Seems we are ready for another release. I made a number of fixes yesterday, and maybe able to make a few more today, then I am done and ready to release 3.2.009. Anything else to put in this? Regards, Mark
Am 02.02.20 um 02:13 schrieb Mark Webb-Johnson:
OK, nothing open here. Regards, Michael
Regards, Mark _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
I’ve tagged 3.2.009 based on where we are today, and built on my edge. If no problems reported overnight, I’ll push to EAP tomorrow. Regards, Mark.
Regards, Michael
My module updated to 3.2.008-134-ge6ac0c7 last night (2am local), and did the single update as it should. m.version is consistent with this. The module sees your 3.2.009-1-g92cc5ed as available. Presume it will update tonight. So, all "go" from this console. Greg Mark Webb-Johnson wrote:
Anything else to put in this? OK, nothing open here.
Regards, Michael
Regards, Mark _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Um, I just noticed that all the metrics except for the 12v battery voltage are zero. The car is awake and charging right now, but hasn't been driven since the software update to 3.2.008-134-ge6ac0c7, if that matters. I believe the TPMS metrics don't update until it's driven, but I should be seeing the temps. All gray and zero. I tried putting the car in Drive (just sitting there), and the TPMS data came on after a few minutes. But the rest of the metrics are still zero and gray. The VDS shows the correct temps, and is operating normally. Oops? Greg Greg D. wrote:
Greg
Regards, Michael
Greg, On the server I am seeing you running 3.2.008-134-ge6ac0c7/ota_0/edge and all the data looks fine. For example: ovms> metric list v.b ... Vehicle Response: v.b.12v.voltage 13.04V v.b.12v.voltage.ref 12.6V v.b.cac 136.777Ah v.b.consumption 0Wh/km v.b.current 1A v.b.health CAC 136.78Ah SOC 94% LIM 83% MIN 83% MAX 85% v.b.p.level.max 85% v.b.p.level.min 83% v.b.power 0.3985kW v.b.range.est 196.339km v.b.range.ideal 255.885km v.b.soc 95% v.b.soh 82.9213% ovms> metric list v.c ... Vehicle Response: v.c.charging no v.c.climit 24A v.c.current 0A v.c.duration.full 14Min v.c.kwh 9kWh v.c.mode standard v.c.pilot yes v.c.state done v.c.substate powerwait v.c.time 0Sec v.c.voltage 0V The temperature bug for Roadster is a known issue, and is fixed in 4082bb2a (and released in 3.2.009). I triggered an update for you (to 3.2.009-1-g92cc5ed), and that installed ok. I’ll try to find out if the temperature bug is fixed now or not. Regards, Mark.
Oops?
Greg
Greg
Regards, Michael
Hi Mark, Saw the update Metrics look good now. What changed? The module is reporting another update is pending for tonight. 3.2.009-2-g39cdb7e. Same version number... Greg On February 2, 2020 4:24:35 PM PST, Mark Webb-Johnson <mark@webb-johnson.net> wrote:
Greg,
Oops?
Greg
Greg
Regards, Michael
-- This space for rent...
Not sure. It was like that when I got to it. Firmware: 3.2.009-2-g39cdb7e/ota_0/edge (build idf v3.3-beta3-775-gdc1ca69 Feb 3 2020 09:00:33) Running partition: ota_0 Boot partition: ota_0 Factory image: 3.1.001 OTA_O image: 3.2.009-2-g39cdb7e OTA_1 image: 3.2.009-1-g92cc5ed Server Available: 3.2.009-2-g39cdb7e (no update required) I think it all looks ok. You have the latest. It now looks ok, and probably worth squeezing these last few updates in. So, I will make a 3.2.010 now and release to EAP. Regards, Mark.
On 3 Feb 2020, at 10:49 AM, Greg D <gregd2350@gmail.com> wrote:
Hi Mark,
Greg
On February 2, 2020 4:24:35 PM PST, Mark Webb-Johnson <mark@webb-johnson.net> wrote: Greg,
On 3 Feb 2020, at 5:08 AM, Greg D. <gregd2350@gmail.com <mailto:gregd2350@gmail.com>> wrote:
Oops?
Greg
Greg
On 2 Feb 2020, at 6:21 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Regards, Michael
Regards, Mark _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
-- This space for rent... _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Probably me triggering your update (a few minutes before I sent that eMail ). The normal update should be at 2am. I normally use ‘ota status’ to see what is available/installed. Regards, Mark.
On 3 Feb 2020, at 12:46 PM, Greg D. <gregd2350@gmail.com> wrote:
Hmmpf. So, when are updates supposed to happen? I have it set to "2" in the GUI, presumably 2am local time. The update to 3.2.008-134 occurred at 02:05 on 2/2/2020. Then the android app says it updated to 3.2.009-1 at 16:15. If that wasn't you, then why the second update at that time?
Currently the app says that 3.2.009-2 is available, as of 17:02. But the GUI says that I'm running 3.2.009-2 (the app has no record of this), and that 3.2.010 is available. When did you trigger the update?
Confused...
Greg
On 3 Feb 2020, at 10:49 AM, Greg D <gregd2350@gmail.com <mailto:gregd2350@gmail.com>> wrote:
Hi Mark,
Greg
On February 2, 2020 4:24:35 PM PST, Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> wrote: Greg,
Oops?
Greg
Greg
> On 2 Feb 2020, at 6:21 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: > > Am 02.02.20 um 02:13 schrieb Mark Webb-Johnson: >> Seems we are ready for another release. I made a number of fixes yesterday, and maybe able to make a few more today, then I am done and ready to release 3.2.009. >> >> Anything else to put in this? > OK, nothing open here. > > Regards, > Michael > > >> Regards, Mark >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev> > -- > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev> _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
-- This space for rent... _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
Greg D -
Greg D. -
Mark Webb-Johnson -
