Ioniq 5 - Pushing up some prerequisite changes to components/vehicles
Hi all, I have 6 commits that I would _like_ to get pushed up that are changes to components/vehicles required for my Ioniq 5 changes to work. I can push them all up in a single merge request for review, or separate them out into bits. Some of them I am expecting there to be opinions on. I'm prepared to simplify some, and one in particular has grounds for nixing. I think it's a good change, but I could manage without it. One is a simple bugfix - a literal one-character change: void OvmsVehicle::BmsRestartCellTemperatures() { m_bms_bitset_t.clear(); - m_bms_bitset_v.resize(m_bms_readings_t); + m_bms_bitset_t.resize(m_bms_readings_t); m_bms_bitset_ct = 0; } On is a simple code readability change. Using an enum instead of magic status values for m_bms_talerts. Simple enough, but I'm prepared to simplify that to a standard enum or get rid of it. There's some battery related ones where I want to be able to not quite know the number of cells from the start and let the OBD responses specify. There's also a battery one where the info for the cells have different timings (because one has other info), so I want to be able to clear a range of cells rather than just reset and start filling the info again. I've modified slightly the dump for the battery cell voltage/temperature, allowing for either or both columns to be visible if available. It also copes with the above 'not set' scenario. Finally, the controversial one: I am using std::vector<uint8_t> as a buffer in my ioniq5 code.. and I wanted to be able to use it for the polling instead of std::string. I've not replaced the std::string but added the ability to have either. If my aversion to using std::string for binary data is misplaced, then I'm ok with the currently small modification to my code that would use the std::string version. Thoughts? Shall I just push the code up to my own repo? Merge request? //.ichael
Michael, Am 19.10.22 um 07:26 schrieb Michael Geddes:
Hi all,
Please keep PRs as small as possible, focusing on one specific modification / addition at a time. That way, every merge commit can easily be reverted if necessary, and changes can be followed and referred to easily. Especially keep framework changes separate from vehicle specific ones. It's also OK to open the PRs tagged as drafts / work in progress, that helps in commenting on certain parts and tracing refinements. Create one branch for each PR, pushing new commits into the branch will automatically update any open PR created from it.
Obviously a copy & paste bug, nice find. I wonder how that could slip through without causing crashes, as there are more voltages than temperatures in most packs. Please don't hesitate with opening PRs even for single fixes like this, the sooner we include them, the better.
The magic values are simply alert levels, but go ahead, readability is a good goal.
Dynamic pack layout reconfiguration is no issue, I've done that on the Twizy (look for comments "update pack layout" or calls to BmsSetCellArrangement*).
That may be a bad idea, maybe better to implement some synchronization / drop readings out of sync. Reaching a consistent state, the BMS will calculate deviations etc.. Crucial on that part is an analysis of the consistency of the cell readings to determine the reliability of deviations exceeding thresholds. See my comments in BmsSetCellVoltage() and list thread: http://lists.openvehicles.com/pipermail/ovmsdev/2021-February/015079.html
Sounds good.
The general use case of ISO-TP data is actually dynamic binary strings. They are meant to and need to be easily aggregated, cut, merged, partially extracted etc., so they really are strings, not vectors (type wise).
//.ichael
Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Thanks Michael, I had already created my commits under the assumption that you would prefer the general changes separate from the vehicle-specific commits. I have created 3 pull requests so far. 1) the bug - that's a no-brainer. 2) 'finalisation' of temperatures and voltages. (Draft, see below) 3) vector poll. This is more a point of discussion (see below) A couple of the next bugs are kind of dependent on the second, so I'll wait until I get that sorted out. More comments below. On Fri, 21 Oct 2022 at 23:31, Michael Balzer <dexter@expeedo.de> wrote:
Michael,
Hi all,
Ooh. That's useful. It's been a while since I've used github for collab. Switched the battery sensor P/R over to a draft.
Yep. Done and understood.
I'll include it once the Battery Cell code is finalised.
specify.
BmsSetCellArrangement does clear all the values... which is probably the main thing I was trying to avoid. Ie- I get to the end and go 'ooh.. only this number of cells were filled in'. More comments in the P/R about what I want to achieve and fall-back positions.
I've skimmed the comments but will read properly and digest. Yeah it
might be best if I just clear the values at the start of the more often running one and then once the other ones come in it will finalise once it gets to the end of those.. so they aren't too far apart.
Sounds good.
I'll push this once the FinaliseCellVoltage pull-request is finalised and accepted.
Hmm.. I'm not sure I entirely agree about needing to aggregate/cut/merge; we know the size of the buffer after the first packet comes in so we can pre-set the buffer internal size and append data as it comes in without casting from uint8_t* to char *. Even if the size is wrong, we can still very easily append to a vector. ON the extraction, I have efficient templated functions that extract the data from the std::vector<uint8_t> buffer.. including to a std::string if required, or to big-endian/little-endian signed/unsigned integers of 1..4 bytes with sign-extension now. These also check bounds so are quite safe - possibly safer than the macros. The bounds check has already proved itself useful. I have pushed up a draft request 'single poll to buffer' as it is the easiest way to describe what I want to do. The first commit is the meat of the change ... but the second is adding all the utility functions. They probably don't belong in vehicle.h/cpp, but that's easy enough to change. I had them in my ioniq 5 specific code - but have shoved them in there just for a point of discussion. The great thing about the template functions here is that they should expand inline at compile time to quite efficient code.
Regards, Michael
//.ichael
Hi Michael, Just wanted to say that if you override my objections on the std::vector<unit8_t> in the single poll code then I'm fine with that, I recognised that it's absolutely your call and that bit has a small impact on my code so far. I can even add versions of the extraction functions that use std::string if you want (they would just be inline template wrappers around common code anyway so zero compiled cost). Also: Is there a better place to put those templated functions? A version of my sign_extend function is already being proposed being used here: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/736 - it would be good if both versions of this function were available in a single place. (There's sign_extend<UINT, INT>(int_value, sign_bit) and sign_extend<UINT, INT, SIGNBIT>(int_value) - so they should work fine as overloaded template functions). I would consider also whether I use std::string in my own code where I'm extracting my data out of complete ISOTP poll results. Up to you. That has slightly more impact, but the code change is pretty easy. //.ichael On Sat, 22 Oct 2022 at 07:56, Michael Geddes <frog@bunyip.wheelycreek.net> wrote:
Thanks Michael,
Michael,
Hi all,
specify.
Sounds good.
Regards, Michael
//.ichael
Michael, what I really dislike about your change is that it adds complexity to the underlying function just to fulfill an -- in my eyes more academic -- type style choice: having to handle multiple buffer pointers just to provide different typing approaches is bad. You could introduce a new construct to provide a single polymorphic pointer, but that again adds complexity. Agreed, std::string is a bit type-sloppy in depending on char being unsigned 8 bit, but that's all to consider, and can easily be enforced if ever necessary. On the plus side, std::string has far better library support, better interoperability (see our use cases), and small string optimization, which is especially useful for our platform, as most poll requests and responses easily fit into the initial capacity, normally eliminating the need for heap allocations. So, besides the type independency, I think std::vector has no advantage here. There's another thing I'd like to address: it seems you're planning to use single polls extensively? If so, please don't, unless you're also going to do a full rewrite of the poller towards a job/worker service task architecture (that's a very old todo). The single poll utility is really meant for sparse/manual polls outside the normal polling scheme. See my comment on the method: * PollSingleRequest: perform *prioritized synchronous* single OBD2/UDS request * Pass a full OBD2/UDS request (mode/type, PID, additional payload). * The request is sent immediately, *aborting a running poll list request*. The previous * poller state is automatically restored after the request has been performed, but * *without any guarantee for repetition or omission of an aborted poll*. This was really meant more for user/script use than for standard vehicle polls, though it's OK to use it, where applicable, with caution. For all standard polling, install a PID list. You can vary a list by the poll state, and you can switch lists if necessary. PID lists can easily be generated dynamically, see the VWUP code for an example. The place for general CAN utility methods is the components/can/src/canutils module, general utility methods go into the main/ovms_utils module. Regarding CAN buffer data extraction, there are currently probably as many approaches as there are vehicle modules. Certainly would be nice to have some standard way here, but won't be simple to rework the existing vehicle adaptors. The template approach is a nice one for a general solution, but keep in mind not every vehicle will use big endian encoding, in some cases not even consistently throughout the installed devices. To be really general, your byte addressing needs to support more than 256 bytes in the buffer. Your templates also lack bit masking and shifting. Some devices use packed structs with odd sized bit fields. The DBC engine has support for all this, but not generalized. I remember Mark getting a headache from this… Regards, Michael Am 23.10.22 um 02:23 schrieb Michael Geddes:
Hi Michael,
//.ichael
Thanks Michael,
Michael,
Am 19.10.22 um 07:26 schrieb Michael Geddes: > Hi all, > > I have 6 commits that I would _like_ to get pushed up that are changes > to components/vehicles required for my Ioniq 5 changes to work. > > I can push them all up in a single merge request for review, or > separate them out into bits. Some of them I am expecting there to be > opinions on. I'm prepared to simplify some, and one in particular has > grounds for nixing. I think it's a good change, but I could manage > without it.
> > One is a simple bugfix - a literal one-character change: > void OvmsVehicle::BmsRestartCellTemperatures() > { > m_bms_bitset_t.clear(); > - m_bms_bitset_v.resize(m_bms_readings_t); > + m_bms_bitset_t.resize(m_bms_readings_t); > m_bms_bitset_ct = 0; > }
> > On is a simple code readability change. Using an enum instead of magic > status values for m_bms_talerts. Simple enough, but I'm prepared to > simplify that to a standard enum or get rid of it.
> > There's some battery related ones where I want to be able to not quite > know the number of cells from the start and let the OBD responses specify.
> > There's also a battery one where the info for the cells have different > timings (because one has other info), so I want to be able to clear a > range of cells rather than just reset and start filling the info again.
I've skimmed the comments but will read properly and digest. Yeah it might be best if I just clear the values at the start of the more often running one and then once the other ones come in it will finalise once it gets to the end of those.. so they aren't too far apart.
> > I've modified slightly the dump for the battery cell > voltage/temperature, allowing for either or both columns to be visible > if available. It also copes with the above 'not set' scenario.
Sounds good.
> > Finally, the controversial one: I am using std::vector<uint8_t> as a > buffer in my ioniq5 code.. and I wanted to be able to use it for the > polling instead of std::string. I've not replaced the std::string but > added the ability to have either. > > If my aversion to using std::string for binary data is misplaced, then > I'm ok with the currently small modification to my code that would use > the std::string version.
Regards, Michael
//.ichael
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Thanks Michael, I have taken it in, and I'll use std::string in poll once code. I guess it might make sense to convert everything else to std::string. It wouldn't be a big task. I had just taken out that commit and reworked anyway, and now that you say it's not the best way of doing things, I'm even happier I made that choice, as I had intended to possibly make more use of it and won't now. At the moment I'm using it to get the VIN (snipped) where I'll try a couple of times only, rather than continually poll for it. Hmm... yea - I guess I could do some dynamically created poll table. Will definitely consider that. Further comments inline below: On Sun, 23 Oct 2022 at 16:15, Michael Balzer <dexter@expeedo.de> wrote:
Michael,
Ahh.. cool.
I had already implemented little-endian and big-endian versions of the data extract. I will now explicitly mark all of them.
Consider that fixed.
I have a get_bit<>() function and so I would propose it be implemented in a similar way... ie exract the byte first, then get the bits. Something like: extract_int<1,2>(byte) --> Extract bits len 2 starting from bit 1. We can easily sign-extend that too.
Regards, Michael
Hi Michael,
//.ichael
Thanks Michael,
Michael,
Hi all,
specify.
Sounds good.
Regards, Michael
//.ichael
_______________________________________________ OvmsDev mailing listOvmsDev@lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
Ok - so I've pared down my requirements on the BMS module to the ability to be able to cap the # of Voltages/Temperatures at a lower (only) value than initialised at. This means that the code to create the averages etc is just pulled out to a private function here: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/753 This P/R request adds the buffer extraction tools (with 32bit length) to ovms utils. https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/754 //.ichael On Sun, 23 Oct 2022 at 17:38, Michael Geddes <frog@bunyip.wheelycreek.net> wrote:
Thanks Michael,
Michael,
* PollSingleRequest: perform *prioritized synchronous* single OBD2/UDS request * Pass a full OBD2/UDS request (mode/type, PID, additional payload). * The request is sent immediately, *aborting a running poll list request*. The previous * poller state is automatically restored after the request has been performed, but * *without any guarantee for repetition or omission of an aborted poll* .
Ahh.. cool.
Regards, Michael
Hi Michael,
//.ichael
Thanks Michael,
Michael,
Hi all,
magic
quite
visible
Sounds good.
then
Regards, Michael
//.ichael
While I'm still happy with the base data extraction tools, I'm wondering if some more direct tools would be better. For example some methods on the Base vehicle that takes a buffer, a byte index and template byte count a Metric object and a multiplier.. That will conditionally set the metric if the data is within bounds. Or methods on the metrics themselves that has similar results. I notice that index by 4 bit 'nibbles' is also a Thing That Is Done. I'm happy to implement that if there's appetite for it... And possibly look at a few Vehicles to switch to that Michael On Mon, 24 Oct 2022, 1:26 pm Michael Geddes, <frog@bunyip.wheelycreek.net> wrote:
//.ichael
Thanks Michael,
Michael,
Ahh.. cool.
Regards, Michael
Hi Michael,
//.ichael
On Sat, 22 Oct 2022 at 07:56, Michael Geddes < frog@bunyip.wheelycreek.net> wrote:
Thanks Michael,
Michael,
Hi all,
magic
quite
visible
Sounds good.
a
Regards, Michael
//.ichael
Michael, please don't change existing vehicle code for personal code style reasons. The existing data extraction methods have been working and will continue to work. By adding your utilities to the framework, we're giving everyone interested the opportunity to consider using these, we don't force them to do. Regarding your combined data extraction & metric setting utility, from my experience this won't be applicable in many (most) cases, or would need quite a lot of extra features exceeding a simple scaling. Applications often need or want to change metrics only indirectly after processing the raw data read from the bus, often in combination with other readings and/or delayed. Validity checks also need to be done in a broad variety, often with side conditions. A good approach is to first define & refine your generalized methods locally in your component. Keep an eye on the existing method signatures, so once you're happy with them it's easy to move them into the framework. That way you'll avoid having to break compatibility for other developers possibly already using an early release of your method. Regards, Michael Am 27.10.22 um 09:36 schrieb Michael Geddes:
Michael
//.ichael
Thanks Michael,
Michael,
Ahh.. cool.
Regards, Michael
Hi Michael,
//.ichael
Thanks Michael,
Michael,
Sounds good.
Regards, Michael
//.ichael
No problems at all, these were just thoughts. So are those 2 PRs ok as they stand? I have a couple more in the pipeline(as I previously described) before the main I5 one. Mihael On Sat, 29 Oct 2022, 8:16 pm Michael Balzer, <dexter@expeedo.de> wrote:
Michael,
Regards, Michael
Michael
//.ichael
Thanks Michael,
Michael,
Ahh.. cool.
Regards, Michael
Hi Michael,
//.ichael
Thanks Michael,
Michael,
Sounds good.
Regards, Michael
//.ichael
I've already merged PR #754 and commented on #753. Other opinions on #753 are of course welcome. Regards, Michael Am 29.10.22 um 16:25 schrieb Michael Geddes:
Mihael
Michael,
Regards, Michael
Michael
//.ichael
Thanks Michael,
Michael,
Ahh.. cool.
Regards, Michael
Hi Michael,
//.ichael
Thanks Michael,
Michael,
Sounds good.
Regards, Michael
//.ichael
I'm close to the ioniq5 release now. (Read-only for the moment). Thanks for your support and patience! One of the things I included were the following defines in vehicle.h which I think should go here, but I'm really not fussed. #define VEHICLE_OBD_BROADCAST_MODULE_TX 0x7df #define VEHICLE_OBD_BROADCAST_MODULE_RX 0x0 These are used in the following call to get at the VIN. std::string response; int res = PollSingleRequest( m_can1, VEHICLE_OBD_BROADCAST_MODULE_TX, VEHICLE_OBD_BROADCAST_MODULE_RX, VEHICLE_POLL_TYPE_OBDIIVEHICLE, 2, response, 1000); questions: - Do you want one/both these in vehicle.h (I can always just have 0 in place of *_RX in the call)? - If so, should I: - make a separate P/R or - just include it as a commit in the Ioniq-5 P/R ? //.ichael On Sat, 29 Oct 2022 at 22:48, Michael Balzer <dexter@expeedo.de> wrote:
Regards, Michael
Mihael
Michael,
Regards, Michael
Michael
//.ichael
On Sun, 23 Oct 2022 at 17:38, Michael Geddes < frog@bunyip.wheelycreek.net> wrote:
Thanks Michael,
Michael,
Ahh.. cool.
Regards, Michael
Hi Michael,
//.ichael
Thanks Michael,
> Michael, > > Am 19.10.22 um 07:26 schrieb Michael Geddes: > > Hi all, > > > > I have 6 commits that I would _like_ to get pushed up that are > changes > > to components/vehicles required for my Ioniq 5 changes to work. > > > > I can push them all up in a single merge request for review, or > > separate them out into bits. Some of them I am expecting there to > be > > opinions on. I'm prepared to simplify some, and one in particular > has > > grounds for nixing. I think it's a good change, but I could manage > > without it. > > Please keep PRs as small as possible, focusing on one specific > modification / addition at a time. That way, every merge commit can > easily be reverted if necessary, and changes can be followed and > referred to easily. Especially keep framework changes separate from > vehicle specific ones. > > It's also OK to open the PRs tagged as drafts / work in progress, > that > helps in commenting on certain parts and tracing refinements. Create > one > branch for each PR, pushing new commits into the branch will > automatically update any open PR created from it.
> > > > > One is a simple bugfix - a literal one-character change: > > void OvmsVehicle::BmsRestartCellTemperatures() > > { > > m_bms_bitset_t.clear(); > > - m_bms_bitset_v.resize(m_bms_readings_t); > > + m_bms_bitset_t.resize(m_bms_readings_t); > > m_bms_bitset_ct = 0; > > } > > Obviously a copy & paste bug, nice find. I wonder how that could > slip > through without causing crashes, as there are more voltages than > temperatures in most packs. > > Please don't hesitate with opening PRs even for single fixes like > this, > the sooner we include them, the better. >
> > > > > On is a simple code readability change. Using an enum instead of > magic > > status values for m_bms_talerts. Simple enough, but I'm prepared > to > > simplify that to a standard enum or get rid of it. > > The magic values are simply alert levels, but go ahead, readability > is a > good goal. > > I'll include it once the Battery Cell code is finalised.
> > > > There's some battery related ones where I want to be able to not > quite > > know the number of cells from the start and let the OBD responses > specify. > > Dynamic pack layout reconfiguration is no issue, I've done that on > the > Twizy (look for comments "update pack layout" or calls to > BmsSetCellArrangement*). > > BmsSetCellArrangement does clear all the values... which is probably the main thing I was trying to avoid. Ie- I get to the end and go 'ooh.. only this number of cells were filled in'. More comments in the P/R about what I want to achieve and fall-back positions.
> > > There's also a battery one where the info for the cells have > different > > timings (because one has other info), so I want to be able to > clear a > > range of cells rather than just reset and start filling the info > again. > > That may be a bad idea, maybe better to implement some > synchronization / > drop readings out of sync. > > Reaching a consistent state, the BMS will calculate deviations etc.. > Crucial on that part is an analysis of the consistency of the cell > readings to determine the reliability of deviations exceeding > thresholds. > > See my comments in BmsSetCellVoltage() and list thread: > > http://lists.openvehicles.com/pipermail/ovmsdev/2021-February/015079.html > > I've skimmed the comments but will read properly and digest. Yeah it might be best if I just clear the values at the start of the more often running one and then once the other ones come in it will finalise once it gets to the end of those.. so they aren't too far apart.
> > > > I've modified slightly the dump for the battery cell > > voltage/temperature, allowing for either or both columns to be > visible > > if available. It also copes with the above 'not set' scenario. > > Sounds good. > I'll push this once the FinaliseCellVoltage pull-request is finalised and accepted.
> > > > > Finally, the controversial one: I am using std::vector<uint8_t> > as a > > buffer in my ioniq5 code.. and I wanted to be able to use it for > the > > polling instead of std::string. I've not replaced the std::string > but > > added the ability to have either. > > > > If my aversion to using std::string for binary data is misplaced, > then > > I'm ok with the currently small modification to my code that would > use > > the std::string version. > > The general use case of ISO-TP data is actually dynamic binary > strings. > They are meant to and need to be easily aggregated, cut, merged, > partially extracted etc., so they really are strings, not vectors > (type > wise).
> > Regards, > Michael > //.ichael
If you only add the #defines, that's ok included in your PR. If you also change usages of 0x7df etc. in the vehicle framework, that would be a separate PR. Regards, Michael Am 02.11.22 um 00:54 schrieb Michael Geddes:
questions:
* Do you want one/both these in vehicle.h (I can always just have 0 in place of *_RX in the call)? * If so, should I: o make a separate P/R or o just include it as a commit in the Ioniq-5 P/R ?
//.ichael
Regards, Michael
Mihael
Michael,
Regards, Michael
Michael
//.ichael
Thanks Michael,
Michael,
Ahh.. cool.
Regards, Michael
Hi Michael,
//.ichael
Thanks Michael,
Michael,
Sounds good.
Regards, Michael
//.ichael
Excellent, Pull request has gone up for Ioniq 5 https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/762 I hope I haven't pre-empted some of the config things/defaults. There is still a bunch of work I'd like to do in discovering more addresses... and I'm kinda hoping that somebody with better resources can fill in some controls (I got as far as confirming that none of the ones from the Kia/Kona work). For eg I found accelerator pedal percent, but not the brake, and I've confirmed all the door and lids.. except the charge port one! Unfortunately I also don't have a second driver in the household (who can physically drive my car without extra controls) so I can't drive around and query stuff.. but I have a friend who might be up for it. The VIN I get is a weird partial thing with the letters (in a weird order) and no number. NFI if it's encoded weirdly or what. I have an OBD splitter on the way that might help me work out why the HUD I bought doesn't work (at the least I can test the voltage drop). //.ichael On Wed, 2 Nov 2022 at 14:57, Michael Balzer <dexter@expeedo.de> wrote:
Regards, Michael
questions:
//.ichael
Regards, Michael
Mihael
Michael,
Regards, Michael
Michael
On Mon, 24 Oct 2022, 1:26 pm Michael Geddes, < frog@bunyip.wheelycreek.net> wrote:
//.ichael
Thanks Michael,
Michael,
Ahh.. cool.
Regards, Michael
Hi Michael,
//.ichael
> Thanks Michael, > > I had already created my commits under the assumption that you would > prefer the general changes separate from the vehicle-specific commits. > > I have created 3 pull requests so far. > 1) the bug - that's a no-brainer. > 2) 'finalisation' of temperatures and voltages. (Draft, see below) > 3) vector poll. This is more a point of discussion (see below) > > A couple of the next bugs are kind of dependent on the second, so > I'll wait until I get that sorted out. > > More comments below. > > On Fri, 21 Oct 2022 at 23:31, Michael Balzer <dexter@expeedo.de> > wrote: > >> Michael, >> >> Am 19.10.22 um 07:26 schrieb Michael Geddes: >> > Hi all, >> > >> > I have 6 commits that I would _like_ to get pushed up that are >> changes >> > to components/vehicles required for my Ioniq 5 changes to work. >> > >> > I can push them all up in a single merge request for review, or >> > separate them out into bits. Some of them I am expecting there >> to be >> > opinions on. I'm prepared to simplify some, and one in particular >> has >> > grounds for nixing. I think it's a good change, but I could >> manage >> > without it. >> >> Please keep PRs as small as possible, focusing on one specific >> modification / addition at a time. That way, every merge commit can >> easily be reverted if necessary, and changes can be followed and >> referred to easily. Especially keep framework changes separate from >> vehicle specific ones. >> >> It's also OK to open the PRs tagged as drafts / work in progress, >> that >> helps in commenting on certain parts and tracing refinements. >> Create one >> branch for each PR, pushing new commits into the branch will >> automatically update any open PR created from it. > > Ooh. That's useful. It's been a while since I've used github for > collab. Switched the battery sensor P/R over to a draft. > > >> >> > > >> > One is a simple bugfix - a literal one-character change: >> > void OvmsVehicle::BmsRestartCellTemperatures() >> > { >> > m_bms_bitset_t.clear(); >> > - m_bms_bitset_v.resize(m_bms_readings_t); >> > + m_bms_bitset_t.resize(m_bms_readings_t); >> > m_bms_bitset_ct = 0; >> > } >> >> Obviously a copy & paste bug, nice find. I wonder how that could >> slip >> through without causing crashes, as there are more voltages than >> temperatures in most packs. >> >> Please don't hesitate with opening PRs even for single fixes like >> this, >> the sooner we include them, the better. >> > > Yep. Done and understood. > > >> >> > >> > On is a simple code readability change. Using an enum instead of >> magic >> > status values for m_bms_talerts. Simple enough, but I'm prepared >> to >> > simplify that to a standard enum or get rid of it. >> >> The magic values are simply alert levels, but go ahead, readability >> is a >> good goal. >> >> I'll include it once the Battery Cell code is finalised. > >> > >> > There's some battery related ones where I want to be able to not >> quite >> > know the number of cells from the start and let the OBD responses >> specify. >> >> Dynamic pack layout reconfiguration is no issue, I've done that on >> the >> Twizy (look for comments "update pack layout" or calls to >> BmsSetCellArrangement*). >> >> BmsSetCellArrangement does clear all the values... which is > probably the main thing I was trying to avoid. Ie- I get to the end and go > 'ooh.. only this number of cells were filled in'. More comments in the P/R > about what I want to achieve and fall-back positions. > > > >> > There's also a battery one where the info for the cells have >> different >> > timings (because one has other info), so I want to be able to >> clear a >> > range of cells rather than just reset and start filling the info >> again. >> >> That may be a bad idea, maybe better to implement some >> synchronization / >> drop readings out of sync. >> >> Reaching a consistent state, the BMS will calculate deviations >> etc.. >> Crucial on that part is an analysis of the consistency of the cell >> readings to determine the reliability of deviations exceeding >> thresholds. >> >> See my comments in BmsSetCellVoltage() and list thread: >> >> http://lists.openvehicles.com/pipermail/ovmsdev/2021-February/015079.html >> >> I've skimmed the comments but will read properly and digest. Yeah > it might be best if I just clear the values at the start of the more often > running one and then once the other ones come in it will finalise once it > gets to the end of those.. so they aren't too far apart. > > >> > >> > I've modified slightly the dump for the battery cell >> > voltage/temperature, allowing for either or both columns to be >> visible >> > if available. It also copes with the above 'not set' scenario. >> >> Sounds good. >> > I'll push this once the FinaliseCellVoltage pull-request is > finalised and accepted. > >> >> > >> > Finally, the controversial one: I am using std::vector<uint8_t> >> as a >> > buffer in my ioniq5 code.. and I wanted to be able to use it for >> the >> > polling instead of std::string. I've not replaced the std::string >> but >> > added the ability to have either. >> > >> > If my aversion to using std::string for binary data is misplaced, >> then >> > I'm ok with the currently small modification to my code that >> would use >> > the std::string version. >> >> The general use case of ISO-TP data is actually dynamic binary >> strings. >> They are meant to and need to be easily aggregated, cut, merged, >> partially extracted etc., so they really are strings, not vectors >> (type >> wise). > > Hmm.. I'm not sure I entirely agree about needing to > aggregate/cut/merge; we know the size of the buffer after the first packet > comes in so we can pre-set the buffer internal size and append data as it > comes in without casting from uint8_t* to char *. Even if the size is > wrong, we can still very easily append to a vector. > > ON the extraction, I have efficient templated functions that extract > the data from the std::vector<uint8_t> buffer.. including to a std::string > if required, or to big-endian/little-endian signed/unsigned integers of > 1..4 bytes with sign-extension now. These also check bounds so are quite > safe - possibly safer than the macros. The bounds check has already proved > itself useful. > > I have pushed up a draft request 'single poll to buffer' as it is > the easiest way to describe what I want to do. The first commit is the > meat of the change ... but the second is adding all the utility functions. > They probably don't belong in vehicle.h/cpp, but that's easy enough to > change. I had them in my ioniq 5 specific code - but have shoved them in > there just for a point of discussion. > > The great thing about the template functions here is that they > should expand inline at compile time to quite efficient code. > >> >> Regards, >> Michael >> > //.ichael >
Michael, very nice initial release. Some of your custom metrics are clearly standard candidates, I'll have a closer look. Some of your metrics namings are a bit off the standard scheme, for example "xiq.version" would better be "xiq.m.version". Reason for this is users can use the same metrics query pattern to get all standard and custom metrics of that segment, e.g. to get all software versions: OVMS# me li m.ver m.version 3.3.003-63-g942d04f7/ota_0/edge (build idf v3.3.4-849-g6e214dc335 Nov 2 2022 08:00:16) xvu.m.version 0.22.5 Nov 2 2022 08:00:41 Likewise "v.d." should list all door related metrics, and so on. But you're free to go against that scheme where appropriate. Before reworking these, let me check for standard model candidates. Your door and seat belt ones clearly are some. Build is already on my server, I'll also post a note on the german Goingelectric forum. Regards, Michael Am 02.11.22 um 10:04 schrieb Michael Geddes:
Excellent,
//.ichael
Regards, Michael
questions:
//.ichael
Regards, Michael
Mihael
Michael,
Regards, Michael
Michael
//.ichael
Thanks Michael,
Michael,
Ahh.. cool.
Regards, Michael
Hi Michael,
//.ichael
Thanks Michael,
Michael,
Sounds good.
Regards, Michael
//.ichael
Those formats I just copied from the previous code... So am very happy to change them. Let me know if you decide on some standard metrics... I would welcome some assistance in mapping out more metrics (and commands?) Michael On Thu, 3 Nov 2022, 12:33 am Michael Balzer, <dexter@expeedo.de> wrote:
Michael,
Regards, Michael
Excellent,
//.ichael
Regards, Michael
questions:
//.ichael
Regards, Michael
Mihael
Michael,
Regards, Michael
Michael
//.ichael
Thanks Michael,
> Michael, > > what I really dislike about your change is that it adds complexity > to the underlying function just to fulfill an -- in my eyes more academic > -- type style choice: having to handle multiple buffer pointers just to > provide different typing approaches is bad. You could introduce a new > construct to provide a single polymorphic pointer, but that again adds > complexity. > > Agreed, std::string is a bit type-sloppy in depending on char being > unsigned 8 bit, but that's all to consider, and can easily be enforced if > ever necessary. > > On the plus side, std::string has far better library support, better > interoperability (see our use cases), and small string optimization, which > is especially useful for our platform, as most poll requests and responses > easily fit into the initial capacity, normally eliminating the need for > heap allocations. > > So, besides the type independency, I think std::vector has no > advantage here. > > > There's another thing I'd like to address: it seems you're planning > to use single polls extensively? > > If so, please don't, unless you're also going to do a full rewrite > of the poller towards a job/worker service task architecture (that's a very > old todo). > > The single poll utility is really meant for sparse/manual polls > outside the normal polling scheme. See my comment on the method: > > * PollSingleRequest: perform *prioritized synchronous* single > OBD2/UDS request > * Pass a full OBD2/UDS request (mode/type, PID, additional > payload). > * The request is sent immediately, *aborting a running poll list > request*. The previous > * poller state is automatically restored after the request has > been performed, but > * *without any guarantee for repetition or omission of an aborted > poll*. > > This was really meant more for user/script use than for standard > vehicle polls, though it's OK to use it, where applicable, with caution. > > For all standard polling, install a PID list. You can vary a list by > the poll state, and you can switch lists if necessary. PID lists can easily > be generated dynamically, see the VWUP code for an example. > > > The place for general CAN utility methods is the > components/can/src/canutils module, general utility methods go into the > main/ovms_utils module. > Ahh.. cool.
> > Regarding CAN buffer data extraction, there are currently probably > as many approaches as there are vehicle modules. Certainly would be nice to > have some standard way here, but won't be simple to rework the existing > vehicle adaptors. > > The template approach is a nice one for a general solution, but keep > in mind not every vehicle will use big endian encoding, in some cases not > even consistently throughout the installed devices. >
> > To be really general, your byte addressing needs to support more > than 256 bytes in the buffer. > Consider that fixed.
> Your templates also lack bit masking and shifting. Some devices use > packed structs with odd sized bit fields. The DBC engine has support for > all this, but not generalized. I remember Mark getting a headache from this… > I have a get_bit<>() function and so I would propose it be implemented in a similar way... ie exract the byte first, then get the bits. Something like: extract_int<1,2>(byte) --> Extract bits len 2 starting from bit 1. We can easily sign-extend that too.
> Regards, > Michael > > > Am 23.10.22 um 02:23 schrieb Michael Geddes: > > Hi Michael, > > Just wanted to say that if you override my objections on the > std::vector<unit8_t> in the single poll code then I'm fine with that, I > recognised that it's absolutely your call and that bit has a small impact > on my code so far. I can even add versions of the extraction functions > that use std::string if you want (they would just be inline > template wrappers around common code anyway so zero compiled cost). > > Also: Is there a better place to put those templated functions? A > version of my sign_extend function is already being proposed being used > here: > https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/736 > - it would be good if both versions of this function were available in a > single place. (There's sign_extend<UINT, INT>(int_value, sign_bit) and > sign_extend<UINT, INT, SIGNBIT>(int_value) - so they should work fine as > overloaded template functions). > > I would consider also whether I use std::string in my own code where > I'm extracting my data out of complete ISOTP poll results. Up to you. That > has slightly more impact, but the code change is pretty easy. > > //.ichael > > On Sat, 22 Oct 2022 at 07:56, Michael Geddes < > frog@bunyip.wheelycreek.net> wrote: > >> Thanks Michael, >> >> I had already created my commits under the assumption that you >> would prefer the general changes separate from the vehicle-specific commits. >> >> I have created 3 pull requests so far. >> 1) the bug - that's a no-brainer. >> 2) 'finalisation' of temperatures and voltages. (Draft, see below) >> 3) vector poll. This is more a point of discussion (see below) >> >> A couple of the next bugs are kind of dependent on the second, so >> I'll wait until I get that sorted out. >> >> More comments below. >> >> On Fri, 21 Oct 2022 at 23:31, Michael Balzer <dexter@expeedo.de> >> wrote: >> >>> Michael, >>> >>> Am 19.10.22 um 07:26 schrieb Michael Geddes: >>> > Hi all, >>> > >>> > I have 6 commits that I would _like_ to get pushed up that are >>> changes >>> > to components/vehicles required for my Ioniq 5 changes to work. >>> > >>> > I can push them all up in a single merge request for review, or >>> > separate them out into bits. Some of them I am expecting there >>> to be >>> > opinions on. I'm prepared to simplify some, and one in >>> particular has >>> > grounds for nixing. I think it's a good change, but I could >>> manage >>> > without it. >>> >>> Please keep PRs as small as possible, focusing on one specific >>> modification / addition at a time. That way, every merge commit >>> can >>> easily be reverted if necessary, and changes can be followed and >>> referred to easily. Especially keep framework changes separate >>> from >>> vehicle specific ones. >>> >>> It's also OK to open the PRs tagged as drafts / work in progress, >>> that >>> helps in commenting on certain parts and tracing refinements. >>> Create one >>> branch for each PR, pushing new commits into the branch will >>> automatically update any open PR created from it. >> >> Ooh. That's useful. It's been a while since I've used github for >> collab. Switched the battery sensor P/R over to a draft. >> >> >>> >>> >> > >>> > One is a simple bugfix - a literal one-character change: >>> > void OvmsVehicle::BmsRestartCellTemperatures() >>> > { >>> > m_bms_bitset_t.clear(); >>> > - m_bms_bitset_v.resize(m_bms_readings_t); >>> > + m_bms_bitset_t.resize(m_bms_readings_t); >>> > m_bms_bitset_ct = 0; >>> > } >>> >>> Obviously a copy & paste bug, nice find. I wonder how that could >>> slip >>> through without causing crashes, as there are more voltages than >>> temperatures in most packs. >>> >>> Please don't hesitate with opening PRs even for single fixes like >>> this, >>> the sooner we include them, the better. >>> >> >> Yep. Done and understood. >> >> >>> >>> > >>> > On is a simple code readability change. Using an enum instead of >>> magic >>> > status values for m_bms_talerts. Simple enough, but I'm >>> prepared to >>> > simplify that to a standard enum or get rid of it. >>> >>> The magic values are simply alert levels, but go ahead, >>> readability is a >>> good goal. >>> >>> I'll include it once the Battery Cell code is finalised. >> >>> > >>> > There's some battery related ones where I want to be able to not >>> quite >>> > know the number of cells from the start and let the OBD >>> responses specify. >>> >>> Dynamic pack layout reconfiguration is no issue, I've done that on >>> the >>> Twizy (look for comments "update pack layout" or calls to >>> BmsSetCellArrangement*). >>> >>> BmsSetCellArrangement does clear all the values... which is >> probably the main thing I was trying to avoid. Ie- I get to the end and go >> 'ooh.. only this number of cells were filled in'. More comments in the P/R >> about what I want to achieve and fall-back positions. >> >> > >>> > There's also a battery one where the info for the cells have >>> different >>> > timings (because one has other info), so I want to be able to >>> clear a >>> > range of cells rather than just reset and start filling the info >>> again. >>> >>> That may be a bad idea, maybe better to implement some >>> synchronization / >>> drop readings out of sync. >>> >>> Reaching a consistent state, the BMS will calculate deviations >>> etc.. >>> Crucial on that part is an analysis of the consistency of the cell >>> readings to determine the reliability of deviations exceeding >>> thresholds. >>> >>> See my comments in BmsSetCellVoltage() and list thread: >>> >>> http://lists.openvehicles.com/pipermail/ovmsdev/2021-February/015079.html >>> >>> I've skimmed the comments but will read properly and digest. >> Yeah it might be best if I just clear the values at the start of the more >> often running one and then once the other ones come in it will finalise >> once it gets to the end of those.. so they aren't too far apart. >> >> >>> > >>> > I've modified slightly the dump for the battery cell >>> > voltage/temperature, allowing for either or both columns to be >>> visible >>> > if available. It also copes with the above 'not set' scenario. >>> >>> Sounds good. >>> >> I'll push this once the FinaliseCellVoltage pull-request is >> finalised and accepted. >> >>> >>> > >>> > Finally, the controversial one: I am using std::vector<uint8_t> >>> as a >>> > buffer in my ioniq5 code.. and I wanted to be able to use it for >>> the >>> > polling instead of std::string. I've not replaced the >>> std::string but >>> > added the ability to have either. >>> > >>> > If my aversion to using std::string for binary data is >>> misplaced, then >>> > I'm ok with the currently small modification to my code that >>> would use >>> > the std::string version. >>> >>> The general use case of ISO-TP data is actually dynamic binary >>> strings. >>> They are meant to and need to be easily aggregated, cut, merged, >>> partially extracted etc., so they really are strings, not vectors >>> (type >>> wise). >> >> Hmm.. I'm not sure I entirely agree about needing to >> aggregate/cut/merge; we know the size of the buffer after the first packet >> comes in so we can pre-set the buffer internal size and append data as it >> comes in without casting from uint8_t* to char *. Even if the size is >> wrong, we can still very easily append to a vector. >> >> ON the extraction, I have efficient templated functions that >> extract the data from the std::vector<uint8_t> buffer.. including to a >> std::string if required, or to big-endian/little-endian signed/unsigned >> integers of 1..4 bytes with sign-extension now. These also check bounds so >> are quite safe - possibly safer than the macros. The bounds check has >> already proved itself useful. >> >> I have pushed up a draft request 'single poll to buffer' as it is >> the easiest way to describe what I want to do. The first commit is the >> meat of the change ... but the second is adding all the utility functions. >> They probably don't belong in vehicle.h/cpp, but that's easy enough to >> change. I had them in my ioniq 5 specific code - but have shoved them in >> there just for a point of discussion. >> >> The great thing about the template functions here is that they >> should expand inline at compile time to quite efficient code. >> >>> >>> Regards, >>> Michael >>> >> //.ichael >> > > _______________________________________________ > OvmsDev mailing listOvmsDev@lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > -- > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev >
On common metrics candidates for seatbelts - notice that from the previous code, they had 'driver' and 'passenger' for the front belts as that seems quite relevant for those... and certainly seems good especially for seat-belts. In Australia we are Right-Hand-Drive which makes it particularly relevant to me. They could be: v.sb.driver v.sb.passenger v.sb.rl v.sb.rm v.sb.rr Or follow the fl and fr :| Or Both? For displaying on an image, right/left seem more appropriate, but for triggers / scripting, driver/passenger has advantages. Thoughts? In the Hyundai OBD values, it appears that the values for open/close etc are based on driver side, and passenger side. //.ichael On Thu, 3 Nov 2022 at 00:33, Michael Balzer <dexter@expeedo.de> wrote:
Michael,
Regards, Michael
Excellent,
//.ichael
Regards, Michael
questions:
//.ichael
Regards, Michael
Mihael
Michael,
Regards, Michael
Michael
//.ichael
Thanks Michael,
Michael Balzer -
Michael Geddes
