Re: [Ovmsdev] v3.1.5 Android App to Google Play
Hi Mark, Thank you for the update. Unfortunately there are still some french translation strings I provided you missing. Do you want me to give you the latest strings again? Denis. Mark Webb-Johnson <mark@webb-johnson.net> a écrit :
The v3.1.5 Android App has been released to Google Play.
Enhancements are minor and primarily include support for the display of battery CAC values in the vehicle info sheet. The logo artwork has also been updated, to better reflect the multiple vehicle support we now have available.
Denis, Whoops, sorry about that. I thought I had everything. The only thing I added this time was CAC, and as that doesn't need to be / can't be translated. Yes, please send in the latest strings, and I'll get them merged in. Regards, Mark. On 2 Sep, 2013, at 3:50 AM, Denis KRAUTH <denis.krauth@gmail.com> wrote:
Hi Mark,
Denis.
Hi Mark, Here is my latest values-fr\strings.xml file for the French translation. The missing strings in the latest Google Play release I noticed are those relative to the vehicle view: textMOTOR, textPEM, textBATTERY etc. I also improved some strings for better UI-fitting as they were to long. Denis -----Message d'origine----- De : ovmsdev-bounces@lists.teslaclub.hk [mailto:ovmsdev-bounces@lists.teslaclub.hk] De la part de Mark Webb-Johnson Envoyé : lundi 2 septembre 2013 03:08 À : OVMS Developers Objet : Re: [Ovmsdev] v3.1.5 Android App to Google Play Denis, Whoops, sorry about that. I thought I had everything. The only thing I added this time was CAC, and as that doesn't need to be / can't be translated. Yes, please send in the latest strings, and I'll get them merged in. Regards, Mark. On 2 Sep, 2013, at 3:50 AM, Denis KRAUTH <denis.krauth@gmail.com> wrote:
Hi Mark,
Denis.
Denis, I've put that in, and pushed to github. I'll include it in the next version (probably later this week). Regards, Mark. On 2 Sep, 2013, at 7:33 PM, "Denis KRAUTH" <denis.krauth@gmail.com> wrote:
Hi Mark,
Denis
Denis,
Hi Mark,
Denis.
_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <strings.xml>_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
While waiting for the GeoSIM guys to figure out the SMS problem in Sweden, I am testing the OVMS with a long forgotten card with a Swedish operator Tele2, that I managed to get to work... or sort of. The initialization seems to go ok - the OVMS gets to the point of 1 green blink, and then after 2 such normal blinks, pulls lots of red blinks and goes back to 3 (or 4) green blinks - I have hard time counting them that fast. I have configured the gprs correctly with internet.tele2.se as an apn, no username, no password. When I send "GPRS?" sms, I get in response the apn name and the other parameters, and the status is "not connected" with (0x42). What does 0x42 mean, and is there anything else I could try?
Hi Nikolay, I've seen this behavior (0x42) a couple of times, usually the first time after registering the module, the GPRS states somethinh like '+ATCHIPSHUT' and then 0x42 In net.h I find #define NET_STATE_NETINITCP 0x42 // Short pause during GPRS TCP reconnect I assume the 0x42 occurs if the GPRS-attach is unsuccessful and the module goes for a retry. When powering up the module I usually get the following led sequnce: Green led 9x - 9x - 9x -> red+green led 1 long -> green led 6x - 5x - 2x- 1x With one of my early Think City-fw builds (on 2.5.1) the module always initialized with green led 6x - 6x - 6x - 4x -1x (no red led) All is OK if the green flashes 1x only (then GSM and GPRS is OK). Can you try your Tele2-SIM in a phone or a computer, to verify you can make GPRS-attach? Are you sure Tele2 has the sufficient coverage at the location you are testing? (make sure the antenna connector is applied correct) /Håkon 2013/9/3 Nikolay Shishkov <nshishkov@yahoo.com>
Denis KRAUTH -
Håkon Markussen -
Mark Webb-Johnson -
Nikolay Shishkov
