[Ovmsdev] Can't compile due to wolfssh
Ludovic LANGE
ll-ovmsdev at lange.nom.fr
Sun May 14 03:37:11 HKT 2023
Chris,
Very puzzling what you experience. As I did exactly the same in a fresh
dir without any issue:
* git clone
git at github.com:openvehicles/Open-Vehicle-Monitoring-System-3.git
* cd Open-Vehicle-Monitoring-System-3/
* git submodule update --init --recursive
* cd vehicle/OVMS.V3/
* cp support/sdkconfig.default.hw31 sdkconfig
* make
(And compilation was OK)
In particular you can see the reverts here :
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commits/master
* 7b1c932eab4e00d6a20ba1cc8f30d7dbf6db7e2d : Revert "compatibility
with WolfSSH >= 1.4.12"
* beaada5aaa6c76da2d83612d263a1f3eb17e240c : Revert "Upgrade wolfssh
1.4.13"
Can you confirm that in your local dir you have these 2 commits ? And
that the last commit id is indeed e7f41bd8d9aabc0cecba369dc1b7e3641e748d17 ?
Are other people on the list experience the same as Chris does here ? I
know that Github has had some issues in the past week but I'm very
puzzled about the different experiences between both of us.
Regarding your last comment on master : I do take full responsibility
for the issue you're facing, as I did wrongly communicate about the
order of PRs that should have been applied to master. However, it was
not an experimentation - the experimentation has been properly done on a
branch as expected.
Le 13/05/2023 à 21:14, Chris van der Meijden a écrit :
> OK ... I deleted the master from my repo on github ... Did a fresh
> pull from OVMS master to my local and then a fresh push from there to
> a new master in my github repo.
> Compiling does not work, so this will also be the case for anyone
> pulling fresh from master.
> That is not good ... The OVMS master needs urgently to be restored to
> a working repository.
> I would also like to suggest to stop experimenting with OVMS master
> and use a branch instead untill things are stable.
> Am Samstag, dem 13.05.2023 um 19:59 +0200 schrieb Chris van der Meijden:
>> Could you please explain in detail what I need to do?
>> I tried to pull the code completely fresh from master. That does not
>> work.
>> What if a new user tries to compile from scratch? Will they run into
>> the same issues?
>> Am Samstag, dem 13.05.2023 um 19:32 +0200 schrieb Ludovic LANGE:
>> Hi Chris,
>> Yes we unfortunately had an issue where we merged, then reverted a patch.
>> It seems that unfortunately it didn't work for you. Could you try to
>> fetch, then reset your git repo to HEAD, it seems you did not fetch
>> the "revert" patches ?
>> Let us know.
>> Le 13/05/2023 à 19:08, Chris van der Meijden a écrit :
>> Today I pulled the newest version. During the pull my Wolfssh
>> directory was deleted. I then renewed all the submodules and I got
>> the newest Wolfssh.
>> But now the verion 3.3.003-467-ge7f41bd8-dirty won't compile (why is
>> it "dirty" anyways, I didn't change the code ...).
>> First I get
>> CXX build/console_ssh/src/console_ssh.o
>> /home/chris/OVMS/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp:
>> In function 'void wolfssh_logger(wolfSSH_LogLevel, const char*)':
>> /home/chris/OVMS/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp:1176:10:
>> error: enumeration value 'WS_LOG_CERTMAN' not handled in switch
>> [-Werror=switch]
>> switch (level)
>> Then I add case WS_LOG_CERTMAN: on line 1178:
>> static void wolfssh_logger(enum wolfSSH_LogLevel level, const char*
>> const msg)
>> switch (level)
>> But the I run into this error:
>> /home/chris/OVMS/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:
>> In function 'IdentifyKey':
>> /home/chris/OVMS/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:883:9:
>> warning: unused variable 'dynType' [-Wunused-variable]
>> int dynType = isPrivate ? DYNTYPE_PRIVKEY : DYNTYPE_PUBKEY;
>> In function 'DoKexDhReply':
>> /home/chris/OVMS/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:3947:17:
>> error: implicit declaration of function 'PRIVATE_KEY_UNLOCK'
>> [-Werror=implicit-function-declaration]
>> PRIVATE_KEY_UNLOCK();
>> /home/chris/OVMS/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:3952:17:
>> error: implicit declaration of function 'PRIVATE_KEY_LOCK'
>> PRIVATE_KEY_LOCK();
>> Any ideas?
>> Regards Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230513/87369eb1/attachment.htm>
