[Ovmsdev] ESP-IDF v4 / v5 - baby steps
Ludovic LANGE
ll-ovmsdev at lange.nom.fr
Sun Feb 5 22:45:07 HKT 2023
Hi Michael,
Sorry to hear you have issues but very happy that you're trying to
compile it ! We're going to solve those :-)
I don't use this command `idf.py set-target esp32` myself - but after
trying it, it works as expected.
(By the look of it, it says "Set Target to: esp32, new sdkconfig
created. Existing sdkconfig renamed to sdkconfig.old." so I would be
careful not to use it too much as you loose your sdkconfig)
The only commands I'm using are:
* menuconfig (once in a while)
* fullclean (while switching ESP-IDF version ; also doing `rm -rf build/`)
* clean (if some changes have been made and not caught by cmake)
* build (90% of the time)
* app-flash
* monitor
My versions of git / bison / flex are (for the record):
-- Found Git: /usr/local/bin/git (found version "2.39.1")
-- The C compiler identification is GNU 11.2.0
-- The CXX compiler identification is GNU 11.2.0
-- Found BISON: /usr/bin/bison (found version "2.3")
-- Found FLEX: /usr/bin/flex (found version "2.6.4")
(I also had success with bison 3.8.2 so not an issue)
and my cmake is : cmake version 3.25.2
and ninja is at version 1.11.1
I set a required version of cmake 3.16 in the main CMakeLists.txt, as
recommended by ESP-IDF v5 instructions, but if it's the issue we can
modify this.
Could you please check your version and see if there is something to try
here ?
During the `set-target esp32` run, my output is similar to yours but
continues:
> Adding "set-target"'s dependency "fullclean" to list of commands with
> default set of options.
> Executing action: fullclean
> Executing action: set-target
> Set Target to: esp32, new sdkconfig created. Existing sdkconfig
> Running cmake in directory SRCS/OVMS-wt2/vehicle/OVMS.V3/build
> Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1
> -DIDF_TARGET=esp32 -DCCACHE_ENABLE=0 SRCS/OVMS-wt2/vehicle/OVMS.V3"...
> CMake Warning (dev) at CMakeLists.txt:8 (message):
> WARNING - OVMSv3 build is only supported on ESP-IDF 3.3.x
> This warning is for project developers. Use -Wno-dev to suppress it.
> -- The ASM compiler identification is GNU
> -- Found assembler:
> SRCS/ESP-IDF-TOOLS/5.0/tools/xtensa-esp32-elf/esp-2022r1-11.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Check for working C compiler:
> - skipped
> -- Detecting C compile features
> -- Detecting C compile features - done
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- Check for working CXX compiler:
> SRCS/ESP-IDF-TOOLS/5.0/tools/xtensa-esp32-elf/esp-2022r1-11.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++
> - skipped
> -- Detecting CXX compile features
> -- Detecting CXX compile features - done
> -- Building ESP-IDF components for target esp32
> Processing 2 dependencies:
> [1/2] espressif/mdns (1.0.7)
> [2/2] idf (5.0.0)
> -- IDF Version: 5.0.0 - NOT enabling strverscmp
> -- Project sdkconfig file SRCS/OVMS-wt2/vehicle/OVMS.V3/sdkconfig
> -- Looking for sys/types.h
> -- Looking for sys/types.h - found
> -- Looking for stdint.h
> -- Looking for stdint.h - found
> -- Looking for stddef.h
> -- Looking for stddef.h - found
> -- Check size of time_t
> -- Check size of time_t - done
> -- Found Python3:
> SRCS/ESP-IDF-TOOLS/5.0/python_env/idf5.0_py3.10_env/bin/python (found
> version "3.10.9") found components: Interpreter
> -- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS
> -- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS - Success
> -- App "ovms3" version: 3.3.003-316-gcb90ef8c-dirty
> -- Adding linker script
> SRCS/OVMS-wt2/vehicle/OVMS.V3/build/esp-idf/esp_system/ld/memory.ld
> SRCS/ESP-IDF/5.0/components/esp_system/ld/esp32/sections.ld.in
> SRCS/ESP-IDF/5.0/components/esp_rom/esp32/ld/esp32.rom.ld
> SRCS/ESP-IDF/5.0/components/esp_rom/esp32/ld/esp32.rom.api.ld
> SRCS/ESP-IDF/5.0/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
> SRCS/ESP-IDF/5.0/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
> SRCS/ESP-IDF/5.0/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
> SRCS/ESP-IDF/5.0/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
> SRCS/ESP-IDF/5.0/components/soc/esp32/ld/esp32.peripherals.ld
> -- Adding linker script SRCS/OVMS-wt2/vehicle/OVMS.V3/main/ovms_boot.ld
> -- wolfssl : EXCLUDE_ASM =
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/aes_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/aes_gcm_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/aes_gcm_x86_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/chacha_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/fe_x25519_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/poly1305_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-32-aes-asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-32-curve25519.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-32-sha256-asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-32-sha512-asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-curve25519.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-sha3-asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-sha512-asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/sha256_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/sha3_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/sha512_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/sp_x86_64_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/wc_kyber_asm.S
> -- Found Perl: /usr/local/bin/perl (found version "5.36.0")
> -- Component idf::main will be linked with -Wl,--whole-archive
> -- Component idf::pcp will be linked with -Wl,--whole-archive
> -- Component idf::ovms_buffer will be linked with -Wl,--whole-archive
> -- Component idf::can will be linked with -Wl,--whole-archive
> -- Component idf::canopen will be linked with -Wl,--whole-archive
> -- Component idf::wolfssl will be linked with -Wl,--whole-archive
> -- Component idf::console_ssh will be linked with -Wl,--whole-archive
> -- Component idf::console_telnet will be linked with -Wl,--whole-archive
> -- Component idf::crypto will be linked with -Wl,--whole-archive
> -- Component idf::dbc will be linked with -Wl,--whole-archive
> -- Component idf::esp32adc will be linked with -Wl,--whole-archive
> -- Component idf::esp32bluetooth will be linked with -Wl,--whole-archive
> -- Component idf::esp32can will be linked with -Wl,--whole-archive
> -- Component idf::esp32system will be linked with -Wl,--whole-archive
> -- Component idf::esp32wifi will be linked with -Wl,--whole-archive
> -- Component idf::ext12v will be linked with -Wl,--whole-archive
> -- Component idf::max7317 will be linked with -Wl,--whole-archive
> -- Component idf::mcp2515 will be linked with -Wl,--whole-archive
> -- Component idf::microrl will be linked with -Wl,--whole-archive
> -- Component idf::obd2ecu will be linked with -Wl,--whole-archive
> -- Component idf::ovms_http will be linked with -Wl,--whole-archive
> -- Component idf::ovms_location will be linked with -Wl,--whole-archive
> -- Component idf::ovms_mdns will be linked with -Wl,--whole-archive
> -- Component idf::ovms_netlib will be linked with -Wl,--whole-archive
> -- Component idf::ovms_ota will be linked with -Wl,--whole-archive
> -- Component idf::pushover will be linked with -Wl,--whole-archive
> -- Component idf::ovms_webserver will be linked with -Wl,--whole-archive
> -- Component idf::ovms_plugins will be linked with -Wl,--whole-archive
> -- Component idf::ovms_tls will be linked with -Wl,--whole-archive
> -- Component idf::ovms_script will be linked with -Wl,--whole-archive
> -- Component idf::ovms_server will be linked with -Wl,--whole-archive
> -- Component idf::ovms_server_v2 will be linked with -Wl,--whole-archive
> -- Component idf::ovms_server_v3 will be linked with -Wl,--whole-archive
> -- Component idf::ovms_tpms will be linked with -Wl,--whole-archive
> -- Component idf::powermgmt will be linked with -Wl,--whole-archive
> -- Component idf::retools will be linked with -Wl,--whole-archive
> -- Component idf::retools_pidscan will be linked with -Wl,--whole-archive
> -- Component idf::retools_testerpresent will be linked with
> -Wl,--whole-archive
> -- Component idf::sdcard will be linked with -Wl,--whole-archive
> -- Component idf::simcom will be linked with -Wl,--whole-archive
> -- Component idf::spi will be linked with -Wl,--whole-archive
> -- Component idf::strverscmp will be linked with -Wl,--whole-archive
> -- Component idf::swcan will be linked with -Wl,--whole-archive
> -- Component idf::vehicle will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_bmwi3 will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_boltev will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_cadillac_c2_cts will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_chevrolet_c6_corvette will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_dbc will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_demo will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_fiat500 will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_hyundai_ioniq5 will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_hyundai_ioniqvfl will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_jaguaripace will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_kianiroev will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_kiasoulev will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_maxus_edeliver3 will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_mercedesb250e will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_mgev will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_minise will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_mitsubishi will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_nissanleaf will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_none will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_obdii will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_renaulttwizy will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_renaultzoe will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_renaultzoe_ph2_obd will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_smarted will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_smarteq will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_teslamodel3 will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_teslamodels will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_teslaroadster will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_thinkcity will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_toyotarav4ev will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_track will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_voltampera will be linked with
> -Wl,--whole-archive
> -- Component idf::vehicle_vweup will be linked with -Wl,--whole-archive
> -- Component idf::vehicle_zeva will be linked with -Wl,--whole-archive
> -- Component idf::vfsedit will be linked with -Wl,--whole-archive
> -- Component idf::zip will be linked with -Wl,--whole-archive
> -- Components: app_trace app_update bootloader bootloader_support bt
> can canopen cmock console console_ssh console_telnet crypto cxx dbc
> driver duktape efuse esp-tls esp32adc esp32bluetooth esp32can
> esp32system esp32wifi esp_adc esp_app_format esp_common esp_eth
> esp_event esp_gdbstub esp_hid esp_http_client esp_http_server
> esp_https_ota esp_https_server esp_hw_support esp_lcd esp_local_ctrl
> esp_netif esp_partition esp_phy esp_pm esp_psram esp_ringbuf esp_rom
> esp_system esp_timer esp_wifi espcoredump espressif__mdns esptool_py
> ext12v fatfs freertos hal heap http_parser idf_test ieee802154 json
> libtelnet log lwip main max7317 mbedtls mcp2515 microrl mongoose mqtt
> newlib nvs_flash obd2ecu openthread ovms_buffer ovms_cellular
> ovms_http ovms_location ovms_mdns ovms_netlib ovms_ota ovms_plugins
> ovms_script ovms_server ovms_server_v2 ovms_server_v3 ovms_tls
> ovms_tpms ovms_webserver partition_table pcp perfmon powermgmt
> protobuf-c protocomm pthread pushover retools retools_pidscan
> retools_testerpresent sdcard sdmmc simcom soc spi spi_flash spiffs
> strverscmp swcan tcp_transport ulp unity usb vehicle vehicle_bmwi3
> vehicle_boltev vehicle_cadillac_c2_cts vehicle_chevrolet_c6_corvette
> vehicle_dbc vehicle_demo vehicle_fiat500 vehicle_hyundai_ioniq5
> vehicle_hyundai_ioniqvfl vehicle_jaguaripace vehicle_kianiroev
> vehicle_kiasoulev vehicle_maxus_edeliver3 vehicle_mercedesb250e
> vehicle_mgev vehicle_minise vehicle_mitsubishi vehicle_nissanleaf
> vehicle_none vehicle_obdii vehicle_renaulttwizy vehicle_renaultzoe
> vehicle_renaultzoe_ph2_obd vehicle_smarted vehicle_smarteq
> vehicle_teslamodel3 vehicle_teslamodels vehicle_teslaroadster
> vehicle_thinkcity vehicle_toyotarav4ev vehicle_track
> vehicle_voltampera vehicle_vweup vehicle_zeva vfs vfsedit
> wear_levelling wifi_provisioning wolfssh wolfssl wpa_supplicant xtensa zip
> -- Component paths: SRCS/ESP-IDF/5.0/components/app_trace
> SRCS/ESP-IDF/5.0/components/app_update
> SRCS/ESP-IDF/5.0/components/bootloader
> SRCS/ESP-IDF/5.0/components/bootloader_support
> SRCS/ESP-IDF/5.0/components/bt
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/can
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/canopen
> SRCS/ESP-IDF/5.0/components/cmock
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/console
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/console_ssh
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/console_telnet
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/crypto
> SRCS/ESP-IDF/5.0/components/cxx
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/dbc
> SRCS/ESP-IDF/5.0/components/driver
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/duktape
> SRCS/ESP-IDF/5.0/components/efuse SRCS/ESP-IDF/5.0/components/esp-tls
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/esp32adc
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/esp32bluetooth
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/esp32can
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/esp32system
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/esp32wifi
> SRCS/ESP-IDF/5.0/components/esp_adc
> SRCS/ESP-IDF/5.0/components/esp_app_format
> SRCS/ESP-IDF/5.0/components/esp_common
> SRCS/ESP-IDF/5.0/components/esp_eth
> SRCS/ESP-IDF/5.0/components/esp_event
> SRCS/ESP-IDF/5.0/components/esp_gdbstub
> SRCS/ESP-IDF/5.0/components/esp_hid
> SRCS/ESP-IDF/5.0/components/esp_http_client
> SRCS/ESP-IDF/5.0/components/esp_http_server
> SRCS/ESP-IDF/5.0/components/esp_https_ota
> SRCS/ESP-IDF/5.0/components/esp_https_server
> SRCS/ESP-IDF/5.0/components/esp_hw_support
> SRCS/ESP-IDF/5.0/components/esp_lcd
> SRCS/ESP-IDF/5.0/components/esp_local_ctrl
> SRCS/ESP-IDF/5.0/components/esp_netif
> SRCS/ESP-IDF/5.0/components/esp_partition
> SRCS/ESP-IDF/5.0/components/esp_phy SRCS/ESP-IDF/5.0/components/esp_pm
> SRCS/ESP-IDF/5.0/components/esp_psram
> SRCS/ESP-IDF/5.0/components/esp_ringbuf
> SRCS/ESP-IDF/5.0/components/esp_timer
> SRCS/ESP-IDF/5.0/components/esp_wifi
> SRCS/ESP-IDF/5.0/components/espcoredump
> SRCS/OVMS-wt2/vehicle/OVMS.V3/managed_components/espressif__mdns
> SRCS/ESP-IDF/5.0/components/esptool_py
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ext12v
> SRCS/ESP-IDF/5.0/components/fatfs SRCS/ESP-IDF/5.0/components/freertos
> SRCS/ESP-IDF/5.0/components/hal SRCS/ESP-IDF/5.0/components/heap
> SRCS/ESP-IDF/5.0/components/http_parser
> SRCS/ESP-IDF/5.0/components/idf_test
> SRCS/ESP-IDF/5.0/components/ieee802154
> SRCS/ESP-IDF/5.0/components/json
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/libtelnet
> SRCS/ESP-IDF/5.0/components/log SRCS/ESP-IDF/5.0/components/lwip
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/max7317
> SRCS/ESP-IDF/5.0/components/mbedtls
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/mcp2515
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/microrl
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/mongoose
> SRCS/ESP-IDF/5.0/components/mqtt SRCS/ESP-IDF/5.0/components/newlib
> SRCS/ESP-IDF/5.0/components/nvs_flash
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/obd2ecu
> SRCS/ESP-IDF/5.0/components/openthread
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_buffer
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_cellular
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_http
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_location
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_mdns
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_netlib
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_ota
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_plugins
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_script
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_server
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_server_v2
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_server_v3
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_tls
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_tpms
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_webserver
> SRCS/ESP-IDF/5.0/components/partition_table
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/pcp
> SRCS/ESP-IDF/5.0/components/perfmon
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/powermgmt
> SRCS/ESP-IDF/5.0/components/protobuf-c
> SRCS/ESP-IDF/5.0/components/protocomm
> SRCS/ESP-IDF/5.0/components/pthread
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/pushover
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/retools
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/retools_pidscan
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/retools_testerpresent
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/sdcard
> SRCS/ESP-IDF/5.0/components/sdmmc
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/simcom
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/spi
> SRCS/ESP-IDF/5.0/components/spi_flash
> SRCS/ESP-IDF/5.0/components/spiffs
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/strverscmp
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/swcan
> SRCS/ESP-IDF/5.0/components/tcp_transport
> SRCS/ESP-IDF/5.0/components/ulp SRCS/ESP-IDF/5.0/components/unity
> SRCS/ESP-IDF/5.0/components/usb
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_bmwi3
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_boltev
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_cadillac_c2_cts
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_chevrolet_c6_corvette
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_dbc
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_demo
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_fiat500
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_hyundai_ioniq5
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_hyundai_ioniqvfl
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_jaguaripace
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_kianiroev
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_kiasoulev
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_maxus_edeliver3
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_mercedesb250e
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_mgev
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_minise
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_mitsubishi
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_nissanleaf
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_none
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_obdii
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_renaulttwizy
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_renaultzoe
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_renaultzoe_ph2_obd
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_smarted
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_smarteq
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_teslamodel3
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_teslamodels
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_teslaroadster
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_thinkcity
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_toyotarav4ev
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_track
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_voltampera
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_vweup
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_zeva
> SRCS/ESP-IDF/5.0/components/vfs
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vfsedit
> SRCS/ESP-IDF/5.0/components/wear_levelling
> SRCS/ESP-IDF/5.0/components/wifi_provisioning
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssh
> SRCS/ESP-IDF/5.0/components/wpa_supplicant
> SRCS/ESP-IDF/5.0/components/xtensa
> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/zip
> -- Configuring done
> -- Generating done
> -- Build files have been written to: SRCS/OVMS-wt2/vehicle/OVMS.V3/build
So the next line that should have been printed, instead of the error,
would have been:
Could you check that your env variable `IDF_PATH` is pointing to the
proper copy of ESP-IDF (v5 then) ? It's currently set to
`/home/balzer/esp/esp-idf`.
(The main CMakeLists.txt includes
`$ENV{IDF_PATH}/tools/cmake/project.cmake`)
The important env variables for ESP-IDF would be:
* CMAKE_COLOR_DIAGNOSTICS set to 1 to have beautiful error messages
* ESPBAUD set to 921600
* ESPPORT set to your usb device (mine is /dev/cu.usbserial-0001)
* ESP_IDF_VERSION (5.0 here)
* IDF_PATH should be set to the proper 5.0 root
* IDF_TOOLS_EXPORT_CMD on my installation is equivalent to
$IDF_PATH/export.sh
* IDF_TOOLS_INSTALL_CMD on my installation is equivalent to
$IDF_PATH/install.sh
* IDF_TOOLS_PATH should be set to proper 5.0 tools root
* IDF_PYTHON_ENV_PATH on my installation is equivalent to
$IDF_TOOLS_PATH/python_env/idf5.0_py3.10_env
* OPENOCD_SCRIPTS on my installation is equivalent to
$IDF_TOOLS_PATH/tools/openocd-esp32/v0.11.0-esp32-20221026/openocd-esp32/share/openocd/scripts
and
* PATH which should include a few occurrences of $IDF_PATH and
$IDF_TOOLS_PATH
All of them should be automatically set it you have installed per the
docs, and the fact that "hello_world" compiles is a good indicator that
it was OK on your install , but double-checking is always interesting.
Let me know the result of your checks.
Le 05/02/2023 à 11:48, Michael Balzer a écrit :
> Ludovic,
> I'm having trouble getting the experimental-esp-idf-v5 branch to even
> configure.
> Configuring and building the "hello_world" example with idf5.0 works
> without any issues, so it's related to our sources.
> I've tried removing the build directory, doing "idf.py python-clean",
> doing "idf.py clean" "idf.py fullclean", but I always get this,
> already when doing set-target:
> balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3>
> Build directory
> '/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build'
> not found. Nothing to clean.
> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3"...
> -- Found Git: /usr/bin/git (found version "2.35.3")
> -- Found assembler:
> /home/balzer/.espressif/tools/xtensa-esp32-elf/esp-2022r1-11.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
> - skipped
> /home/balzer/.espressif/tools/xtensa-esp32-elf/esp-2022r1-11.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++
> - skipped
> [2/2] idf (5.0.0)
> -- Found BISON: /usr/bin/bison (found version "3.0.4")
> CMake Error at
> /home/balzer/esp/esp-idf/tools/cmake/component.cmake:224 (message):
> CMake Warning (dev) at build_properties.temp.cmake:8:
> Syntax Warning in cmake code at column 51
> Argument not separated from preceding token by whitespace.
> Call Stack (most recent call first):
> /home/balzer/esp/esp-idf/tools/cmake/scripts/component_get_requirements.cmake:3
> (include)
> CMake Error: Error required internal CMake variable not set, cmake
> may not
> be built correctly.
> Missing variable is:
> CMAKE_FIND_LIBRARY_PREFIXES
> may not
> be built correctly.
> CMAKE_FIND_LIBRARY_SUFFIXES
> /home/balzer/esp/esp-idf/tools/cmake/build.cmake:553
> (__component_get_requirements)
> /home/balzer/esp/esp-idf/tools/cmake/project.cmake:440
> (idf_build_process)
> CMakeLists.txt:18 (project)
> -- Configuring incomplete, errors occurred!
> See also
> "/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/CMakeFiles/CMakeOutput.log".
> cmake failed with exit code 1, output of the command is in the
> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/log/idf_py_stderr_output_8211
> and
> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/log/idf_py_stdout_output_8211
> Any idea about this?
> Am 02.02.23 um 22:38 schrieb Ludovic LANGE:
>> Hi list,
>> I started to split my big list of patches into smaller, more
>> manageable, easier to review PRs:
>> * missing headers
>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/825>
>> #825
>> * ESP-IDF v5+: dependency on ovms_webserver.h
>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/824>
>> #824
>> * ESP-IDF v5+: change type of TaskHandle_t
>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/823>#823
>> * changes to (long deprecated) ADC constants
>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/822>
>> #822
>> * ESP-IDF v5+: static assertion failed: std::vector must have the
>> same value_type as its allocator
>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/821>
>> #821
>> * ESP-IDF v5+: static assertion failed: comparison object must be
>> invocable as const
>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/820>
>> #820
>> * ESP-IDF v4+ : remove deprecated and unused esp_event_loop.h
>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/819>
>> #819
>> * remove warning by replacing rom/queue.h with sys/queue.h
>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/818>
>> #818
>> * remove warning : '_GNU_SOURCE' redefined
>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/817>
>> #817
>> * ESP-IDF v4+ : esp_intr.h is deprecated, replaced by
>> esp_intr_alloc.h
>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/816>
>> #816
>> * Add header and fix function signature
>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/815>
>> #815
>> * replace some constants with their more adapted counterpart
>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/813>
>> #813
>> Let me know if it's the proper approach ; and if some of you can
>> review those changes and comment on them, it'll help merging those -
>> and progress in reaching ESP-IDFv5 compatibility.
>> Best regards,
>> Le 31/01/2023 à 01:49, Ludovic LANGE a écrit :
>>> Hi list,
>>> Another quick post to share with you the progress on the ESP-IDFv5 +
>>> cmake endeavour:
>>> * ESP-IDF v5 version of OVMSv3 is now officially booting and seems
>>> to work fine (then again, I'm not doing any real-world testing
>>> for lack of time / car at the moment - it's here that you can
>>> help me) with a few caveats detailed in the PR or the README.md
>>> <https://github.com/llange/Open-Vehicle-Monitoring-System-3/blob/experimental-esp-idf-v5/README.md>.
>>> * The branch
>>> https://github.com/llange/Open-Vehicle-Monitoring-System-3/tree/experimental-esp-idf-v5
>>> is now ready for testing, sharing, studying, ...
>>> * I created a draft PR
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/810
>>> (just like for ESP-IDFv4), in order to show the diff and gather
>>> feedback. Not to be merged as-is.
>>> * I'll try to break it into smaller low-impact / easy-to-review
>>> PR's that could be merged as-is in current master (warning
>>> corrections, header definitions, xxprintf type impact, etc...),
>>> so that the big pieces could be more easily reviewed.
>>> Please note that those branches / PRs are still Work-In-Progress,
>>> and that I may certainly (and wrongly) `push --force` some changes
>>> as I rebase, update or split the big PR into smaller, easy to study
>>> PRs. I'll try not to but can't promise :-)
>>> So if you checkout the branch, please be warned and know your git
>>> commands to either reset or rebase your working copy...
>>> Next on my list are, in no particular order:
>>> * Have a few patches/bugs fixed in upstream wolfSSL (in progress)
>>> in order to enable
>>> * Check to see if we could upgrade mongoose (not absolutely
>>> necessary because it works / compile OK with a small patch)
>>> * Fix the remaining warnings
>>> o And change the ADC implementation that is deprecated now
>>> o deprecation of esp_vfs_fat_spiflash_mount /
>>> esp_vfs_fat_spiflash_unmount
>>> * Fix the WIP WIP WIP commits
>>> * Resume work on
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/752
>>> Boot time warnings to study and check if OK:
>>> * W (1091) esp_psram: Virtual address not enough for PSRAM, map as
>>> much as we can. 4MB is mapped
>>> * W (2132) ADC: legacy driver is deprecated, please migrate to
>>> `esp_adc/adc_oneshot.h` (<- this one is easy to understand...)
>>> Additional instructions:
>>> When first building, your sdkconfig will be converted as some config
>>> options did change betwen ESP-IDF v3.x and v5.x.
>>> Run `menuconfig` and :
>>> * *Select FREERTOS_ENABLE_BACKWARD_COMPATIBILITY*(=y)
>>> "configENABLE_BACKWARD_COMPATIBILITY"
>>> * *Unselect MG_ENABLE_SSL*(=n) "Enable MONGOOSE SSL/TLS support"
>>> If any of you with some free time could be nice enough to try to
>>> reproduce such a build and share the experience here. Let me know
>>> how the instructions could be updated and what issues you are facing.
>>> Best regards,
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230205/10d54d85/attachment-0001.htm>
