[Ovmsdev] Integration of Simcom 7670 and changes to Simcom Powering
Info Zeitnitz
info at zeitnitz.eu
Mon Mar 31 17:01:16 HKT 2025
Hi Michael,
great! Thanks a lot for your effort and patience.
I first thought, that debugging the code without direct access to the hardware would be very difficult, but this really worked out fine.
So, I will issue a PR.
Best regards
Christian
Am 30.03.2025 um 17:31 schrieb Michael Balzer via OvmsDev:
> Christian,
> this looks very good now. I've mistreated my test modules in all ways I could think of including switching off the running modem via S1, the cellular system recovered nicely from all situations.
> Am 30.03.25 um 16:01 schrieb Info via OvmsDev:
>> Hi Michael,
>> I think I found the problem which caused the 5360 not to powercycle correctly. Actually the T_on time was in that instance set to 1126913089 ms, so this will take a while!
>> This was caused by a stupid mistake with an incorrect modulo calculation of the timing index .
>> I fixed the unused variables as well.
>> Best regards
>> Christian
>> Am 30.03.2025 um 14:26 schrieb Michael Balzer via OvmsDev:
>>> PS: please fix the two unused variables now in gsmnmea.cpp:
>>> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_cellular/src/gsmnmea.cpp: In member function 'void GsmNMEA::IncomingLine(std::__cxx11::string)':
>>> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_cellular/src/gsmnmea.cpp:148:40: warning: variable 'vdop' set but not used [-Wunused-but-set-variable]
>>> float lat=0, lon=0, alt=0, hdop=0, vdop=0, pdop=0;
>>> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_cellular/src/gsmnmea.cpp:148:48: warning: variable 'pdop' set but not used [-Wunused-but-set-variable]
>>> Am 30.03.25 um 14:21 schrieb Michael Balzer via OvmsDev:
>>>> Christian,
>>>> the user way to power off/on the modem is via "power cellular off/on", that's what I test/ed, and that works.
>>>> After having no issues now with the 7600, I did the tests with my old 5360 module.
>>>> That generally also worked, with one exception: on one of four crash reboots, the cellular system got stuck in PowerOffOn state, with state ticker at 0 and no more activity.
>>>> Logs attached.
>>>> Regards,
>>>> Michael
>>>> Am 30.03.25 um 13:08 schrieb Info via OvmsDev:
>>>>> Michael,
>>>>> one more thing: if you are performing another test, please check from the console, that the powering of the modem works as well.
>>>>> cellular setstate PoweringOff
>>>>> cellular setstate PoweringOn
>>>>> It did not work when I started with the 7670 and I had to modify ovms_cellular (set m_powermode according to the state) to get it going.
>>>>> Thanks
>>>>> Christian
>>>>> Am 30.03.2025 um 12:02 schrieb Info via OvmsDev:
>>>>>> OK, thanks Michael.
>>>>>> At least this was an easy fix.
>>>>>> Had a look at the NMEA code and I screwed up the istringstream object when checking for the CGNSSINFO string.
>>>>>> Fixed it and I hope this works now as well.
>>>>>> Best regards
>>>>>> Christian
>>>>>> Am 29.03.2025 um 18:42 schrieb Michael Balzer via OvmsDev:
>>>>>>> Christian,
>>>>>>> the GSM/PPP part now works smoothly with all standard situations tested so far.
>>>>>>> But the GPS part doesn't work. It looks like the NMEA sentences are received in the MUX channel, but not forwarded to the NMEA module.
>>>>>>> V (794230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
>>>>>>> V (794230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
>>>>>>> These should be the NMEA sentences, but there are no corresponding log entries from gsm-nmea.
>>>>>>> New logs attached.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 29.03.25 um 15:13 schrieb Info via OvmsDev:
>>>>>>>> Hi Michael,
>>>>>>>> thanks for testing.
>>>>>>>> The results look odd, so I went back to the schematics of OVMS modules and realized, that I was mistaken. The PWRKEY pin is actually inverted in the modules as well. This definetly explains
>>>>>>>> the strange behaviour.
>>>>>>>> I changed now the logic in simcom_powering.h and the inverted PWRKEY level is now the default.
>>>>>>>> Could you please run another test?
>>>>>>>> Best regards
>>>>>>>> Christian
>>>>>>>> Am 29.03.2025 um 09:25 schrieb Michael Balzer via OvmsDev:
>>>>>>>>> Christian,
>>>>>>>>> well done on the 7670 support :-)
>>>>>>>>> I've just done some first tests of your branch on the 7600, which turned up some issues. Logs attached:
>>>>>>>>> * Cold boot failed in 2 of 3 test boots, with the driver getting stuck in a loop (poweredon / identify / muxstart)
>>>>>>>>> * Regular shutdown fails to power down the modem in time -- for a deep sleep phase, this would mean the modem will remain powered on
>>>>>>>>> * After a crash, the modem driver gets somehow stuck in PowerOffOn state
>>>>>>>>> It seems the test for reaction ("AT") sometimes gets skipped, even though the modem isn't ready yet.
>>>>>>>>> On the failed cold boot log, you can see this at the end:
>>>>>>>>> *I (389178) cellular-modem-auto: Power Cycle*
>>>>>>>>> I (389178) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
>>>>>>>>> D (389178) events: Signal(system.modem.poweringon)
>>>>>>>>> D (389188) events: Signal(egpio.output.0.low)
>>>>>>>>> D (391678) events: Signal(egpio.output.0.high)
>>>>>>>>> D (396678) events: Signal(egpio.output.0.low)
>>>>>>>>> D (396878) events: Signal(egpio.output.0.high)
>>>>>>>>> *I (396878) cellular: State: Enter Identify state
>>>>>>>>> D (396978) cellular: tx-cmd: AT+CGMM*
>>>>>>>>> I (397008) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600
>>>>>>>>> D (397008) cellular: Remove old 'auto' modem driver
>>>>>>>>> I (397008) cellular: Set modem driver to 'SIM7600'
>>>>>>>>> *I (397008) cellular: State: Enter PoweredOn state*
>>>>>>>>> D (397008) events: Signal(system.modem.installed)
>>>>>>>>> D (397008) events: Signal(system.modem.poweredon)
>>>>>>>>> D (406178) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
>>>>>>>>> D (408178) cellular: tx-cmd: AT+CGMR;+ICCID
>>>>>>>>> D (416178) cellular: tx-cmd: AT+CMUX=0;+CATR=6
>>>>>>>>> D (434808) cellular: mux-rx-line #0 (2/46): OK
>>>>>>>>> *D (434808) cellular: mux-rx-line #0 (3/39): RDY*
>>>>>>>>> D (434808) cellular: mux-rx-line #0 (12/23): +CPIN: READY
>>>>>>>>> D (434808) cellular: mux-rx-line #0 (8/11): SMS DONE
>>>>>>>>> D (434808) cellular: mux-rx-line #0 (7/0): PB DONE
>>>>>>>>> I (434808) cellular: State: Enter MuxStart state
>>>>>>>>> D (434808) events: Signal(system.modem.muxstart)
>>>>>>>>> Regards,
>>>>>>>>> Michael
>>>>>>>>> Am 26.03.25 um 13:13 schrieb Info Zeitnitz via OvmsDev:
>>>>>>>>>> Dear all,
>>>>>>>>>> I finished to integrate the Simcom 7670 modem into the OVMS code.
>>>>>>>>>> See https://github.com/zbchristian/Open-Vehicle-Monitoring-System-3.git branch update_cellular.
>>>>>>>>>> Modem Powering
>>>>>>>>>> I had problems to get the 7670 working with the current code. The modem was stuck in a power cycle loop.
>>>>>>>>>> I checked the Simcom documentation for the 4 models 5360, 7000 series, 7600, 7670 and the powering procedure via the PWRKEY pin is the same, but with different on/off timing. Depending on
>>>>>>>>>> the hardware, the PWRKEY can be inverted as well. This is the case for my Lilygo TCall board, but I think not for the OVMS HW versions. At least version 3.1 connects the corresponding
>>>>>>>>>> MAX7317 pin directly to the modem.
>>>>>>>>>> Assuming, that all hardware versions use the PWRKEY procedure for powering, I streamlined the code and moved the corresponding functions into separate files (simcom_powering.cpp and
>>>>>>>>>> simcom_powering.h). This avoids the duplication of the code.
>>>>>>>>>> All this leads to substantial changes in ovms_cellular and ovms_cellular_modem_driver as well.
>>>>>>>>>> The code works now perfectly for the 7670, but testing is required for all other models.
>>>>>>>>>> If my assumptions about the OVMS HW versions are not correct, or the modems do not work as documented, some modifications might be needed.
>>>>>>>>>> GNSS Location
>>>>>>>>>> The 7670 no longer accepts the currently used AT commands to obtain the location as a GRMC sentence. So, I added code to the new 7670 class to request the location via the AT+CGNSSINFO
>>>>>>>>>> command.
>>>>>>>>>> Since this has to be send explicitly again and again, I implemented a corresponding call in the StatusPoller of the 7670.
>>>>>>>>>> All the NMEA related code has been adapted to handle the corresponding CGNSSINFO response.
>>>>>>>>>> In conclusion, before doing a pull request, it would make sense that the code is tested with the other hardware and modem models.
>>>>>>>>>> So, tell me what you think and if the general strategy of the mods make sense to you.
>>>>>>>>>> Best regards
>>>>>>>>>> Christian
>>>>>>>>>> _______________________________________________
>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>>>>>>>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250331/53e2987e/attachment-0001.htm>
