Everyone, I'm currently working on the next Android release including KustomWidget support and a native app widget based on the old Automagic gauge widget. Automagic has been dead for some time now, and it keeps crashing on Androids >= 7. My changes so far are in the hub, APK builds are available here: * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk * debug build for extended logging: https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk There's an issue with the App related to Android >= 10 though, which I haven't found yet. It's been reported in the forum: * https://www.openvehicles.com/node/3410 I could use some help with that, I've got no idea other than blaming Android. I've seen the effect in my emulator tests, and it seems to occur more frequently with non-roadster images. Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Hey Michael, I just installed the "release" Version on LineageOS 19.1 (Android 12) without Google components. The vehicle setup was without any troubles. I could select the yellow VW e-UP image without crashing. The App version is set wrong under "Vehicle info" (3.19.1, 2021122401). Everything seems to be faster than before. When I change the checkbox on "Track vehicle" under "Position" the App crashes. But after a new start of the app the value of the checkbox has changed. Perhaps this first impression is of some help. Regards Chris Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer:
Everyone,
My changes so far are in the hub, APK builds are available here: * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk * debug build for extended logging: https://dexters-web.de/f/tw- beta/OpenVehicleApp-22092401-debug.apk
Regards, Michael
Chris, thanks for testing. A crash log would help on any crashes you see. Btw, I don't bump the revision until the actual release build. Crashes related to the car image don't occur immediately, it sometimes takes hours of use before it happens. When it does, clearing the App cache fixes the crash for another random period. Speed optimization was one goal. What about the widget? Thanks, Michael Am 24.09.22 um 22:43 schrieb Chris van der Meijden:
Hey Michael,
Regards
Chris
Everyone,
Regards, Michael
Hey Michael, this is from logcat when I change "Track vehicle" and the app crashes: 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission Denial: receiving Intent { act=android.intent.action.SERVICE_STATE flg=0x1000010 (has extras) } to ProcessRecord{8dcdd54 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) requires android.permission.ACCESS_FINE_LOCATION due to sender android (uid 1001) I saw now, that this crash also happens in the production app. The widget is running well. I will keep the app running for while and will see if it stays stable. Regards Chris Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael Balzer:
Chris,
Thanks, Michael
Hey Michael,
Regards
Chris
Everyone,
Regards, Michael
Chris, that's not a crash log, that's just a warning. On that warning: the App requests android.permission.ACCESS_FINE_LOCATION by it's manifest. Maybe with LineageOS you need to manually give it that permission? A crash log has class "E" (error) and includes an exception and a backtrace, for an example see: https://issuetracker.google.com/issues/201308676#comment4 On the crash: maybe it's because you don't have the Google components, not sure if FragMap can handle that. The forum post relates to /e/OS … maybe I need some emulator images running alternative Androids now… Regards, Michael Am 25.09.22 um 11:40 schrieb Chris van der Meijden:
Hey Michael,
Regards
Chris
Chris,
Thanks, Michael
Am 24.09.22 um 22:43 schrieb Chris van der Meijden: Hey Michael,
Regards
Chris
Everyone,
Regards, Michael
As I don't have Google components I don't see the map, so I did not give the location permissions. But the crash on "Track vehicle" is just a minor, old, behauviour of the app and has no effect on the daily usage. Just an incidential finding. Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael Balzer:
Chris,
Regards, Michael
Hey Michael,
Regards
Chris
Chris,
Thanks, Michael
Hey Michael,
Regards
Chris
Everyone,
Regards, Michael
Just guessing, but does int icon; in MyGcmListenerService.java at line 132 not need to be initialized like int icon = 0; now you use .setSmallIcon((icon != 0) ? icon : R.drawable.map_car_default) at line 150 now? As the images and the Google stuff are related to that integer it made me thinking ... Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael Balzer:
Chris,
Regards, Michael
Hey Michael,
Regards
Chris
Chris,
Thanks, Michael
Hey Michael,
Regards
Chris
Everyone,
Regards, Michael
No, icon can only be 0 from the else branch, in that case it shall fall back to the default image. But I've meanwhile found (I think) your maps/track crash, commit is already in the hub. The checkbox handler didn't check if the map object is initialized. https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicle... Regards, Michael Am 25.09.22 um 15:46 schrieb Chris van der Meijden:
int icon;
in MyGcmListenerService.java <https://github.com/devmarxx/Open-Vehicle-Android/commit/3c13100a6a25257fe694be3050a1b76ca2b6fb44#diff-c13198cb33bb355f600c37f8889cedcb72346835dbb7e357c031c57aba424487> at line 132
int icon = 0;
now you use
.setSmallIcon((icon!= 0) ? icon: R.drawable.map_car_default)
at line 150 now?
Chris,
Regards, Michael
Am 25.09.22 um 11:40 schrieb Chris van der Meijden: Hey Michael,
Regards
Chris
Chris,
Thanks, Michael
Regards
Chris
Everyone,
Regards, Michael
Hey Michael Cool, thanx! I just compiled the app with the new code. I got a lint error: GPSTracker.java:73: Error: Missing permissions required by LocationManager.requestLocationUpdates: android.permission.ACCESS_COARSE_LOCATION or android.permission.ACCESS_FINE_LOCATION [MissingPermission] locationManager.requestLocationUpdates( ^ so I compiled with gradlew build -x lint and I could build the apk. The app is running and the checkbox crash is solved :-) If there is anything else I can check, just let me know. Regards Chris Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael Balzer:
Regards, Michael
int icon;
int icon = 0;
now you use
at line 150 now?
Chris,
Regards, Michael
Hey Michael,
Regards
Chris
Chris,
Thanks, Michael
Hey Michael,
Regards
Chris
Everyone,
Regards, Michael
I like the new KWGT Widget feature: Above is the Tesla Widget of our Model 3, beneath that my OVMS KWGT widget of our VW e-UP. I had to allow "Passing data to other apps". The syntax for getting the intent variables to text in KWGT is i.e. $br(ovms, car_sel_vehicle_label)$ Other variables can be found here: https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-I... The image is local on the filesystem of the phone and does not come by intent. Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael Balzer:
Regards, Michael
int icon;
int icon = 0;
now you use
at line 150 now?
Chris,
Regards, Michael
Hey Michael,
Regards
Chris
Chris,
Thanks, Michael
Hey Michael,
Regards
Chris
Everyone,
Regards, Michael
Correction: $br(ovms, sel_vehicle_label)$ Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb Chris van der Meijden:
Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael Balzer: No, icon can only be 0 from the else branch, in that case it shall fall back to the default image.
Regards, Michael
int icon;
int icon = 0;
now you use
at line 150 now?
Chris,
Regards, Michael
Hey Michael,
Regards
Chris
Chris,
Thanks, Michael
Hey Michael,
Regards
Chris
Everyone,
Regards, Michael
Nice, please go ahead if you want to create an includable example widget :-) I've found out you can also use progress bars to display values, enable formula input on the "step" & set the formular to e.g. $br(ovms, car_soc)$. Works, although I need to convert all car model values to strings for KWGT. Btw, I also need to unroll the TPMS arrays, they are split into a "_cnt" & "_<n>" variables. I need to add an info on this to the wiki. I haven't found out how to send a broadcast from KWGT yet, is that possible? That would enable creating command shortcuts & buttons as with Automagic. Regards, Michael Am 26.09.22 um 12:13 schrieb Chris van der Meijden:
Correction:
Regards, Michael
Am 25.09.22 um 15:46 schrieb Chris van der Meijden: Just guessing, but does
int icon;
int icon = 0;
now you use
at line 150 now?
Chris,
Regards, Michael
Regards
Chris
Chris,
Thanks, Michael
Regards
Chris
Everyone,
Regards, Michael
For an includable example it would be nice if we could send the vehicle image from the OVMS app to KWGT. You can assign "Activities" to the "Touch" event on an image. Would be cool if that works, so we can start the remote climate control similar to how I do that with my OVMS-Fireplace app: https://github.com/devmarxx/OVMS-Fireplace Am Montag, dem 26.09.2022 um 13:56 +0200 schrieb Michael Balzer:
Regards, Michael
Correction:
Regards, Michael
int icon;
int icon = 0;
now you use
at line 150 now?
Chris,
Regards, Michael
Hey Michael,
Regards
Chris
Chris,
Thanks, Michael
Hey Michael,
Regards
Chris
Everyone,
Regards, Michael
New test build: * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-release.apk * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-debug.apk This includes major extensions & code rewrites, I think I'll bump the version to 4.0 when releasing this to Google Play. Main goal & outcome of this effort: command bookmarks. The App now offers stored commands (see notifications tab). Stored commands can be pinned to the launcher and selected from third party Apps like KWGT as shortcuts to execute on triggers / actions. So this enabled custom widgets to include buttons triggering car commands. Commands are given using the user syntax, i.e. don't need the MP function prefix. You can still call an MP function by using the user syntax, i.e. "#…". Command responses are shown as a dialog with a timeoout of 5 seconds unless you hold it by touching or begin scrolling a long response. If the App is paused it will be resumed and switch to the notifications page (which keeps a record of all commands & responses). If the App isn't running, only the response dialog is shown on the launcher. All this of course needs the service to be enabled & allow commands to be sent. Command responses are also broadcasted now, so KWGT et al can receive them -- but they will currently need to know the command sent previously and copy command responses if they need to keep them, I don't know if KWGT can do that (Automagic can). KWGT seems to only have a simple variable storage model. I think about extending the ApiService to keep a command queue so the broadcast can at least carry the command, the response is supposedly produced for. Unfortunately the MP API cannot guarantee this, as it doesn't currently return a copy of the original command or a command ID reference with the response, so this would at best be a guess. Not sure if users actually need this. Note: I haven't pushed the code changes to github yet, I'd first like to get some test feedback. I've tested this on Android 6, 7, 11 & 13, but not on any degoogled Androids. Regards, Michael Am 26.09.22 um 17:26 schrieb Chris van der Meijden:
Regards, Michael
Am 26.09.22 um 12:13 schrieb Chris van der Meijden: Correction:
Regards, Michael
int icon;
int icon = 0;
now you use
at line 150 now?
Chris,
Regards, Michael
Regards
Chris
Chris,
Thanks, Michael
Regards
Chris
Everyone,
Regards, Michael
Hi Michael I just installed the release apk on my degoogled Lineageos 19.1. Installation went without any troubles. I tested the broadcast with my fireplace app via webinent: action: 'com.openvehicles.OVMS.SendCommand', extras: { sel_vehicleid: vid, sel_server_password: pwd, msg_command: '7,climatecontrol on' } It works still fine and I can see the response dialog in the OVMS app. I don't understand the "MP function". Do you have an example for for i.e. "climatecontrol on" via Buttons in KWGT? I'd love to test that :-) And do you know if there is a way to send intent broadcasts with KWGT? I tried with a "GLOBALE", but I could not get that to work. Regards Chris Am Samstag, dem 08.10.2022 um 15:37 +0200 schrieb Michael Balzer:
Regards, Michael
Regards, Michael
Correction:
Regards, Michael
int icon;
int icon = 0;
now you use
at line 150 now?
Chris,
Regards, Michael
Hey Michael,
Regards
Chris
Chris,
Thanks, Michael
Hey Michael,
Regards
Chris
Everyone,
Regards, Michael
Chris, "com.openvehicles.OVMS.SendCommand" is the old command action, it's still supported and should work the same way as before, except there are some new extras in the response intent. The "SendCommand" interface is raw MP function level, that's why you need to prefix "7," for text commands (7 = execute text command). Other MP commands work just the same way as raw commands, e.g. "20,<pin>" will lock the car if supported. (https://docs.openvehicles.com/en/latest/protocol_v2/commands.html) The newly added command intent action is "com.openvehicles.OVMS.action.COMMAND", it just takes one extra "command", which takes the command just as entered in the notification page. See help there for the syntax, text commands can be given as in the shell, to send the above MP lock command, you'd enter "#20,<pin>". This action currently always sends the command to the currently selected vehicle. KWGT doesn't support sending intents, that's why I've done all this. To call a stored command from KWGT, set a suitable element's touch handler to "start shortcut". After clicking on that action, you can open a selector. It will show the list of shortcut providers installed including the OVMS App now. Click on the OVMS entry, then select the command from the list of stored commands. Regards, Michael Am 08.10.22 um 17:54 schrieb Chris van der Meijden:
Hi Michael
Regards
Chris
New test build:
Regards, Michael
Am 26.09.22 um 17:26 schrieb Chris van der Meijden: For an includable example it would be nice if we could send the vehicle image from the OVMS app to KWGT.
Regards, Michael
Regards, Michael
int icon;
int icon = 0;
now you use
at line 150 now?
Chris,
Regards, Michael
Regards
Chris
Chris,
Thanks, Michael
Regards
Chris
> Everyone, > > I'm currently working on the next Android release including > KustomWidget support and a native app widget based on the old > Automagic gauge widget. > > Automagic has been dead for some time now, and it keeps crashing > on Androids >= 7. > > My changes so far are in the hub, APK builds are available here: > > > * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk > * debug build for extended logging: > https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk > > > There's an issue with the App related to Android >= 10 though, > which I haven't found yet. It's been reported in the forum: > > > * https://www.openvehicles.com/node/3410 > > I could use some help with that, I've got no idea other than > blaming Android. > > I've seen the effect in my emulator tests, and it seems to occur > more frequently with non-roadster images. > > Regards, > Michael > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
I have been playing with the "SH" function of KWGT and tried to send a broadcast over the shell, like adb: 'am broadcast -a com.whereismywifeserver.intent.TEST --es sms_body "test from adb"' That did not work, there where "rights" issues. I took a look at the commands documentation. I will play a bit with that. Thanx for explaining! Am Samstag, dem 08.10.2022 um 18:54 +0200 schrieb Michael Balzer:
Chris,
Regards, Michael
Hi Michael
Regards
Chris
Regards, Michael
Regards, Michael
Correction:
Regards, Michael
int icon;
int icon = 0;
now you use
at line 150 now?
Chris,
Regards, Michael
Hey Michael,
Regards
Chris
Chris,
Thanks, Michael
Hey Michael,
Regards
Chris
> Everyone, > > I'm currently working on the next Android release > including KustomWidget support and a native app widget > based on the old Automagic gauge widget. > > Automagic has been dead for some time now, and it keeps > crashing on Androids >= 7. > > My changes so far are in the hub, APK builds are > available here: > > > * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk > * debug build for extended logging: https://dexters-web.de/f/tw- > beta/OpenVehicleApp-22092401-debug.apk > > There's an issue with the App related to Android >= 10 > though, which I haven't found yet. It's been reported in > the forum: > > > * https://www.openvehicles.com/node/3410 > I could use some help with that, I've got no idea other > than blaming Android. > I've seen the effect in my emulator tests, and it seems > to occur more frequently with non-roadster images. > > Regards, > Michael > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Chris, AFAIK you need to have an adb connection or a rooted Android to use "am", so not suitable as a general way to call OVMS commands. With your (rooted) Lineageos you should be able to use it like this: am broadcast -a com.openvehicles.OVMS.SendCommand -e sel_vehicleid xxx -e sel_server_password xxx -e msg_command "7,stat" And I missed mentioning I also added support for user command syntax to "SendCommand", so you can now alternatively do am broadcast -a com.openvehicles.OVMS.SendCommand -e sel_vehicleid xxx -e sel_server_password xxx -e command "stat" Playing with am, I found out… am start -n com.openvehicles.OVMS/.api.CommandActivity -a com.openvehicles.OVMS.action.COMMAND -e command "stat" …actually works to trigger the new command receiver. I thought restricting the new receiver to app-internal intents would be possible, but it apparently isn't. That bothers me, it means any App could issue a command without knowing the credentials or an auth key and without a previous explicit user interaction to allow this. So I need to add a credentials check to the new action, which means you will need to reinstall all bookmarks / shortcut assignments. Please wait with complex setups until I've added that. Regards, Michael Am 08.10.22 um 19:30 schrieb Chris van der Meijden:
'am broadcast -acom.whereismywifeserver.intent.TEST --essms_body "test fromadb"'
Chris,
Regards, Michael
Am 08.10.22 um 17:54 schrieb Chris van der Meijden: Hi Michael
Regards
Chris
New test build:
Regards, Michael
Regards, Michael
Regards, Michael
int icon;
int icon = 0;
now you use
at line 150 now?
Chris,
Regards, Michael
Regards
Chris
> Chris, > > thanks for testing. A crash log would help on any crashes you > see. Btw, I don't bump the revision until the actual release build. > > Crashes related to the car image don't occur immediately, it > sometimes takes hours of use before it happens. When it does, > clearing the App cache fixes the crash for another random period. > > Speed optimization was one goal. What about the widget? > > Thanks, > Michael > > > Am 24.09.22 um 22:43 schrieb Chris van der Meijden: > Hey Michael, > > I just installed the "release" Version on LineageOS 19.1 > (Android 12) without Google components. > > The vehicle setup was without any troubles. I could select the > yellow VW e-UP image without crashing. > > The App version is set wrong under "Vehicle info" (3.19.1, > 2021122401). > > Everything seems to be faster than before. > > When I change the checkbox on "Track vehicle" under "Position" > the App crashes. But after a new start of the app the value of > the checkbox has changed. > > Perhaps this first impression is of some help. > > Regards > > Chris > > Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer: > > > > > > >> Everyone, >> >> I'm currently working on the next Android release including >> KustomWidget support and a native app widget based on the old >> Automagic gauge widget. >> >> Automagic has been dead for some time now, and it keeps >> crashing on Androids >= 7. >> >> My changes so far are in the hub, APK builds are available here: >> >> >> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk >> * debug build for extended logging: >> https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk >> >> >> There's an issue with the App related to Android >= 10 though, >> which I haven't found yet. It's been reported in the forum: >> >> >> * https://www.openvehicles.com/node/3410 >> >> I could use some help with that, I've got no idea other than >> blaming Android. >> >> I've seen the effect in my emulator tests, and it seems to >> occur more frequently with non-roadster images. >> >> Regards, >> Michael >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Hi Michael, thank you for your response. As always of great help :-) Good that you could find a possible security risc concerning the credentials. Regards Chris Am Sonntag, dem 09.10.2022 um 10:53 +0200 schrieb Michael Balzer:
Chris,
Regards, Michael
Chris,
Regards, Michael
Hi Michael
Regards
Chris
Regards, Michael
Regards, Michael
Correction:
Regards, Michael
int icon;
int icon = 0;
now you use
at line 150 now?
Chris,
Regards, Michael
Hey Michael,
Regards
Chris
> Chris, > > thanks for testing. A crash log would help on any crashes > you see. Btw, I don't bump the revision until the actual > release build. > > Crashes related to the car image don't occur immediately, > it sometimes takes hours of use before it happens. When > it does, clearing the App cache fixes the crash for > another random period. > > Speed optimization was one goal. What about the widget? > > Thanks, > Michael > > > Am 24.09.22 um 22:43 schrieb Chris van der Meijden: > > Hey Michael, > > I just installed the "release" Version on LineageOS 19.1 > (Android 12) without Google components. > > The vehicle setup was without any troubles. I could > select the yellow VW e-UP image without crashing. > > The App version is set wrong under "Vehicle info" > (3.19.1, 2021122401). > > Everything seems to be faster than before. > > When I change the checkbox on "Track vehicle" under > "Position" the App crashes. But after a new start of the > app the value of the checkbox has changed. > > Perhaps this first impression is of some help. > > Regards > > Chris > > Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael > Balzer: > > > > > > > > > Everyone, > > > > I'm currently working on the next Android release > > including KustomWidget support and a native app widget > > based on the old Automagic gauge widget. > > > > Automagic has been dead for some time now, and it keeps > > crashing on Androids >= 7. > > > > My changes so far are in the hub, APK builds are > > available here: > > > > > > * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk > > * debug build for extended logging: https://dexters-web.de/f/tw- > > beta/OpenVehicleApp-22092401-debug.apk > > > > There's an issue with the App related to Android >= 10 > > though, which I haven't found yet. It's been reported > > in the forum: > > > > > > * https://www.openvehicles.com/node/3410 > > I could use some help with that, I've got no idea other > > than blaming Android. > > I've seen the effect in my emulator tests, and it seems > > to occur more frequently with non-roadster images. > > > > Regards, > > Michael > > > > _______________________________________________ > > OvmsDev mailing list > > OvmsDev@lists.openvehicles.com > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Chris, Michael, new builds with the announced new security scheme: * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100901-release.apk * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100901-debug.apk This adds a new API key authorization to both Intent interfaces. The API key is automatically generated on App launch, and can be viewed, copied and regenerated from the general options page. It can be used for both command intents by passing in as extra "apikey", allowing to omit the vehicle password. The vehicle id is now also optional on both interfaces, if omitted the current vehicle will be used. To change the car you can either pass the vehicle password or the apikey along with the vehicle id. So with am, you can now use: * am broadcast -a com.openvehicles.OVMS.SendCommand -e apikey … -e command "stat" * am start -a com.openvehicles.OVMS.action.COMMAND -e apikey … -e command "stat" The second guarantees the activity is started, so the response will be visible. I'll probably restrict displaying the response to action.COMMAND in the next build, so SendCommand will be for background operations while action.COMMAND is for interactive uses. Android 10 (API 29) has a new limitation for displaying results (starting UI activities) from a service (https://developer.android.com/guide/components/activities/background-starts), so that works only by chance now anyway. Regards, Michael Am 09.10.22 um 12:45 schrieb Chris van der Meijden:
Hi Michael,
Regards
Chris
Chris,
Regards, Michael
Am 08.10.22 um 19:30 schrieb Chris van der Meijden: I have been playing with the "SH" function of KWGT and tried to send a broadcast over the shell, like adb:
Chris,
Regards, Michael
Regards
Chris
New test build:
Regards, Michael
Regards, Michael
Regards, Michael
int icon;
int icon = 0;
now you use
at line 150 now?
> Chris, > > that's not a crash log, that's just a warning. > > On that warning: the App requests > android.permission.ACCESS_FINE_LOCATION by it's manifest. Maybe > with LineageOS you need to manually give it that permission? > > A crash log has class "E" (error) and includes an exception and > a backtrace, for an example see: > https://issuetracker.google.com/issues/201308676#comment4 > > On the crash: maybe it's because you don't have the Google > components, not sure if FragMap can handle that. > > The forum post relates to /e/OS … maybe I need some emulator > images running alternative Androids now… > > Regards, > Michael > > > Am 25.09.22 um 11:40 schrieb Chris van der Meijden: > Hey Michael, > > this is from logcat when I change "Track vehicle" and the app > crashes: > > 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission > Denial: receiving Intent { > act=android.intent.action.SERVICE_STATE flg=0x1000010 (has > extras) } to ProcessRecord{8dcdd54 > 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) requires > android.permission.ACCESS_FINE_LOCATION due to sender android > (uid 1001) > > I saw now, that this crash also happens in the production app. > > The widget is running well. I will keep the app running for > while and will see if it stays stable. > > Regards > > Chris > > Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael Balzer: > > > > > > >> Chris, >> >> thanks for testing. A crash log would help on any crashes you >> see. Btw, I don't bump the revision until the actual release build. >> >> Crashes related to the car image don't occur immediately, it >> sometimes takes hours of use before it happens. When it does, >> clearing the App cache fixes the crash for another random period. >> >> Speed optimization was one goal. What about the widget? >> >> Thanks, >> Michael >> >> >> Am 24.09.22 um 22:43 schrieb Chris van der Meijden: >> Hey Michael, >> >> I just installed the "release" Version on LineageOS 19.1 >> (Android 12) without Google components. >> >> The vehicle setup was without any troubles. I could select the >> yellow VW e-UP image without crashing. >> >> The App version is set wrong under "Vehicle info" (3.19.1, >> 2021122401). >> >> Everything seems to be faster than before. >> >> When I change the checkbox on "Track vehicle" under "Position" >> the App crashes. But after a new start of the app the value of >> the checkbox has changed. >> >> Perhaps this first impression is of some help. >> >> Regards >> >> Chris >> >> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer: >> >> >> >> >> >> >> >>> Everyone, >>> >>> I'm currently working on the next Android release including >>> KustomWidget support and a native app widget based on the old >>> Automagic gauge widget. >>> >>> Automagic has been dead for some time now, and it keeps >>> crashing on Androids >= 7. >>> >>> My changes so far are in the hub, APK builds are available here: >>> >>> >>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk >>> * debug build for extended logging: >>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk >>> >>> >>> There's an issue with the App related to Android >= 10 though, >>> which I haven't found yet. It's been reported in the forum: >>> >>> >>> * https://www.openvehicles.com/node/3410 >>> >>> I could use some help with that, I've got no idea other than >>> blaming Android. >>> >>> I've seen the effect in my emulator tests, and it seems to >>> occur more frequently with non-roadster images. >>> >>> Regards, >>> Michael >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
I tested the new build. Everything is working fine for me. I think it is a good idea to restrict the respond to only action.COMMAND and leave SendCommand for background operation. Am Sonntag, dem 09.10.2022 um 16:05 +0200 schrieb Michael Balzer:
Chris, Michael,
new builds with the announced new security scheme: * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100901-release.apk * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100901-debug.apk This adds a new API key authorization to both Intent interfaces. The API key is automatically generated on App launch, and can be viewed, copied and regenerated from the general options page. It can be used for both command intents by passing in as extra "apikey", allowing to omit the vehicle password. The vehicle id is now also optional on both interfaces, if omitted the current vehicle will be used. To change the car you can either pass the vehicle password or the apikey along with the vehicle id. So with am, you can now use: * am broadcast -a com.openvehicles.OVMS.SendCommand -e apikey … -e command "stat" * am start -a com.openvehicles.OVMS.action.COMMAND -e apikey … -e command "stat" The second guarantees the activity is started, so the response will be visible. I'll probably restrict displaying the response to action.COMMAND in the next build, so SendCommand will be for background operations while action.COMMAND is for interactive uses. Android 10 (API 29) has a new limitation for displaying results (starting UI activities) from a service (https://developer.android.com/guide/components/activities/background-starts ), so that works only by chance now anyway.
Regards, Michael
Hi Michael,
Regards
Chris
Chris,
Regards, Michael
Chris,
The "SendCommand" interface is raw MP function level, that's why you need to prefix "7," for text commands (7 = execute text command). Other MP commands work just the same way as raw commands, e.g. "20,<pin>" will lock the car if supported. (https://docs.openvehicles.com/en/latest/protocol_v2/commands.html )
Regards, Michael
Hi Michael
Regards
Chris
Regards, Michael
Regards, Michael
Correction:
Regards, Michael
int icon;
int icon = 0;
now you use
at line 150 now?
> Chris, > > that's not a crash log, that's just a warning. > > On that warning: the App requests > android.permission.ACCESS_FINE_LOCATION by it's manifest. > Maybe with LineageOS you need to manually give it that > permission? > > A crash log has class "E" (error) and includes an > exception and a backtrace, for an example see: > https://issuetracker.google.com/issues/201308676#comment4 > > On the crash: maybe it's because you don't have the > Google components, not sure if FragMap can handle that. > > The forum post relates to /e/OS … maybe I need some > emulator images running alternative Androids now… > > Regards, > Michael > > > Am 25.09.22 um 11:40 schrieb Chris van der Meijden: > > Hey Michael, > > this is from logcat when I change "Track vehicle" and the > app crashes: > > 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission > Denial: receiving Intent { > act=android.intent.action.SERVICE_STATE flg=0x1000010 > (has extras) } to ProcessRecord{8dcdd54 > 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) > requires android.permission.ACCESS_FINE_LOCATION due to > sender android (uid 1001) > > I saw now, that this crash also happens in the production > app. > > The widget is running well. I will keep the app running > for while and will see if it stays stable. > > Regards > > Chris > > Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael > Balzer: > > > > > > > > > Chris, > > > > thanks for testing. A crash log would help on any > > crashes you see. Btw, I don't bump the revision until > > the actual release build. > > > > Crashes related to the car image don't occur > > immediately, it sometimes takes hours of use before it > > happens. When it does, clearing the App cache fixes the > > crash for another random period. > > > > Speed optimization was one goal. What about the widget? > > > > Thanks, > > Michael > > > > > > Am 24.09.22 um 22:43 schrieb Chris van der Meijden: > > > > Hey Michael, > > > > I just installed the "release" Version on LineageOS > > 19.1 (Android 12) without Google components. > > > > The vehicle setup was without any troubles. I could > > select the yellow VW e-UP image without crashing. > > > > The App version is set wrong under "Vehicle info" > > (3.19.1, 2021122401). > > > > Everything seems to be faster than before. > > > > When I change the checkbox on "Track vehicle" under > > "Position" the App crashes. But after a new start of > > the app the value of the checkbox has changed. > > > > Perhaps this first impression is of some help. > > > > Regards > > > > Chris > > > > Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb > > Michael Balzer: > > > > > > > > > > > > > > > > > > > Everyone, > > > > > > I'm currently working on the next Android release > > > including KustomWidget support and a native app > > > widget based on the old Automagic gauge widget. > > > > > > Automagic has been dead for some time now, and it > > > keeps crashing on Androids >= 7. > > > > > > My changes so far are in the hub, APK builds are > > > available here: > > > > > > > > > * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk > > > * debug build for extended logging: https://dexters-web.de/f/tw- > > > beta/OpenVehicleApp-22092401-debug.apk > > > > > > There's an issue with the App related to Android >= > > > 10 though, which I haven't found yet. It's been > > > reported in the forum: > > > > > > > > > * https://www.openvehicles.com/node/3410 > > > I could use some help with that, I've got no idea > > > other than blaming Android. > > > I've seen the effect in my emulator tests, and it > > > seems to occur more frequently with non-roadster > > > images. > > > > > > Regards, > > > Michael > > > > > > _______________________________________________ > > > OvmsDev mailing list > > > OvmsDev@lists.openvehicles.com > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > _______________________________________________ > > OvmsDev mailing list > > OvmsDev@lists.openvehicles.com > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > _______________________________________________ > > OvmsDev mailing list > > OvmsDev@lists.openvehicles.com > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Chris, Michael, thanks for tests & feedback. Code changes so far are now in the hub: https://github.com/openvehicles/Open-Vehicle-Android/commit/c23b3dbd772bdae7... This has become a very large commit, and it mixes some version update changes that became necessary & deprecation fixes I should have kept separate, but cannot disentangle now. Some things still to do for the release, most notably removing UI interaction from the service. So if any other stuff shall be added to the next release, tell me & go ahead preparing that. Regards, Michael Am 09.10.22 um 17:09 schrieb Chris van der Meijden:
Chris, Michael,
Regards, Michael
Am 09.10.22 um 12:45 schrieb Chris van der Meijden: Hi Michael,
Regards
Chris
Chris,
Regards, Michael
Chris,
Regards, Michael
Regards
Chris
New test build:
Regards, Michael
Regards, Michael
> I like the new KWGT Widget feature: > > > Above is the Tesla Widget of our Model 3, beneath that my OVMS > KWGT widget of our VW e-UP. > > I had to allow "Passing data to other apps". The syntax for > getting the intent variables to text in KWGT is i.e. > > $br(ovms, car_sel_vehicle_label)$ > > Other variables can be found here: > https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-I... > > The image is local on the filesystem of the phone and does not > come by intent. > > > Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael Balzer: > No, icon can only be 0 from the else branch, in that case it > shall fall back to the default image. > > But I've meanwhile found (I think) your maps/track crash, commit > is already in the hub. The checkbox handler didn't check if the > map object is initialized. > > https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicle... > > Regards, > Michael > > > Am 25.09.22 um 15:46 schrieb Chris van der Meijden: > Just guessing, but does > > int icon; > > in MyGcmListenerService.java > <https://github.com/devmarxx/Open-Vehicle-Android/commit/3c13100a6a25257fe694be3050a1b76ca2b6fb44#diff-c13198cb33bb355f600c37f8889cedcb72346835dbb7e357c031c57aba424487> at > line 132 > > not need to be initialized like > > int icon = 0; > > now you use > > .setSmallIcon((icon!= 0) ? icon: R.drawable.map_car_default) > > at line 150 now? > > As the images and the Google stuff are related to that integer > it made me thinking ... > > > Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael Balzer: > > > > > > >> Chris, >> >> that's not a crash log, that's just a warning. >> >> On that warning: the App requests >> android.permission.ACCESS_FINE_LOCATION by it's manifest. Maybe >> with LineageOS you need to manually give it that permission? >> >> A crash log has class "E" (error) and includes an exception and >> a backtrace, for an example see: >> https://issuetracker.google.com/issues/201308676#comment4 >> >> On the crash: maybe it's because you don't have the Google >> components, not sure if FragMap can handle that. >> >> The forum post relates to /e/OS … maybe I need some emulator >> images running alternative Androids now… >> >> Regards, >> Michael >> >> >> Am 25.09.22 um 11:40 schrieb Chris van der Meijden: >> Hey Michael, >> >> this is from logcat when I change "Track vehicle" and the app >> crashes: >> >> 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission >> Denial: receiving Intent { >> act=android.intent.action.SERVICE_STATE flg=0x1000010 (has >> extras) } to ProcessRecord{8dcdd54 >> 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) >> requires android.permission.ACCESS_FINE_LOCATION due to sender >> android (uid 1001) >> >> I saw now, that this crash also happens in the production app. >> >> The widget is running well. I will keep the app running for >> while and will see if it stays stable. >> >> Regards >> >> Chris >> >> Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael Balzer: >> >> >> >> >> >> >> >>> Chris, >>> >>> thanks for testing. A crash log would help on any crashes you >>> see. Btw, I don't bump the revision until the actual release >>> build. >>> >>> Crashes related to the car image don't occur immediately, it >>> sometimes takes hours of use before it happens. When it does, >>> clearing the App cache fixes the crash for another random period. >>> >>> Speed optimization was one goal. What about the widget? >>> >>> Thanks, >>> Michael >>> >>> >>> Am 24.09.22 um 22:43 schrieb Chris van der Meijden: >>> Hey Michael, >>> >>> I just installed the "release" Version on LineageOS 19.1 >>> (Android 12) without Google components. >>> >>> The vehicle setup was without any troubles. I could select the >>> yellow VW e-UP image without crashing. >>> >>> The App version is set wrong under "Vehicle info" (3.19.1, >>> 2021122401). >>> >>> Everything seems to be faster than before. >>> >>> When I change the checkbox on "Track vehicle" under "Position" >>> the App crashes. But after a new start of the app the value of >>> the checkbox has changed. >>> >>> Perhaps this first impression is of some help. >>> >>> Regards >>> >>> Chris >>> >>> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer: >>> >>> >>> >>> >>> >>> >>> >>> >>>> Everyone, >>>> >>>> I'm currently working on the next Android release including >>>> KustomWidget support and a native app widget based on the old >>>> Automagic gauge widget. >>>> >>>> Automagic has been dead for some time now, and it keeps >>>> crashing on Androids >= 7. >>>> >>>> My changes so far are in the hub, APK builds are available here: >>>> >>>> >>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk >>>> * debug build for extended logging: >>>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk >>>> >>>> >>>> There's an issue with the App related to Android >= 10 >>>> though, which I haven't found yet. It's been reported in the >>>> forum: >>>> >>>> >>>> * https://www.openvehicles.com/node/3410 >>>> >>>> I could use some help with that, I've got no idea other than >>>> blaming Android. >>>> >>>> I've seen the effect in my emulator tests, and it seems to >>>> occur more frequently with non-roadster images. >>>> >>>> Regards, >>>> Michael >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
It compiled and runs without troubles, but I needed to build with gradlew build -x lint Am Sonntag, dem 09.10.2022 um 19:16 +0200 schrieb Michael Balzer:
Regards, Michael
Chris, Michael,
Regards, Michael
Hi Michael,
Regards
Chris
Chris,
Regards, Michael
Chris,
Regards, Michael
Hi Michael
Regards
Chris
Regards, Michael
You can assign "Activities" to the "Touch" event on an image. Would be cool if that works, so we can start the remote climate control similar to how I do that with my OVMS- Fireplace app:
Regards, Michael
Correction:
> I like the new KWGT Widget feature: > > > Above is the Tesla Widget of our Model 3, beneath that my > OVMS KWGT widget of our VW e-UP. > > I had to allow "Passing data to other apps". The syntax > for getting the intent variables to text in KWGT is i.e. > > $br(ovms, car_sel_vehicle_label)$ > > Other variables can be found here: > https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-I... > > The image is local on the filesystem of the phone and > does not come by intent. > > > Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael > Balzer: > No, icon can only be 0 from the else branch, in that case > it shall fall back to the default image. > > But I've meanwhile found (I think) your maps/track crash, > commit is already in the hub. The checkbox handler didn't > check if the map object is initialized. > > https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicle... > > Regards, > Michael > > > Am 25.09.22 um 15:46 schrieb Chris van der Meijden: > > Just guessing, but does > > int icon; > > in MyGcmListenerService.java at line 132 > > not need to be initialized like > > int icon = 0; > > now you use > > .setSmallIcon((icon != 0) ? icon : > R.drawable.map_car_default) > > at line 150 now? > > As the images and the Google stuff are related to that > integer it made me thinking ... > > > Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael > Balzer: > > > > > > > > > Chris, > > > > that's not a crash log, that's just a warning. > > > > On that warning: the App requests > > android.permission.ACCESS_FINE_LOCATION by it's > > manifest. Maybe with LineageOS you need to manually > > give it that permission? > > > > A crash log has class "E" (error) and includes an > > exception and a backtrace, for an example see: > > https://issuetracker.google.com/issues/201308676#comment4 > > > > On the crash: maybe it's because you don't have the > > Google components, not sure if FragMap can handle that. > > > > The forum post relates to /e/OS … maybe I need some > > emulator images running alternative Androids now… > > > > Regards, > > Michael > > > > > > Am 25.09.22 um 11:40 schrieb Chris van der Meijden: > > > > Hey Michael, > > > > this is from logcat when I change "Track vehicle" and > > the app crashes: > > > > 09-25 11:16:01.410 1710 1839 W BroadcastQueue: > > Permission Denial: receiving Intent { > > act=android.intent.action.SERVICE_STATE flg=0x1000010 > > (has extras) } to ProcessRecord{8dcdd54 > > 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) > > requires android.permission.ACCESS_FINE_LOCATION due to > > sender android (uid 1001) > > > > I saw now, that this crash also happens in the > > production app. > > > > The widget is running well. I will keep the app running > > for while and will see if it stays stable. > > > > Regards > > > > Chris > > > > Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb > > Michael Balzer: > > > > > > > > > > > > > > > > > > > Chris, > > > > > > thanks for testing. A crash log would help on any > > > crashes you see. Btw, I don't bump the revision until > > > the actual release build. > > > > > > Crashes related to the car image don't occur > > > immediately, it sometimes takes hours of use before > > > it happens. When it does, clearing the App cache > > > fixes the crash for another random period. > > > > > > Speed optimization was one goal. What about the > > > widget? > > > > > > Thanks, > > > Michael > > > > > > > > > Am 24.09.22 um 22:43 schrieb Chris van der Meijden: > > > > > > Hey Michael, > > > > > > I just installed the "release" Version on LineageOS > > > 19.1 (Android 12) without Google components. > > > > > > The vehicle setup was without any troubles. I could > > > select the yellow VW e-UP image without crashing. > > > > > > The App version is set wrong under "Vehicle info" > > > (3.19.1, 2021122401). > > > > > > Everything seems to be faster than before. > > > > > > When I change the checkbox on "Track vehicle" under > > > "Position" the App crashes. But after a new start of > > > the app the value of the checkbox has changed. > > > > > > Perhaps this first impression is of some help. > > > > > > Regards > > > > > > Chris > > > > > > Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb > > > Michael Balzer: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Everyone, > > > > > > > > I'm currently working on the next Android release > > > > including KustomWidget support and a native app > > > > widget based on the old Automagic gauge widget. > > > > > > > > Automagic has been dead for some time now, and it > > > > keeps crashing on Androids >= 7. > > > > > > > > My changes so far are in the hub, APK builds are > > > > available here: > > > > > > > > > > > > * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk > > > > * debug build for extended logging: https://dexters-web.de/f/tw- > > > > beta/OpenVehicleApp-22092401-debug.apk > > > > > > > > There's an issue with the App related to Android >= > > > > 10 though, which I haven't found yet. It's been > > > > reported in the forum: > > > > > > > > > > > > * https://www.openvehicles.com/node/3410 > > > > I could use some help with that, I've got no idea > > > > other than blaming Android. > > > > I've seen the effect in my emulator tests, and it > > > > seems to occur more frequently with non-roadster > > > > images. > > > > > > > > Regards, > > > > Michael > > > > > > > > _______________________________________________ > > > > OvmsDev mailing list > > > > OvmsDev@lists.openvehicles.com > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > > > > _______________________________________________ > > > OvmsDev mailing list > > > OvmsDev@lists.openvehicles.com > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > _______________________________________________ > > > OvmsDev mailing list > > > OvmsDev@lists.openvehicles.com > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > _______________________________________________ > > OvmsDev mailing list > > OvmsDev@lists.openvehicles.com > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > _______________________________________________ > > OvmsDev mailing list > > OvmsDev@lists.openvehicles.com > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Features and Parameters are not showing. Clicking there brings me to Messages. Starting in landscape and then turning to portrait is fixed :-) Am 9. Oktober 2022 20:22:50 MESZ schrieb Chris van der Meijden <chris@arachnon.de>:
Regards, Michael
Chris, Michael,
Regards, Michael
Hi Michael,
Regards
Chris
Chris,
Regards, Michael
Chris,
Regards, Michael
Hi Michael
Regards
Chris
Regards, Michael
> Nice, please go ahead if you want to create an includable > example widget :-) > > I've found out you can also use progress bars to display > values, enable formula input on the "step" & set the > formular to e.g. $br(ovms, car_soc)$. > > Works, although I need to convert all car model values to > strings for KWGT. Btw, I also need to unroll the TPMS > arrays, they are split into a "_cnt" & "_<n>" variables. I > need to add an info on this to the wiki. > > I haven't found out how to send a broadcast from KWGT yet, > is that possible? That would enable creating command > shortcuts & buttons as with Automagic. > > Regards, > Michael > > > > Am 26.09.22 um 12:13 schrieb Chris van der Meijden: > > Correction: > > $br(ovms, sel_vehicle_label)$ > > Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb Chris van > der Meijden: > > > > > > > > I like the new KWGT Widget feature: > > > > > > Above is the Tesla Widget of our Model 3, beneath that my > > OVMS KWGT widget of our VW e-UP. > > > > I had to allow "Passing data to other apps". The syntax > > for getting the intent variables to text in KWGT is i.e. > > > > $br(ovms, car_sel_vehicle_label)$ > > > > Other variables can be found here: > > https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-I... > > > > The image is local on the filesystem of the phone and > > does not come by intent. > > > > > > Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael > > Balzer: > > No, icon can only be 0 from the else branch, in that case > > it shall fall back to the default image. > > > > But I've meanwhile found (I think) your maps/track crash, > > commit is already in the hub. The checkbox handler didn't > > check if the map object is initialized. > > > > https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicle... > > > > Regards, > > Michael > > > > > > Am 25.09.22 um 15:46 schrieb Chris van der Meijden: > > > > Just guessing, but does > > > > int icon; > > > > in MyGcmListenerService.java at line 132 > > > > not need to be initialized like > > > > int icon = 0; > > > > now you use > > > > .setSmallIcon((icon != 0) ? icon : > > R.drawable.map_car_default) > > > > at line 150 now? > > > > As the images and the Google stuff are related to that > > integer it made me thinking ... > > > > > > Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael > > Balzer: > > > > > > > > > > > > > > > > > Chris, > > > > > > that's not a crash log, that's just a warning. > > > > > > On that warning: the App requests > > > android.permission.ACCESS_FINE_LOCATION by it's > > > manifest. Maybe with LineageOS you need to manually > > > give it that permission? > > > > > > A crash log has class "E" (error) and includes an > > > exception and a backtrace, for an example see: > > > https://issuetracker.google.com/issues/201308676#comment4 > > > > > > On the crash: maybe it's because you don't have the > > > Google components, not sure if FragMap can handle that. > > > > > > The forum post relates to /e/OS … maybe I need some > > > emulator images running alternative Androids now… > > > > > > Regards, > > > Michael > > > > > > > > > Am 25.09.22 um 11:40 schrieb Chris van der Meijden: > > > > > > Hey Michael, > > > > > > this is from logcat when I change "Track vehicle" and > > > the app crashes: > > > > > > 09-25 11:16:01.410 1710 1839 W BroadcastQueue: > > > Permission Denial: receiving Intent { > > > act=android.intent.action.SERVICE_STATE flg=0x1000010 > > > (has extras) } to ProcessRecord{8dcdd54 > > > 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) > > > requires android.permission.ACCESS_FINE_LOCATION due to > > > sender android (uid 1001) > > > > > > I saw now, that this crash also happens in the > > > production app. > > > > > > The widget is running well. I will keep the app running > > > for while and will see if it stays stable. > > > > > > Regards > > > > > > Chris > > > > > > Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb > > > Michael Balzer: > > > > > > > > > > > > > > > > > > > > > > > > > > > > Chris, > > > > > > > > thanks for testing. A crash log would help on any > > > > crashes you see. Btw, I don't bump the revision until > > > > the actual release build. > > > > > > > > Crashes related to the car image don't occur > > > > immediately, it sometimes takes hours of use before > > > > it happens. When it does, clearing the App cache > > > > fixes the crash for another random period. > > > > > > > > Speed optimization was one goal. What about the > > > > widget? > > > > > > > > Thanks, > > > > Michael > > > > > > > > > > > > Am 24.09.22 um 22:43 schrieb Chris van der Meijden: > > > > > > > > Hey Michael, > > > > > > > > I just installed the "release" Version on LineageOS > > > > 19.1 (Android 12) without Google components. > > > > > > > > The vehicle setup was without any troubles. I could > > > > select the yellow VW e-UP image without crashing. > > > > > > > > The App version is set wrong under "Vehicle info" > > > > (3.19.1, 2021122401). > > > > > > > > Everything seems to be faster than before. > > > > > > > > When I change the checkbox on "Track vehicle" under > > > > "Position" the App crashes. But after a new start of > > > > the app the value of the checkbox has changed. > > > > > > > > Perhaps this first impression is of some help. > > > > > > > > Regards > > > > > > > > Chris > > > > > > > > Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb > > > > Michael Balzer: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Everyone, > > > > > > > > > > I'm currently working on the next Android release > > > > > including KustomWidget support and a native app > > > > > widget based on the old Automagic gauge widget. > > > > > > > > > > Automagic has been dead for some time now, and it > > > > > keeps crashing on Androids >= 7. > > > > > > > > > > My changes so far are in the hub, APK builds are > > > > > available here: > > > > > > > > > > > > > > > * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk > > > > > * debug build for extended logging: https://dexters-web.de/f/tw- > > > > > beta/OpenVehicleApp-22092401-debug.apk > > > > > > > > > > There's an issue with the App related to Android >= > > > > > 10 though, which I haven't found yet. It's been > > > > > reported in the forum: > > > > > > > > > > > > > > > * https://www.openvehicles.com/node/3410 > > > > > I could use some help with that, I've got no idea > > > > > other than blaming Android. > > > > > I've seen the effect in my emulator tests, and it > > > > > seems to occur more frequently with non-roadster > > > > > images. > > > > > > > > > > Regards, > > > > > Michael > > > > > > > > > > _______________________________________________ > > > > > OvmsDev mailing list > > > > > OvmsDev@lists.openvehicles.com > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > > > > > > > _______________________________________________ > > > > OvmsDev mailing list > > > > OvmsDev@lists.openvehicles.com > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > > > _______________________________________________ > > > > OvmsDev mailing list > > > > OvmsDev@lists.openvehicles.com > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > > > > _______________________________________________ > > > OvmsDev mailing list > > > OvmsDev@lists.openvehicles.com > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > _______________________________________________ > > > OvmsDev mailing list > > > OvmsDev@lists.openvehicles.com > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > _______________________________________________ > > OvmsDev mailing list > > OvmsDev@lists.openvehicles.com > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > _______________________________________________ > > OvmsDev mailing list > > OvmsDev@lists.openvehicles.com > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > _______________________________________________ > > OvmsDev mailing list > > OvmsDev@lists.openvehicles.com > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Am 09.10.22 um 20:40 schrieb van der Meijden, Chris:
Features and Parameters are not showing. Clicking there brings me to Messages. Oops, yes, confirmed.
Nothing changed with the old ScaleLayout, it's on my list, but with low priority. So I don't think it's fixed, was working sometimes before.
Regards, Michael
Am 09.10.22 um 17:09 schrieb Chris van der Meijden: I tested the new build. Everything is working fine for me.
Chris, Michael,
Regards, Michael
Regards
Chris
Chris,
Regards, Michael
Chris,
Regards, Michael
Regards
Chris
New test build:
Regards, Michael
> Nice, please go ahead if you want to create an includable > example widget :-) > > I've found out you can also use progress bars to display > values, enable formula input on the "step" & set the > formular to e.g. $br(ovms, car_soc)$. > > Works, although I need to convert all car model values to > strings for KWGT. Btw, I also need to unroll the TPMS > arrays, they are split into a "_cnt" & "_<n>" variables. I > need to add an info on this to the wiki. > > I haven't found out how to send a broadcast from KWGT yet, > is that possible? That would enable creating command > shortcuts & buttons as with Automagic. > > Regards, > Michael > > > > Am 26.09.22 um 12:13 schrieb Chris van der Meijden: > Correction: > > $br(ovms, sel_vehicle_label)$ > > Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb Chris van > der Meijden: > > > > > > >> I like the new KWGT Widget feature: >> >> >> Above is the Tesla Widget of our Model 3, beneath that my >> OVMS KWGT widget of our VW e-UP. >> >> I had to allow "Passing data to other apps". The syntax for >> getting the intent variables to text in KWGT is i.e. >> >> $br(ovms, car_sel_vehicle_label)$ >> >> Other variables can be found here: >> https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-I... >> >> The image is local on the filesystem of the phone and does >> not come by intent. >> >> >> Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael >> Balzer: >> No, icon can only be 0 from the else branch, in that case >> it shall fall back to the default image. >> >> But I've meanwhile found (I think) your maps/track crash, >> commit is already in the hub. The checkbox handler didn't >> check if the map object is initialized. >> >> https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicle... >> >> Regards, >> Michael >> >> >> Am 25.09.22 um 15:46 schrieb Chris van der Meijden: >> Just guessing, but does >> >> int icon; >> >> in MyGcmListenerService.java >> <https://github.com/devmarxx/Open-Vehicle-Android/commit/3c13100a6a25257fe694be3050a1b76ca2b6fb44#diff-c13198cb33bb355f600c37f8889cedcb72346835dbb7e357c031c57aba424487> at >> line 132 >> >> not need to be initialized like >> >> int icon = 0; >> >> now you use >> >> .setSmallIcon((icon!= 0) ? icon: R.drawable.map_car_default) >> >> at line 150 now? >> >> As the images and the Google stuff are related to that >> integer it made me thinking ... >> >> >> Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael >> Balzer: >> >> >> >> >> >> >> >>> Chris, >>> >>> that's not a crash log, that's just a warning. >>> >>> On that warning: the App requests >>> android.permission.ACCESS_FINE_LOCATION by it's manifest. >>> Maybe with LineageOS you need to manually give it that >>> permission? >>> >>> A crash log has class "E" (error) and includes an >>> exception and a backtrace, for an example see: >>> https://issuetracker.google.com/issues/201308676#comment4 >>> >>> On the crash: maybe it's because you don't have the Google >>> components, not sure if FragMap can handle that. >>> >>> The forum post relates to /e/OS … maybe I need some >>> emulator images running alternative Androids now… >>> >>> Regards, >>> Michael >>> >>> >>> Am 25.09.22 um 11:40 schrieb Chris van der Meijden: >>> Hey Michael, >>> >>> this is from logcat when I change "Track vehicle" and the >>> app crashes: >>> >>> 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission >>> Denial: receiving Intent { >>> act=android.intent.action.SERVICE_STATE flg=0x1000010 (has >>> extras) } to ProcessRecord{8dcdd54 >>> 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) >>> requires android.permission.ACCESS_FINE_LOCATION due to >>> sender android (uid 1001) >>> >>> I saw now, that this crash also happens in the production app. >>> >>> The widget is running well. I will keep the app running >>> for while and will see if it stays stable. >>> >>> Regards >>> >>> Chris >>> >>> Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael >>> Balzer: >>> >>> >>> >>> >>> >>> >>> >>> >>>> Chris, >>>> >>>> thanks for testing. A crash log would help on any crashes >>>> you see. Btw, I don't bump the revision until the actual >>>> release build. >>>> >>>> Crashes related to the car image don't occur immediately, >>>> it sometimes takes hours of use before it happens. When >>>> it does, clearing the App cache fixes the crash for >>>> another random period. >>>> >>>> Speed optimization was one goal. What about the widget? >>>> >>>> Thanks, >>>> Michael >>>> >>>> >>>> Am 24.09.22 um 22:43 schrieb Chris van der Meijden: >>>> Hey Michael, >>>> >>>> I just installed the "release" Version on LineageOS 19.1 >>>> (Android 12) without Google components. >>>> >>>> The vehicle setup was without any troubles. I could >>>> select the yellow VW e-UP image without crashing. >>>> >>>> The App version is set wrong under "Vehicle info" >>>> (3.19.1, 2021122401). >>>> >>>> Everything seems to be faster than before. >>>> >>>> When I change the checkbox on "Track vehicle" under >>>> "Position" the App crashes. But after a new start of the >>>> app the value of the checkbox has changed. >>>> >>>> Perhaps this first impression is of some help. >>>> >>>> Regards >>>> >>>> Chris >>>> >>>> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael >>>> Balzer: >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>>> Everyone, >>>>> >>>>> I'm currently working on the next Android release >>>>> including KustomWidget support and a native app widget >>>>> based on the old Automagic gauge widget. >>>>> >>>>> Automagic has been dead for some time now, and it keeps >>>>> crashing on Androids >= 7. >>>>> >>>>> My changes so far are in the hub, APK builds are >>>>> available here: >>>>> >>>>> >>>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk >>>>> * debug build for extended logging: >>>>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk >>>>> >>>>> >>>>> There's an issue with the App related to Android >= 10 >>>>> though, which I haven't found yet. It's been reported in >>>>> the forum: >>>>> >>>>> >>>>> * https://www.openvehicles.com/node/3410 >>>>> >>>>> I could use some help with that, I've got no idea other >>>>> than blaming Android. >>>>> >>>>> I've seen the effect in my emulator tests, and it seems >>>>> to occur more frequently with non-roadster images. >>>>> >>>>> Regards, >>>>> Michael >>>>> >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
New builds: * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22101601-release.apk * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22101601-debug.apk This also fixes the feature & parameter bug, but major change is the command activity & service rework. Command shortcuts now also work without the service enabled, i.e. start the service on demand. This even works reasonably fast. I've removed all UI activities from the service, so this should now basically work the same way on all Android versions. The command activity now also supports queueing, multiple commands can be sent to it at once. It will execute them in series, with each result being shown for 5 seconds or according to user interaction. On commands returning multiple rows, only the first 10-15 will be shown. Command intent extras for action com.openvehicles.OVMS.action.COMMAND are now: * Intent extras expected/supported: * - vehicleid (optional) * - apikey or (with vehicleid) password * - title (optional) * - command (optional, no command means only change the car) * * Commands need to be in user input syntax: * - MMI/USSD commands: prefix "*", example: "*100#" * - Modem commands: prefix "@", example: "@ATI" * - MP MSG commands: prefix "#", example: "#31" * - Text commands: everything else, example: "stat" Changes are on github, tests & feedback are welcome. If you've added command bookmarks somewhere before, you may need to delete and recreate them to see the title in the UI. Regards, Michael Am 09.10.22 um 22:11 schrieb Michael Balzer:
Regards, Michael
Chris, Michael,
Regards, Michael
Regards
Chris
Chris,
Regards, Michael
Chris,
Regards, Michael
I just installed the release apk on my degoogled Lineageos 19.1.
Installation went without any troubles. I tested the broadcast with my fireplace app via webinent:
action: 'com.openvehicles.OVMS.SendCommand', extras: { sel_vehicleid: vid, sel_server_password: pwd, msg_command: '7,climatecontrol on' }
It works still fine and I can see the response dialog in the OVMS app.
I don't understand the "MP function". Do you have an example for for i.e. "climatecontrol on" via Buttons in KWGT? I'd love to test that :-)
And do you know if there is a way to send intent broadcasts with KWGT? I tried with a "GLOBALE", but I could not get that to work.
Regards
Chris
Am Samstag, dem 08.10.2022 um 15:37 +0200 schrieb Michael Balzer:
> New test build: > > * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-release.apk > * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-debug.apk > > > This includes major extensions & code rewrites, I think I'll > bump the version to 4.0 when releasing this to Google Play. > > Main goal & outcome of this effort: command bookmarks. > > The App now offers stored commands (see notifications tab). > Stored commands can be pinned to the launcher and selected > from third party Apps like KWGT as shortcuts to execute on > triggers / actions. > > So this enabled custom widgets to include buttons triggering > car commands. > > Commands are given using the user syntax, i.e. don't need > the MP function prefix. You can still call an MP function by > using the user syntax, i.e. "#…". > > Command responses are shown as a dialog with a timeoout of 5 > seconds unless you hold it by touching or begin scrolling a > long response. If the App is paused it will be resumed and > switch to the notifications page (which keeps a record of > all commands & responses). If the App isn't running, only > the response dialog is shown on the launcher. > > All this of course needs the service to be enabled & allow > commands to be sent. > > Command responses are also broadcasted now, so KWGT et al > can receive them -- but they will currently need to know the > command sent previously and copy command responses if they > need to keep them, I don't know if KWGT can do that > (Automagic can). KWGT seems to only have a simple variable > storage model. > > I think about extending the ApiService to keep a command > queue so the broadcast can at least carry the command, the > response is supposedly produced for. Unfortunately the MP > API cannot guarantee this, as it doesn't currently return a > copy of the original command or a command ID reference with > the response, so this would at best be a guess. Not sure if > users actually need this. > > > Note: I haven't pushed the code changes to github yet, I'd > first like to get some test feedback. I've tested this on > Android 6, 7, 11 & 13, but not on any degoogled Androids. > > Regards, > Michael > > > Am 26.09.22 um 17:26 schrieb Chris van der Meijden: > For an includable example it would be nice if we could send > the vehicle image from the OVMS app to KWGT. > > You can assign "Activities" to the "Touch" event on an > image. Would be cool if that works, so we can start the > remote climate control similar to how I do that with my > OVMS-Fireplace app: > > https://github.com/devmarxx/OVMS-Fireplace > > > Am Montag, dem 26.09.2022 um 13:56 +0200 schrieb Michael Balzer: > > > > > >> Nice, please go ahead if you want to create an includable >> example widget :-) >> >> I've found out you can also use progress bars to display >> values, enable formula input on the "step" & set the >> formular to e.g. $br(ovms, car_soc)$. >> >> Works, although I need to convert all car model values to >> strings for KWGT. Btw, I also need to unroll the TPMS >> arrays, they are split into a "_cnt" & "_<n>" variables. I >> need to add an info on this to the wiki. >> >> I haven't found out how to send a broadcast from KWGT yet, >> is that possible? That would enable creating command >> shortcuts & buttons as with Automagic. >> >> Regards, >> Michael >> >> >> >> Am 26.09.22 um 12:13 schrieb Chris van der Meijden: >> Correction: >> >> $br(ovms, sel_vehicle_label)$ >> >> Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb Chris van >> der Meijden: >> >> >> >> >> >> >>> I like the new KWGT Widget feature: >>> >>> >>> Above is the Tesla Widget of our Model 3, beneath that my >>> OVMS KWGT widget of our VW e-UP. >>> >>> I had to allow "Passing data to other apps". The syntax >>> for getting the intent variables to text in KWGT is i.e. >>> >>> $br(ovms, car_sel_vehicle_label)$ >>> >>> Other variables can be found here: >>> https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-I... >>> >>> The image is local on the filesystem of the phone and does >>> not come by intent. >>> >>> >>> Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael >>> Balzer: >>> No, icon can only be 0 from the else branch, in that case >>> it shall fall back to the default image. >>> >>> But I've meanwhile found (I think) your maps/track crash, >>> commit is already in the hub. The checkbox handler didn't >>> check if the map object is initialized. >>> >>> https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicle... >>> >>> Regards, >>> Michael >>> >>> >>> Am 25.09.22 um 15:46 schrieb Chris van der Meijden: >>> Just guessing, but does >>> >>> int icon; >>> >>> in MyGcmListenerService.java >>> <https://github.com/devmarxx/Open-Vehicle-Android/commit/3c13100a6a25257fe694be3050a1b76ca2b6fb44#diff-c13198cb33bb355f600c37f8889cedcb72346835dbb7e357c031c57aba424487> at >>> line 132 >>> >>> not need to be initialized like >>> >>> int icon = 0; >>> >>> now you use >>> >>> .setSmallIcon((icon!= 0) ? icon: R.drawable.map_car_default) >>> >>> at line 150 now? >>> >>> As the images and the Google stuff are related to that >>> integer it made me thinking ... >>> >>> >>> Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael >>> Balzer: >>> >>> >>> >>> >>> >>> >>> >>>> Chris, >>>> >>>> that's not a crash log, that's just a warning. >>>> >>>> On that warning: the App requests >>>> android.permission.ACCESS_FINE_LOCATION by it's manifest. >>>> Maybe with LineageOS you need to manually give it that >>>> permission? >>>> >>>> A crash log has class "E" (error) and includes an >>>> exception and a backtrace, for an example see: >>>> https://issuetracker.google.com/issues/201308676#comment4 >>>> >>>> On the crash: maybe it's because you don't have the >>>> Google components, not sure if FragMap can handle that. >>>> >>>> The forum post relates to /e/OS … maybe I need some >>>> emulator images running alternative Androids now… >>>> >>>> Regards, >>>> Michael >>>> >>>> >>>> Am 25.09.22 um 11:40 schrieb Chris van der Meijden: >>>> Hey Michael, >>>> >>>> this is from logcat when I change "Track vehicle" and the >>>> app crashes: >>>> >>>> 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission >>>> Denial: receiving Intent { >>>> act=android.intent.action.SERVICE_STATE flg=0x1000010 >>>> (has extras) } to ProcessRecord{8dcdd54 >>>> 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) >>>> requires android.permission.ACCESS_FINE_LOCATION due to >>>> sender android (uid 1001) >>>> >>>> I saw now, that this crash also happens in the production >>>> app. >>>> >>>> The widget is running well. I will keep the app running >>>> for while and will see if it stays stable. >>>> >>>> Regards >>>> >>>> Chris >>>> >>>> Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael >>>> Balzer: >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>>> Chris, >>>>> >>>>> thanks for testing. A crash log would help on any >>>>> crashes you see. Btw, I don't bump the revision until >>>>> the actual release build. >>>>> >>>>> Crashes related to the car image don't occur >>>>> immediately, it sometimes takes hours of use before it >>>>> happens. When it does, clearing the App cache fixes the >>>>> crash for another random period. >>>>> >>>>> Speed optimization was one goal. What about the widget? >>>>> >>>>> Thanks, >>>>> Michael >>>>> >>>>> >>>>> Am 24.09.22 um 22:43 schrieb Chris van der Meijden: >>>>> Hey Michael, >>>>> >>>>> I just installed the "release" Version on LineageOS 19.1 >>>>> (Android 12) without Google components. >>>>> >>>>> The vehicle setup was without any troubles. I could >>>>> select the yellow VW e-UP image without crashing. >>>>> >>>>> The App version is set wrong under "Vehicle info" >>>>> (3.19.1, 2021122401). >>>>> >>>>> Everything seems to be faster than before. >>>>> >>>>> When I change the checkbox on "Track vehicle" under >>>>> "Position" the App crashes. But after a new start of the >>>>> app the value of the checkbox has changed. >>>>> >>>>> Perhaps this first impression is of some help. >>>>> >>>>> Regards >>>>> >>>>> Chris >>>>> >>>>> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb >>>>> Michael Balzer: >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>>> Everyone, >>>>>> >>>>>> I'm currently working on the next Android release >>>>>> including KustomWidget support and a native app widget >>>>>> based on the old Automagic gauge widget. >>>>>> >>>>>> Automagic has been dead for some time now, and it keeps >>>>>> crashing on Androids >= 7. >>>>>> >>>>>> My changes so far are in the hub, APK builds are >>>>>> available here: >>>>>> >>>>>> >>>>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk >>>>>> * debug build for extended logging: >>>>>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk >>>>>> >>>>>> >>>>>> There's an issue with the App related to Android >= 10 >>>>>> though, which I haven't found yet. It's been reported >>>>>> in the forum: >>>>>> >>>>>> >>>>>> * https://www.openvehicles.com/node/3410 >>>>>> >>>>>> I could use some help with that, I've got no idea other >>>>>> than blaming Android. >>>>>> >>>>>> I've seen the effect in my emulator tests, and it seems >>>>>> to occur more frequently with non-roadster images. >>>>>> >>>>>> Regards, >>>>>> Michael >>>>>> >>>>>> _______________________________________________ >>>>>> OvmsDev mailing list >>>>>> OvmsDev@lists.openvehicles.com >>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>> >>>>> >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>> >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Hi Michael I compiled the new code without any troubles (again on the commandline with -x lint). Features and Parameters are working perfect now. My Fireplace app can send its "web intent" and my (simple) KWGT widget also does what it has to do. Everything seems fine for me. Many thanks, again. Regards Chris Am Sonntag, dem 16.10.2022 um 17:53 +0200 schrieb Michael Balzer:
Regards, Michael
Regards, Michael
Chris, Michael,
release.apk
* https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100901- debug.apk This adds a new API key authorization to both Intent interfaces. The API key is automatically generated on App launch, and can be viewed, copied and regenerated from the general options page. It can be used for both command intents by passing in as extra "apikey", allowing to omit the vehicle password. The vehicle id is now also optional on both interfaces, if omitted the current vehicle will be used. To change the car you can either pass the vehicle password or the apikey along with the vehicle id. So with am, you can now use: * am broadcast -a com.openvehicles.OVMS.SendCommand -e apikey … -e command "stat" * am start -a com.openvehicles.OVMS.action.COMMAND -e apikey … -e command "stat" The second guarantees the activity is started, so the response will be visible. I'll probably restrict displaying the response to action.COMMAND in the next build, so SendCommand will be for background operations while action.COMMAND is for interactive uses. Android 10 (API 29) has a new limitation for displaying results (starting UI activities) from a service
Regards, Michael
Hi Michael,
thank you for your response. As always of great help :-)
Good that you could find a possible security risc concerning the credentials.
Regards
Chris
Am Sonntag, dem 09.10.2022 um 10:53 +0200 schrieb Michael Balzer:
Chris,
AFAIK you need to have an adb connection or a rooted Android to use "am", so not suitable as a general way to call OVMS commands.
With your (rooted) Lineageos you should be able to use it like this:
am broadcast -a com.openvehicles.OVMS.SendCommand -e sel_vehicleid xxx -e sel_server_password xxx -e msg_command "7,stat"
And I missed mentioning I also added support for user command syntax to "SendCommand", so you can now alternatively do
am broadcast -a com.openvehicles.OVMS.SendCommand -e sel_vehicleid xxx -e sel_server_password xxx -e command "stat"
Playing with am, I found out…
am start -n com.openvehicles.OVMS/.api.CommandActivity -a com.openvehicles.OVMS.action.COMMAND -e command "stat"
…actually works to trigger the new command receiver. I thought restricting the new receiver to app-internal intents would be possible, but it apparently isn't. That bothers me, it means any App could issue a command without knowing the credentials or an auth key and without a previous explicit user interaction to allow this.
So I need to add a credentials check to the new action, which means you will need to reinstall all bookmarks / shortcut assignments. Please wait with complex setups until I've added that.
Regards, Michael
Am 08.10.22 um 19:30 schrieb Chris van der Meijden:
I have been playing with the "SH" function of KWGT and tried to send a broadcast over the shell, like adb:
'am broadcast -a com.whereismywifeserver.intent.TEST --es sms_body "test from adb"'
That did not work, there where "rights" issues.
I took a look at the commands documentation. I will play a bit with that.
Thanx for explaining!
Am Samstag, dem 08.10.2022 um 18:54 +0200 schrieb Michael Balzer:
> Chris, > > "com.openvehicles.OVMS.SendCommand" is the old command > action, it's still supported and should work the same way > as before, except there are some new extras in the > response intent. > > The "SendCommand" interface is raw MP function level, > that's why you need to prefix "7," for text commands (7 = > execute text command). Other MP commands work just the > same way as raw commands, e.g. "20,<pin>" will lock the > car if supported. > (https://docs.openvehicles.com/en/latest/protocol_v2/commands.html > ) > > The newly added command intent action is > "com.openvehicles.OVMS.action.COMMAND", it just takes one > extra "command", which takes the command just as entered > in the notification page. See help there for the syntax, > text commands can be given as in the shell, to send the > above MP lock command, you'd enter "#20,<pin>". This > action currently always sends the command to the > currently selected vehicle. > > KWGT doesn't support sending intents, that's why I've > done all this. > > To call a stored command from KWGT, set a suitable > element's touch handler to "start shortcut". After > clicking on that action, you can open a selector. It will > show the list of shortcut providers installed including > the OVMS App now. Click on the OVMS entry, then select > the command from the list of stored commands. > > Regards, > Michael > > > Am 08.10.22 um 17:54 schrieb Chris van der Meijden: > > Hi Michael > > I just installed the release apk on my degoogled > Lineageos 19.1. > > Installation went without any troubles. I tested the > broadcast with my fireplace app via webinent: > > action: 'com.openvehicles.OVMS.SendCommand', > extras: { > sel_vehicleid: vid, > sel_server_password: pwd, > msg_command: '7,climatecontrol on' > } > > It works still fine and I can see the response dialog in > the OVMS app. > > I don't understand the "MP function". Do you have an > example for for i.e. "climatecontrol on" via Buttons in > KWGT? I'd love to test that :-) > > And do you know if there is a way to send intent > broadcasts with KWGT? I tried with a "GLOBALE", but I > could not get that to work. > > Regards > > Chris > > > Am Samstag, dem 08.10.2022 um 15:37 +0200 schrieb Michael > Balzer: > > > > > > > New test build: > > * https://dexters-web.de/f/tw-beta/OpenVehicleApp- 22100801-release.apk > > * https://dexters-web.de/f/tw-beta/OpenVehicleApp- 22100801-debug.apk > > > > This includes major extensions & code rewrites, I think > > I'll bump the version to 4.0 when releasing this to > > Google Play. > > > > Main goal & outcome of this effort: command bookmarks. > > > > The App now offers stored commands (see notifications > > tab). Stored commands can be pinned to the launcher and > > selected from third party Apps like KWGT as shortcuts > > to execute on triggers / actions. > > > > So this enabled custom widgets to include buttons > > triggering car commands. > > > > Commands are given using the user syntax, i.e. don't > > need the MP function prefix. You can still call an MP > > function by using the user syntax, i.e. "#…". > > > > Command responses are shown as a dialog with a timeoout > > of 5 seconds unless you hold it by touching or begin > > scrolling a long response. If the App is paused it will > > be resumed and switch to the notifications page (which > > keeps a record of all commands & responses). If the App > > isn't running, only the response dialog is shown on the > > launcher. > > > > All this of course needs the service to be enabled & > > allow commands to be sent. > > > > Command responses are also broadcasted now, so KWGT et > > al can receive them -- but they will currently need to > > know the command sent previously and copy command > > responses if they need to keep them, I don't know if > > KWGT can do that (Automagic can). KWGT seems to only > > have a simple variable storage model. > > > > I think about extending the ApiService to keep a > > command queue so the broadcast can at least carry the > > command, the response is supposedly produced for. > > Unfortunately the MP API cannot guarantee this, as it > > doesn't currently return a copy of the original command > > or a command ID reference with the response, so this > > would at best be a guess. Not sure if users actually > > need this. > > > > > > Note: I haven't pushed the code changes to github yet, > > I'd first like to get some test feedback. I've tested > > this on Android 6, 7, 11 & 13, but not on any degoogled > > Androids. > > > > Regards, > > Michael > > > > > > Am 26.09.22 um 17:26 schrieb Chris van der Meijden: > > > > For an includable example it would be nice if we could > > send the vehicle image from the OVMS app to KWGT. > > > > You can assign "Activities" to the "Touch" event on an > > image. Would be cool if that works, so we can start the > > remote climate control similar to how I do that with my > > OVMS-Fireplace app: > > > > https://github.com/devmarxx/OVMS-Fireplace > > > > > > Am Montag, dem 26.09.2022 um 13:56 +0200 schrieb > > Michael Balzer: > > > > > > > > > > > > > > > Nice, please go ahead if you want to create an > > > includable example widget :-) > > > > > > I've found out you can also use progress bars to > > > display values, enable formula input on the "step" & > > > set the formular to e.g. $br(ovms, car_soc)$. > > > > > > Works, although I need to convert all car model > > > values to strings for KWGT. Btw, I also need to > > > unroll the TPMS arrays, they are split into a "_cnt" > > > & "_<n>" variables. I need to add an info on this to > > > the wiki. > > > > > > I haven't found out how to send a broadcast from KWGT > > > yet, is that possible? That would enable creating > > > command shortcuts & buttons as with Automagic. > > > > > > Regards, > > > Michael > > > > > > > > > > > > Am 26.09.22 um 12:13 schrieb Chris van der Meijden: > > > > > > Correction: > > > > > > $br(ovms, sel_vehicle_label)$ > > > > > > Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb > > > Chris van der Meijden: > > > > > > > > > > > > > > > > > > > > > > > > > I like the new KWGT Widget feature: > > > > > > > > > > > > Above is the Tesla Widget of our Model 3, beneath > > > > that my OVMS KWGT widget of our VW e-UP. > > > > > > > > I had to allow "Passing data to other apps". The > > > > syntax for getting the intent variables to text in > > > > KWGT is i.e. > > > > > > > > $br(ovms, car_sel_vehicle_label)$ > > > > > > > > Other variables can be found here: > > > > https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-I... > > > > > > > > The image is local on the filesystem of the phone > > > > and does not come by intent. > > > > > > > > > > > > Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb > > > > Michael Balzer: > > > > No, icon can only be 0 from the else branch, in > > > > that case it shall fall back to the default image. > > > > > > > > But I've meanwhile found (I think) your maps/track > > > > crash, commit is already in the hub. The checkbox > > > > handler didn't check if the map object is > > > > initialized. > > > > > > > > https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicle... > > > > > > > > Regards, > > > > Michael > > > > > > > > > > > > Am 25.09.22 um 15:46 schrieb Chris van der Meijden: > > > > > > > > Just guessing, but does > > > > > > > > int icon; > > > > > > > > in MyGcmListenerService.java at line 132 > > > > > > > > not need to be initialized like > > > > > > > > int icon = 0; > > > > > > > > now you use > > > > > > > > .setSmallIcon((icon != 0) ? icon : > > > > R.drawable.map_car_default) > > > > > > > > at line 150 now? > > > > > > > > As the images and the Google stuff are related to > > > > that integer it made me thinking ... > > > > > > > > > > > > Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb > > > > Michael Balzer: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Chris, > > > > > > > > > > that's not a crash log, that's just a warning. > > > > > > > > > > On that warning: the App requests > > > > > android.permission.ACCESS_FINE_LOCATION by it's > > > > > manifest. Maybe with LineageOS you need to > > > > > manually give it that permission? > > > > > > > > > > A crash log has class "E" (error) and includes an > > > > > exception and a backtrace, for an example see: > > > > > https://issuetracker.google.com/issues/201308676#comment4 > > > > > > > > > > On the crash: maybe it's because you don't have > > > > > the Google components, not sure if FragMap can > > > > > handle that. > > > > > > > > > > The forum post relates to /e/OS … maybe I need > > > > > some emulator images running alternative Androids > > > > > now… > > > > > > > > > > Regards, > > > > > Michael > > > > > > > > > > > > > > > Am 25.09.22 um 11:40 schrieb Chris van der > > > > > Meijden: > > > > > > > > > > Hey Michael, > > > > > > > > > > this is from logcat when I change "Track vehicle" > > > > > and the app crashes: > > > > > > > > > > 09-25 11:16:01.410 1710 1839 W BroadcastQueue: > > > > > Permission Denial: receiving Intent { > > > > > act=android.intent.action.SERVICE_STATE > > > > > flg=0x1000010 (has extras) } to > > > > > ProcessRecord{8dcdd54 > > > > > 2053:com.android.systemui/u0a148} (pid=2053, > > > > > uid=10148) requires > > > > > android.permission.ACCESS_FINE_LOCATION due to > > > > > sender android (uid 1001) > > > > > > > > > > I saw now, that this crash also happens in the > > > > > production app. > > > > > > > > > > The widget is running well. I will keep the app > > > > > running for while and will see if it stays > > > > > stable. > > > > > > > > > > Regards > > > > > > > > > > Chris > > > > > > > > > > Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb > > > > > Michael Balzer: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Chris, > > > > > > > > > > > > thanks for testing. A crash log would help on > > > > > > any crashes you see. Btw, I don't bump the > > > > > > revision until the actual release build. > > > > > > > > > > > > Crashes related to the car image don't occur > > > > > > immediately, it sometimes takes hours of use > > > > > > before it happens. When it does, clearing the > > > > > > App cache fixes the crash for another random > > > > > > period. > > > > > > > > > > > > Speed optimization was one goal. What about the > > > > > > widget? > > > > > > > > > > > > Thanks, > > > > > > Michael > > > > > > > > > > > > > > > > > > Am 24.09.22 um 22:43 schrieb Chris van der > > > > > > Meijden: > > > > > > > > > > > > Hey Michael, > > > > > > > > > > > > I just installed the "release" Version on > > > > > > LineageOS 19.1 (Android 12) without Google > > > > > > components. > > > > > > > > > > > > The vehicle setup was without any troubles. I > > > > > > could select the yellow VW e-UP image without > > > > > > crashing. > > > > > > > > > > > > The App version is set wrong under "Vehicle > > > > > > info" (3.19.1, 2021122401). > > > > > > > > > > > > Everything seems to be faster than before. > > > > > > > > > > > > When I change the checkbox on "Track vehicle" > > > > > > under "Position" the App crashes. But after a > > > > > > new start of the app the value of the checkbox > > > > > > has changed. > > > > > > > > > > > > Perhaps this first impression is of some help. > > > > > > > > > > > > Regards > > > > > > > > > > > > Chris > > > > > > > > > > > > Am Samstag, dem 24.09.2022 um 20:10 +0200 > > > > > > schrieb Michael Balzer: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Everyone, > > > > > > > > > > > > > > I'm currently working on the next Android > > > > > > > release including KustomWidget support and a > > > > > > > native app widget based on the old Automagic > > > > > > > gauge widget. > > > > > > > > > > > > > > Automagic has been dead for some time now, > > > > > > > and it keeps crashing on Androids >= 7. > > > > > > > > > > > > > > My changes so far are in the hub, APK builds > > > > > > > are available here: > > > > > > > > > > > > > > > > > > > > > * https://dexters-web.de/f/tw- beta/OpenVehicleApp-22092401-release.apk > > > > > > > * debug build for extended logging: https://dexters-web.de/f/tw- > > > > > > > beta/OpenVehicleApp-22092401-debug.apk > > > > > > > > > > > > > > There's an issue with the App related to > > > > > > > Android >= 10 though, which I haven't found > > > > > > > yet. It's been reported in the forum: > > > > > > > > > > > > > > > > > > > > > * https://www.openvehicles.com/node/3410 > > > > > > > I could use some help with that, I've got no > > > > > > > idea other than blaming Android. > > > > > > > I've seen the effect in my emulator tests, > > > > > > > and it seems to occur more frequently with > > > > > > > non-roadster images. > > > > > > > > > > > > > > Regards, > > > > > > > Michael > > > > > > > > > > > > > > _____________________________________________ > > > > > > > __ > > > > > > > OvmsDev mailing list > > > > > > > OvmsDev@lists.openvehicles.com > > > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > > > > > > > > > > > > > _______________________________________________ > > > > > > OvmsDev mailing list > > > > > > OvmsDev@lists.openvehicles.com > > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > > > > > > > _______________________________________________ > > > > > > OvmsDev mailing list > > > > > > OvmsDev@lists.openvehicles.com > > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > > > > > > > > > > _______________________________________________ > > > > > OvmsDev mailing list > > > > > OvmsDev@lists.openvehicles.com > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > > > > > _______________________________________________ > > > > > OvmsDev mailing list > > > > > OvmsDev@lists.openvehicles.com > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > > > > > > > _______________________________________________ > > > > OvmsDev mailing list > > > > OvmsDev@lists.openvehicles.com > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > > > _______________________________________________ > > > > OvmsDev mailing list > > > > OvmsDev@lists.openvehicles.com > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > > > _______________________________________________ > > > > OvmsDev mailing list > > > > OvmsDev@lists.openvehicles.com > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > > > > _______________________________________________ > > > OvmsDev mailing list > > > OvmsDev@lists.openvehicles.com > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > _______________________________________________ > > > OvmsDev mailing list > > > OvmsDev@lists.openvehicles.com > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > > _______________________________________________ > > OvmsDev mailing list > > OvmsDev@lists.openvehicles.com > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > _______________________________________________ > > OvmsDev mailing list > > OvmsDev@lists.openvehicles.com > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Everyone, some new fixes & optimizations, and I've added a "latest" directory to the hub, so the latest builds are easy to reach for anyone interested: https://github.com/openvehicles/Open-Vehicle-Android/tree/master/latest The builds are "officially" signed, so can be installed over an existing play store release and vice versa. Regards, Michael Am 16.10.22 um 19:16 schrieb Chris van der Meijden:
Hi Michael
Regards
Chris
New builds:
Regards, Michael
Chris, Michael, thanks for tests & feedback.
Code changes so far are now in the hub: https://github.com/openvehicles/Open-Vehicle-Android/commit/c23b3dbd772bdae7...
This has become a very large commit, and it mixes some version update changes that became necessary & deprecation fixes I should have kept separate, but cannot disentangle now.
Some things still to do for the release, most notably removing UI interaction from the service. So if any other stuff shall be added to the next release, tell me & go ahead preparing that.
Regards, Michael
I think it is a good idea to restrict the respond to only action.COMMAND and leave SendCommand for background operation.
Am Sonntag, dem 09.10.2022 um 16:05 +0200 schrieb Michael Balzer:
Chris, Michael,
new builds with the announced new security scheme:
* https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100901-release.apk * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100901-debug.apk
Android 10 (API 29) has a new limitation for displaying results (starting UI activities) from a service (https://developer.android.com/guide/components/activities/background-starts), so that works only by chance now anyway.
Regards, Michael
Am 09.10.22 um 12:45 schrieb Chris van der Meijden: Hi Michael,
Regards
Chris
> Chris, > > AFAIK you need to have an adb connection or a rooted Android to > use "am", so not suitable as a general way to call OVMS commands. > > With your (rooted) Lineageos you should be able to use it like this: > > am broadcast -a com.openvehicles.OVMS.SendCommand -e > sel_vehicleid xxx -e sel_server_password xxx -e msg_command "7,stat" > > And I missed mentioning I also added support for user command > syntax to "SendCommand", so you can now alternatively do > > am broadcast -a com.openvehicles.OVMS.SendCommand -e > sel_vehicleid xxx -e sel_server_password xxx -e command "stat" > > Playing with am, I found out… > > am start -n com.openvehicles.OVMS/.api.CommandActivity -a > com.openvehicles.OVMS.action.COMMAND -e command "stat" > > …actually works to trigger the new command receiver. I thought > restricting the new receiver to app-internal intents would be > possible, but it apparently isn't. That bothers me, it means any > App could issue a command without knowing the credentials or an > auth key and without a previous explicit user interaction to > allow this. > > So I need to add a credentials check to the new action, which > means you will need to reinstall all bookmarks / shortcut > assignments. Please wait with complex setups until I've added that. > > Regards, > Michael > > > > Am 08.10.22 um 19:30 schrieb Chris van der Meijden: > I have been playing with the "SH" function of KWGT and tried to > send a broadcast over the shell, like adb: > > 'am broadcast -acom.whereismywifeserver.intent.TEST --essms_body > "test fromadb"' > > That did not work, there where "rights" issues. > > I took a look at the commands documentation. I will play a bit > with that. > > Thanx for explaining! > > > Am Samstag, dem 08.10.2022 um 18:54 +0200 schrieb Michael Balzer: > > > > >> Chris, >> >> "com.openvehicles.OVMS.SendCommand" is the old command action, >> it's still supported and should work the same way as before, >> except there are some new extras in the response intent. >> >> The "SendCommand" interface is raw MP function level, that's >> why you need to prefix "7," for text commands (7 = execute text >> command). Other MP commands work just the same way as raw >> commands, e.g. "20,<pin>" will lock the car if supported. >> (https://docs.openvehicles.com/en/latest/protocol_v2/commands.html) >> >> The newly added command intent action is >> "com.openvehicles.OVMS.action.COMMAND", it just takes one extra >> "command", which takes the command just as entered in the >> notification page. See help there for the syntax, text commands >> can be given as in the shell, to send the above MP lock >> command, you'd enter "#20,<pin>". This action currently always >> sends the command to the currently selected vehicle. >> >> KWGT doesn't support sending intents, that's why I've done all >> this. >> >> To call a stored command from KWGT, set a suitable element's >> touch handler to "start shortcut". After clicking on that >> action, you can open a selector. It will show the list of >> shortcut providers installed including the OVMS App now. Click >> on the OVMS entry, then select the command from the list of >> stored commands. >> >> Regards, >> Michael >> >> >> Am 08.10.22 um 17:54 schrieb Chris van der Meijden: >> Hi Michael >> >> I just installed the release apk on my degoogled Lineageos 19.1. >> >> Installation went without any troubles. I tested the broadcast >> with my fireplace app via webinent: >> >> action: 'com.openvehicles.OVMS.SendCommand', >> extras: { >> sel_vehicleid: vid, >> sel_server_password: pwd, >> msg_command: '7,climatecontrol on' >> } >> >> It works still fine and I can see the response dialog in the >> OVMS app. >> >> I don't understand the "MP function". Do you have an example >> for for i.e. "climatecontrol on" via Buttons in KWGT? I'd love >> to test that :-) >> >> And do you know if there is a way to send intent broadcasts >> with KWGT? I tried with a "GLOBALE", but I could not get that >> to work. >> >> Regards >> >> Chris >> >> >> Am Samstag, dem 08.10.2022 um 15:37 +0200 schrieb Michael Balzer: >> >> >> >> >> >>> New test build: >>> >>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-release.apk >>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-debug.apk >>> >>> >>> This includes major extensions & code rewrites, I think I'll >>> bump the version to 4.0 when releasing this to Google Play. >>> >>> Main goal & outcome of this effort: command bookmarks. >>> >>> The App now offers stored commands (see notifications tab). >>> Stored commands can be pinned to the launcher and selected >>> from third party Apps like KWGT as shortcuts to execute on >>> triggers / actions. >>> >>> So this enabled custom widgets to include buttons triggering >>> car commands. >>> >>> Commands are given using the user syntax, i.e. don't need the >>> MP function prefix. You can still call an MP function by using >>> the user syntax, i.e. "#…". >>> >>> Command responses are shown as a dialog with a timeoout of 5 >>> seconds unless you hold it by touching or begin scrolling a >>> long response. If the App is paused it will be resumed and >>> switch to the notifications page (which keeps a record of all >>> commands & responses). If the App isn't running, only the >>> response dialog is shown on the launcher. >>> >>> All this of course needs the service to be enabled & allow >>> commands to be sent. >>> >>> Command responses are also broadcasted now, so KWGT et al can >>> receive them -- but they will currently need to know the >>> command sent previously and copy command responses if they >>> need to keep them, I don't know if KWGT can do that (Automagic >>> can). KWGT seems to only have a simple variable storage model. >>> >>> I think about extending the ApiService to keep a command queue >>> so the broadcast can at least carry the command, the response >>> is supposedly produced for. Unfortunately the MP API cannot >>> guarantee this, as it doesn't currently return a copy of the >>> original command or a command ID reference with the response, >>> so this would at best be a guess. Not sure if users actually >>> need this. >>> >>> >>> Note: I haven't pushed the code changes to github yet, I'd >>> first like to get some test feedback. I've tested this on >>> Android 6, 7, 11 & 13, but not on any degoogled Androids. >>> >>> Regards, >>> Michael >>> >>> >>> Am 26.09.22 um 17:26 schrieb Chris van der Meijden: >>> For an includable example it would be nice if we could send >>> the vehicle image from the OVMS app to KWGT. >>> >>> You can assign "Activities" to the "Touch" event on an image. >>> Would be cool if that works, so we can start the remote >>> climate control similar to how I do that with my >>> OVMS-Fireplace app: >>> >>> https://github.com/devmarxx/OVMS-Fireplace >>> >>> >>> Am Montag, dem 26.09.2022 um 13:56 +0200 schrieb Michael Balzer: >>> >>> >>> >>> >>> >>> >>>> Nice, please go ahead if you want to create an includable >>>> example widget :-) >>>> >>>> I've found out you can also use progress bars to display >>>> values, enable formula input on the "step" & set the formular >>>> to e.g. $br(ovms, car_soc)$. >>>> >>>> Works, although I need to convert all car model values to >>>> strings for KWGT. Btw, I also need to unroll the TPMS arrays, >>>> they are split into a "_cnt" & "_<n>" variables. I need to >>>> add an info on this to the wiki. >>>> >>>> I haven't found out how to send a broadcast from KWGT yet, is >>>> that possible? That would enable creating command shortcuts & >>>> buttons as with Automagic. >>>> >>>> Regards, >>>> Michael >>>> >>>> >>>> >>>> Am 26.09.22 um 12:13 schrieb Chris van der Meijden: >>>> Correction: >>>> >>>> $br(ovms, sel_vehicle_label)$ >>>> >>>> Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb Chris van >>>> der Meijden: >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>>> I like the new KWGT Widget feature: >>>>> >>>>> >>>>> Above is the Tesla Widget of our Model 3, beneath that my >>>>> OVMS KWGT widget of our VW e-UP. >>>>> >>>>> I had to allow "Passing data to other apps". The syntax for >>>>> getting the intent variables to text in KWGT is i.e. >>>>> >>>>> $br(ovms, car_sel_vehicle_label)$ >>>>> >>>>> Other variables can be found here: >>>>> https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-I... >>>>> >>>>> The image is local on the filesystem of the phone and does >>>>> not come by intent. >>>>> >>>>> >>>>> Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael >>>>> Balzer: >>>>> No, icon can only be 0 from the else branch, in that case it >>>>> shall fall back to the default image. >>>>> >>>>> But I've meanwhile found (I think) your maps/track crash, >>>>> commit is already in the hub. The checkbox handler didn't >>>>> check if the map object is initialized. >>>>> >>>>> https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicle... >>>>> >>>>> Regards, >>>>> Michael >>>>> >>>>> >>>>> Am 25.09.22 um 15:46 schrieb Chris van der Meijden: >>>>> Just guessing, but does >>>>> >>>>> int icon; >>>>> >>>>> in MyGcmListenerService.java >>>>> <https://github.com/devmarxx/Open-Vehicle-Android/commit/3c13100a6a25257fe694be3050a1b76ca2b6fb44#diff-c13198cb33bb355f600c37f8889cedcb72346835dbb7e357c031c57aba424487> at >>>>> line 132 >>>>> >>>>> not need to be initialized like >>>>> >>>>> int icon = 0; >>>>> >>>>> now you use >>>>> >>>>> .setSmallIcon((icon!= 0) ? icon: R.drawable.map_car_default) >>>>> >>>>> at line 150 now? >>>>> >>>>> As the images and the Google stuff are related to that >>>>> integer it made me thinking ... >>>>> >>>>> >>>>> Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael >>>>> Balzer: >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>>> Chris, >>>>>> >>>>>> that's not a crash log, that's just a warning. >>>>>> >>>>>> On that warning: the App requests >>>>>> android.permission.ACCESS_FINE_LOCATION by it's manifest. >>>>>> Maybe with LineageOS you need to manually give it that >>>>>> permission? >>>>>> >>>>>> A crash log has class "E" (error) and includes an exception >>>>>> and a backtrace, for an example see: >>>>>> https://issuetracker.google.com/issues/201308676#comment4 >>>>>> >>>>>> On the crash: maybe it's because you don't have the Google >>>>>> components, not sure if FragMap can handle that. >>>>>> >>>>>> The forum post relates to /e/OS … maybe I need some >>>>>> emulator images running alternative Androids now… >>>>>> >>>>>> Regards, >>>>>> Michael >>>>>> >>>>>> >>>>>> Am 25.09.22 um 11:40 schrieb Chris van der Meijden: >>>>>> Hey Michael, >>>>>> >>>>>> this is from logcat when I change "Track vehicle" and the >>>>>> app crashes: >>>>>> >>>>>> 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission >>>>>> Denial: receiving Intent { >>>>>> act=android.intent.action.SERVICE_STATE flg=0x1000010 (has >>>>>> extras) } to ProcessRecord{8dcdd54 >>>>>> 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) >>>>>> requires android.permission.ACCESS_FINE_LOCATION due to >>>>>> sender android (uid 1001) >>>>>> >>>>>> I saw now, that this crash also happens in the production app. >>>>>> >>>>>> The widget is running well. I will keep the app running for >>>>>> while and will see if it stays stable. >>>>>> >>>>>> Regards >>>>>> >>>>>> Chris >>>>>> >>>>>> Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael >>>>>> Balzer: >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>>> Chris, >>>>>>> >>>>>>> thanks for testing. A crash log would help on any crashes >>>>>>> you see. Btw, I don't bump the revision until the actual >>>>>>> release build. >>>>>>> >>>>>>> Crashes related to the car image don't occur immediately, >>>>>>> it sometimes takes hours of use before it happens. When it >>>>>>> does, clearing the App cache fixes the crash for another >>>>>>> random period. >>>>>>> >>>>>>> Speed optimization was one goal. What about the widget? >>>>>>> >>>>>>> Thanks, >>>>>>> Michael >>>>>>> >>>>>>> >>>>>>> Am 24.09.22 um 22:43 schrieb Chris van der Meijden: >>>>>>> Hey Michael, >>>>>>> >>>>>>> I just installed the "release" Version on LineageOS 19.1 >>>>>>> (Android 12) without Google components. >>>>>>> >>>>>>> The vehicle setup was without any troubles. I could select >>>>>>> the yellow VW e-UP image without crashing. >>>>>>> >>>>>>> The App version is set wrong under "Vehicle info" (3.19.1, >>>>>>> 2021122401). >>>>>>> >>>>>>> Everything seems to be faster than before. >>>>>>> >>>>>>> When I change the checkbox on "Track vehicle" under >>>>>>> "Position" the App crashes. But after a new start of the >>>>>>> app the value of the checkbox has changed. >>>>>>> >>>>>>> Perhaps this first impression is of some help. >>>>>>> >>>>>>> Regards >>>>>>> >>>>>>> Chris >>>>>>> >>>>>>> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael >>>>>>> Balzer: >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>>> Everyone, >>>>>>>> >>>>>>>> I'm currently working on the next Android release >>>>>>>> including KustomWidget support and a native app widget >>>>>>>> based on the old Automagic gauge widget. >>>>>>>> >>>>>>>> Automagic has been dead for some time now, and it keeps >>>>>>>> crashing on Androids >= 7. >>>>>>>> >>>>>>>> My changes so far are in the hub, APK builds are >>>>>>>> available here: >>>>>>>> >>>>>>>> >>>>>>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk >>>>>>>> * debug build for extended logging: >>>>>>>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk >>>>>>>> >>>>>>>> >>>>>>>> There's an issue with the App related to Android >= 10 >>>>>>>> though, which I haven't found yet. It's been reported in >>>>>>>> the forum: >>>>>>>> >>>>>>>> >>>>>>>> * https://www.openvehicles.com/node/3410 >>>>>>>> >>>>>>>> I could use some help with that, I've got no idea other >>>>>>>> than blaming Android. >>>>>>>> >>>>>>>> I've seen the effect in my emulator tests, and it seems >>>>>>>> to occur more frequently with non-roadster images. >>>>>>>> >>>>>>>> Regards, >>>>>>>> Michael >>>>>>>> >>>>>>>> _______________________________________________ >>>>>>>> OvmsDev mailing list >>>>>>>> OvmsDev@lists.openvehicles.com >>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>>>> >>>>>>> >>>>>>> _______________________________________________ >>>>>>> OvmsDev mailing list >>>>>>> OvmsDev@lists.openvehicles.com >>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>>>> >>>>>>> _______________________________________________ >>>>>>> OvmsDev mailing list >>>>>>> OvmsDev@lists.openvehicles.com >>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>>> >>>>>> >>>>>> _______________________________________________ >>>>>> OvmsDev mailing list >>>>>> OvmsDev@lists.openvehicles.com >>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>>> >>>>>> _______________________________________________ >>>>>> OvmsDev mailing list >>>>>> OvmsDev@lists.openvehicles.com >>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>> >>>>> >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>> >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>> >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
I build from Android Studio, no special settings (should all be in the files). Am 09.10.22 um 20:22 schrieb Chris van der Meijden:
It compiled and runs without troubles, but I needed to build with
gradlew build -x lint
Am Sonntag, dem 09.10.2022 um 19:16 +0200 schrieb Michael Balzer:
Regards, Michael
Am 09.10.22 um 17:09 schrieb Chris van der Meijden: I tested the new build. Everything is working fine for me.
Chris, Michael,
Regards, Michael
Regards
Chris
Chris,
Regards, Michael
Am 08.10.22 um 19:30 schrieb Chris van der Meijden: I have been playing with the "SH" function of KWGT and tried to send a broadcast over the shell, like adb:
'am broadcast -acom.whereismywifeserver.intent.TEST --essms_body "test fromadb"'
Chris,
"com.openvehicles.OVMS.SendCommand" is the old command action, it's still supported and should work the same way as before, except there are some new extras in the response intent.
The "SendCommand" interface is raw MP function level, that's why you need to prefix "7," for text commands (7 = execute text command). Other MP commands work just the same way as raw commands, e.g. "20,<pin>" will lock the car if supported. (https://docs.openvehicles.com/en/latest/protocol_v2/commands.html)
The newly added command intent action is "com.openvehicles.OVMS.action.COMMAND", it just takes one extra "command", which takes the command just as entered in the notification page. See help there for the syntax, text commands can be given as in the shell, to send the above MP lock command, you'd enter "#20,<pin>". This action currently always sends the command to the currently selected vehicle.
KWGT doesn't support sending intents, that's why I've done all this.
To call a stored command from KWGT, set a suitable element's touch handler to "start shortcut". After clicking on that action, you can open a selector. It will show the list of shortcut providers installed including the OVMS App now. Click on the OVMS entry, then select the command from the list of stored commands.
Regards, Michael
Am 08.10.22 um 17:54 schrieb Chris van der Meijden: Hi Michael
Regards
Chris
New test build:
* https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-release.apk * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-debug.apk
This includes major extensions & code rewrites, I think I'll bump the version to 4.0 when releasing this to Google Play.
The App now offers stored commands (see notifications tab). Stored commands can be pinned to the launcher and selected from third party Apps like KWGT as shortcuts to execute on triggers / actions.
So this enabled custom widgets to include buttons triggering car commands.
Commands are given using the user syntax, i.e. don't need the MP function prefix. You can still call an MP function by using the user syntax, i.e. "#…".
Command responses are shown as a dialog with a timeoout of 5 seconds unless you hold it by touching or begin scrolling a long response. If the App is paused it will be resumed and switch to the notifications page (which keeps a record of all commands & responses). If the App isn't running, only the response dialog is shown on the launcher.
All this of course needs the service to be enabled & allow commands to be sent.
Command responses are also broadcasted now, so KWGT et al can receive them -- but they will currently need to know the command sent previously and copy command responses if they need to keep them, I don't know if KWGT can do that (Automagic can). KWGT seems to only have a simple variable storage model.
I think about extending the ApiService to keep a command queue so the broadcast can at least carry the command, the response is supposedly produced for. Unfortunately the MP API cannot guarantee this, as it doesn't currently return a copy of the original command or a command ID reference with the response, so this would at best be a guess. Not sure if users actually need this.
Note: I haven't pushed the code changes to github yet, I'd first like to get some test feedback. I've tested this on Android 6, 7, 11 & 13, but not on any degoogled Androids.
Regards, Michael
Am 26.09.22 um 17:26 schrieb Chris van der Meijden: For an includable example it would be nice if we could send the vehicle image from the OVMS app to KWGT.
You can assign "Activities" to the "Touch" event on an image. Would be cool if that works, so we can start the remote climate control similar to how I do that with my OVMS-Fireplace app:
> Nice, please go ahead if you want to create an includable > example widget :-) > > I've found out you can also use progress bars to display values, > enable formula input on the "step" & set the formular to e.g. > $br(ovms, car_soc)$. > > Works, although I need to convert all car model values to > strings for KWGT. Btw, I also need to unroll the TPMS arrays, > they are split into a "_cnt" & "_<n>" variables. I need to add > an info on this to the wiki. > > I haven't found out how to send a broadcast from KWGT yet, is > that possible? That would enable creating command shortcuts & > buttons as with Automagic. > > Regards, > Michael > > > > Am 26.09.22 um 12:13 schrieb Chris van der Meijden: > Correction: > > $br(ovms, sel_vehicle_label)$ > > Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb Chris van der > Meijden: > > > > > > >> I like the new KWGT Widget feature: >> >> >> Above is the Tesla Widget of our Model 3, beneath that my OVMS >> KWGT widget of our VW e-UP. >> >> I had to allow "Passing data to other apps". The syntax for >> getting the intent variables to text in KWGT is i.e. >> >> $br(ovms, car_sel_vehicle_label)$ >> >> Other variables can be found here: >> https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-I... >> >> The image is local on the filesystem of the phone and does not >> come by intent. >> >> >> Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael Balzer: >> No, icon can only be 0 from the else branch, in that case it >> shall fall back to the default image. >> >> But I've meanwhile found (I think) your maps/track crash, >> commit is already in the hub. The checkbox handler didn't check >> if the map object is initialized. >> >> https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicle... >> >> Regards, >> Michael >> >> >> Am 25.09.22 um 15:46 schrieb Chris van der Meijden: >> Just guessing, but does >> >> int icon; >> >> in MyGcmListenerService.java >> <https://github.com/devmarxx/Open-Vehicle-Android/commit/3c13100a6a25257fe694be3050a1b76ca2b6fb44#diff-c13198cb33bb355f600c37f8889cedcb72346835dbb7e357c031c57aba424487> at >> line 132 >> >> not need to be initialized like >> >> int icon = 0; >> >> now you use >> >> .setSmallIcon((icon!= 0) ? icon: R.drawable.map_car_default) >> >> at line 150 now? >> >> As the images and the Google stuff are related to that integer >> it made me thinking ... >> >> >> Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael Balzer: >> >> >> >> >> >> >> >>> Chris, >>> >>> that's not a crash log, that's just a warning. >>> >>> On that warning: the App requests >>> android.permission.ACCESS_FINE_LOCATION by it's manifest. >>> Maybe with LineageOS you need to manually give it that permission? >>> >>> A crash log has class "E" (error) and includes an exception >>> and a backtrace, for an example see: >>> https://issuetracker.google.com/issues/201308676#comment4 >>> >>> On the crash: maybe it's because you don't have the Google >>> components, not sure if FragMap can handle that. >>> >>> The forum post relates to /e/OS … maybe I need some emulator >>> images running alternative Androids now… >>> >>> Regards, >>> Michael >>> >>> >>> Am 25.09.22 um 11:40 schrieb Chris van der Meijden: >>> Hey Michael, >>> >>> this is from logcat when I change "Track vehicle" and the app >>> crashes: >>> >>> 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission >>> Denial: receiving Intent { >>> act=android.intent.action.SERVICE_STATE flg=0x1000010 (has >>> extras) } to ProcessRecord{8dcdd54 >>> 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) >>> requires android.permission.ACCESS_FINE_LOCATION due to sender >>> android (uid 1001) >>> >>> I saw now, that this crash also happens in the production app. >>> >>> The widget is running well. I will keep the app running for >>> while and will see if it stays stable. >>> >>> Regards >>> >>> Chris >>> >>> Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael Balzer: >>> >>> >>> >>> >>> >>> >>> >>> >>>> Chris, >>>> >>>> thanks for testing. A crash log would help on any crashes you >>>> see. Btw, I don't bump the revision until the actual release >>>> build. >>>> >>>> Crashes related to the car image don't occur immediately, it >>>> sometimes takes hours of use before it happens. When it does, >>>> clearing the App cache fixes the crash for another random period. >>>> >>>> Speed optimization was one goal. What about the widget? >>>> >>>> Thanks, >>>> Michael >>>> >>>> >>>> Am 24.09.22 um 22:43 schrieb Chris van der Meijden: >>>> Hey Michael, >>>> >>>> I just installed the "release" Version on LineageOS 19.1 >>>> (Android 12) without Google components. >>>> >>>> The vehicle setup was without any troubles. I could select >>>> the yellow VW e-UP image without crashing. >>>> >>>> The App version is set wrong under "Vehicle info" (3.19.1, >>>> 2021122401). >>>> >>>> Everything seems to be faster than before. >>>> >>>> When I change the checkbox on "Track vehicle" under >>>> "Position" the App crashes. But after a new start of the app >>>> the value of the checkbox has changed. >>>> >>>> Perhaps this first impression is of some help. >>>> >>>> Regards >>>> >>>> Chris >>>> >>>> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer: >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>>> Everyone, >>>>> >>>>> I'm currently working on the next Android release including >>>>> KustomWidget support and a native app widget based on the >>>>> old Automagic gauge widget. >>>>> >>>>> Automagic has been dead for some time now, and it keeps >>>>> crashing on Androids >= 7. >>>>> >>>>> My changes so far are in the hub, APK builds are available here: >>>>> >>>>> >>>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk >>>>> * debug build for extended logging: >>>>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk >>>>> >>>>> >>>>> There's an issue with the App related to Android >= 10 >>>>> though, which I haven't found yet. It's been reported in the >>>>> forum: >>>>> >>>>> >>>>> * https://www.openvehicles.com/node/3410 >>>>> >>>>> I could use some help with that, I've got no idea other than >>>>> blaming Android. >>>>> >>>>> I've seen the effect in my emulator tests, and it seems to >>>>> occur more frequently with non-roadster images. >>>>> >>>>> Regards, >>>>> Michael >>>>> >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Just installed this. Love that stored command thing. Anyway, I opened up the 'Car' section and it showed 9999.0km and I thought 'well that's wrong'. Anyway, turns out it's not wrong. I actually have 9999.0km on the odometer. //.ichael On Sat, 8 Oct 2022 at 21:37, Michael Balzer <dexter@expeedo.de> wrote:
New test build:
- https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-release.apk - https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-debug.apk
Regards, Michael
Nice, please go ahead if you want to create an includable example widget :-)
I've found out you can also use progress bars to display values, enable formula input on the "step" & set the formular to e.g. $br(ovms, car_soc)$.
Works, although I need to convert all car model values to strings for KWGT. Btw, I also need to unroll the TPMS arrays, they are split into a "_cnt" & "_<n>" variables. I need to add an info on this to the wiki.
I haven't found out how to send a broadcast from KWGT yet, is that possible? That would enable creating command shortcuts & buttons as with Automagic.
Regards, Michael
Am 26.09.22 um 12:13 schrieb Chris van der Meijden: Correction:
Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb Chris van der Meijden:
Above is the Tesla Widget of our Model 3, beneath that my OVMS KWGT widget of our VW e-UP.
I had to allow "Passing data to other apps". The syntax for getting the intent variables to text in KWGT is i.e.
The image is local on the filesystem of the phone and does not come by intent.
Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael Balzer: No, icon can only be 0 from the else branch, in that case it shall fall back to the default image.
But I've meanwhile found (I think) your maps/track crash, commit is already in the hub. The checkbox handler didn't check if the map object is initialized.
Regards, Michael
Am 25.09.22 um 15:46 schrieb Chris van der Meijden: Just guessing, but does
int icon;
in MyGcmListenerService.java <https://github.com/devmarxx/Open-Vehicle-Android/commit/3c13100a6a25257fe694be3050a1b76ca2b6fb44#diff-c13198cb33bb355f600c37f8889cedcb72346835dbb7e357c031c57aba424487> at line 132
int icon = 0;
now you use
.setSmallIcon((icon != 0) ? icon : R.drawable.map_car_default)
at line 150 now?
As the images and the Google stuff are related to that integer it made me thinking ...
Chris,
On that warning: the App requests android.permission.ACCESS_FINE_LOCATION by it's manifest. Maybe with LineageOS you need to manually give it that permission?
A crash log has class "E" (error) and includes an exception and a backtrace, for an example see: https://issuetracker.google.com/issues/201308676#comment4
On the crash: maybe it's because you don't have the Google components, not sure if FragMap can handle that.
The forum post relates to /e/OS … maybe I need some emulator images running alternative Androids now…
Regards, Michael
Am 25.09.22 um 11:40 schrieb Chris van der Meijden: Hey Michael,
this is from logcat when I change "Track vehicle" and the app crashes:
09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission Denial: receiving Intent { act=android.intent.action.SERVICE_STATE flg=0x1000010 (has extras) } to ProcessRecord{8dcdd54 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) requires android.permission.ACCESS_FINE_LOCATION due to sender android (uid 1001)
The widget is running well. I will keep the app running for while and will see if it stays stable.
Regards
Chris
Chris,
thanks for testing. A crash log would help on any crashes you see. Btw, I don't bump the revision until the actual release build.
Crashes related to the car image don't occur immediately, it sometimes takes hours of use before it happens. When it does, clearing the App cache fixes the crash for another random period.
Thanks, Michael
Am 24.09.22 um 22:43 schrieb Chris van der Meijden: Hey Michael,
I just installed the "release" Version on LineageOS 19.1 (Android 12) without Google components.
The vehicle setup was without any troubles. I could select the yellow VW e-UP image without crashing.
The App version is set wrong under "Vehicle info" (3.19.1, 2021122401).
When I change the checkbox on "Track vehicle" under "Position" the App crashes. But after a new start of the app the value of the checkbox has changed.
Regards
Chris
Everyone,
I'm currently working on the next Android release including KustomWidget support and a native app widget based on the old Automagic gauge widget.
Automagic has been dead for some time now, and it keeps crashing on Androids >= 7.
- https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk - debug build for extended logging: https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk
There's an issue with the App related to Android >= 10 though, which I haven't found yet. It's been reported in the forum:
- https://www.openvehicles.com/node/3410
I could use some help with that, I've got no idea other than blaming Android. I've seen the effect in my emulator tests, and it seems to occur more frequently with non-roadster images.
Regards, Michael
_______________________________________________ OvmsDev mailing listOvmsDev@lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
:-)) Am Sonntag, dem 09.10.2022 um 16:22 +0800 schrieb Michael Geddes:
//.ichael
New test build: * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801- release.apk * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801- debug.apk
Regards, Michael
Regards, Michael
Regards, Michael
int icon;
int icon = 0;
now you use
at line 150 now?
Chris,
Regards, Michael
Regards
Chris
> Chris, > > thanks for testing. A crash log would help on any crashes > you see. Btw, I don't bump the revision until the actual > release build. > > Crashes related to the car image don't occur immediately, > it sometimes takes hours of use before it happens. When > it does, clearing the App cache fixes the crash for > another random period. > > Speed optimization was one goal. What about the widget? > > Thanks, > Michael > > > Am 24.09.22 um 22:43 schrieb Chris van der Meijden: > Hey Michael, > > I just installed the "release" Version on LineageOS 19.1 > (Android 12) without Google components. > > The vehicle setup was without any troubles. I could > select the yellow VW e-UP image without crashing. > > The App version is set wrong under "Vehicle info" > (3.19.1, 2021122401). > > Everything seems to be faster than before. > > When I change the checkbox on "Track vehicle" under > "Position" the App crashes. But after a new start of the > app the value of the checkbox has changed. > > Perhaps this first impression is of some help. > > Regards > > Chris > > Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael > Balzer: > > > > > > > Everyone, > > > > I'm currently working on the next Android release > > including KustomWidget support and a native app widget > > based on the old Automagic gauge widget. > > > > Automagic has been dead for some time now, and it keeps > > crashing on Androids >= 7. > > > > My changes so far are in the hub, APK builds are > > available here: > > > > * https://dexters-web.de/f/tw-beta/OpenVehicleApp-
> > * debug build for extended logging: https://dexters- web.de/f/tw- > > beta/OpenVehicleApp-22092401-debug.apk > > > > There's an issue with the App related to Android >= 10 > > though, which I haven't found yet. It's been reported > > in the forum: > > > > * https://www.openvehicles.com/node/3410 > > I could use some help with that, I've got no idea other > > than blaming Android. > > I've seen the effect in my emulator tests, and it seems > > to occur more frequently with non-roadster images. > > > > Regards, > > Michael > > > > _______________________________________________ > > OvmsDev mailing list > > OvmsDev@lists.openvehicles.com > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Hi, have installed the new app. One thing I have noticed, is that the rear door open is not showing at all. I thought it was that the signals weren't being read correctly (I'm making good progress on the Ioniq 5 module), but it turns out those values are correct - but just not showing on the app. Also related - the front door opening icon doesn't quite line up with the main image (it's showing a bit down from the door on the Hyundai Ioniq image). What's the process for getting a new Image for the Ioniq 5? I saw somebody suggested the module being able to provide it, which would be good. //.ichael On Sun, 25 Sept 2022 at 02:10, Michael Balzer <dexter@expeedo.de> wrote:
Everyone,
Regards, Michael
Michael, the default image set only provides generic front doors. Follow the wiki guide to integrate extended / model specific images: https://github.com/openvehicles/Open-Vehicle-Android/wiki/Adding-Vehicle-Ima... Regards, Michael Am 27.09.22 um 05:38 schrieb Michael Geddes:
//.ichael
Everyone,
* https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk * debug build for extended logging: https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk
Regards, Michael
Hi Michael My KWGT widget switches constantly between displaying the information (3 "broadcast" text elements and one image) and "Loading ...": Could it be, that we need some kind of buffer in the ApiService.java in case the app is not able to provide the actual intent array due to bad connectivity from the app to the server? Regards Chris
I don't see this effect on my KWGT test devices with my test widgets. The car data already is buffered twice, once on the server and once in the App. I added Kustom broadcasts on push notifications and command results, the one on command results doesn't include the standard car data yet. Maybe that breaks some of your widget formulas? To try, add… intent.putExtras(mCarData.getBroadcastData()); …in ApiService.onResultCommand() before the sends. Regards, Michael Am 28.09.22 um 08:43 schrieb Chris van der Meijden:
Hi Michael
Regards
Chris
I added intent.putExtras(mCarData.getBroadcastData()); on line 524 in api/ApiService.java without success. I still saw the switching to "Loading" and back. I deleted all my "$br(ovms, ...)$" and it still shows the "Loading" beh auviour. So, sorry, it seems to be a LineagOS problem. Am Mittwoch, dem 28.09.2022 um 13:33 +0200 schrieb Michael Balzer:
Regards, Michael
Hi Michael
Regards
Chris
I foud the problem. I was using the KWGT AOSP version to be able to import a preset. But that version tries to load ads. And as it blocked KWGT with my firewall, well, it tried to load an ad and got stuck on "Loading". I'm back to the non AOSP, non Pro version and made the widget again and everything runs fine now. Sorry for the waves ... Chris Am Mittwoch, dem 28.09.2022 um 14:22 +0200 schrieb Chris van der Meijden:
I added
I deleted all my "$br(ovms, ...)$" and it still shows the "Loading" b ehauviour.
Am Mittwoch, dem 28.09.2022 um 13:33 +0200 schrieb Michael Balzer: I don't see this effect on my KWGT test devices with my test widgets.
Regards, Michael
Hi Michael
Regards
Chris
Ok, I have had a look at that, and hopefully can get an Ioniq 5 image going. Is it possible to change the tyre pressure display to kPa? Michael On Tue, 27 Sept 2022, 11:38 am Michael Geddes, <frog@bunyip.wheelycreek.net> wrote:
//.ichael
Everyone,
Regards, Michael
Pressure can be set to bar from the car page menu (1 bar = 100 kPa). Regards, Michael Am 04.10.22 um 06:35 schrieb Michael Geddes:
//.ichael
Everyone,
Regards, Michael
Chris van der Meijden -
Michael Balzer -
Michael Geddes -
van der Meijden, Chris
