[Ovmsdev] Improvements to BMS command display
    Tue Nov  1 16:49:57 HKT 2022
Michael,
regarding separate temperature / voltage display, I suggest adding sub
commands, i.e. "bms temp" / "bms volt".
Regarding the layout: it's difficult to tell what will fit, especially
in vertical orientation, as this depends on the display and font size
chosen. With a font size of 12.0 on my Huawei, max 4 columns would fit:
https://drive.google.com/file/d/1ra6QWcPh03rd5GO9xyykY3ZI_ofRrzj1/view?usp=share_link
https://drive.google.com/file/d/1rasYOBL8lY1NwM9oq_gL6pvcX-uinJjj/view?usp=share_link
Regarding your temperature sensors: it's possible you've actually got
<modules>+1 sensors if they are placed between the modules. You should
see that when heating up the battery by driving, an empty/reserved
module space wouldn't heat up as much as filled modules. For a layout of
temperature sensors between the cell modules, you could decide to derive
the module temperature by building the average of it's adjacent sensors.
Am 01.11.22 um 09:19 schrieb Michael Geddes:
> Is there any reason I shouldn't create a pull request for this?
> At the moment a multiple of 5 (but not a multiple of 4) will give you
> 5 columns ..
> though I suspect this won't output nicely on the mobile app
> 'Messages' which really will probably only work nicely with 4+1=5
> total columns.
> This is my latest output
> with
> Voltage
>   Cells = 180 (of 192 max)
>   Readings Per Module = 12 (so 15 modules of a possible 16)
> Temperature
>   Readings = 16
> OVMS# bms
> Voltage:
>     Average: 3.636V [3.620V - 3.640V]
>   Deviation: SD   7.98mV [max 0.00mV], 0 warnings, 0 alerts
> Temperature:
>     Average:  17.2C [ 17.0C -  18.0C]
>   Deviation: SD   0.39C  [max 0.39C], 0 warnings, 0 alerts
> Cells:
>   1 | 3.640V 3.640V 3.640V 3.640V |  18.0C |
>     | 3.640V 3.640V 3.640V 3.640V |        |
>   2 | 3.620V 3.640V 3.640V 3.640V |  17.0C |
>   3 | 3.640V 3.640V 3.640V 3.640V |  18.0C |
>   4 | 3.620V 3.640V 3.640V 3.640V |  17.0C |
>     | 3.640V 3.640V 3.620V 3.640V |        |
>   5 | 3.620V 3.640V 3.640V 3.640V |  17.0C |
>   6 | 3.640V 3.640V 3.640V 3.640V |  17.0C |
>     | 3.640V 3.620V 3.640V 3.640V |        |
>   7 | 3.640V 3.640V 3.640V 3.640V |  17.0C |
>     | 3.640V 3.620V 3.620V 3.640V |        |
>   8 | 3.620V 3.640V 3.640V 3.640V |  17.0C |
>   9 | 3.640V 3.640V 3.640V 3.640V |  17.0C |
>     | 3.640V 3.640V 3.620V 3.620V |        |
>  10 | 3.640V 3.640V 3.640V 3.640V |  17.0C |
>     | 3.620V 3.620V 3.620V 3.640V |        |
>  11 | 3.620V 3.640V 3.640V 3.640V |  17.0C |
>     | 3.620V 3.640V 3.640V 3.640V |        |
>     | 3.620V 3.640V 3.620V 3.620V |        |
>  12 | 3.620V 3.640V 3.620V 3.620V |  17.0C |
>     | 3.640V 3.640V 3.640V 3.620V |        |
>  13 | 3.620V 3.620V 3.640V 3.640V |  17.0C |
>     | 3.620V 3.640V 3.640V 3.620V |        |
>     | 3.640V 3.620V 3.640V 3.620V |        |
>  14 | 3.620V 3.640V 3.640V 3.640V |  17.0C |
>  15 | 3.620V 3.640V 3.640V 3.640V |  18.0C |
>  16 |                             |  17.0C |
> On Tue, 1 Nov 2022 at 07:29, Michael Geddes
> <frog at bunyip.wheelycreek.net> wrote:
>     .. As to whether this is correct for my i5: it might actually be
>     correct.
>     My i5 seems to have 180 of a possible 192 cells. It seems that
>     it's likely there are 12 cell packs  in a module
>     (https://insideevs.com/news/539940/hyundai-ioniq5-battery-pack-opened/)
>     Which possibly means they still have a temperature sensor for the
>     unfilled module!? Which would make this correct!
>     I wonder if I should cap the temperature sensors based on the
>     number of battery packs?
>     Anyway.
>     Should I try and reduce the height of that last module entry?
>     //.ichael
>     On Tue, 1 Nov 2022 at 07:19, Michael Geddes
>         Hi all,
>         I'll create a PR soon, but just wanted to ask something first.
>         I've made the 'bms' command so that it will work with
>         temperature OR voltages and only display that one column. For
>         example:
>         OVMS# bms
>         Temperature:
>             Average:   3.6C [  3.6C -   3.6C]
>           Deviation: SD   0.00C  [max 0.48C], 0 warnings, 0 alerts
>         Cells:
>           1 |  14.0C |
>           2 |  14.0C |
>           3 |  14.0C |
>           4 |  15.0C |
>           5 |  14.0C |
>           6 |   3.6C |
>           7 |   3.6C |
>           8 |   3.6C |
>           9 |   3.6C |
>          10 |   3.6C |
>          11 |   3.6C |
>          12 |   3.6C |
>          13 |   3.6C |
>          14 |   3.6C |
>          15 |   3.6C |
>          16 |   3.6C |
>         The other improvement I'm trying, and want some feedback on is
>         when you have readings-per-module set > 4. Here I don't have
>         it set quite right.. but you get the idea.  The setting is at
>         12, which ends up being quite wide (yes, there's one
>         temperature sensor off on its own, so my setting is not quite
>         right yet).
>         At the moment the column count is capped at 4 (and will cope
>         with it not dividing properly), but the idea would be
>         something along the lines of trying n % 3 and n % 5 first and
>         then 4. So cap the column count at 3, 5 or 4 depending.  The
>         idea is that this becomes readable in the APP!
>         Thoughts?
>         OVMS# bms
>         Voltage:
>             Average: 3.632V [3.620V - 3.640V]
>           Deviation: SD   9.75mV [max 0.00mV], 0 warnings, 0 alerts
>         Temperature:
>             Average:  14.0C [ 13.0C -  15.0C]
>           Deviation: SD   0.35C  [max 0.48C], 0 warnings, 0 alerts
>         Cells:
>           1 | 3.640V 3.640V 3.640V 3.640V |  14.0C |
>           2 | 3.620V 3.620V 3.640V 3.640V |  14.0C |
>             | 3.620V 3.620V 3.640V 3.640V |        |
>           3 | 3.620V 3.640V 3.640V 3.640V |  14.0C |
>           4 | 3.620V 3.640V 3.640V 3.640V |  14.0C |
>           5 | 3.620V 3.620V 3.640V 3.640V |  14.0C |
>           6 | 3.640V 3.640V 3.640V 3.640V |  15.0C |
>             | 3.640V 3.620V 3.620V 3.620V |        |
>           7 | 3.640V 3.640V 3.640V 3.640V |  13.0C |
>             | 3.620V 3.620V 3.620V 3.620V |        |
>           8 | 3.620V 3.640V 3.620V 3.640V |  14.0C |
>           9 | 3.640V 3.640V 3.640V 3.640V |  14.0C |
>          10 | 3.620V 3.640V 3.640V 3.620V |  14.0C |
>          11 | 3.620V 3.640V 3.640V 3.640V |  14.0C |
>             | 3.620V 3.620V 3.640V 3.620V |        |
>          12 | 3.620V 3.620V 3.620V 3.620V |  14.0C |
>          13 | 3.620V 3.620V 3.640V 3.640V |  14.0C |
>          14 | 3.620V 3.620V 3.640V 3.640V |  14.0C |
>          15 | 3.620V 3.640V 3.640V 3.640V |  14.0C |
>          16 |                             |  14.0C |
>         OVMS#
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221101/fea8b60b/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221101/fea8b60b/attachment-0001.sig>
