[Ovmsdev] Integration of Simcom 7670 and changes to Simcom Powering
Sun Mar 30 20:26:42 HKT 2025
PS: please fix the two unused variables now in gsmnmea.cpp:
/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_cellular/src/gsmnmea.cpp:
In member function 'void GsmNMEA::IncomingLine(std::__cxx11::string)':
/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_cellular/src/gsmnmea.cpp:148:40:
warning: variable 'vdop' set but not used [-Wunused-but-set-variable]
float lat=0, lon=0, alt=0, hdop=0, vdop=0, pdop=0;
/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_cellular/src/gsmnmea.cpp:148:48:
warning: variable 'pdop' set but not used [-Wunused-but-set-variable]
Am 30.03.25 um 14:21 schrieb Michael Balzer via OvmsDev:
> Christian,
> the user way to power off/on the modem is via "power cellular off/on",
> that's what I test/ed, and that works.
> After having no issues now with the 7600, I did the tests with my old
> 5360 module.
> That generally also worked, with one exception: on one of four crash
> reboots, the cellular system got stuck in PowerOffOn state, with state
> ticker at 0 and no more activity.
> Logs attached.
> Am 30.03.25 um 13:08 schrieb Info via OvmsDev:
>> Michael,
>> one more thing: if you are performing another test, please check from
>> the console, that the powering of the modem works as well.
>> cellular setstate PoweringOff
>> cellular setstate PoweringOn
>> It did not work when I started with the 7670 and I had to modify
>> ovms_cellular (set m_powermode according to the state) to get it going.
>> Thanks
>> Christian
>> Am 30.03.2025 um 12:02 schrieb Info via OvmsDev:
>>> OK, thanks Michael.
>>> At least this was an easy fix.
>>> Had a look at the NMEA code and I screwed up the istringstream
>>> object when checking for the CGNSSINFO string.
>>> Fixed it and I hope this works now as well.
>>> Best regards
>>> Christian
>>> Am 29.03.2025 um 18:42 schrieb Michael Balzer via OvmsDev:
>>>> Christian,
>>>> the GSM/PPP part now works smoothly with all standard situations
>>>> tested so far.
>>>> But the GPS part doesn't work. It looks like the NMEA sentences are
>>>> received in the MUX channel, but not forwarded to the NMEA module.
>>>> V (794230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa,
>>>> LEN=78)
>>>> V (794230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4,
>>>> LEN=82)
>>>> These should be the NMEA sentences, but there are no corresponding
>>>> log entries from gsm-nmea.
>>>> New logs attached.
>>>> Regards,
>>>> Michael
>>>> Am 29.03.25 um 15:13 schrieb Info via OvmsDev:
>>>>> Hi Michael,
>>>>> thanks for testing.
>>>>> The results look odd, so I went back to the schematics of OVMS
>>>>> modules and realized, that I was mistaken. The PWRKEY pin is
>>>>> actually inverted in the modules as well. This definetly explains
>>>>> the strange behaviour.
>>>>> I changed now the logic in simcom_powering.h and the inverted
>>>>> PWRKEY level is now the default.
>>>>> Could you please run another test?
>>>>> Best regards
>>>>> Christian
>>>>> Am 29.03.2025 um 09:25 schrieb Michael Balzer via OvmsDev:
>>>>>> Christian,
>>>>>> well done on the 7670 support :-)
>>>>>> I've just done some first tests of your branch on the 7600, which
>>>>>> turned up some issues. Logs attached:
>>>>>> * Cold boot failed in 2 of 3 test boots, with the driver
>>>>>> getting stuck in a loop (poweredon / identify / muxstart)
>>>>>> * Regular shutdown fails to power down the modem in time -- for
>>>>>> a deep sleep phase, this would mean the modem will remain
>>>>>> powered on
>>>>>> * After a crash, the modem driver gets somehow stuck in
>>>>>> PowerOffOn state
>>>>>> It seems the test for reaction ("AT") sometimes gets skipped,
>>>>>> even though the modem isn't ready yet.
>>>>>> On the failed cold boot log, you can see this at the end:
>>>>>> *I (389178) cellular-modem-auto: Power Cycle*
>>>>>> I (389178) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
>>>>>> D (389178) events: Signal(system.modem.poweringon)
>>>>>> D (389188) events: Signal(egpio.output.0.low)
>>>>>> D (391678) events: Signal(egpio.output.0.high)
>>>>>> D (396678) events: Signal(egpio.output.0.low)
>>>>>> D (396878) events: Signal(egpio.output.0.high)
>>>>>> *I (396878) cellular: State: Enter Identify state
>>>>>> D (396978) cellular: tx-cmd: AT+CGMM*
>>>>>> I (397008) cellular: Identified cellular modem:
>>>>>> SIM7600/Experimental support for SIMCOM SIM7600
>>>>>> D (397008) cellular: Remove old 'auto' modem driver
>>>>>> I (397008) cellular: Set modem driver to 'SIM7600'
>>>>>> *I (397008) cellular: State: Enter PoweredOn state*
>>>>>> D (397008) events: Signal(system.modem.installed)
>>>>>> D (397008) events: Signal(system.modem.poweredon)
>>>>>> D (406178) cellular: tx-cmd:
>>>>>> AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
>>>>>> D (408178) cellular: tx-cmd: AT+CGMR;+ICCID
>>>>>> D (416178) cellular: tx-cmd: AT+CMUX=0;+CATR=6
>>>>>> D (434808) cellular: mux-rx-line #0 (2/46): OK
>>>>>> *D (434808) cellular: mux-rx-line #0 (3/39): RDY*
>>>>>> D (434808) cellular: mux-rx-line #0 (12/23): +CPIN: READY
>>>>>> D (434808) cellular: mux-rx-line #0 (8/11): SMS DONE
>>>>>> D (434808) cellular: mux-rx-line #0 (7/0): PB DONE
>>>>>> I (434808) cellular: State: Enter MuxStart state
>>>>>> D (434808) events: Signal(system.modem.muxstart)
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 26.03.25 um 13:13 schrieb Info Zeitnitz via OvmsDev:
>>>>>>> Dear all,
>>>>>>> I finished to integrate the Simcom 7670 modem into the OVMS code.
>>>>>>> See
>>>>>>> https://github.com/zbchristian/Open-Vehicle-Monitoring-System-3.git
>>>>>>> branch update_cellular.
>>>>>>> Modem Powering
>>>>>>> I had problems to get the 7670 working with the current code.
>>>>>>> The modem was stuck in a power cycle loop.
>>>>>>> I checked the Simcom documentation for the 4 models 5360, 7000
>>>>>>> series, 7600, 7670 and the powering procedure via the PWRKEY pin
>>>>>>> is the same, but with different on/off timing. Depending on the
>>>>>>> hardware, the PWRKEY can be inverted as well. This is the case
>>>>>>> for my Lilygo TCall board, but I think not for the OVMS HW
>>>>>>> versions. At least version 3.1 connects the corresponding
>>>>>>> MAX7317 pin directly to the modem.
>>>>>>> Assuming, that all hardware versions use the PWRKEY procedure
>>>>>>> for powering, I streamlined the code and moved the corresponding
>>>>>>> functions into separate files (simcom_powering.cpp and
>>>>>>> simcom_powering.h). This avoids the duplication of the code.
>>>>>>> All this leads to substantial changes in ovms_cellular and
>>>>>>> ovms_cellular_modem_driver as well.
>>>>>>> The code works now perfectly for the 7670, but testing is
>>>>>>> required for all other models.
>>>>>>> If my assumptions about the OVMS HW versions are not correct, or
>>>>>>> the modems do not work as documented, some modifications might
>>>>>>> be needed.
>>>>>>> GNSS Location
>>>>>>> The 7670 no longer accepts the currently used AT commands to
>>>>>>> obtain the location as a GRMC sentence. So, I added code to the
>>>>>>> new 7670 class to request the location via the AT+CGNSSINFO
>>>>>>> command.
>>>>>>> Since this has to be send explicitly again and again, I
>>>>>>> implemented a corresponding call in the StatusPoller of the 7670.
>>>>>>> All the NMEA related code has been adapted to handle the
>>>>>>> corresponding CGNSSINFO response.
>>>>>>> In conclusion, before doing a pull request, it would make sense
>>>>>>> that the code is tested with the other hardware and modem models.
>>>>>>> So, tell me what you think and if the general strategy of the
>>>>>>> mods make sense to you.
>>>>>>> Best regards
>>>>>>> Christian
>>>>>>> OvmsDev mailing list
>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>>>>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250330/428f88db/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250330/428f88db/attachment-0001.sig>
