[Ovmsdev] Can't compile due to wolfssh
Chris van der Meijden
chris at arachnon.de
Sun May 14 03:56:06 HKT 2023
After wolfssh was deleted during the fetch I did
git submodule update --init --recursive
git pull --recurse-submodules
git submodule update --remote
Then I was stranded with the wrong wolfssh version.
git submodule sync --recursive
corrected the wolfssh version now.
Sorry for my words on "experimenting". Sometimes the complexity of it
all is a bit frustrating.
Am Samstag, dem 13.05.2023 um 21:37 +0200 schrieb Ludovic LANGE:
> Chris,
> Very puzzling what you experience. As I did exactly the same in a
> fresh dir without any issue:
> * git clone git at github.com:openvehicles/Open-Vehicle-Monitoring-
> System-3.git
> * cd Open-Vehicle-Monitoring-System-3/
> * git submodule update --init --recursive
> * cd vehicle/OVMS.V3/
> * cp support/sdkconfig.default.hw31 sdkconfig
> * make
> (And compilation was OK)
> In particular you can see the reverts here
> :https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commits/master
> * 7b1c932eab4e00d6a20ba1cc8f30d7dbf6db7e2d : Revert "compatibility
> with WolfSSH >= 1.4.12"
> * beaada5aaa6c76da2d83612d263a1f3eb17e240c : Revert "Upgrade wolfssh
> 1.4.13"
> Can you confirm that in your local dir you have these 2 commits ? And
> that the last commit id is indeed
> e7f41bd8d9aabc0cecba369dc1b7e3641e748d17 ?
> Are other people on the list experience the same as Chris does here ?
> I know that Github has had some issues in the past week but I'm very
> puzzled about the different experiences between both of us.
> Regarding your last comment on master : I do take full responsibility
> for the issue you're facing, as I did wrongly communicate about the
> order of PRs that should have been applied to master. However, it was
> not an experimentation - the experimentation has been properly done
> on a branch as expected.
> Le 13/05/2023 à 21:14, Chris van der Meijden a écrit :
> OK ... I deleted the master from my repo on github ... Did a fresh
> pull from OVMS master to my local and then a fresh push from there to
> a new master in my github repo.
> Compiling does not work, so this will also be the case for anyone
> pulling fresh from master.
> That is not good ... The OVMS master needs urgently to be restored to
> a working repository.
> I would also like to suggest to stop experimenting with OVMS master
> and use a branch instead untill things are stable.
> Am Samstag, dem 13.05.2023 um 19:59 +0200 schrieb Chris van der
> Meijden:
> > Could you please explain in detail what I need to do?
> > I tried to pull the code completely fresh from master. That does
> > not work.
> > What if a new user tries to compile from scratch? Will they run
> > into the same issues?
> > Am Samstag, dem 13.05.2023 um 19:32 +0200 schrieb Ludovic LANGE:
> > Hi Chris,
> > Yes we unfortunately had an issue where we merged, then reverted a
> > patch.
> > It seems that unfortunately it didn't work for you. Could you try
> > to fetch, then reset your git repo to HEAD, it seems you did not
> > fetch the "revert" patches ?
> > Let us know.
> > Le 13/05/2023 à 19:08, Chris van der Meijden a écrit :
> > Today I pulled the newest version. During the pull my Wolfssh
> > directory was deleted. I then renewed all the submodules and I got
> > the newest Wolfssh.
> > But now the verion 3.3.003-467-ge7f41bd8-dirty won't compile (why
> > is it "dirty" anyways, I didn't change the code ...).
> > First I get
> > CXX build/console_ssh/src/console_ssh.o
> > /home/chris/OVMS/Open-Vehicle-Monitoring-System-
> > 3/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp: In
> > function 'void wolfssh_logger(wolfSSH_LogLevel, const char*)':
> > 3/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp:1176:1
> > 0: error: enumeration value 'WS_LOG_CERTMAN' not handled in switch
> > [-Werror=switch]
> > switch (level)
> > Then I add case WS_LOG_CERTMAN: on line 1178:
> > static void wolfssh_logger(enum wolfSSH_LogLevel level, const char*
> > const msg)
> > switch (level)
> > But the I run into this error:
> > 3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c: In
> > function 'IdentifyKey':
> > 3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:883:9:
> > warning: unused variable 'dynType' [-Wunused-variable]
> > int dynType = isPrivate ? DYNTYPE_PRIVKEY : DYNTYPE_PUBKEY;
> > function 'DoKexDhReply':
> > 3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:3947:17
> > : error: implicit declaration of function 'PRIVATE_KEY_UNLOCK' [-
> > Werror=implicit-function-declaration]
> > PRIVATE_KEY_UNLOCK();
> > 3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:3952:17
> > : error: implicit declaration of function 'PRIVATE_KEY_LOCK' [-
> > PRIVATE_KEY_LOCK();
> > Any ideas?
> > Regards Chris
> > OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230513/ca938d93/attachment.htm>
