Hi first of all I want to introduce myself. I'm a new Twizy 45 owner and a software developer (or at least I was ages ago :-) ). Actually I spend my free time doing some prototyping using Arduino and, now, doing some Twizy hacking as well. I'm interested in contributing at the project as developer and tester for twizy 45. My github id is gluca (https://github.com/gluca). Now the firmware questions: When upgrading firmware which branch should I use? Do I have to rebuild or I will find a pre-build hex file for twizy? In any case, I've downloaded the microchip project and switched to the V2_RT_Production configuration and it builds (I had some trouble in finding the C18 compiler for osx but i've found a 3.40 version). Now I've enabled all switches (OVMS_TWIZY_CFG and OVMS_TWIZY_BATTMON) and created a new configuration (V2_RT_Production_fullfeature). I will use my branch for experiments. Now the dev parts: 1) M2M Sims. I live in Italy and M2M data plan are not (yet?) accessible at reasonable rates. In any cases M2M data plans are "data plan" only and typically do not include sms (at least sending sms). I was wondering if some other way can be provided for alerts and other messaging needs. 2) Twizy 45 settings. I've read both user guide and all the ods files and I think I've found some errors on ods. Specifically ts map break/neutral rpm values for twizy 80 and 45 seems swapped. 3) Roadmap. Is there any roadmap for twizy functionalities I can partecipate in developing/testing? Gianluca Magalotti ITIL V3 Certified email: gianluca@magalotti.net Mob: +39 340 7418648 Mob: +39 3474 3474 25 Linkedin: http://www.linkedin.com/in/gianlucamagalotti/
Gianluca, welcome :-) Branch "master" is the current main branch, if there is a beta version available in another branch, there will be a note on this list. You don't need to rebuild yourself, I provide flashable releases in the german Twizy forum: http://www.vectrix-forum.de/index.php?option=com_kunena&Itemid=72&func=view&... The Twizy 45 default settings have been provided by another german forum member, so I cannot check them myself. The values for T80 are definitely correct. The T45 TSMAP brake/neutral rpm values seem to be right, as the T45 has a higher gear ratio. I thought the drive rpms could be wrong, but as the drive map is normally flat 100% that normally has no effect so could have slipped through at Renault/SEVCON. There is no formal roadmap, and my firmware todo list only contains nice2haves, most of them maybe not implementable. I'll write an extract later on. What's lacking most from my point of view is Twizy specific support on the App. The remaining firmware ROM space will probably also be needed to implement the necessary CFG commands for the App. Regards, Michael Am 02.06.2014 19:01, schrieb Gianluca Magalotti:
*Gianluca Magalotti* ITIL V3 Certified
email: gianluca@magalotti.net <mailto:gianluca@magalotti.net> Mob: +39 340 7418648 Mob: +39 3474 3474 25 Linkedin: http://www.linkedin.com/in/gianlucamagalotti/
-- Michael Balzer * Paradestr. 8 * D-42107 Wuppertal Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
Gianluca Magalotti -
