[Ovmsdev] ESP-IDF v4 / v5 - baby steps
Fri Feb 3 23:47:01 HKT 2023
Ludovic,
`int` or `int32_t` is correct, `INT` is defined by the fatfs
(/esp-idf/components/fatfs/src/integer.h) as `int`.
Btw, I recommend using ctags with an index on both the esp-idf and the
OVMS tree, makes looking up definitions very easy.
Am 23.01.23 um 22:19 schrieb Ludovic LANGE:
> A new things that need to be checked : in
> https://github.com/llange/Open-Vehicle-Monitoring-System-3/commit/f31117a48d4e293b2be01e8b48c1d580d0af834e
> i had to replace `INT` with another type. This time I choose `int32_t`
> but I'm not really sure because I could not find a way to see where
> and how INT was defined. I could only verify (by compilation tricks)
> that sizeof(INT) == sizeof(int32_t).
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230203/2e01ad44/attachment.sig>
