Re: [Ovmsdev] Coding help
Thanks Henrik every bit helps Regards Shane
On 3 Apr 2021, at 12:33, henrik.scheel@spjeldager.dk wrote:
Each byte is a cell-bundle voltage, and you simply multiply the byte value with 0.02
See https://github.com/langemand/SoulEVSpy/blob/master/app/src/main/java/com/evr...
Best regards, Henrik -- Best regards / venlig hilsen Henrik Scheel Mobil: +45 2720 9828
-------- Oprindelig besked -------- Fra: ovmsdev-request@lists.openvehicles.com Dato: lør. d. 3. apr. 2021 13.02 Til: ovmsdev@lists.openvehicles.com Emne: OvmsDev Digest, Vol 111, Issue 9 Send OvmsDev mailing list submissions to ovmsdev@lists.openvehicles.com
To subscribe or unsubscribe via the World Wide Web, visit http://lists.openvehicles.com/mailman/listinfo/ovmsdev or, via email, send a message with subject or body 'help' to ovmsdev-request@lists.openvehicles.com
You can reach the person managing the list at ovmsdev-owner@lists.openvehicles.com
When replying, please edit your Subject line so it is more specific than "Re: Contents of OvmsDev digest..."
Today's Topics:
1. Re: Coding help (Michael Balzer)
Message: 1 Date: Sat, 3 Apr 2021 13:02:06 +0200 From: Michael Balzer <dexter@expeedo.de> To: ovmsdev@lists.openvehicles.com Subject: Re: [Ovmsdev] Coding help Message-ID: <53c8b247-77d8-b272-5c6d-a815c5aa413f@expeedo.de> Content-Type: text/plain; charset="utf-8"; Format="flowed"
OVMS# obd can1 request device -t1000 7e4 7ec 2102 7e4[7ec] 2102: Response: ff ff ff ff c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c5 | ................ c5 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 | ................ c4 c4 c4 c4???????????????????????????????????? | ....
OVMS# obd can1 request device -t1000 7e4 7ec 2103 7e4[7ec] 2103: Response: ff ff ff ff c4 c4 c4 c4 c4 c4 c4 c5 c5 c4 c4 c4 | ................ c4 c4 c4 c4 c4 c5 c5 c5 c4 c5 c5 c5 c4 c5 c4 c4 | ................ c5 c4 c4 c4???????????????????????????????????? | ....
OVMS# obd can1 request device -t1000 7e4 7ec 2104 7e4[7ec] 2104: Response: ff ff ff ff c4 c4 c5 c4 c4 c4 c4 c4 c4 c4 c4 c4 | ................ c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 c4 | ................ c4 c5 c4 c4???????????????????????????????????? | ....
Your voltages obviously are 16 bit values, so you'll need to use RXB_UINT16() and multiply your loop index by 2.
Regards, Michael
Am 03.04.21 um 12:04 schrieb Shane @ Kilve Engineering:
Hi has anyone got a sample of the data for the cell voltages on the ioniq vfl just so I can see how the macro is handling it? Or is it played out the same as below?
Regards Shane
On 29 Mar 2021, at 22:20, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Shane,
Am 29.03.21 um 20:17 schrieb Shane @ Kilve Engineering:
can any one tell me what the "v.e.c.login" is and is it need for something to work?
v.e.c.config yes = ECU/controller in configuration state
It's not used by the framework currently.
also any one with any ideas how to deal with cell voltages in a string this long? ?took me blumim ages to find the bms when the tx and rx are 128 address apart!!
748[7c8]:e113 10 90 10 92 10 93 10 93 10 8e 10 92 10 8f 10 90 10 92 10 6c 10 93 10 93 10 8f 10 91 10 92 10 92 10 92 10 92 10 92 10 92 10 90 10 8e 10 90 10 92 10 8d 10 90 10 91 10 8f 10 8e 10 8f 10 91 10 90 10 90 10 91 10 8e 10 91 10 8e 10 91 10 90 10 8e 10 90 10 92 10 90 10 94 10 91 10 91 10 93 10 90 10 91 10 90 10 8f 10 93 10 92 10 8e 10 90 10 91 10 8b 10 92 10 90 10 91 10 8e 10 90 10 90 10 90 10 91 10 90 10 8f 10 90 10 90 10 8e 10 92 10 8e 10 91 10 89 10 91 10 91 10 91 10 8d 10 8f 10 8d 10 86 10 8a 10 8e 10 8f 10 91 10 90 10 92 10 94 10 88 10 8f 10 94 10 91 10 91 10 91 10 93 10 91 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Simply loop over the cells contained. Have a look at the buffer macro utils, e.g.: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master...
Regards, Michael
Shane
On 5 Mar 2021, at 20:45, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Shane,
OvmsVehicle::PollSetPidList(m_can1, obdii_polls); ? ? OvmsVehicle::PollSetState(0);
needs to be done in your vehicle init, i.e. the constructor after RegisterCanBus().
Please read the vehicle_obdii module source for a complete polling example.
Regards, Michael
Am 05.03.21 um 17:59 schrieb Shane @ Kilve Engineering:
Thanks Michael,
Had a try and ended up with this bit added but return anything
Where am I going wrong?
Shane
#include "ovms_log.h" *static**const**char**TAG= "v-edeliver3";
#include "vehicle_edeliver3.h" #include "metrics_standard.h"
*namespace*? {
*const*OvmsVehicle::poll_pid_tobdii_polls[] = { ? ? { 0x7e3, 0x7eb, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0xf194, { 10, 10, 10, 10 }, 0, ISOTP_STD }, //VIN ? ? { 0x7e3, 0x7eb, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0xe003, { 10, 10, 10, 10 }, 0, ISOTP_STD }, //SOH POLL_LIST_END }; };
OvmsVehicleEdeliver3::OvmsVehicleEdeliver3() ? { ? ? ESP_LOGI(TAG, "Start eDeliver3 vehicle module");
RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS); ? }
OvmsVehicleEdeliver3::~OvmsVehicleEdeliver3() ? { ? ? ESP_LOGI(TAG, "Stop eDeliver3 vehicle module");
memset(m_vin, 0, *sizeof*(m_vin)); ? }
//testing polls
*void*OvmsVehicleEdeliver3::IncomingPollReply( ?? canbus* bus, uint16_t type, uint16_t pid, uint8_t* data, uint8_t length, uint16_t mlremain) { string& rxbuf = med_obd_rxbuf;
OvmsVehicle::PollSetPidList(m_can1, obdii_polls); OvmsVehicle::PollSetState(0);
// init / fill rx buffer: *if* (m_poll_ml_frame == 0) { rxbuf.clear(); rxbuf.reserve(length + mlremain); ?? } rxbuf.append((*char**)data, length); *if* (mlremain) *return*;
// complete: *switch* (pid) { *case* 0xe003: { *unsigned* *int* soh_raw = ((*unsigned* *int*)rxbuf[0] << 8) | (*unsigned* *int*)rxbuf[1]; *float* soh = soh_raw / 10; StdMetrics.ms_v_bat_soh->SetValue(soh); *break*; ?? ? } ?? } }
// end testing polls
> On 5 Mar 2021, at 12:37, Michael Balzer <dexter@expeedo.de > <mailto:dexter@expeedo.de>> wrote: > > Shane, > > on OBD polling basics: > http://lists.openvehicles.com/pipermail/ovmsdev/2020-December/014758.html > > Regards, > Michael > > > Am 04.03.21 um 19:45 schrieb Shane @ Kilve Engineering: >> Good evening Michael, >> >> Or any one that has the time to help, >> >> Ive now successfully retrieved as much info as I can without >> polling any info for the maxus, but I have have now found an ecu >> that responds to pid requests. >> >> For example if I use the obdii pid scanner I get the loads of >> data back and I?ve decoded some of it, just need a bit of >> guidance how to write the code to get the same info >> >> A part of a scan is as follows >> >> Scan complete (7e3 e000-e100) >> Scan started : 2021-03-04 18:32:36 GMT >> Last response: 2021-03-04 18:32:39 GMT >> 7e3[7eb]:e000 00 >> 7e3[7eb]:e001 64 >> 7e3[7eb]:e002 4b >> 7e3[7eb]:e003 26 bc >> 7e3[7eb]:e004 00 07 >> 7e3[7eb]:e005 2f >> 7e3[7eb]:e006 2e >> 7e3[7eb]:e007 02 00 >> 7e3[7eb]:e008 01 ff >> 7e3[7eb]:e009 02 00 >> 7e3[7eb]:e010 02 00 >> >> I know that e003 is SOH = 26bc = 9916 /100 = 99.16% SOH >> And e002 is a temp 4b = 75 / 10 = 7.5 degrees >> >> So if some one can help me with an example of how to correctly >> code this one I can work out the rest, >> >> Ive looked through various vehicles but everyone uses different >> methods and I can?t seem to get one to work for me. >> >> Any help much appreciated >> >> Shane >> >>> On 15 Feb 2021, at 08:05, Michael Balzer <dexter@expeedo.de >>> <mailto:dexter@expeedo.de>> wrote: >>> >>> Shane, >>> >>> I forgot to mention: if you're working on a new vehicle module, >>> you'll also need to start the bus somewhere in your >>> initialization code. Example: >>> >>> ? RegisterCanBus(1, CAN_MODE_ACTIVE, CAN_SPEED_500KBPS); >>> >>> Regards, >>> Michael >>> >>> >>> Am 15.02.21 um 08:36 schrieb Michael Balzer: >>>> Shane, >>>> >>>> Am 14.02.21 um 16:42 schrieb Shane @ Kilve Engineering: >>>>> can any one help me with a bit of code to retrieve ve some >>>>> data from ecu can1/6f2? 00 4c 00 00 01 97 bc 00 as i cant >>>>> poll this ecu it just broadcasts when its active, ive tried >>>>> polling it but does not respond, i need to choose one byte >>>>> and allocate it to a PID. >>>> >>>> I don't know what you mean by "allocating a byte to a PID", >>>> but if you want to process frames received directly, simply >>>> override IncomingFrameCan1() (or ?2/3/4 depending on your bus). >>>> >>>> Reduced example: >>>> >>>> void OvmsVehicleXYZ::IncomingFrameCan1(CAN_frame_t *p_frame) >>>> { >>>> ? uint8_t *d = p_frame->data.u8; >>>> >>>> ? switch (p_frame->MsgID) >>>> ? { >>>> ??? case 0x6f2: >>>> ????? // for example, assuming the SOC is in byte 1: >>>> StdMetrics.ms_v_bat_soc->SetValue(d[1]); >>>> ????? break; >>>> ? } >>>> } >>>> >>>> If you're outside a vehicle context, you can register your own >>>> CAN receiver by creating a queue and calling >>>> MyCan.RegisterListener(). See the vehicle module for an example. >>>> >>>> Regards, >>>> Michael >>>> >>> > > -- > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > <mailto:OvmsDev@lists.openvehicles.com> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
henrik.scheel@spjeldager.dk -
Shane@Kilve-Engineering.co.uk
