I have many problem with my new OVMS (OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600) Now i use the the following fw (3.3.002-31-g3604f462) The crash logs i attached. If i restart the network from my MAC with cable, is see (photo attached) - Warning: cellulars: Cannot restart, as modem driver is not loaded and i get a following for the wi-f many timei: - wifi: bcn_timeout, ap_probe_send_start -- Best wishes: Tamás Kovács
Most of your crashes are stack overflows. You can currently only see the task causing this on the USB terminal, it will be shown in the crash info. Check if your sdkconfig has lower stack sizes than the suggested defaults: OVMS.V3> diff support/sdkconfig.default.hw31 sdkconfig Btw, I currently build my releases with CONFIG_OVMS_SYS_COMMAND_STACK_SIZE=10240 due to the config restore issue. Regards, Michael Am 04.05.22 um 06:11 schrieb Tamás Kovács:
Michael Balzer -
Tamás Kovács
