[Ovmsdev] Improvements to BMS command display
    Tue Nov  1 17:25:57 HKT 2022
I don't think 5 columns would fit including padding & border, but you
really can't get this to work on any device, so simply choose something
that will work most of the time.
Rows splitted into 2x3 actually would result in 4 columns total, so that
will work for me anyway.
Am 01.11.22 um 10:12 schrieb Michael Geddes:
> Adding the separate sub-commands would be easy enough to add to this
> to force only temp or only volt. I had
> contemplated it and it would be very easy given what I've already done.
> I think from your screenshot, you would be ok with 4 + 1 cols too in
> that narrow arrangement.. so maybe I should just limit the display to
> 5 cols overall ?
> imho I think that would be a lot better than what happens now with
> readings per module > 4!
> Your Six modules would split into 2 lines of 3 in the current code..
> would that be a problem?
> For the ioniq 5, the info from the csv for torquepro shows a possible
> 192 cells, and it describes the temperatures as belonging to 'battery
> pack 1' through to 'battery pack 16', so I'm inclined to think that
> they have a temperature sensor there for pack 16? even though it would
> be empty in my car (180 cells filled).
> //.ichael
> On Tue, 1 Nov 2022 at 16:50, Michael Balzer <dexter at expeedo.de> wrote:
>     Michael,
>     regarding separate temperature / voltage display, I suggest adding
>     sub commands, i.e. "bms temp" / "bms volt".
>     Regarding the layout: it's difficult to tell what will fit,
>     especially in vertical orientation, as this depends on the display
>     and font size chosen. With a font size of 12.0 on my Huawei, max 4
>     columns would fit:
>     https://drive.google.com/file/d/1ra6QWcPh03rd5GO9xyykY3ZI_ofRrzj1/view?usp=share_link
>     https://drive.google.com/file/d/1rasYOBL8lY1NwM9oq_gL6pvcX-uinJjj/view?usp=share_link
>     Regarding your temperature sensors: it's possible you've actually
>     got <modules>+1 sensors if they are placed between the modules.
>     You should see that when heating up the battery by driving, an
>     empty/reserved module space wouldn't heat up as much as filled
>     modules. For a layout of temperature sensors between the cell
>     modules, you could decide to derive the module temperature by
>     building the average of it's adjacent sensors.
>     Regards,
>     Michael
>     Am 01.11.22 um 09:19 schrieb Michael Geddes:
>>     Is there any reason I shouldn't create a pull request for this?
>>     At the moment a multiple of 5 (but not a multiple of 4) will give
>>     you 5 columns ..
>>     though I suspect this won't output nicely on the mobile app
>>     'Messages' which really will probably only work nicely with 4+1=5
>>     total columns.
>>     This is my latest output
>>     with
>>     Voltage
>>       Cells = 180 (of 192 max)
>>       Readings Per Module = 12  (so 15 modules of a possible 16)
>>     Temperature
>>       Readings = 16
>>     OVMS# bms
>>     Voltage:
>>         Average: 3.636V [3.620V - 3.640V]
>>       Deviation: SD   7.98mV [max 0.00mV], 0 warnings, 0 alerts
>>     Temperature:
>>         Average:  17.2C [ 17.0C -  18.0C]
>>       Deviation: SD   0.39C  [max 0.39C], 0 warnings, 0 alerts
>>     Cells:
>>       1 | 3.640V 3.640V 3.640V 3.640V |  18.0C |
>>         | 3.640V 3.640V 3.640V 3.640V |        |
>>       2 | 3.620V 3.640V 3.640V 3.640V |  17.0C |
>>       3 | 3.640V 3.640V 3.640V 3.640V |  18.0C |
>>       4 | 3.620V 3.640V 3.640V 3.640V |  17.0C |
>>         | 3.640V 3.640V 3.620V 3.640V |        |
>>       5 | 3.620V 3.640V 3.640V 3.640V |  17.0C |
>>       6 | 3.640V 3.640V 3.640V 3.640V |  17.0C |
>>         | 3.640V 3.620V 3.640V 3.640V |        |
>>       7 | 3.640V 3.640V 3.640V 3.640V |  17.0C |
>>         | 3.640V 3.620V 3.620V 3.640V |        |
>>       8 | 3.620V 3.640V 3.640V 3.640V |  17.0C |
>>       9 | 3.640V 3.640V 3.640V 3.640V |  17.0C |
>>         | 3.640V 3.640V 3.620V 3.620V |        |
>>      10 | 3.640V 3.640V 3.640V 3.640V |  17.0C |
>>         | 3.620V 3.620V 3.620V 3.640V |        |
>>      11 | 3.620V 3.640V 3.640V 3.640V |  17.0C |
>>         | 3.620V 3.640V 3.640V 3.640V |        |
>>         | 3.620V 3.640V 3.620V 3.620V |        |
>>      12 | 3.620V 3.640V 3.620V 3.620V |  17.0C |
>>         | 3.640V 3.640V 3.640V 3.620V |        |
>>      13 | 3.620V 3.620V 3.640V 3.640V |  17.0C |
>>         | 3.620V 3.640V 3.640V 3.620V |        |
>>         | 3.640V 3.620V 3.640V 3.620V |        |
>>      14 | 3.620V 3.640V 3.640V 3.640V |  17.0C |
>>      15 | 3.620V 3.640V 3.640V 3.640V |  18.0C |
>>      16 |                             |  17.0C |
>>     On Tue, 1 Nov 2022 at 07:29, Michael Geddes
>>     <frog at bunyip.wheelycreek.net> wrote:
>>         .. As to whether this is correct for my i5: it might actually
>>         be correct.
>>         My i5 seems to have 180 of a possible 192 cells. It seems
>>         that it's likely there are 12 cell packs  in a module
>>         (https://insideevs.com/news/539940/hyundai-ioniq5-battery-pack-opened/)
>>         Which possibly means they still have a temperature sensor for
>>         the unfilled module!? Which would make this correct!
>>         I wonder if I should cap the temperature sensors based on the
>>         number of battery packs?
>>         Anyway.
>>         Should I try and reduce the height of that last module entry?
>>         //.ichael
>>         On Tue, 1 Nov 2022 at 07:19, Michael Geddes
>>             Hi all,
>>             I'll create a PR soon, but just wanted to ask something
>>             first.
>>             I've made the 'bms' command so that it will work with
>>             temperature OR voltages and only display that one column.
>>             For example:
>>             OVMS# bms
>>             Temperature:
>>                 Average:   3.6C [  3.6C -   3.6C]
>>               Deviation: SD   0.00C  [max 0.48C], 0 warnings, 0 alerts
>>             Cells:
>>               1 |  14.0C |
>>               2 |  14.0C |
>>               3 |  14.0C |
>>               4 |  15.0C |
>>               5 |  14.0C |
>>               6 |   3.6C |
>>               7 |   3.6C |
>>               8 |   3.6C |
>>               9 |   3.6C |
>>              10 |   3.6C |
>>              11 |   3.6C |
>>              12 |   3.6C |
>>              13 |   3.6C |
>>              14 |   3.6C |
>>              15 |   3.6C |
>>              16 |   3.6C |
>>             The other improvement I'm trying, and want some feedback
>>             on is when you have readings-per-module set > 4. Here I
>>             don't have it set quite right.. but you get the idea.
>>             The setting is at 12, which ends up being quite wide
>>             (yes, there's one temperature sensor off on its own, so
>>             my setting is not quite right yet).
>>             At the moment the column count is capped at 4 (and will
>>             cope with it not dividing properly), but the idea would
>>             be something along the lines of trying n % 3 and n % 5
>>             first and then 4. So cap the column count at 3, 5 or 4
>>             depending.  The idea is that this becomes readable in the
>>             APP!
>>             Thoughts?
>>             OVMS# bms
>>             Voltage:
>>                 Average: 3.632V [3.620V - 3.640V]
>>               Deviation: SD   9.75mV [max 0.00mV], 0 warnings, 0 alerts
>>             Temperature:
>>                 Average:  14.0C [ 13.0C -  15.0C]
>>               Deviation: SD   0.35C  [max 0.48C], 0 warnings, 0 alerts
>>             Cells:
>>               1 | 3.640V 3.640V 3.640V 3.640V |  14.0C |
>>               2 | 3.620V 3.620V 3.640V 3.640V |  14.0C |
>>                 | 3.620V 3.620V 3.640V 3.640V |  |
>>               3 | 3.620V 3.640V 3.640V 3.640V |  14.0C |
>>               4 | 3.620V 3.640V 3.640V 3.640V |  14.0C |
>>               5 | 3.620V 3.620V 3.640V 3.640V |  14.0C |
>>               6 | 3.640V 3.640V 3.640V 3.640V |  15.0C |
>>                 | 3.640V 3.620V 3.620V 3.620V |  |
>>               7 | 3.640V 3.640V 3.640V 3.640V |  13.0C |
>>                 | 3.620V 3.620V 3.620V 3.620V |  |
>>               8 | 3.620V 3.640V 3.620V 3.640V |  14.0C |
>>               9 | 3.640V 3.640V 3.640V 3.640V |  14.0C |
>>              10 | 3.620V 3.640V 3.640V 3.620V |  14.0C |
>>              11 | 3.620V 3.640V 3.640V 3.640V |  14.0C |
>>                 | 3.620V 3.620V 3.640V 3.620V |  |
>>              12 | 3.620V 3.620V 3.620V 3.620V |  14.0C |
>>              13 | 3.620V 3.620V 3.640V 3.640V |  14.0C |
>>              14 | 3.620V 3.620V 3.640V 3.640V |  14.0C |
>>              15 | 3.620V 3.640V 3.640V 3.640V |  14.0C |
>>              16 |                             |  14.0C |
>>             OVMS#
>>     _______________________________________________
>>     OvmsDev mailing list
>>     OvmsDev at lists.openvehicles.com
>>     http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>     Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>     Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221101/7e87861a/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221101/7e87861a/attachment-0001.sig>
