[Ovmsdev] ESP-IDF v4 / v5 - baby steps
Sun Feb 5 18:48:26 HKT 2023
Ludovic,
I'm having trouble getting the experimental-esp-idf-v5 branch to even
configure.
Configuring and building the "hello_world" example with idf5.0 works
without any issues, so it's related to our sources.
I've tried removing the build directory, doing "idf.py python-clean",
doing "idf.py clean" "idf.py fullclean", but I always get this, already
when doing set-target:
balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3>
idf.py set-target esp32
Adding "set-target"'s dependency "fullclean" to list of commands with
default set of options.
Executing action: fullclean
Build directory
'/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build'
not found. Nothing to clean.
Executing action: set-target
Set Target to: esp32, new sdkconfig created. Existing sdkconfig renamed
to sdkconfig.old.
Running cmake in directory
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1
-DIDF_TARGET=esp32 -DCCACHE_ENABLE=0
/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3"...
CMake Warning (dev) at CMakeLists.txt:8 (message):
WARNING - OVMSv3 build is only supported on ESP-IDF 3.3.x
This warning is for project developers. Use -Wno-dev to suppress it.
-- Found Git: /usr/bin/git (found version "2.35.3")
-- The C compiler identification is GNU 11.2.0
-- The CXX compiler identification is GNU 11.2.0
-- The ASM compiler identification is GNU
-- Found assembler:
/home/balzer/.espressif/tools/xtensa-esp32-elf/esp-2022r1-11.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler:
- skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler:
/home/balzer/.espressif/tools/xtensa-esp32-elf/esp-2022r1-11.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++
- skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Building ESP-IDF components for target esp32
Processing 2 dependencies:
[1/2] espressif/mdns (1.0.7)
[2/2] idf (5.0.0)
-- Found BISON: /usr/bin/bison (found version "3.0.4")
-- Found FLEX: /usr/bin/flex (found version "2.6.4")
-- IDF Version: 5.0.0 - NOT enabling strverscmp
CMake Error at /home/balzer/esp/esp-idf/tools/cmake/component.cmake:224
(message):
CMake Warning (dev) at build_properties.temp.cmake:8:
Syntax Warning in cmake code at column 51
Argument not separated from preceding token by whitespace.
Call Stack (most recent call first):
/home/balzer/esp/esp-idf/tools/cmake/scripts/component_get_requirements.cmake:3
(include)
CMake Error: Error required internal CMake variable not set, cmake
may not
be built correctly.
Missing variable is:
CMAKE_FIND_LIBRARY_PREFIXES
may not
be built correctly.
CMAKE_FIND_LIBRARY_SUFFIXES
/home/balzer/esp/esp-idf/tools/cmake/build.cmake:553
(__component_get_requirements)
/home/balzer/esp/esp-idf/tools/cmake/project.cmake:440
(idf_build_process)
CMakeLists.txt:18 (project)
-- Configuring incomplete, errors occurred!
See also
"/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/CMakeFiles/CMakeOutput.log".
cmake failed with exit code 1, output of the command is in the
/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/log/idf_py_stderr_output_8211
and
/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/log/idf_py_stdout_output_8211
Any idea about this?
Am 02.02.23 um 22:38 schrieb Ludovic LANGE:
> Hi list,
> I started to split my big list of patches into smaller, more
> manageable, easier to review PRs:
> * missing headers
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/825>
> #825
> * ESP-IDF v5+: dependency on ovms_webserver.h
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/824>
> #824
> * ESP-IDF v5+: change type of TaskHandle_t
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/823>#823
> * changes to (long deprecated) ADC constants
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/822>
> #822
> * ESP-IDF v5+: static assertion failed: std::vector must have the
> same value_type as its allocator
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/821>
> #821
> * ESP-IDF v5+: static assertion failed: comparison object must be
> invocable as const
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/820>
> #820
> * ESP-IDF v4+ : remove deprecated and unused esp_event_loop.h
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/819>
> #819
> * remove warning by replacing rom/queue.h with sys/queue.h
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/818>
> #818
> * remove warning : '_GNU_SOURCE' redefined
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/817>
> #817
> * ESP-IDF v4+ : esp_intr.h is deprecated, replaced by
> esp_intr_alloc.h
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/816>
> #816
> * Add header and fix function signature
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/815>
> #815
> * replace some constants with their more adapted counterpart
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/813>
> #813
> Let me know if it's the proper approach ; and if some of you can
> review those changes and comment on them, it'll help merging those -
> and progress in reaching ESP-IDFv5 compatibility.
> Best regards,
> Le 31/01/2023 à 01:49, Ludovic LANGE a écrit :
>> Hi list,
>> Another quick post to share with you the progress on the ESP-IDFv5 +
>> cmake endeavour:
>> * ESP-IDF v5 version of OVMSv3 is now officially booting and seems
>> to work fine (then again, I'm not doing any real-world testing
>> for lack of time / car at the moment - it's here that you can
>> help me) with a few caveats detailed in the PR or the README.md
>> <https://github.com/llange/Open-Vehicle-Monitoring-System-3/blob/experimental-esp-idf-v5/README.md>.
>> * The branch
>> https://github.com/llange/Open-Vehicle-Monitoring-System-3/tree/experimental-esp-idf-v5
>> is now ready for testing, sharing, studying, ...
>> * I created a draft PR
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/810
>> (just like for ESP-IDFv4), in order to show the diff and gather
>> feedback. Not to be merged as-is.
>> * I'll try to break it into smaller low-impact / easy-to-review
>> PR's that could be merged as-is in current master (warning
>> corrections, header definitions, xxprintf type impact, etc...),
>> so that the big pieces could be more easily reviewed.
>> Please note that those branches / PRs are still Work-In-Progress, and
>> that I may certainly (and wrongly) `push --force` some changes as I
>> rebase, update or split the big PR into smaller, easy to study PRs.
>> I'll try not to but can't promise :-)
>> So if you checkout the branch, please be warned and know your git
>> commands to either reset or rebase your working copy...
>> Next on my list are, in no particular order:
>> * Have a few patches/bugs fixed in upstream wolfSSL (in progress)
>> in order to enable
>> * Check to see if we could upgrade mongoose (not absolutely
>> necessary because it works / compile OK with a small patch)
>> * Fix the remaining warnings
>> o And change the ADC implementation that is deprecated now
>> o deprecation of esp_vfs_fat_spiflash_mount /
>> esp_vfs_fat_spiflash_unmount
>> * Fix the WIP WIP WIP commits
>> * Resume work on
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/752
>> Boot time warnings to study and check if OK:
>> * W (1091) esp_psram: Virtual address not enough for PSRAM, map as
>> much as we can. 4MB is mapped
>> * W (2132) ADC: legacy driver is deprecated, please migrate to
>> `esp_adc/adc_oneshot.h` (<- this one is easy to understand...)
>> Additional instructions:
>> When first building, your sdkconfig will be converted as some config
>> options did change betwen ESP-IDF v3.x and v5.x.
>> Run `menuconfig` and :
>> * *Select FREERTOS_ENABLE_BACKWARD_COMPATIBILITY*(=y)
>> "configENABLE_BACKWARD_COMPATIBILITY"
>> * *Unselect MG_ENABLE_SSL*(=n) "Enable MONGOOSE SSL/TLS support"
>> If any of you with some free time could be nice enough to try to
>> reproduce such a build and share the experience here. Let me know how
>> the instructions could be updated and what issues you are facing.
>> Best regards,
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230205/a729e219/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230205/a729e219/attachment-0001.sig>
