Re: [Ovmsdev] OvmsDev Digest, Vol 49, Issue 25
nice! Sorry can't help with the developing, since it's not my field of programming. But have you considered setting up a donation for leaf development? there has been a demand for leaf-alternative a long time, and the devs here that worked on it have left. One of the devs Jermey has no leaf no more, so no pushing for the leaf. It's very important that the leaf development now pushes forward to get somewhere and not halt before we get there. How will your code be with the new hardware that is comming? Anyways. I did a poll last year on how many that where interested in changing to a opensource alternative for carwings/nissan connect. and like 30-40 said yes. I estimate that atleast 60 leafs are interested in norway. ps: I think the number for opensource alternative might be even higher now after the Nissan disaster: http://www.troyhunt.com/2016/02/controlling-vehicle-features-of-nissan.html?... I tested the security hole yesterday, and it was wide open. today it's partialy closed. look at the response time before nissan acted on it. it's a disaster. On 21 February 2016 at 05:00, <ovmsdev-request@lists.teslaclub.hk> wrote:
Send OvmsDev mailing list submissions to ovmsdev@lists.teslaclub.hk
To subscribe or unsubscribe via the World Wide Web, visit http://lists.teslaclub.hk/mailman/listinfo/ovmsdev or, via email, send a message with subject or body 'help' to ovmsdev-request@lists.teslaclub.hk
You can reach the person managing the list at ovmsdev-owner@lists.teslaclub.hk
When replying, please edit your Subject line so it is more specific than "Re: Contents of OvmsDev digest..."
Today's Topics:
1. Nissan Leaf Remote Climate Control (Tom Parker)
Message: 1 Date: Sun, 21 Feb 2016 12:16:35 +1300 From: Tom Parker <tom@carrott.org> Subject: [Ovmsdev] Nissan Leaf Remote Climate Control To: OVMS Developers <ovmsdev@lists.teslaclub.hk> Message-ID: <56C8F3D3.2090406@carrott.org> Content-Type: text/plain; charset=utf-8; format=flowed
I got remote climate control on & off working, but only during charge. I've abused the alert and homelink commands for now:
https://carrott.org/git/Open-Vehicle-Monitoring-System.git/commitdiff/84a658...
I can't promise I won't force-push into this branch until it's ready for merging, so if you are from the future you may need to look at the branch
https://carrott.org/git/Open-Vehicle-Monitoring-System.git/shortlog/refs/hea...
Tested on my 2012 Gen 1 JDM Leaf with Carwings (Apparently the TCU and hence Carwings doesn't work in New Zealand due to incompatible cell network).
Next is to investigate the wakeup logic line between the TCU and VCU. I've got http://docslide.us/documents/nissan-leaf-2011-2012-ev-control-system.html which describes two EV System Activation Request Signal connections (on page 88), both on the VCU E63 connector. Pin 96 is from the charger (on page 84) and pin 84 is from the TCU (on page 85).
I'm guessing I can observe how the charger wakes up the VCU and add some GPIO output hardware to the OVMS do the same thing to on the TCU line.
Remote charging will probably work the same way, but I can't test it since the only way I can currently get the car to pay attention to these messages is for it to be charging already.
End of OvmsDev Digest, Vol 49, Issue 25 ***************************************
On 02/25/2016 10:17 PM, Thor wrote:
nice!
Sorry can't help with the developing, since it's not my field of programming. But have you considered setting up a donation for leaf development? there has been a demand for leaf-alternative a long time, and the devs here that worked on it have left. One of the devs Jermey has no leaf no more, so no pushing for the leaf. It's very important that the leaf development now pushes forward to get somewhere and not halt before we get there. Donations of sleep would be helpful, but difficult to arrange.
I expect I'll have remote climate control working in the next couple of weeks. https://carmanuals2.com/brand/nissan/leaf-2012-372 looks like the TCU (AV Page 64) and charger (VC page 24) use different signals to wake up the VCU (charger is 5v, TCU is 12v). I can't promise much more than remote climate control, monitoring of the battery temperature and discovering the source of a clicking relay every 20 seconds or so (I've only seen the clicking relay once, so not sure what is causing that).
How will your code be with the new hardware that is comming? Looking at the leaf support, the CAN setup and the CAN transmit code is obviously hardware dependent. Is there an abstracted CAN tx function lurking somewhere? Something like a sendCanMsg(id, length, data) function? I get that might be difficult on the PIC with the limited stack, but a macro ought to work if that is a problem.
Unless we do a run of special OVMSv2 boards, the Gen 1 Leaf is going to need some fiddly hardware mods for remote control to work. We should add exposed GPIO with suitable over voltage etc protection to the OVMS v3 wish list if it isn't there already. I'm thinking I'll use one of the spare pins on the diag connector on my v2 module so I don't have squeeze another connector onto the case.
Saw that, what were they thinking? Nissan updated the server & app last month was that worldwide? Is the problem with the new system or the old one? Did the old software require credentials? If so, why on earth didn't they carry them over (I see some people have been grumbling about having to re-register). I haven't looked too closely at the OVMS security other than to note RC4 and MD5 are pretty old primitives, and I'd have to look a lot closer at how and why HMAC MD5 is used to comment further. I'm not up on the state of SMS source authentication, is it easy to spoof a source address, or does that really require spoofing the cell network itself which probably means being close to the car? I also wouldn't rule out sniffing the password from an SMS going over the air, but I guess that's not a threat we're going to face very often. As an aside, the following python script might be useful when invoked like so $ download.py https://carmanuals2.com/brand/nissan/leaf-2012-372 https://carmanuals2.com/nissan/ #! /usr/bin/python3 from html.parser import HTMLParser import os.path import re import requests import sys start_url = sys.argv[1] book_parent = sys.argv[2] def get_book(book_url): book_id = book_url.split("-")[-1] download_url = "https://carmanuals2.com/d/" + book_id filename = book_url[len(book_parent):] + ".pdf" if os.path.exists(filename): print("Skipping", download_url, "as", filename, "exists") return print("Saving", download_url, "to", filename) with open(filename, 'wb') as handle: r = requests.get(download_url, stream=True) if not r.ok: raise ValueError(r.response_code) for block in r.iter_content(1024): handle.write(block) class MyHTMLParser(HTMLParser): def handle_starttag(self, tag, attrs): if tag == "a": book_url = list(filter(lambda x: x[0] == 'href', attrs))[0][1] if re.match(".*-[0-9]+$", book_url): if book_url.startswith(book_parent): print(book_url) get_book(book_url) r = requests.get(start_url) parser = MyHTMLParser() parser.feed(r.text) And the following terrible shell script, when run in the directory containing the pdf files will rename the relevant ones so they link together properly: #! /bin/bash for F in * do TITLE=`pdfinfo $F | grep Title | cut -c 17-` if [[ $TITLE == *Config* ]] then NAME=`echo $TITLE | cut -d '(' -f 2 | cut -d '.' -f 1` echo $F $TITLE $NAME.pdf mv $F $NAME.pdf fi done
Thor -
Tom Parker
