Fwd: [ovms:2087] Consult on Renault twizy
@michael, Could you help this user? I greped for the error text in OVMS v2, v3 and Android, source code, but can’t find it. Regards, Mark.
Begin forwarded message:
bricoauto has created the ticket 'Consult on Renault twizy': https://www.openvehicles.com/node/2087#comment-0 State: new Priority: normal
You can visit the following URL to update this ticket: https://www.openvehicles.com/node/2087#comment-form
Ticket text: ------------------------------
I have successfully installed the Ovms 3.1 module in my renault twizy, but I still do not know how to modify parameters. For example with the App, if I want to modify the speed limitation, it tells me the following error message: Can bus not in active mode
I guess that writing or reading by can not be active, because I can not see the fault logs etc ... Could you help me with this? Regards!
For the record:
In order to send commands to the Twizy, you need to enable CAN write access.
You can do so either by using the web UI or by setting feature 15 to 1 or by issuing "config set xrt canwrite yes".
@Mark: the error text is defined here: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master... Regards, Michael Am 19.09.18 um 04:09 schrieb Mark Webb-Johnson:
@michael,
Thanks. That makes sense (I was looking in vehicle_twizy folder, and app sources). You mention a twizy user guide? Do you have a link for that, so I can add it to the website? Regards, Mark
On 19 Sep 2018, at 3:59 PM, Michael Balzer <dexter@expeedo.de> wrote:
For the record:
In order to send commands to the Twizy, you need to enable CAN write access. You can do so either by using the web UI or by setting feature 15 to 1 or by issuing "config set xrt canwrite yes".
@Mark: the error text is defined here: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master... <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/canopen/src/canopen.cpp#L373>
Regards, Michael
@michael,
<Screenshot_20180918-222459.png>
bricoauto has created the ticket 'Consult on Renault twizy': https://www.openvehicles.com/node/2087#comment-0 <https://www.openvehicles.com/node/2087#comment-0> State: new Priority: normal
You can visit the following URL to update this ticket: https://www.openvehicles.com/node/2087#comment-form <https://www.openvehicles.com/node/2087#comment-form>
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
It's still the V2 user guide I meant. I need to find time to make a V3 version. As features, commands and configs are very similar, the V2 guide is still valid. I added some basic info on the differences to my FAQ: https://dexters-web.de/faq/en#usermanual Regards, Michael Am 19.09.18 um 10:03 schrieb Mark Webb-Johnson:
On 19 Sep 2018, at 3:59 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
For the record:
Regards, Michael
@michael,
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Mark Webb-Johnson -
