Anyone who knows what happens here? It keeps rebooting. Last boot was 240 second(s) ago Time at boot: 2019-06-08 07:04:18 GMT This is reset #193 since last power cycle Detected boot reason: Crash (12/12) Crash counters: 193 total, 0 early Last crash: Alloca exception on core 0 Registers: PC : 0x4009251a PS : 0x00060834 A0 : 0x80090666 A1 : 0x3ffc8d90 A2 : 0x3ffc9b64 A3 : 0x3ffc9528 A4 : 0x3ffc950c A5 : 0x00000001 A6 : 0x000000fe A7 : 0x3fa21d38 A8 : 0x3ffc9528 A9 : 0x00000018 A10 : 0x3ffc9528 A11 : 0x00000018 A12 : 0x3f40c407 A13 : 0x3f40c288 A14 : 0x000000fe A15 : 0x00000001 SAR : 0x00000004 EXCCAUSE: 0x00000005 EXCVADDR: 0x00000000 LBEG : 0x40099439 LEND : 0x40099449 LCOUNT : 0xffffffff Backtrace: 0x4009251a 0x40090663 0x4008ef17 0x4008ef89 0x40084693 0x40084781 0x401138de 0x401029af 0x400931c3 0x4009320b 0x40084179 0x400845b1 0x4000bec7 0x4019c70d 0x401a2342 0x40128887 0x40128947 0x4024bf49 0x400e7f19 0x400e7f7d 0x400e76b1 0x400f0dc9 0x4009117b 0x40128887 0x40128947 0x402! 4bf49 0x4 00e7f19 0x400e7f7d 0x400e76b1 0x400f0dc9 0x4009117b Version: 3.2.002-65-g02a07a2/ota_0/edge (build idf v3.1-dev-2835-g1512694 May 17 2019 00:00:19) Firmware: 3.2.002-65-g02a07a2/ota_0/edge (build idf v3.1-dev-2835-g1512694 May 17 2019 00:00:19) Running partition: ota_0 Boot partition: ota_0 Factory image: 3.1.010-5-g00a770e1-dirty OTA_O image: 3.2.002-65-g02a07a2 OTA_1 image: 3.1.011-387-g739dbf49-dirty Regards, Stein Arne Sordal
Please check your logs at verbose level for details on the crash point. Regards, Michael Am 08.06.19 um 09:12 schrieb ovms:
Anyone who knows what happens here? It keeps rebooting. Last boot was 240 second(s) ago Time at boot: 2019-06-08 07:04:18 GMT This is reset #193 since last power cycle Detected boot reason: Crash (12/12) Crash counters: 193 total, 0 early Last crash: Alloca exception on core 0 Registers: PC : 0x4009251a PS : 0x00060834 A0 : 0x80090666 A1 : 0x3ffc8d90 A2 : 0x3ffc9b64 A3 : 0x3ffc9528 A4 : 0x3ffc950c A5 : 0x00000001 A6 : 0x000000fe A7 : 0x3fa21d38 A8 : 0x3ffc9528 A9 : 0x00000018 A10 : 0x3ffc9528 A11 : 0x00000018 A12 : 0x3f40c407 A13 : 0x3f40c288 A14 : 0x000000fe A15 : 0x00000001 SAR : 0x00000004 EXCCAUSE: 0x00000005 EXCVADDR: 0x00000000 LBEG : 0x40099439 LEND : 0x40099449 LCOUNT : 0xffffffff Backtrace: 0x4009251a 0x40090663 0x4008ef17 0x4008ef89 0x40084693 0x40084781 0x401138de 0x401029af 0x400931c3 0x4009320b 0x40084179 0x400845b1 0x4000bec7 0x4019c70d 0x401a2342 0x40128887 0x40128947 0x4024bf49 0x400e7f19 0x400e7f7d 0x400e76b1 0x400f0dc9 0x4009117b 0x40128887 0x40128947 0x4024bf49 0x400e7f19 0x400e7f7d 0x400e76b1 0x400f0dc9 0x4009117b Version: 3.2.002-65-g02a07a2/ota_0/edge (build idf v3.1-dev-2835-g1512694 May 17 2019 00:00:19) ---------------------------------------------------------------------------------------------------------------------------------------------------------------- Firmware: 3.2.002-65-g02a07a2/ota_0/edge (build idf v3.1-dev-2835-g1512694 May 17 2019 00:00:19) Running partition: ota_0 Boot partition: ota_0 Factory image: 3.1.010-5-g00a770e1-dirty OTA_O image: 3.2.002-65-g02a07a2 OTA_1 image: 3.1.011-387-g739dbf49-dirty Regards, Stein Arne Sordal
Thanks for the reply Michael. I suddenly remembered that I had set GPS stream to 1 in the app. I set GPS stream to 0 again and there is no longer a problem. Regards, Stein Arne On 2019-06-08 09:53, Michael Balzer <dexter@expeedo.de> wrote: > Please check your logs at verbose level for details on the crash point. > > Regards, > Michael > > > > Am 08.06.19 um 09:12 schrieb ovms: > > > > > > Anyone who knows what happens here? It keeps rebooting. > > > > > > > > Last boot was 240 second(s) ago Time at boot: 2019-06-08 07:04:18 GMT This is reset #193 since last power cycle Detected boot reason: Crash (12/12) Crash counters: 193 total, 0 early Last crash: Alloca exception on core 0 Registers: PC : 0x4009251a PS : 0x00060834 A0 : 0x80090666 A1 : 0x3ffc8d90 A2 : 0x3ffc9b64 A3 : 0x3ffc9528 A4 : 0x3ffc950c A5 : 0x00000001 A6 : 0x000000fe A7 : 0x3fa21d38 A8 : 0x3ffc9528 A9 : 0x00000018 A10 : 0x3ffc9528 A11 : 0x00000018 A12 : 0x3f40c407 A13 : 0x3f40c288 A14 : 0x000000fe A15 : 0x0000000! 1 SAR : 0 x00000004 EXCCAUSE: 0x00000005 EXCVADDR: 0x00000000 LBEG : 0x40099439 LEND : 0x40099449 LCOUNT : 0xffffffff Backtrace: 0x4009251a 0x40090663 0x4008ef17 0x4008ef89 0x40084693 0x40084781 0x401138de 0x401029af 0x400931c3 0x4009320b 0x40084179 0x400845b1 0x4000bec7 0x4019c70d 0x401a2342 0x40128887 0x40128947 0x4024bf49 0x400e7f19 0x400e7f7d 0x400e76b1 0x400f0dc9 0x4009117b 0x40128887 0x40128947 0x4024bf49 0x400e7f19 0x400e7f7d 0x400e76b1 0x400f0dc9 0x4009117b Version: 3.2.002-65-g02a07a2/ota_0/edge (build idf v3.1-dev-2835-g1512694 May 17 2019 00:00:19) Firmware: 3.2.002-65-g02a07a2/ota_0/edge (build idf v3.1-dev-2835-g1512694 May 17 2019 00:00:19) Running partition: ota_0 Boot partition: ota_0 Factory image: 3.1.010-5-g00a770e1-dirty OTA_O image: 3.2.002-65-g02a07a2 OTA_1 image: 3.1.011-387-g739dbf49-dirty > > > > > > > > Regards, > > > > Stein Arne Sordal > > > > > > _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com (mailto:Ovm! sDev@list s.openvehicles.com) http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > > -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
It shouldn't crash from GPS streaming though, so it would still make sense to share the logs. Regards, Michael Am 08.06.19 um 09:57 schrieb ovms:
Regards, Michael
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Michael Balzer -
ovms
