Hi I get this error when trying to compile 3.2.005 I have done everything in the developer guide. $ make app CXX build/can/src/canlog_tcpserver.o In file included from D:/Users/Tipe/msys32/home/Tipe/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/simcom.h:34:0, from D:/Users/Tipe/msys32/home/Tipe/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_peripherals.h:67, from D:/Users/Tipe/msys32/home/Tipe/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/canlog_tcpserver.cpp:37: D:/Users/Tipe/msys32/home/Tipe/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/gsmpppos.h:43:30: fatal error: netif/ppp/pppapi.h: No such file or directory compilation terminated. make[1]: *** [/home/Tipe/esp/esp-idf/make/component_wrapper.mk:286: src/canlog_tcpserver.o] Fel 1 make: *** [D:/Users/Tipe/msys32/home/Tipe/esp/esp-idf/make/project.mk:468: component-can-build] Fel 2 Regards
Solved it. It was not enough to update esp-idf. Had to clone a fresh one. Regards TIMO PENTTILÄ Från: OvmsDev <ovmsdev-bounces@lists.openvehicles.com> För Timo Penttilä Skickat: den 30 september 2019 20:53 Till: ovmsdev@lists.openvehicles.com Ämne: [Ovmsdev] Error compiling 3.2.005 Hi I get this error when trying to compile 3.2.005 I have done everything in the developer guide. $ make app CXX build/can/src/canlog_tcpserver.o In file included from D:/Users/Tipe/msys32/home/Tipe/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/simcom.h:34:0, from D:/Users/Tipe/msys32/home/Tipe/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_peripherals.h:67, from D:/Users/Tipe/msys32/home/Tipe/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/canlog_tcpserver.cpp:37: D:/Users/Tipe/msys32/home/Tipe/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/gsmpppos.h:43:30: fatal error: netif/ppp/pppapi.h: No such file or directory compilation terminated. make[1]: *** [/home/Tipe/esp/esp-idf/make/component_wrapper.mk:286: src/canlog_tcpserver.o] Fel 1 make: *** [D:/Users/Tipe/msys32/home/Tipe/esp/esp-idf/make/project.mk:468: component-can-build] Fel 2 Regards
Timo Penttilä
