[Ovmsdev] TCP/IP Assertion fail / stack trace
Michael Geddes
Sat Mar 29 15:37:17 HKT 2025
I've been having a few reboots due to aborts. Any ideas on where I might
look at for this one which is in the TCPIP stack:
---8<------
0x4008ddae is in invoke_abort
(/home/michaelg/esp/esp-idf/components/esp32/panic.c:156).
151 #endif
152 while (1) {
153 if (esp_cpu_in_ocd_debug_mode()) {
154 __asm__ ("break 0,0");
155 }
156 *((int *) 0) = 0;
157 }
158 }
159
160 void abort()
0x4008e049 is in abort
(/home/michaelg/esp/esp-idf/components/esp32/panic.c:171).
166 * don't overwrite that.
167 */
168 if (esp_reset_reason_get_hint() == ESP_RST_UNKNOWN) {
169 esp_reset_reason_set_hint(ESP_RST_PANIC);
170 }
171 invoke_abort();
172 }
173
174
175 static const char *edesc[] = {
0x400925ff is in multi_heap_assert
(/home/michaelg/esp/esp-idf/components/heap/multi_heap_platform.h:54).
49 #ifndef NDEBUG
50 if(!condition) {
51 #ifndef CONFIG_OPTIMIZATION_ASSERTIONS_SILENT
52 ets_printf(format, line, address);
53 #endif // CONFIG_OPTIMIZATION_ASSERTIONS_SILENT
54 abort();
55 }
56 #else // NDEBUG
57 (void) condition;
58 #endif // NDEBUG
0x40092629 is in get_prev_free_block
(/home/michaelg/esp/esp-idf/components/heap/multi_heap.c:187).
182 static heap_block_t *get_prev_free_block(heap_t *heap, const
heap_block_t *block)
183 {
184 assert(!is_first_block(heap, block)); /* can't look for a block
before first_block */
185
186 for (heap_block_t *b = &heap->first_block; b != NULL && b <
block; b = b->next_free) {
187 MULTI_HEAP_ASSERT(is_free(b), b); // Block should be free
188 if (b->next_free == NULL || b->next_free >= block) {
189 if (is_free(block)) {
190 /* if block is on freelist, 'b' should be the item
before it. */
191 MULTI_HEAP_ASSERT(b->next_free == block,
&b->next_free);
0x40092a9a is in multi_heap_free_impl
(/home/michaelg/esp/esp-idf/components/heap/multi_heap.c:484).
479 MULTI_HEAP_ASSERT(!is_first_block(heap, pb), pb); // block
should not be first block
480
481 heap_block_t *next = get_next_block(pb);
482
483 /* Update freelist pointers */
484 heap_block_t *prev_free = get_prev_free_block(heap, pb);
485 // freelist validity check
486 MULTI_HEAP_ASSERT(prev_free->next_free == NULL ||
prev_free->next_free > pb, &prev_free->next_free);
487 pb->next_free = prev_free->next_free;
488 prev_free->next_free = pb;
0x4009302e is in multi_heap_free
(/home/michaelg/esp/esp-idf/components/heap/multi_heap_poisoning.c:225).
220 #ifdef SLOW
221 /* replace everything with FREE_FILL_PATTERN, including the
poison head/tail */
222 memset(head, FREE_FILL_PATTERN,
223 head->alloc_size + POISON_OVERHEAD);
224 #endif
225 multi_heap_free_impl(heap, head);
226
227 multi_heap_internal_unlock(heap);
228 }
229
0x4008449d is in heap_caps_free
(/home/michaelg/esp/esp-idf/components/heap/heap_caps.c:268).
263 ptr = (void *)dramAddrPtr[-1];
264 }
265
266 heap_t *heap = find_containing_heap(ptr);
267 assert(heap != NULL && "free() target pointer is outside heap
areas");
268 multi_heap_free(heap->heap, ptr);
269 }
270
271 IRAM_ATTR void *heap_caps_realloc( void *ptr, size_t size, int caps)
272 {
0x40084a91 is in _free_r
(/home/michaelg/esp/esp-idf/components/newlib/syscalls.c:42).
37 return heap_caps_malloc_default( size );
38 }
39
40 void IRAM_ATTR _free_r(struct _reent *r, void* ptr)
41 {
42 heap_caps_free( ptr );
43 }
44
45 void* IRAM_ATTR _realloc_r(struct _reent *r, void* ptr, size_t size)
46 {
0x40118a48 is in mem_free
(/home/michaelg/esp/esp-idf/components/lwip/lwip/src/core/mem.c:176).
171 LWIP_ASSERT("rmem == MEM_ALIGN(rmem)", (rmem ==
LWIP_MEM_ALIGN(rmem)));
172 #if LWIP_STATS && MEM_STATS
173 rmem = (u8_t*)rmem - MEM_LIBC_STATSHELPER_SIZE;
174 MEM_STATS_DEC_USED(used, *(mem_size_t*)rmem);
175 #endif
176 mem_clib_free(rmem);
177 }
178
179 #elif MEM_USE_POOLS
180
0x40118a9f is in do_memp_free_pool
(/home/michaelg/esp/esp-idf/components/lwip/lwip/src/core/memp.c:432).
427 #endif
428
429 #if MEMP_MEM_MALLOC
430 LWIP_UNUSED_ARG(desc);
431 SYS_ARCH_UNPROTECT(old_level);
432 mem_free(memp);
433 #else /* MEMP_MEM_MALLOC */
434 memp->next = *desc->tab;
435 *desc->tab = memp;
436
0x40118b17 is in memp_free
(/home/michaelg/esp/esp-idf/components/lwip/lwip/src/core/memp.c:489).
484
485 #ifdef LWIP_HOOK_MEMP_AVAILABLE
486 old_first = *memp_pools[type]->tab;
487 #endif
488
489 do_memp_free_pool(memp_pools[type], mem);
490
491 #ifdef LWIP_HOOK_MEMP_AVAILABLE
492 if (old_first == NULL) {
493 LWIP_HOOK_MEMP_AVAILABLE(type);
0x4011e911 is in sys_timeouts_mbox_fetch
(/home/michaelg/esp/esp-idf/components/lwip/lwip/src/core/timeouts.c:354).
349 if (handler != NULL) {
350 LWIP_DEBUGF(TIMERS_DEBUG, ("sct calling h=%s arg=%p\n",
351 tmptimeout->handler_name, arg));
352 }
353 #endif /* LWIP_DEBUG_TIMERNAMES */
354 memp_free(MEMP_SYS_TIMEOUT, tmptimeout);
355 if (handler != NULL) {
356 #if !NO_SYS
357 /* For LWIP_TCPIP_CORE_LOCKING, lock the core before
calling the
358 timeout handler function. */
0x401186f8 is in tcpip_thread
(/home/michaelg/esp/esp-idf/components/lwip/lwip/src/api/tcpip.c:109).
104 LOCK_TCPIP_CORE();
105 while (1) { /* MAIN Loop */
106 UNLOCK_TCPIP_CORE();
107 LWIP_TCPIP_THREAD_ALIVE();
108 /* wait for a message, timeouts are processed while waiting */
109 TCPIP_MBOX_FETCH(&mbox, (void **)&msg);
110 LOCK_TCPIP_CORE();
111 if (msg == NULL) {
112 LWIP_DEBUGF(TCPIP_DEBUG, ("tcpip_thread: invalid message:
NULL\n"));
113 LWIP_ASSERT("tcpip_thread: invalid message", 0);
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250329/f73a47f6/attachment.htm>
