[Ovmsdev] ESP-IDF v4 / v5 - baby steps
Ludovic LANGE ll-ovmsdev at lange.nom.fr
Fri Feb 3 05:38:38 HKT 2023
Hi list,
I started to split my big list of patches into smaller, more manageable,
easier to review PRs:
  * missing headers
    <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/825>
    #825
  * ESP-IDF v5+: dependency on ovms_webserver.h
    <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/824>
    #824
  * ESP-IDF v5+: change type of TaskHandle_t
    <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/823>#823
  * changes to (long deprecated) ADC constants
    <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/822>
    #822
  * ESP-IDF v5+: static assertion failed: std::vector must have the same
    value_type as its allocator
    <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/821>
    #821
  * ESP-IDF v5+: static assertion failed: comparison object must be
    invocable as const
    <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/820>
    #820
  * ESP-IDF v4+ : remove deprecated and unused esp_event_loop.h
    <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/819>
    #819
  * remove warning by replacing rom/queue.h with sys/queue.h
    <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/818>
    #818
  * remove warning : '_GNU_SOURCE' redefined
    <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/817>
    #817
  * ESP-IDF v4+ : esp_intr.h is deprecated, replaced by esp_intr_alloc.h
    <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/816>
    #816
  * Add header and fix function signature
    <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/815>
    #815
  * replace some constants with their more adapted counterpart
    <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/813>
    #813
Let me know if it's the proper approach ; and if some of you can review
those changes and comment on them, it'll help merging those - and
progress in reaching ESP-IDFv5 compatibility.
Best regards,
Le 31/01/2023 à 01:49, Ludovic LANGE a écrit :
> Hi list,
> Another quick post to share with you the progress on the ESP-IDFv5 +
> cmake endeavour:
>   * ESP-IDF v5 version of OVMSv3 is now officially booting and seems
>     to work fine (then again, I'm not doing any real-world testing for
>     lack of time / car at the moment - it's here that you can help me)
>     with a few caveats detailed in the PR or the README.md
>     <https://github.com/llange/Open-Vehicle-Monitoring-System-3/blob/experimental-esp-idf-v5/README.md>.
>   * The branch
>     https://github.com/llange/Open-Vehicle-Monitoring-System-3/tree/experimental-esp-idf-v5
>     is now ready for testing, sharing, studying, ...
>   * I created a draft PR
>     https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/810
>     (just like for ESP-IDFv4), in order to show the diff and gather
>     feedback. Not to be merged as-is.
>   * I'll try to break it into smaller low-impact / easy-to-review PR's
>     that could be merged as-is in current master (warning corrections,
>     header definitions, xxprintf type impact, etc...), so that the big
>     pieces could be more easily reviewed.
> Please note that those branches / PRs are still Work-In-Progress, and
> that I may certainly (and wrongly) `push --force` some changes as I
> rebase, update or split the big PR into smaller, easy to study PRs.
> I'll try not to but can't promise :-)
> So if you checkout the branch, please be warned and know your git
> commands to either reset or rebase your working copy...
> Next on my list are, in no particular order:
>   * Have a few patches/bugs fixed in upstream wolfSSL (in progress) in
>     order to enable
>   * Check to see if we could upgrade mongoose (not absolutely
>     necessary because it works / compile OK with a small patch)
>   * Fix the remaining warnings
>       o And change the ADC implementation that is deprecated now
>       o deprecation of esp_vfs_fat_spiflash_mount /
>         esp_vfs_fat_spiflash_unmount
>   * Fix the WIP WIP WIP commits
>   * Resume work on
>     https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/752
> Boot time warnings to study and check if OK:
>   * W (1091) esp_psram: Virtual address not enough for PSRAM, map as
>     much as we can. 4MB is mapped
>   * W (2132) ADC: legacy driver is deprecated, please migrate to
>     `esp_adc/adc_oneshot.h`   (<- this one is easy to understand...)
> Additional instructions:
> When first building, your sdkconfig will be converted as some config
> options did change betwen ESP-IDF v3.x and v5.x.
> Run `menuconfig` and :
>   * *Select FREERTOS_ENABLE_BACKWARD_COMPATIBILITY*(=y)
>     "configENABLE_BACKWARD_COMPATIBILITY"
>   * *Unselect MG_ENABLE_SSL*(=n) "Enable MONGOOSE SSL/TLS support"
> If any of you with some free time could be nice enough to try to
> reproduce such a build and share the experience here. Let me know how
> the instructions could be updated and what issues you are facing.
> Best regards,
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230202/771b40ec/attachment.htm>
