[Ovmsdev] Integration of Simcom 7670 and changes to Simcom Powering
Info info at zeitnitz.eu
Sun Mar 30 22:01:59 HKT 2025
Hi Michael,
I think I found the problem which caused the 5360 not to powercycle
correctly. Actually the T_on time was in that instance set to 1126913089
ms, so this will take a while!
This was caused by a stupid mistake with an incorrect modulo calculation
of the timing index .
I fixed the unused variables as well.
Best regards
    Christian
Am 30.03.2025 um 14:26 schrieb Michael Balzer via OvmsDev:
> PS: please fix the two unused variables now in gsmnmea.cpp:
> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_cellular/src/gsmnmea.cpp:
> In member function 'void GsmNMEA::IncomingLine(std::__cxx11::string)':
> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_cellular/src/gsmnmea.cpp:148:40:
> warning: variable 'vdop' set but not used [-Wunused-but-set-variable]
>      float lat=0, lon=0, alt=0, hdop=0, vdop=0, pdop=0;
> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_cellular/src/gsmnmea.cpp:148:48:
> warning: variable 'pdop' set but not used [-Wunused-but-set-variable]
> Am 30.03.25 um 14:21 schrieb Michael Balzer via OvmsDev:
>> Christian,
>> the user way to power off/on the modem is via "power cellular
>> off/on", that's what I test/ed, and that works.
>> After having no issues now with the 7600, I did the tests with my old
>> 5360 module.
>> That generally also worked, with one exception: on one of four crash
>> reboots, the cellular system got stuck in PowerOffOn state, with
>> state ticker at 0 and no more activity.
>> Logs attached.
>> Am 30.03.25 um 13:08 schrieb Info via OvmsDev:
>>> Michael,
>>> one more thing: if you are performing another test, please check
>>> from the console, that the powering of the modem works as well.
>>> cellular setstate PoweringOff
>>> cellular setstate PoweringOn
>>> It did not work when I started with the 7670 and I had to modify
>>> ovms_cellular (set m_powermode according to the state) to get it going.
>>> Thanks
>>>   Christian
>>> Am 30.03.2025 um 12:02 schrieb Info via OvmsDev:
>>>> OK, thanks Michael.
>>>> At least this was an easy fix.
>>>> Had a look at the NMEA code and I screwed up the istringstream
>>>> object when checking for the CGNSSINFO string.
>>>> Fixed it and I hope this works now as well.
>>>> Best regards
>>>>   Christian
>>>> Am 29.03.2025 um 18:42 schrieb Michael Balzer via OvmsDev:
>>>>> Christian,
>>>>> the GSM/PPP part now works smoothly with all standard situations
>>>>> tested so far.
>>>>> But the GPS part doesn't work. It looks like the NMEA sentences
>>>>> are received in the MUX channel, but not forwarded to the NMEA module.
>>>>> V (794230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa,
>>>>> LEN=78)
>>>>> V (794230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4,
>>>>> LEN=82)
>>>>> These should be the NMEA sentences, but there are no corresponding
>>>>> log entries from gsm-nmea.
>>>>> New logs attached.
>>>>> Regards,
>>>>> Michael
>>>>> Am 29.03.25 um 15:13 schrieb Info via OvmsDev:
>>>>>> Hi Michael,
>>>>>> thanks for testing.
>>>>>> The results look odd, so I went back to the schematics of OVMS
>>>>>> modules and realized, that I was mistaken. The PWRKEY pin is
>>>>>> actually inverted in the modules as well. This definetly explains
>>>>>> the strange behaviour.
>>>>>> I changed now the logic in simcom_powering.h and the inverted
>>>>>> PWRKEY level is now the default.
>>>>>> Could you please run another test?
>>>>>> Best regards
>>>>>>   Christian
>>>>>> Am 29.03.2025 um 09:25 schrieb Michael Balzer via OvmsDev:
>>>>>>> Christian,
>>>>>>> well done on the 7670 support :-)
>>>>>>> I've just done some first tests of your branch on the 7600,
>>>>>>> which turned up some issues. Logs attached:
>>>>>>>   * Cold boot failed in 2 of 3 test boots, with the driver
>>>>>>>     getting stuck in a loop (poweredon / identify / muxstart)
>>>>>>>   * Regular shutdown fails to power down the modem in time --
>>>>>>>     for a deep sleep phase, this would mean the modem will
>>>>>>>     remain powered on
>>>>>>>   * After a crash, the modem driver gets somehow stuck in
>>>>>>>     PowerOffOn state
>>>>>>> It seems the test for reaction ("AT") sometimes gets skipped,
>>>>>>> even though the modem isn't ready yet.
>>>>>>> On the failed cold boot log, you can see this at the end:
>>>>>>> *I (389178) cellular-modem-auto: Power Cycle*
>>>>>>> I (389178) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
>>>>>>> D (389178) events: Signal(system.modem.poweringon)
>>>>>>> D (389188) events: Signal(egpio.output.0.low)
>>>>>>> D (391678) events: Signal(egpio.output.0.high)
>>>>>>> D (396678) events: Signal(egpio.output.0.low)
>>>>>>> D (396878) events: Signal(egpio.output.0.high)
>>>>>>> *I (396878) cellular: State: Enter Identify state
>>>>>>> D (396978) cellular: tx-cmd: AT+CGMM*
>>>>>>> I (397008) cellular: Identified cellular modem:
>>>>>>> SIM7600/Experimental support for SIMCOM SIM7600
>>>>>>> D (397008) cellular: Remove old 'auto' modem driver
>>>>>>> I (397008) cellular: Set modem driver to 'SIM7600'
>>>>>>> *I (397008) cellular: State: Enter PoweredOn state*
>>>>>>> D (397008) events: Signal(system.modem.installed)
>>>>>>> D (397008) events: Signal(system.modem.poweredon)
>>>>>>> D (406178) cellular: tx-cmd:
>>>>>>> AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
>>>>>>> D (408178) cellular: tx-cmd: AT+CGMR;+ICCID
>>>>>>> D (416178) cellular: tx-cmd: AT+CMUX=0;+CATR=6
>>>>>>> D (434808) cellular: mux-rx-line #0 (2/46): OK
>>>>>>> *D (434808) cellular: mux-rx-line #0 (3/39): RDY*
>>>>>>> D (434808) cellular: mux-rx-line #0 (12/23): +CPIN: READY
>>>>>>> D (434808) cellular: mux-rx-line #0 (8/11): SMS DONE
>>>>>>> D (434808) cellular: mux-rx-line #0 (7/0): PB DONE
>>>>>>> I (434808) cellular: State: Enter MuxStart state
>>>>>>> D (434808) events: Signal(system.modem.muxstart)
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 26.03.25 um 13:13 schrieb Info Zeitnitz via OvmsDev:
>>>>>>>> Dear all,
>>>>>>>> I finished to integrate the Simcom 7670 modem into the OVMS code.
>>>>>>>> See
>>>>>>>> https://github.com/zbchristian/Open-Vehicle-Monitoring-System-3.git
>>>>>>>> branch update_cellular.
>>>>>>>> Modem Powering
>>>>>>>> I had problems to get the 7670 working with the current code.
>>>>>>>> The modem was stuck in a power cycle loop.
>>>>>>>> I checked the Simcom documentation for the 4 models 5360, 7000
>>>>>>>> series, 7600, 7670 and the powering procedure via the PWRKEY
>>>>>>>> pin is the same, but with different on/off timing. Depending on
>>>>>>>> the hardware, the PWRKEY can be inverted as well. This is the
>>>>>>>> case for my Lilygo TCall board, but I think not for the OVMS HW
>>>>>>>> versions. At least version 3.1 connects the corresponding
>>>>>>>> MAX7317 pin directly to the modem.
>>>>>>>> Assuming, that all hardware versions use the PWRKEY procedure
>>>>>>>> for powering, I streamlined the code and moved the
>>>>>>>> corresponding functions into separate files
>>>>>>>> (simcom_powering.cpp and simcom_powering.h). This avoids the
>>>>>>>> duplication of the code.
>>>>>>>> All this leads to substantial changes in ovms_cellular and
>>>>>>>> ovms_cellular_modem_driver as well.
>>>>>>>> The code works now perfectly for the 7670, but testing is
>>>>>>>> required for all other models.
>>>>>>>> If my assumptions about the OVMS HW versions are not correct,
>>>>>>>> or the modems do not work as documented, some modifications
>>>>>>>> might be needed.
>>>>>>>> GNSS Location
>>>>>>>> The 7670 no longer accepts the currently used AT commands to
>>>>>>>> obtain the location  as a GRMC sentence. So, I added code to
>>>>>>>> the new 7670 class to request the location via the AT+CGNSSINFO
>>>>>>>> command.
>>>>>>>> Since this has to be send explicitly again and again,  I
>>>>>>>> implemented a corresponding call in the StatusPoller of the 7670.
>>>>>>>> All the NMEA related code has been adapted to handle the
>>>>>>>> corresponding CGNSSINFO response.
>>>>>>>> In conclusion, before doing a pull request, it would make sense
>>>>>>>> that the code is tested with the other hardware and modem models.
>>>>>>>> So, tell me what you think and if the general strategy of the
>>>>>>>> mods make sense to you.
>>>>>>>> Best regards
>>>>>>>>   Christian
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>>>>>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250330/3c13780c/attachment-0001.htm>
