[Ovmsdev] Integration of Simcom 7670 and changes to Simcom Powering
Sun Mar 30 23:31:54 HKT 2025
Christian,
this looks very good now. I've mistreated my test modules in all ways I
could think of including switching off the running modem via S1, the
cellular system recovered nicely from all situations.
Am 30.03.25 um 16:01 schrieb Info via OvmsDev:
> Hi Michael,
> I think I found the problem which caused the 5360 not to powercycle
> correctly. Actually the T_on time was in that instance set to
> 1126913089 ms, so this will take a while!
> This was caused by a stupid mistake with an incorrect modulo
> calculation of the timing index .
> I fixed the unused variables as well.
> Best regards
>    Christian
> Am 30.03.2025 um 14:26 schrieb Michael Balzer via OvmsDev:
>> PS: please fix the two unused variables now in gsmnmea.cpp:
>> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_cellular/src/gsmnmea.cpp:
>> In member function 'void GsmNMEA::IncomingLine(std::__cxx11::string)':
>> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_cellular/src/gsmnmea.cpp:148:40:
>> warning: variable 'vdop' set but not used [-Wunused-but-set-variable]
>>      float lat=0, lon=0, alt=0, hdop=0, vdop=0, pdop=0;
>> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_cellular/src/gsmnmea.cpp:148:48:
>> warning: variable 'pdop' set but not used [-Wunused-but-set-variable]
>> Am 30.03.25 um 14:21 schrieb Michael Balzer via OvmsDev:
>>> Christian,
>>> the user way to power off/on the modem is via "power cellular
>>> off/on", that's what I test/ed, and that works.
>>> After having no issues now with the 7600, I did the tests with my
>>> old 5360 module.
>>> That generally also worked, with one exception: on one of four crash
>>> reboots, the cellular system got stuck in PowerOffOn state, with
>>> state ticker at 0 and no more activity.
>>> Logs attached.
>>> Am 30.03.25 um 13:08 schrieb Info via OvmsDev:
>>>> Michael,
>>>> one more thing: if you are performing another test, please check
>>>> from the console, that the powering of the modem works as well.
>>>> cellular setstate PoweringOff
>>>> cellular setstate PoweringOn
>>>> It did not work when I started with the 7670 and I had to modify
>>>> ovms_cellular (set m_powermode according to the state) to get it going.
>>>> Thanks
>>>>   Christian
>>>> Am 30.03.2025 um 12:02 schrieb Info via OvmsDev:
>>>>> OK, thanks Michael.
>>>>> At least this was an easy fix.
>>>>> Had a look at the NMEA code and I screwed up the istringstream
>>>>> object when checking for the CGNSSINFO string.
>>>>> Fixed it and I hope this works now as well.
>>>>> Best regards
>>>>>   Christian
>>>>> Am 29.03.2025 um 18:42 schrieb Michael Balzer via OvmsDev:
>>>>>> Christian,
>>>>>> the GSM/PPP part now works smoothly with all standard situations
>>>>>> tested so far.
>>>>>> But the GPS part doesn't work. It looks like the NMEA sentences
>>>>>> are received in the MUX channel, but not forwarded to the NMEA
>>>>>> module.
>>>>>> V (794230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff,
>>>>>> FCS=fa, LEN=78)
>>>>>> FCS=f4, LEN=82)
>>>>>> These should be the NMEA sentences, but there are no
>>>>>> corresponding log entries from gsm-nmea.
>>>>>> New logs attached.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 29.03.25 um 15:13 schrieb Info via OvmsDev:
>>>>>>> Hi Michael,
>>>>>>> thanks for testing.
>>>>>>> The results look odd, so I went back to the schematics of OVMS
>>>>>>> modules and realized, that I was mistaken. The PWRKEY pin is
>>>>>>> actually inverted in the modules as well. This definetly
>>>>>>> explains the strange behaviour.
>>>>>>> I changed now the logic in simcom_powering.h and the inverted
>>>>>>> PWRKEY level is now the default.
>>>>>>> Could you please run another test?
>>>>>>> Best regards
>>>>>>>   Christian
>>>>>>> Am 29.03.2025 um 09:25 schrieb Michael Balzer via OvmsDev:
>>>>>>>> Christian,
>>>>>>>> well done on the 7670 support :-)
>>>>>>>> I've just done some first tests of your branch on the 7600,
>>>>>>>> which turned up some issues. Logs attached:
>>>>>>>>   * Cold boot failed in 2 of 3 test boots, with the driver
>>>>>>>>     getting stuck in a loop (poweredon / identify / muxstart)
>>>>>>>>   * Regular shutdown fails to power down the modem in time --
>>>>>>>>     for a deep sleep phase, this would mean the modem will
>>>>>>>>     remain powered on
>>>>>>>>   * After a crash, the modem driver gets somehow stuck in
>>>>>>>>     PowerOffOn state
>>>>>>>> It seems the test for reaction ("AT") sometimes gets skipped,
>>>>>>>> even though the modem isn't ready yet.
>>>>>>>> On the failed cold boot log, you can see this at the end:
>>>>>>>> *I (389178) cellular-modem-auto: Power Cycle*
>>>>>>>> I (389178) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
>>>>>>>> D (389178) events: Signal(system.modem.poweringon)
>>>>>>>> D (389188) events: Signal(egpio.output.0.low)
>>>>>>>> D (391678) events: Signal(egpio.output.0.high)
>>>>>>>> D (396678) events: Signal(egpio.output.0.low)
>>>>>>>> D (396878) events: Signal(egpio.output.0.high)
>>>>>>>> *I (396878) cellular: State: Enter Identify state
>>>>>>>> D (396978) cellular: tx-cmd: AT+CGMM*
>>>>>>>> I (397008) cellular: Identified cellular modem:
>>>>>>>> SIM7600/Experimental support for SIMCOM SIM7600
>>>>>>>> D (397008) cellular: Remove old 'auto' modem driver
>>>>>>>> I (397008) cellular: Set modem driver to 'SIM7600'
>>>>>>>> *I (397008) cellular: State: Enter PoweredOn state*
>>>>>>>> D (397008) events: Signal(system.modem.installed)
>>>>>>>> D (397008) events: Signal(system.modem.poweredon)
>>>>>>>> D (406178) cellular: tx-cmd:
>>>>>>>> AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
>>>>>>>> D (408178) cellular: tx-cmd: AT+CGMR;+ICCID
>>>>>>>> D (416178) cellular: tx-cmd: AT+CMUX=0;+CATR=6
>>>>>>>> D (434808) cellular: mux-rx-line #0 (2/46): OK
>>>>>>>> *D (434808) cellular: mux-rx-line #0 (3/39): RDY*
>>>>>>>> D (434808) cellular: mux-rx-line #0 (12/23): +CPIN: READY
>>>>>>>> D (434808) cellular: mux-rx-line #0 (8/11): SMS DONE
>>>>>>>> D (434808) cellular: mux-rx-line #0 (7/0): PB DONE
>>>>>>>> I (434808) cellular: State: Enter MuxStart state
>>>>>>>> D (434808) events: Signal(system.modem.muxstart)
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 26.03.25 um 13:13 schrieb Info Zeitnitz via OvmsDev:
>>>>>>>>> Dear all,
>>>>>>>>> I finished to integrate the Simcom 7670 modem into the OVMS code.
>>>>>>>>> See
>>>>>>>>> https://github.com/zbchristian/Open-Vehicle-Monitoring-System-3.git
>>>>>>>>> branch update_cellular.
>>>>>>>>> Modem Powering
>>>>>>>>> I had problems to get the 7670 working with the current code.
>>>>>>>>> The modem was stuck in a power cycle loop.
>>>>>>>>> I checked the Simcom documentation for the 4 models 5360, 7000
>>>>>>>>> series, 7600, 7670 and the powering procedure via the PWRKEY
>>>>>>>>> pin is the same, but with different on/off timing. Depending
>>>>>>>>> on the hardware, the PWRKEY can be inverted as well. This is
>>>>>>>>> the case for my Lilygo TCall board, but I think not for the
>>>>>>>>> OVMS HW versions. At least version 3.1 connects the
>>>>>>>>> corresponding MAX7317 pin directly to the modem.
>>>>>>>>> Assuming, that all hardware versions use the PWRKEY procedure
>>>>>>>>> for powering, I streamlined the code and moved the
>>>>>>>>> corresponding functions into separate files
>>>>>>>>> (simcom_powering.cpp and simcom_powering.h). This avoids the
>>>>>>>>> duplication of the code.
>>>>>>>>> All this leads to substantial changes in ovms_cellular and
>>>>>>>>> ovms_cellular_modem_driver as well.
>>>>>>>>> The code works now perfectly for the 7670, but testing is
>>>>>>>>> required for all other models.
>>>>>>>>> If my assumptions about the OVMS HW versions are not correct,
>>>>>>>>> or the modems do not work as documented, some modifications
>>>>>>>>> might be needed.
>>>>>>>>> GNSS Location
>>>>>>>>> The 7670 no longer accepts the currently used AT commands to
>>>>>>>>> obtain the location  as a GRMC sentence. So, I added code to
>>>>>>>>> the new 7670 class to request the location via the
>>>>>>>>> AT+CGNSSINFO command.
>>>>>>>>> Since this has to be send explicitly again and again,  I
>>>>>>>>> implemented a corresponding call in the StatusPoller of the 7670.
>>>>>>>>> All the NMEA related code has been adapted to handle the
>>>>>>>>> corresponding CGNSSINFO response.
>>>>>>>>> In conclusion, before doing a pull request, it would make
>>>>>>>>> sense that the code is tested with the other hardware and
>>>>>>>>> modem models.
>>>>>>>>> So, tell me what you think and if the general strategy of the
>>>>>>>>> mods make sense to you.
>>>>>>>>> Best regards
>>>>>>>>>   Christian
>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>>>>>>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250330/bb958898/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250330/bb958898/attachment-0001.sig>
