Just a short note on progress. I managed to get a lot done over the weekend. Working with Tom on some misc functions for ACC, and all looks good so far. Basic ACC location management is done, and I've worked out a way of using base64 to encode the ACC structures into our limited 32byte parameters. Seems to work quite well - very lightweight (we already have base64 for the comms protocol), and very expandable. I'm now just trying to pull everything together to get cooldown working. Once that is working, I'll commit (even in that unfinished form). Logging (drive and charge) is already done, and part of this. Flash space is getting concerning (approaching 95% now, for experimental with all vehicles), so we'll have to address that once ACC is out. I'm getting a rather large backlog of other requests now (put aside due to ACC work, trip to USA for TESLIVE, and horrendous day job hours). Once the basic ACC is committed, I'll be able to spend some time to try to work through that. Apologies for the delays (to anyone waiting for me). Regards, Mark.
Wow, let's not do that again. I just spent the past two weeks trying to debug a problem where my car module kept rebooting. The debug crash log showed it seemed to be identical to a normal power-on start. Seems like the module rebooted itself a dozen times a day. After trying everything - more than a dozen firmware changes painfully loaded into the car module, I finally found the problem: the module was rebooting, it was just incorrectly reporting a reboot every time the cellular signal recovered. Good grief. Anyway, back on track again now. Today, I've pushed to github my backlog of 36 commits, totalling 1.5MB! This makes the first 'alpha' release of v2.5 code. A summary of the (extensive) changes: Tesla Roadster Experimental Speedo No longer experimental. Now on bit#0 of permanent feature #13. Old feature #0 no longer used. Drive and Charge logging Server as well as vehicle changes made to support this. Setting bit#1 of permanent feature #13 will turn on logging of drives. Setting bit#2 of permanent feature #13 will turn on logging of charges. If enabled, at the end of each drive/charge the logging system will attempt to upload a *-Log-Drive or *-Log-Charge record with details on the drive/charge. It can store up to 6 such records without server connectivity. The records themselves can be downloaded as historical data using either the HTTP or OVMS protocol APIs. To implement this, a new 'h' style of historical data submission has been supported by the server - this allows for acknowledgement of successful data reception by the server, as well as a time offset for cases where the data cannot be immediately transmitted. Cooldown Core support has been added for 'cool down' charges, and implemented in the Tesla Roadster module. Cooldowns can be initiated by the 'COOLDOWN' SMS message, or by server command #25. Tesla Roadster event notification A few changes have been made to the Tesla Roadster module to try to make it notify the server of major events immediately (such as charge mode changes, charge limit changes, etc). Server support for Authentication failures The server code has been extended to send a PUSH notification in the event a vehicle authentication fails. The server will also send another PUSH notification if the vehicle subsequently authenticates successfully. Distance utility function Courtesy of Tom, a distance utility function to calculate the distance between two GPS locations and tell if they are closer than a pre-set limit. NET fixes Added a few more checkpoints and sanity checks for NET layer data, to try to avoid crashes and overflows. Debug Crash Reason reporting Bug fix to avoid duplicate reports of debug crashes every time the server connection is made. As a side-effect, normal first-time boot-ups will no longer be reported (by design). Stub ACC implementation I've done a lot of work on ACC in my own branch, but not committed to head, yet. I need some more time to do further testing before I'm ready to release. For the moment, there is a minimal implementation the does the ACC location mapping, and is capable of seeing if the car is within range of an ACC location. You can also configure the ACC locations and parameters. More on this will come with v2.5.2. Documentation I've updated the Tesla Roadster user guide, as well as OVMS Protocol guide, for the above. I haven't built binary firmware for this yet, as it is so new and raw. It is running in my car, and now seems stable, but needs more testing before prime-time release. If you want to try it, you'll need to build from source. Then, set feature #13 to 255 (to enable all opt-in features) and you should get a digital speedo (Tesla Roadster v2.x cars only) as well as logging to the server of both drives and charges. I'm over the hump now, and hopefully v2.5.2 can come within the next week. Regards, Mark. On 5 Aug, 2013, at 12:38 PM, Mark Webb-Johnson <mark@webb-johnson.net> wrote:
Mark, Wow, great stuff. Can't wait to have this all working! I built and installed the latest version and tried to do a cooldown, but couldn't get it to work. I arrived home with the batteries at 98F (37C), flashed the OVMS device, and sent a cooldown command. Nothing. I set feature #13 to 255 and sent cooldown again. Nothing. I took a look at the code, set param 15 to "27,45", sent cooldown again. Nothing. I look at the code some more, so that the car had to be "on" for cooldown to work, so I went out and opened the driver's door to wake the car up. Battery pack still at 98F. Sent cooldown again. Nothing. I do have feature 15 (CAN Write) set to 1. The OVMS app lists the firmware version as "2.3.3/TR/V1". As I wanted to cool the batteries and then do a change, I manually kicked off a 12A Range mode charge. What should I try next time the batteries are hot? Tom on 8/15/13 6:55 AM, Mark Webb-Johnson wrote:
Cooldown
NET fixes
Documentation
Nevermin. The build worked, the download didn't. Now I have the correct software on the module, which reports "2.5.1/TR/V1". I may get another chance to try cooldown tonight. Tom on 8/16/13 1:42 PM, Tom Saxton wrote:
Mark,
Tom
Cooldown
NET fixes
Documentation
I tried the cooldown feature with the right firmware installed this time. It worked as expected, charging in Range mode at 240V/16A. After the cooldown, it restored the charge mode to Standard, as expected, but the OVMS app reported that the charge current was restored to 12A instead of 40A as it was when I started cooldown. Tom on 8/16/13 3:17 PM, Tom Saxton wrote:
Tom
Mark,
Tom
Cooldown
NET fixes
Documentation
Tom, Here are the server logs (nothing very confidential in the 'S' and 'D' messages [I've removed odometer, etc, after temperatures], so hope ok to post here): 2013-08-17 00:56:14.477118 -0400 info main: #69 C SAX217 rx msg S 71,M,-1,0,stopped,standard,132,139,40,226,100,27,7,21,0,0,0,-1,151.91,17,-1,0,0,0,0,0 2013-08-17 00:56:14.480328 -0400 info main: #69 C SAX217 rx msg D 128,32,3,38,68,30,... 2013-08-17 01:06:09.329374 -0400 info main: #69 C SAX217 rx msg S 68,M,-1,0,stopped,standard,126,140,40,226,100,27,7,21,0,0,0,-1,151.91,17,-1,0,0,0,0,0 2013-08-17 01:06:09.333821 -0400 info main: #69 C SAX217 rx msg D 128,32,3,41,75,30,... 2013-08-17 01:09:57.185946 -0400 info main: #69 C SAX217 rx msg S 68,M,-1,0,stopped,standard,126,140,12,0,100,27,7,21,0,0,0,-1,151.91,17,-1,0,0,0,0,0 2013-08-17 01:09:57.189470 -0400 info main: #69 C SAX217 rx msg D 100,0,3,35,60,30,... 2013-08-17 01:10:01.765659 -0400 info main: #69 C SAX217 rx msg S 68,M,-1,0,prepare,standard,126,140,12,0,100,0,7,13,0,0,0,-1,151.91,17,-1,0,0,0,0,0 2013-08-17 01:10:13.107763 -0400 info main: #69 C SAX217 rx msg S 68,M,1,0,stopped,standard,126,140,12,0,100,0,2,14,0,0,0,-1,151.91,17,-1,0,0,0,0,0 2013-08-17 01:10:17.925488 -0400 info main: #69 C SAX217 rx msg S 68,M,1,0,stopped,standard,126,140,12,0,100,0,2,14,0,0,0,-1,151.91,17,-1,0,0,0,0,0 2013-08-17 01:10:17.928642 -0400 info main: #69 C SAX217 rx msg D 108,0,3,35,60,30,... 2013-08-17 01:10:42.844896 -0400 info main: #69 C SAX217 rx msg S 68,M,1,0,stopped,standard,126,140,12,0,100,0,2,14,0,0,0,-1,151.91,17,-1,0,0,0,0,0 2013-08-17 01:10:42.849100 -0400 info main: #69 C SAX217 rx msg D 108,0,3,34,59,30,... 2013-08-17 01:12:31.604588 -0400 info main: #24 C SAX217 rx msg S 64,M,239,16,charging,range,151,168,16,1,100,0,5,1,3,0,0,-1,151.91,367,-1,0,0,1,27,42 2013-08-17 01:12:35.524060 -0400 info main: #24 C SAX217 rx msg D 124,0,3,36,57,30,... 2013-08-17 01:12:44.965847 -0400 info main: #24 C SAX217 rx msg D 124,0,3,36,57,30,... 2013-08-17 01:16:31.640460 -0400 info main: #24 C SAX217 rx msg S 68,M,1,0,stopped,standard,127,141,12,5,100,0,3,21,0,0,0,-1,151.91,381,-1,0,0,0,27,38 2013-08-17 01:20:24.337827 -0400 info main: #24 C SAX217 rx msg S 68,M,1,0,stopped,standard,127,141,12,5,100,0,3,21,0,0,0,-1,151.91,381,-1,0,0,0,27,38 2013-08-17 01:20:24.345774 -0400 info main: #24 C SAX217 rx msg D 108,0,3,34,59,28,... 2013-08-17 01:20:50.817512 -0400 info main: #24 C SAX217 rx msg D 108,0,3,34,59,28,... 2013-08-17 01:21:31.476733 -0400 info main: #24 C SAX217 rx msg D 100,0,3,33,59,28,... 2013-08-17 01:21:31.479403 -0400 info main: #24 C SAX217 rx msg S 68,M,-1,127,stopped,standard,127,141,12,-1,100,0,3,21,0,0,0,-1,151.91,381,-1,0,0,0,27,38 2013-08-17 01:28:00.151699 -0400 info main: #24 C SAX217 rx msg S 67,M,-1,127,stopped,standard,125,139,12,-1,100,0,3,21,0,0,0,-1,151.91,381,-1,0,0,0,27,38 2013-08-17 01:28:00.156752 -0400 info main: #24 C SAX217 rx msg D 100,0,3,33,59,28,... 2013-08-17 01:28:40.931885 -0400 info main: #24 C SAX217 rx msg D 100,0,3,33,59,28,... Time zone is EDT. The "S" message fields are: SOC Units ("M" for miles, "K" for kilometres) Line voltage Charge current (amps) Charge state (charging, topoff, done, prepare, heating, stopped) Charge mode (standard, storage, range, performance) Ideal range Estimated range Charge limit (amps) Charge duration (minutes) Charger B4 byte (tba)Charge KWH consumed Charge sub-state Charge state (as a number) Charge mode (as a number) Charge Timer mode (0=onplugin, 1=timer) Charge Timer start time Charge timer stale (-1=none, 0=stale, >0 ok) Vehicle CAC100 value ACC: Mins remaining until car will be full ACC: Mins remaining until car reaches charge limit ACC: Configured range limit ACC: Configured SOC limit Cooldown: Car is cooling down (0=no, 1=yes) Cooldown: Lower limit for battery temperature Cooldown: Time limit (minutes) for cooldown The "D" message fields are: Door state #1 Door state #2 Lock/Unlock state 4 = car is locked Temperature of the PEM (celcius) Temperature of the Motor (celcius) Temperature of the Battery (celcius) From what I can see, earlier (01:06:09) you had current limit at 40A, but at 01:09:57 it was reported as having dropped to 12A. The cool down charge started at 01:12:31 (switching to range mode and 16A) and stopped at 01:16:31 (switching back to standard mode and 12A). The cool down only ran for 4 mins, to bring battery temperature down from 30Celcius to 28Celcius. I guess it hit 27Celcius (your requested limit temperature) quite quickly, then went up 1 more degree after the stop. The strange thing is why the drop in current limit from 40A at 01:06:09 to 12A at 01:09:57. It seems that at 40A the car was driving, but at 12A the car was parked with the charge port open. Do you have the roadster set to save a charge limit of 12A at that location? From what I can see with the 2.x cars, the charge limit based on location is set immediately the charge port is opened (which is why my ACC stuff delays a few seconds before setting what it wants). Regards, Mark. P.S. Thanks for jumping on and helping test this. I've done quite a few cool downs in my 2.5 car, but it is good to see it work in a 1.5. P.P.S. If you look closely, you'll see your hard work on charge time prediction show up. An estimate of 367 minutes from SOC 64% to full range mode, at 16A, changing to 381 minutes in standard mode at 12A. Nice. On 17 Aug, 2013, at 1:35 PM, Tom Saxton <tom@idleloop.com> wrote:
Tom
Tom
Mark,
Tom
Cooldown
NET fixes
Documentation
Hi Mark, I have a theory... Earlier in the day, I did a manual cool down by charging in Range mode at 12A, which I set directly on the touch screen. After the battery pack had cooled, I used the OVMS app to switch to Standard mode at 40A. It stayed at the 40A limit through the rest of the charge, which I interrupted for another drive. When we got home, it apparently switched back to 12A before I started the cool down via the new OVMS feature. So, I wonder if changing the current limit via OVMS doesn't register the same way that doing it on the touch screen does, leaving the car thinking that the earlier change on the touch screen should remain the default for that location? Tom on 8/17/13 6:16 AM, Mark Webb-Johnson wrote:
Tom,
2013-08-17 00:56:14.477118 -0400 info main: #69 C SAX217 rx msg S 71,M,-1,0,stopped,standard,132,139,40,226,100,27,7,21,0,0,0,-1,151.91,17,-1,0, 0,0,0,0 2013-08-17 00:56:14.480328 -0400 info main: #69 C SAX217 rx msg D 128,32,3,38,68,30,... 2013-08-17 01:06:09.329374 -0400 info main: #69 C SAX217 rx msg S 68,M,-1,0,stopped,standard,126,140,40,226,100,27,7,21,0,0,0,-1,151.91,17,-1,0, 0,0,0,0 2013-08-17 01:06:09.333821 -0400 info main: #69 C SAX217 rx msg D 128,32,3,41,75,30,... 2013-08-17 01:09:57.185946 -0400 info main: #69 C SAX217 rx msg S 68,M,-1,0,stopped,standard,126,140,12,0,100,27,7,21,0,0,0,-1,151.91,17,-1,0,0, 0,0,0 2013-08-17 01:09:57.189470 -0400 info main: #69 C SAX217 rx msg D 100,0,3,35,60,30,... 2013-08-17 01:10:01.765659 -0400 info main: #69 C SAX217 rx msg S 68,M,-1,0,prepare,standard,126,140,12,0,100,0,7,13,0,0,0,-1,151.91,17,-1,0,0,0 ,0,0 2013-08-17 01:10:13.107763 -0400 info main: #69 C SAX217 rx msg S 68,M,1,0,stopped,standard,126,140,12,0,100,0,2,14,0,0,0,-1,151.91,17,-1,0,0,0, 0,0 2013-08-17 01:10:17.925488 -0400 info main: #69 C SAX217 rx msg S 68,M,1,0,stopped,standard,126,140,12,0,100,0,2,14,0,0,0,-1,151.91,17,-1,0,0,0, 0,0 2013-08-17 01:10:17.928642 -0400 info main: #69 C SAX217 rx msg D 108,0,3,35,60,30,... 2013-08-17 01:10:42.844896 -0400 info main: #69 C SAX217 rx msg S 68,M,1,0,stopped,standard,126,140,12,0,100,0,2,14,0,0,0,-1,151.91,17,-1,0,0,0, 0,0 2013-08-17 01:10:42.849100 -0400 info main: #69 C SAX217 rx msg D 108,0,3,34,59,30,... 2013-08-17 01:12:31.604588 -0400 info main: #24 C SAX217 rx msg S 64,M,239,16,charging,range,151,168,16,1,100,0,5,1,3,0,0,-1,151.91,367,-1,0,0,1 ,27,42 2013-08-17 01:12:35.524060 -0400 info main: #24 C SAX217 rx msg D 124,0,3,36,57,30,... 2013-08-17 01:12:44.965847 -0400 info main: #24 C SAX217 rx msg D 124,0,3,36,57,30,... 2013-08-17 01:16:31.640460 -0400 info main: #24 C SAX217 rx msg S 68,M,1,0,stopped,standard,127,141,12,5,100,0,3,21,0,0,0,-1,151.91,381,-1,0,0,0 ,27,38 2013-08-17 01:20:24.337827 -0400 info main: #24 C SAX217 rx msg S 68,M,1,0,stopped,standard,127,141,12,5,100,0,3,21,0,0,0,-1,151.91,381,-1,0,0,0 ,27,38 2013-08-17 01:20:24.345774 -0400 info main: #24 C SAX217 rx msg D 108,0,3,34,59,28,... 2013-08-17 01:20:50.817512 -0400 info main: #24 C SAX217 rx msg D 108,0,3,34,59,28,... 2013-08-17 01:21:31.476733 -0400 info main: #24 C SAX217 rx msg D 100,0,3,33,59,28,... 2013-08-17 01:21:31.479403 -0400 info main: #24 C SAX217 rx msg S 68,M,-1,127,stopped,standard,127,141,12,-1,100,0,3,21,0,0,0,-1,151.91,381,-1,0 ,0,0,27,38 2013-08-17 01:28:00.151699 -0400 info main: #24 C SAX217 rx msg S 67,M,-1,127,stopped,standard,125,139,12,-1,100,0,3,21,0,0,0,-1,151.91,381,-1,0 ,0,0,27,38 2013-08-17 01:28:00.156752 -0400 info main: #24 C SAX217 rx msg D 100,0,3,33,59,28,... 2013-08-17 01:28:40.931885 -0400 info main: #24 C SAX217 rx msg D 100,0,3,33,59,28,...
Time zone is EDT.
Tom
Tom
Mark,
Tom
Cooldown
NET fixes
Documentation
Tom, Yes, the OVMS changes of current limit or mode are not permanent. They are not saved by the VDS as geofenced and won't change any existing car geofenced settings. I guess the reason is that the geofencing is done by the VDS not VMS, but am not certain. From what I can tell, the geofenced settings are applied as soon as the charge port is opened. They can be changed after that (but we need to wait a couple of seconds before doing it). Regards, Mark
On 18 Aug, 2013, at 3:02 pm, Tom Saxton <tom@idleloop.com> wrote:
Hi Mark,
I have a theory...
Tom
Tom,
Time zone is EDT.
Tom
Tom
Mark,
Tom
Cooldown
NET fixes
Documentation
> > Just a short note on progress. > > I managed to get a lot done over the weekend. Working with Tom on some > misc > functions for ACC, and all looks good so far. Basic ACC location > management > is done, and I've worked out a way of using base64 to encode the ACC > structures into our limited 32byte parameters. Seems to work quite well - > very lightweight (we already have base64 for the comms protocol), and > very > expandable. > > I'm now just trying to pull everything together to get cooldown working. > Once > that is working, I'll commit (even in that unfinished form). Logging > (drive > and charge) is already done, and part of this. Flash space is getting > concerning (approaching 95% now, for experimental with all vehicles), so > we'll have to address that once ACC is out. > > I'm getting a rather large backlog of other requests now (put aside due > to > ACC work, trip to USA for TESLIVE, and horrendous day job hours). Once > the > basic ACC is committed, I'll be able to spend some time to try to work > through that. Apologies for the delays (to anyone waiting for me). > > Regards, Mark. > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.teslaclub.hk > http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
On 8/15/13 6:55 AM, "Mark Webb-Johnson" <mark@webb-johnson.net> wrote:
The [drive and charge logging] records themselves can be downloaded as historical data using either the HTTP or OVMS protocol APIs.
I'm trying to do this but I'm not seeing the records I expected to see. I received my V2 hardware, did a V2_TR_PRODUCTION build, downloaded the firmware, and configured the module. SMS and the iPhone app are working. The version being reported by the device is 2.5.2/TR/V2. Yesterday evening, I did a "FEATURE 13 255" to enable the logging and ACC goodness. Last night, the car charged. To get the log data, I used the HTTP API historical/ and got this result: [ { 'first' => '2013-08-10 15:37:09', 'distinctrecs' => '1', 'totalsize' => '1511', 'last' => '2013-09-07 21:39:21', 'totalrecs' => '24', 'h_recordtype' => '*-OVM-DebugCrash' }, { 'first' => '2013-02-22 00:00:00', 'distinctrecs' => '4', 'totalsize' => '36920', 'last' => '2013-09-08 00:00:00', 'totalrecs' => '792', 'h_recordtype' => '*-OVM-Utilisation' } ];
From looking at the vehicle firmware, it looks like I should be getting *-Log-Drive and *-Log-Charge records.
Am I doing something wrong? I did get the units param messed up at some point, which I fixed this morning. Would that mess up logging? Tom
Tom, I can't see anything obviously wrong. The settings you have look correct and the units should not affect the charge logging. But, the charge wasn't logged. I re-checked my car logging, just now, and it is still fine - so I don't think this is a regression problem. But, I do see a bug in the code - if the logging was disabled and you had a bunch of drives/charges, the logging table would be filled-up but never sent to the server. Even if you then enabled logging, it still wouldn't work. To see if this is the case, can you try to unplug, wait ten seconds, then replug in the module? Then, go for a drive/charge and see if that fixes it. Regards, Mark. P.S. I'll fix the bug tonight - it is just to add a check for logging enabled before reserving a logging slot. On 9 Sep, 2013, at 6:20 AM, Tom Saxton <tom@idleloop.com> wrote:
Tom
Mark Webb-Johnson -
Tom Saxton
