000003 EXCCAUSE: 0x0000001c EXCVADDR: 0x00000000 LBEG : 0x4008f33c LEND : 0x4008f36a LCOUNT : 0x00000000 ELF file SHA256: 14822bd8e0d2c843b0e5641a469ba2e865a09b94726cb281c70dbbe7bffe8a88 Backtrace: 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90 Rebooting... etc...
