When I start wifi client, it looks like it has acquired the link, but not done DHCP to get an address? -- Steve OVMS # wifi mode client Revelstoke Starting WIFI as a client to Revelstoke... I (742914) wifi: wifi firmware version: ebd3e5d I (742914) wifi: config NVS flash: enabled I (742914) wifi: config nano formating: disabled I (742914) wifi: Init dynamic tx buffer num: 16 I (742914) wifi: Init data frame dynamic rx buffer num: 16 I (742914) wifi: Init management frame dynamic rx buffer num: 16 I (742914) wifi: wifi driver task: 3fff1044, prio:23, stack:4096 I (742914) wifi: Init static rx buffer num: 4 I (742914) wifi: Init dynamic rx buffer num: 16 I (742914) wifi: wifi power manager task: 0x3ffe81d8 prio: 21 stack: 2560 I (742924) wifi: mode : sta (30:ae:a4:37:1b:84) I (745344) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1 I (745994) wifi: state: init -> auth (b0) I (746004) wifi: state: auth -> assoc (0) I (746014) wifi: state: assoc -> run (10) I (746054) wifi: connected with Revelstoke, channel 1 I (749014) wifi: pm start, type:0 OVMS # net Interface#0: lo0 (ifup=1 linkup=1) IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1 DNS: None Default Interface: None OVMS #
That is not correct, at all. For a case where you have a wifi STA connection, but no IP address yet, you should see the ‘st’ network interface, but without an IP. In fact, the ‘st’ interface should appear as soon as you start the wifi client. What does ‘wifi status’ show you? Trying to catch mine, between STA connected and IP assigned, this is what I get: OVMS # wifi mode client STA Starting WIFI as a client to STA... I (27218) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0 I (27108) wifi: wifi firmware version: ebd3e5d I (27118) wifi: config NVS flash: enabled I (27118) wifi: config nano formating: disabled I (27118) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (27128) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (27128) wifi: Init dynamic tx buffer num: 16 I (27128) wifi: Init data frame dynamic rx buffer num: 16 I (27138) wifi: Init management frame dynamic rx buffer num: 16 I (27138) wifi: wifi driver task: 3ffe5f94, prio:23, stack:4096 I (27138) wifi: Init static rx buffer num: 4 I (27148) wifi: Init dynamic rx buffer num: 16 I (27148) wifi: wifi power manager task: 0x3ffea128 prio: 21 stack: 2560 I (27218) wifi: mode : sta (re:da:ct:ed:da:ta) OVMS # network Interface#1: st1 (ifup=0 linkup=1) IPv4: 0.0.0.0/0.0.0.0 gateway 0.0.0.0 Interface#0: lo0 (ifup=1 linkup=1) IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1 DNS: None Default Interface: None I (30268) wifi: n:11 0, o:1 0, ap:255 255, sta:11 0, prof:1 I (30938) wifi: state: init -> auth (b0) I (30948) wifi: state: auth -> assoc (0) I (30958) wifi: state: assoc -> run (10) I (30978) wifi: connected with STA, channel 11 OVMS # network Interface#1: st1 (ifup=1 linkup=1) IPv4: 0.0.0.0/0.0.0.0 gateway 0.0.0.0 Interface#0: lo0 (ifup=1 linkup=1) IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1 DNS: None Default Interface: st1 (0.0.0.0/0.0.0.0 gateway 0.0.0.0) I (33968) wifi: pm start, type:0 I (34288) event: sta ip: x.x.x.56, mask: 255.255.255.0, gw: x.x.x.62 I (34288) netmanager: Set DNS#0 8.8.8.8 I (34298) netmanager: Set DNS#1 8.8.4.4 I (34298) netmanager: Interface priority is st1 (x.x.x.56/255.255.255.0 gateway x.x.x.62) I (34308) time: Starting SNTP client I (34318) ovms-mdns: Starting MDNS service I (34318) esp32wifi: WiFi UP with SSID: STUBBY, MAC: re:da:ct:ed:da:ta, IP: x.x.x.56, mask: 255.255.255.0, gw: x.x.x.62 I (34348) webserver: Launching Web Server I (34358) ssh: Launching SSH Server OVMS # network Interface#1: st1 (ifup=1 linkup=1) IPv4: x.x.x.56/255.255.255.0 gateway x.x.x.62 Interface#0: lo0 (ifup=1 linkup=1) IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1 DNS: 8.8.8.8 8.8.4.4 Default Interface: st1 (x.x.x.56/255.255.255.0 gateway x.x.x.62) D (40248) time: ntp (stratum 1 trusted 1) provides time Mon Mar 19 01:03:25 2018 (535294us) UTC OVMS # wifi status WiFi Power: on Mode: Client mode STA SSID: STUBBY MAC: re:da:ct:ed:da:ta IP: x.x.x.56/255.255.255.0 GW: x.x.x.62 Regards, Mark.
DNS: None
Default Interface: None OVMS # _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Here's my wifi status: OVMS # wifi mode client Revelstoke Starting WIFI as a client to Revelstoke... I (316264) wifi: wifi firmware version: ebd3e5d I (316264) wifi: config NVS flash: enabled I (316264) wifi: config nano formating: disabled I (316264) wifi: Init dynamic tx buffer num: 16 I (316264) wifi: Init data frame dynamic rx buffer num: 16 I (316264) wifi: Init management frame dynamic rx buffer num: 16 I (316264) wifi: wifi driver task: 3ffe8390, prio:23, stack:4096 I (316264) wifi: Init static rx buffer num: 4 I (316264) wifi: Init dynamic rx buffer num: 16 I (316264) wifi: wifi power manager task: 0x3ffef838 prio: 21 stack: 2560 I (316274) wifi: mode : sta (30:ae:a4:37:1b:84) I (318694) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1 I (319344) wifi: state: init -> auth (b0) I (319354) wifi: state: auth -> assoc (0) I (319364) wifi: state: assoc -> run (10) I (319394) wifi: connected with Revelstoke, channel 1 I (322364) wifi: pm start, type:0 OVMS # wifi status WiFi Power: on Mode: Client mode STA SSID: Revelstoke MAC: 00:00:00:00:00:00 IP: 0.0.0.0/0.0.0.0 GW: 0.0.0.0 OVMS # net Interface#0: lo0 (ifup=1 linkup=1) IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1 DNS: None Default Interface: None OVMS # My laptop is connected to Revelstoke, so I know it is working. Is there some aspect of auto-start that I need now to have this work? -- Steve On Mon, 19 Mar 2018, Mark Webb-Johnson wrote:
DNS: None
DNS: None
DNS: None
Very bizarre. Nothing in auto should affect this. You’ve tried resetting the module? Can you paste the output of ‘wifi scan’, so we can see the APs in range? Regards, Mark.
DNS: None
DNS: None
DNS: None
DNS: None
Hmmm, I just did a config change for the default log level from WARN to INFO so I could see more of the timing of wifi and MDNS starting, etc. Now the wifi does get an address and the status looks good. Perhaps some subtle timing sensitivity? -- Steve On Mon, 19 Mar 2018, Mark Webb-Johnson wrote:
You've tried resetting the module?
Can you paste the output of 'wifi scan', so we can see the APs in range?
DNS: None
For a case where you have a wifi STA connection, but no IP address yet, you should see the 'st' network interface, but without an IP. In fact, the 'st' interface should appear as soon as you start the wifi client. What does 'wifi status' show you?
DNS: None
DNS: None
DNS: None
For what it's worth, I have the default log level at Info, and have no trouble getting WiFi to connect (with IP). That said, my module is currently in a state where both wifi and modem have IP addresses, but the server can't (or won't) connect. Stopping / starting the V2 server hangs the module (no prompt returned). Repeated the test, and the bad state seems to occur just after the modem gets its IP address. Wifi connected or not, that's the last the module will talk to anything else. Greg Stephen Casner wrote:
DNS: None
DNS: None
DNS: None
DNS: None
Having the same, Actually, I have to stick to client or apclient mode (otherwise it crash reboots), it doesn’t like an empty or non set wifi.ssid.client neither in auto. ------------------------ rst:0xc (SW_CPU_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT) configsip: 156795334, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:4572 load:0x40078000,len:0 load:0x40078000,len:13184 entry 0x40078d38 I (33) ovms_main: Set default logging level for * to WARN E (34) boot: Crash #6 detected E (727) esp32wifi: AutoInit: Wifi client SSID must be specified in wifi.ssid.client Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console OVMS > en Password: Secure mode OVMS # config set auto wifi.ssid.client JaXX <— here I very quickly set wifi.ssid.client before the next crash OVMS # ***ERROR*** A stack overflow in task tiT has been detected. abort() was called at PC 0x4008efb0 on core 1 0x4008efb0: vApplicationStackOverflowHook at /Users/jaxx/Projects/esp-idf/components/esp32/./panic.c:648 Backtrace: 0x4008edc0:0x3ffca860 0x4008ef97:0x3ffca880 0x4008efb0:0x3ffca8a0 0x4008b470:0x3ffca8c0 0x4008d390:0x3ffca8e0 0x4008d346:0x00000002 0x4008edc0: invoke_abort at /Users/jaxx/Projects/esp-idf/components/esp32/./panic.c:648 0x4008ef97: abort at /Users/jaxx/Projects/esp-idf/components/esp32/./panic.c:648 0x4008efb0: vApplicationStackOverflowHook at /Users/jaxx/Projects/esp-idf/components/esp32/./panic.c:648 0x4008b470: vTaskSwitchContext at /Users/jaxx/Projects/esp-idf/components/freertos/./tasks.c:4837 0x4008d390: _frxt_dispatch at /Users/jaxx/Projects/esp-idf/components/freertos/./portasm.S:406 0x4008d346: _frxt_int_exit at /Users/jaxx/Projects/esp-idf/components/freertos/./portasm.S:206 Rebooting... ets Jun 8 2016 00:22:57 ———————— As soon as the modem arrives in RegisteredHom/NetMode, usually under a minute, wifi (pings && web server) becomes mute and ovmsv2 server (using dexters’ won’t refresh). OVMS > simcom SIMCOM Network Registration: RegisteredHome State: NetMode Ticker: 2 User Data: 0 Mux Status: up Open Channels: 4 Framing Errors: 0 Last RX frame: 1 sec(s) ago RX frames: 52 TX frames: 15 PPP Not Connected Last Error: Undefined GPS Status: enabled, required Time: enabled, required NMEA: GPS/GLONASS Connected on channel: #1 OVMS > network Interface#3: pp3 (ifup=1 linkup=1) IPv4: 10.238.244.249/255.255.255.255 gateway 10.64.64.64 Interface#2: ap2 (ifup=1 linkup=1) IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1 Interface#1: st1 (ifup=1 linkup=1) IPv4: 10.33.92.20/255.255.255.0 gateway 10.33.92.1 Interface#0: lo0 (ifup=1 linkup=1) IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1 DNS: 212.27.40.240 212.27.40.241 Default Interface: st1 (10.33.92.20/255.255.255.0 gateway 10.33.92.1) OVMS > (Home being 10.33.92.0/24) JaXX, sorry for not being around btw./. On 19 Mar 2018 at 04:39 +0100, Greg D. <gregd2350@gmail.com>, wrote:
Greg
DNS: None
DNS: None
DNS: None
DNS: None
Try increasing: CONFIG_TCPIP_TASK_STACK_SIZE=5632 I’ve got some new sdkconfig.defaults almost ready and will upload later, so you can compare. Regards, Mark.
On 19 Mar 2018, at 4:56 PM, Julien “JaXX” Banchet <jaxx@jaxx.org> wrote:
Having the same,
Greg
DNS: None
DNS: None
DNS: None
> On 19 Mar 2018, at 8:52 AM, Stephen Casner <casner@acm.org> wrote: > > When I start wifi client, it looks like it has acquired the link, but > not done DHCP to get an address? > > -- Steve > > OVMS # wifi mode client Revelstoke > Starting WIFI as a client to Revelstoke... > I (742914) wifi: wifi firmware version: ebd3e5d > I (742914) wifi: config NVS flash: enabled > I (742914) wifi: config nano formating: disabled > I (742914) wifi: Init dynamic tx buffer num: 16 > I (742914) wifi: Init data frame dynamic rx buffer num: 16 > I (742914) wifi: Init management frame dynamic rx buffer num: 16 > I (742914) wifi: wifi driver task: 3fff1044, prio:23, stack:4096 > I (742914) wifi: Init static rx buffer num: 4 > I (742914) wifi: Init dynamic rx buffer num: 16 > I (742914) wifi: wifi power manager task: 0x3ffe81d8 prio: 21 stack: 2560 > I (742924) wifi: mode : sta (30:ae:a4:37:1b:84) > I (745344) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1 > I (745994) wifi: state: init -> auth (b0) > I (746004) wifi: state: auth -> assoc (0) > I (746014) wifi: state: assoc -> run (10) > I (746054) wifi: connected with Revelstoke, channel 1 > I (749014) wifi: pm start, type:0 > OVMS # net > Interface#0: lo0 (ifup=1 linkup=1) > IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1 > > DNS: None > > Default Interface: None > OVMS # > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.teslaclub.hk > http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Building and flashing ! (Also set logging to info) Gonna put it in the car (despite the passive GPS issue) Will check on it later today, so late for my day job my Hue lights turned off :) BTW, Michael, if there’s any way you want to remotely play with it, if possible, it’s (supposedly) connecting to your server (TWAXXV3), I have 100GB allowance on it ;-) JaXX./. On 19 Mar 2018 at 10:00 +0100, Mark Webb-Johnson <mark@webb-johnson.net>, wrote:
Try increasing:
That didn’t happen :-) https://twitter.com/happyjaxx/status/975675071451844608 On 19 Mar 2018 at 10:07 +0100, Julien “JaXX” Banchet <jaxx@jaxx.org>, wrote:
Uh oh… CAN bus contact failure? I haven't had any issues like that…
Thanks, should not be necessary, but tell me if you've got an issue I should investigate. Regards, Michael Am 19.03.2018 um 11:09 schrieb Julien “JaXX” Banchet:
It went christmas animation nuts as soon as I plugged it on the bus (already contact ON+GO), and went away the second I unplugged it. I admit having left the v2 (which still carries all my profiles, and in case I needed to limit power+recup on the way as it’s been snowing again) My bet is that there where too many CAN terminations on the bus and the dashboard cluster couldn’t see it’s friends, I’ll give it a shot without v2 on my way back home. (Which leads me to believe the termination resistor on my Arduino OBD shields aren’t connected) JB./. On 19 Mar 2018 at 12:43 +0100, Michael Balzer <dexter@expeedo.de>, wrote:
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Do you have a vehicle module defined, with a can bus active? I had a similar thing when I was set to 1Mbps (it should have been 500Kbps). Regards, Mark.
JB./.
That didn’t happen :-) https://twitter.com/happyjaxx/status/975675071451844608 <https://twitter.com/happyjaxx/status/975675071451844608>
On 19 Mar 2018 at 10:07 +0100, Julien “JaXX” Banchet <jaxx@jaxx.org> <mailto:jaxx@jaxx.org>, wrote:
_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk <mailto:OvmsDev@lists.teslaclub.hk> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
Oh!? A wrong CAN speed ? Haven’t though of that. I have RT set, but I do’t know how to look up the speed which is set (besides the defaulted CONFIG_CAN_SPEED_100KBPS=y in sdkconfig, though I suppose the module sets the right speed, right ?) JB./. On 19 Mar 2018 at 13:39 +0100, Mark Webb-Johnson <mark@webb-johnson.net>, wrote:
JB./.
Yeah, the module sets the speed. I suggest to try without a vehicle mode set to auto-start. Regards, Mark P.S. OVMS v3 doesn’t have termination on the can bus.
JB./.
On 19 Mar 2018, at 7:46 PM, Julien “JaXX” Banchet <jaxx@jaxx.org <mailto:jaxx@jaxx.org>> wrote:
JB./.
On 19 Mar 2018 at 12:43 +0100, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>>, wrote:
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk <mailto:OvmsDev@lists.teslaclub.hk> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
The RT module sets the Twizy CAN speed, no need to configure that. I'm pretty sure it's been caused by the v2 hooked to the bus parallel to the v3. Maybe that can work if you only allow one of them to write to the bus. Btw, Arduino CAN shields often need some jumper for termination. Regards, Michael Am 19.03.2018 um 14:01 schrieb Julien “JaXX” Banchet:
JB./.
JB./.
Tried the v3 alone on the bus (leaving module RT, will try ‘none' later on Marks suggestion) Plugged, waited a minute, then put the contact. It didn’t go very well, I hopefully didn’t burst into flames neither :) https://photos.app.goo.gl/rlkUmowR28AAp8Nf2 JB./. On 19 Mar 2018 at 14:22 +0100, Michael Balzer <dexter@expeedo.de>, wrote:
Regards, Michael
JB./.
JB./.
On 19 Mar 2018 at 10:07 +0100, Julien “JaXX” Banchet <jaxx@jaxx.org>, wrote: > > Gonna put it in the car (despite the passive GPS issue)
Have you tried exchanging the OBD cable? I.e. using the one from your v2 module? Am 19.03.2018 um 15:45 schrieb Julien “JaXX” Banchet:
JB./.
Regards, Michael
JB./.
JB./.
Am 19.03.2018 um 11:09 schrieb Julien “JaXX” Banchet: > That didn’t happen :-) > https://twitter.com/happyjaxx/status/975675071451844608 > > On 19 Mar 2018 at 10:07 +0100, Julien “JaXX” Banchet <jaxx@jaxx.org>, wrote: >> >> Gonna put it in the car (despite the passive GPS issue) > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.teslaclub.hk > http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
I will try the one from v2 but, it’s deeply hidden in the car body :) it’s gonna take me some excavation time :) (yeah, in Paris, people imagine you have interesting stuff to steal on a car that has no windows, so the ovms is pretty well hidden) On 19 Mar 2018 at 17:24 +0100, Michael Balzer <dexter@expeedo.de>, wrote:
JB./.
Regards, Michael
JB./.
JB./.
On 19 Mar 2018 at 12:43 +0100, Michael Balzer <dexter@expeedo.de>, wrote: > Uh oh… CAN bus contact failure? I haven't had any issues like that… > > Am 19.03.2018 um 11:09 schrieb Julien “JaXX” Banchet: > > That didn’t happen :-) > > https://twitter.com/happyjaxx/status/975675071451844608 > > > > On 19 Mar 2018 at 10:07 +0100, Julien “JaXX” Banchet <jaxx@jaxx.org>, wrote: > > > > > > Gonna put it in the car (despite the passive GPS issue) > > > > > > _______________________________________________ > > OvmsDev mailing list > > OvmsDev@lists.teslaclub.hk > > http://lists.teslaclub.hk/mailman/listinfo/ovmsdev > > > -- > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.teslaclub.hk > http://lists.teslaclub.hk/mailman/listinfo/ovmsdev _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Apart from the Merry Xmas CAN issue (will try Mark’s suggestion if the parallel v2 is the culprit) I have now noticed something else being at work (without home wifi, preventing the wifi module of connecting) Unless I set config auto wifi.mode off (tried apclient and ap), the server, either v2 or v3 will keep stuck in connecting. (And would sometimes freeze the module upon stop&&start), like if it didn’t want to use the defaulting ppX interface somehow. https://pastebin.com/cMMsAM5Q On off: everything starts like a charm (from my desk), notifications go out, and the module reacts to remote queries, even after long minutes On 19 Mar 2018 at 09:56 +0100, Julien “JaXX” Banchet <jaxx@jaxx.org>, wrote:
Having the same,
Greg
DNS: None
DNS: None
DNS: None
Greg D. -
Julien “JaXX” Banchet -
Mark Webb-Johnson -
Michael Balzer -
Stephen Casner
