[Ovmsdev] Improvements to BMS command display
Michael Geddes
Tue Nov 1 17:12:42 HKT 2022
Adding the separate sub-commands would be easy enough to add to this to
force only temp or only volt. I had
contemplated it and it would be very easy given what I've already done.
I think from your screenshot, you would be ok with 4 + 1 cols too in that
narrow arrangement.. so maybe I should just limit the display to 5 cols
overall ?
imho I think that would be a lot better than what happens now with readings
per module > 4!
Your Six modules would split into 2 lines of 3 in the current code.. would
that be a problem?
For the ioniq 5, the info from the csv for torquepro shows a possible 192
cells, and it describes the temperatures as belonging to 'battery pack 1'
through to 'battery pack 16', so I'm inclined to think that they have a
temperature sensor there for pack 16? even though it would be empty in my
car (180 cells filled).
//.ichael
On Tue, 1 Nov 2022 at 16:50, Michael Balzer <dexter at expeedo.de> wrote:
> Michael,
> regarding separate temperature / voltage display, I suggest adding sub
> commands, i.e. "bms temp" / "bms volt".
> Regarding the layout: it's difficult to tell what will fit, especially in
> vertical orientation, as this depends on the display and font size chosen.
> With a font size of 12.0 on my Huawei, max 4 columns would fit:
> https://drive.google.com/file/d/1ra6QWcPh03rd5GO9xyykY3ZI_ofRrzj1/view?usp=share_link
> https://drive.google.com/file/d/1rasYOBL8lY1NwM9oq_gL6pvcX-uinJjj/view?usp=share_link
> Regarding your temperature sensors: it's possible you've actually got
> <modules>+1 sensors if they are placed between the modules. You should see
> that when heating up the battery by driving, an empty/reserved module space
> wouldn't heat up as much as filled modules. For a layout of temperature
> sensors between the cell modules, you could decide to derive the module
> temperature by building the average of it's adjacent sensors.
> Am 01.11.22 um 09:19 schrieb Michael Geddes:
> Is there any reason I shouldn't create a pull request for this?
> At the moment a multiple of 5 (but not a multiple of 4) will give you 5
> columns ..
> though I suspect this won't output nicely on the mobile app 'Messages'
> which really will probably only work nicely with 4+1=5 total columns.
> This is my latest output
> with
> Voltage
> Cells = 180 (of 192 max)
> Readings Per Module = 12 (so 15 modules of a possible 16)
> Temperature
> Readings = 16
> OVMS# bms
> Voltage:
> Average: 3.636V [3.620V - 3.640V]
> Deviation: SD 7.98mV [max 0.00mV], 0 warnings, 0 alerts
> Temperature:
> Average: 17.2C [ 17.0C - 18.0C]
> Deviation: SD 0.39C [max 0.39C], 0 warnings, 0 alerts
> Cells:
> 1 | 3.640V 3.640V 3.640V 3.640V | 18.0C |
> | 3.640V 3.640V 3.640V 3.640V | |
> 2 | 3.620V 3.640V 3.640V 3.640V | 17.0C |
> 3 | 3.640V 3.640V 3.640V 3.640V | 18.0C |
> 4 | 3.620V 3.640V 3.640V 3.640V | 17.0C |
> | 3.640V 3.640V 3.620V 3.640V | |
> 5 | 3.620V 3.640V 3.640V 3.640V | 17.0C |
> 6 | 3.640V 3.640V 3.640V 3.640V | 17.0C |
> | 3.640V 3.620V 3.640V 3.640V | |
> 7 | 3.640V 3.640V 3.640V 3.640V | 17.0C |
> | 3.640V 3.620V 3.620V 3.640V | |
> 8 | 3.620V 3.640V 3.640V 3.640V | 17.0C |
> 9 | 3.640V 3.640V 3.640V 3.640V | 17.0C |
> | 3.640V 3.640V 3.620V 3.620V | |
> 10 | 3.640V 3.640V 3.640V 3.640V | 17.0C |
> | 3.620V 3.620V 3.620V 3.640V | |
> 11 | 3.620V 3.640V 3.640V 3.640V | 17.0C |
> | 3.620V 3.640V 3.640V 3.640V | |
> | 3.620V 3.640V 3.620V 3.620V | |
> 12 | 3.620V 3.640V 3.620V 3.620V | 17.0C |
> | 3.640V 3.640V 3.640V 3.620V | |
> 13 | 3.620V 3.620V 3.640V 3.640V | 17.0C |
> | 3.620V 3.640V 3.640V 3.620V | |
> | 3.640V 3.620V 3.640V 3.620V | |
> 14 | 3.620V 3.640V 3.640V 3.640V | 17.0C |
> 15 | 3.620V 3.640V 3.640V 3.640V | 18.0C |
> 16 | | 17.0C |
> On Tue, 1 Nov 2022 at 07:29, Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
>> .. As to whether this is correct for my i5: it might actually be correct.
>> My i5 seems to have 180 of a possible 192 cells. It seems that it's
>> likely there are 12 cell packs in a module (
>> https://insideevs.com/news/539940/hyundai-ioniq5-battery-pack-opened/)
>> Which possibly means they still have a temperature sensor for the
>> unfilled module!? Which would make this correct!
>> I wonder if I should cap the temperature sensors based on the number of
>> battery packs?
>> Anyway.
>> Should I try and reduce the height of that last module entry?
>> //.ichael
>> On Tue, 1 Nov 2022 at 07:19, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>>> Hi all,
>>> I'll create a PR soon, but just wanted to ask something first.
>>> I've made the 'bms' command so that it will work with temperature OR
>>> voltages and only display that one column. For example:
>>> OVMS# bms
>>> Temperature:
>>> Average: 3.6C [ 3.6C - 3.6C]
>>> Deviation: SD 0.00C [max 0.48C], 0 warnings, 0 alerts
>>> Cells:
>>> 1 | 14.0C |
>>> 2 | 14.0C |
>>> 3 | 14.0C |
>>> 4 | 15.0C |
>>> 5 | 14.0C |
>>> 6 | 3.6C |
>>> 7 | 3.6C |
>>> 8 | 3.6C |
>>> 9 | 3.6C |
>>> 10 | 3.6C |
>>> 11 | 3.6C |
>>> 12 | 3.6C |
>>> 13 | 3.6C |
>>> 14 | 3.6C |
>>> 15 | 3.6C |
>>> 16 | 3.6C |
>>> The other improvement I'm trying, and want some feedback on is when you
>>> have readings-per-module set > 4. Here I don't have it set quite right..
>>> but you get the idea. The setting is at 12, which ends up being quite wide
>>> (yes, there's one temperature sensor off on its own, so my setting is not
>>> quite right yet).
>>> At the moment the column count is capped at 4 (and will cope with it not
>>> dividing properly), but the idea would be something along the lines of
>>> trying n % 3 and n % 5 first and then 4. So cap the column count at 3, 5 or
>>> 4 depending. The idea is that this becomes readable in the APP!
>>> Thoughts?
>>> OVMS# bms
>>> Voltage:
>>> Average: 3.632V [3.620V - 3.640V]
>>> Deviation: SD 9.75mV [max 0.00mV], 0 warnings, 0 alerts
>>> Temperature:
>>> Average: 14.0C [ 13.0C - 15.0C]
>>> Deviation: SD 0.35C [max 0.48C], 0 warnings, 0 alerts
>>> Cells:
>>> 1 | 3.640V 3.640V 3.640V 3.640V | 14.0C |
>>> 2 | 3.620V 3.620V 3.640V 3.640V | 14.0C |
>>> | 3.620V 3.620V 3.640V 3.640V | |
>>> 3 | 3.620V 3.640V 3.640V 3.640V | 14.0C |
>>> 4 | 3.620V 3.640V 3.640V 3.640V | 14.0C |
>>> 5 | 3.620V 3.620V 3.640V 3.640V | 14.0C |
>>> 6 | 3.640V 3.640V 3.640V 3.640V | 15.0C |
>>> | 3.640V 3.620V 3.620V 3.620V | |
>>> 7 | 3.640V 3.640V 3.640V 3.640V | 13.0C |
>>> | 3.620V 3.620V 3.620V 3.620V | |
>>> 8 | 3.620V 3.640V 3.620V 3.640V | 14.0C |
>>> 9 | 3.640V 3.640V 3.640V 3.640V | 14.0C |
>>> 10 | 3.620V 3.640V 3.640V 3.620V | 14.0C |
>>> 11 | 3.620V 3.640V 3.640V 3.640V | 14.0C |
>>> | 3.620V 3.620V 3.640V 3.620V | |
>>> 12 | 3.620V 3.620V 3.620V 3.620V | 14.0C |
>>> 13 | 3.620V 3.620V 3.640V 3.640V | 14.0C |
>>> 14 | 3.620V 3.620V 3.640V 3.640V | 14.0C |
>>> 15 | 3.620V 3.640V 3.640V 3.640V | 14.0C |
>>> 16 | | 14.0C |
>>> OVMS#
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221101/5e2bc59f/attachment-0001.htm>
