Scan and discover process for 29bits PID
Hi, Thanks to all the help you provide me here, I was able to identify most of the 11bits ECU with broadcast request and SavvyCAN, and relative PID with the PID scanner.I am a bit confused how I can scan ECU/PID with the extended mode (29 bits). How can I do the same kind of investigation and scanning with the extended mode ? Didier
Didier, support for CAN extended frame mode hasn't yet been implemented on the RE scanner or the OBD poller. As I wrote before, that's totally rare in vehicles, there wasn't any need to support this up to now. If you need it, you're welcome to implement it. But I doubt you need it. You can possibly check by sending some strategic CAN extended frames manually, see command "can can1 tx extended". Regards, Michael Am 25.01.21 um 19:38 schrieb didier@ernotte.com:
Hi,
Thanks to all the help you provide me here, I was able to identify most of the 11bits ECU with broadcast request and SavvyCAN, and relative PID with the PID scanner. I am a bit confused how I can scan ECU/PID with the extended mode (29 bits). How can I do the same kind of investigation and scanning with the extended mode ?
Didier
didier@ernotte.com -
