[Ovmsdev] Integration of Simcom 7670 and changes to Simcom Powering
Sun Mar 30 20:21:19 HKT 2025
Christian,
the user way to power off/on the modem is via "power cellular off/on",
that's what I test/ed, and that works.
After having no issues now with the 7600, I did the tests with my old
5360 module.
That generally also worked, with one exception: on one of four crash
reboots, the cellular system got stuck in PowerOffOn state, with state
ticker at 0 and no more activity.
Logs attached.
Am 30.03.25 um 13:08 schrieb Info via OvmsDev:
> Michael,
> one more thing: if you are performing another test, please check from
> the console, that the powering of the modem works as well.
> cellular setstate PoweringOff
> cellular setstate PoweringOn
> It did not work when I started with the 7670 and I had to modify
> ovms_cellular (set m_powermode according to the state) to get it going.
> Thanks
> Christian
> Am 30.03.2025 um 12:02 schrieb Info via OvmsDev:
>> OK, thanks Michael.
>> At least this was an easy fix.
>> Had a look at the NMEA code and I screwed up the istringstream object
>> when checking for the CGNSSINFO string.
>> Fixed it and I hope this works now as well.
>> Best regards
>> Christian
>> Am 29.03.2025 um 18:42 schrieb Michael Balzer via OvmsDev:
>>> Christian,
>>> the GSM/PPP part now works smoothly with all standard situations
>>> tested so far.
>>> But the GPS part doesn't work. It looks like the NMEA sentences are
>>> received in the MUX channel, but not forwarded to the NMEA module.
>>> V (794230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa,
>>> LEN=78)
>>> V (794230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4,
>>> LEN=82)
>>> These should be the NMEA sentences, but there are no corresponding
>>> log entries from gsm-nmea.
>>> New logs attached.
>>> Am 29.03.25 um 15:13 schrieb Info via OvmsDev:
>>>> Hi Michael,
>>>> thanks for testing.
>>>> The results look odd, so I went back to the schematics of OVMS
>>>> modules and realized, that I was mistaken. The PWRKEY pin is
>>>> actually inverted in the modules as well. This definetly explains
>>>> the strange behaviour.
>>>> I changed now the logic in simcom_powering.h and the inverted
>>>> PWRKEY level is now the default.
>>>> Could you please run another test?
>>>> Best regards
>>>> Christian
>>>> Am 29.03.2025 um 09:25 schrieb Michael Balzer via OvmsDev:
>>>>> Christian,
>>>>> well done on the 7670 support :-)
>>>>> I've just done some first tests of your branch on the 7600, which
>>>>> turned up some issues. Logs attached:
>>>>> * Cold boot failed in 2 of 3 test boots, with the driver getting
>>>>> stuck in a loop (poweredon / identify / muxstart)
>>>>> * Regular shutdown fails to power down the modem in time -- for
>>>>> a deep sleep phase, this would mean the modem will remain
>>>>> powered on
>>>>> * After a crash, the modem driver gets somehow stuck in
>>>>> PowerOffOn state
>>>>> It seems the test for reaction ("AT") sometimes gets skipped, even
>>>>> though the modem isn't ready yet.
>>>>> On the failed cold boot log, you can see this at the end:
>>>>> *I (389178) cellular-modem-auto: Power Cycle*
>>>>> I (389178) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
>>>>> D (389178) events: Signal(system.modem.poweringon)
>>>>> D (389188) events: Signal(egpio.output.0.low)
>>>>> D (391678) events: Signal(egpio.output.0.high)
>>>>> D (396678) events: Signal(egpio.output.0.low)
>>>>> D (396878) events: Signal(egpio.output.0.high)
>>>>> *I (396878) cellular: State: Enter Identify state
>>>>> D (396978) cellular: tx-cmd: AT+CGMM*
>>>>> I (397008) cellular: Identified cellular modem:
>>>>> SIM7600/Experimental support for SIMCOM SIM7600
>>>>> D (397008) cellular: Remove old 'auto' modem driver
>>>>> I (397008) cellular: Set modem driver to 'SIM7600'
>>>>> *I (397008) cellular: State: Enter PoweredOn state*
>>>>> D (397008) events: Signal(system.modem.installed)
>>>>> D (397008) events: Signal(system.modem.poweredon)
>>>>> D (406178) cellular: tx-cmd:
>>>>> AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
>>>>> D (408178) cellular: tx-cmd: AT+CGMR;+ICCID
>>>>> D (416178) cellular: tx-cmd: AT+CMUX=0;+CATR=6
>>>>> D (434808) cellular: mux-rx-line #0 (2/46): OK
>>>>> *D (434808) cellular: mux-rx-line #0 (3/39): RDY*
>>>>> D (434808) cellular: mux-rx-line #0 (12/23): +CPIN: READY
>>>>> D (434808) cellular: mux-rx-line #0 (8/11): SMS DONE
>>>>> D (434808) cellular: mux-rx-line #0 (7/0): PB DONE
>>>>> I (434808) cellular: State: Enter MuxStart state
>>>>> D (434808) events: Signal(system.modem.muxstart)
>>>>> Regards,
>>>>> Michael
>>>>> Am 26.03.25 um 13:13 schrieb Info Zeitnitz via OvmsDev:
>>>>>> Dear all,
>>>>>> I finished to integrate the Simcom 7670 modem into the OVMS code.
>>>>>> See
>>>>>> https://github.com/zbchristian/Open-Vehicle-Monitoring-System-3.git
>>>>>> branch update_cellular.
>>>>>> Modem Powering
>>>>>> I had problems to get the 7670 working with the current code. The
>>>>>> modem was stuck in a power cycle loop.
>>>>>> I checked the Simcom documentation for the 4 models 5360, 7000
>>>>>> series, 7600, 7670 and the powering procedure via the PWRKEY pin
>>>>>> is the same, but with different on/off timing. Depending on the
>>>>>> hardware, the PWRKEY can be inverted as well. This is the case
>>>>>> for my Lilygo TCall board, but I think not for the OVMS HW
>>>>>> versions. At least version 3.1 connects the corresponding MAX7317
>>>>>> pin directly to the modem.
>>>>>> Assuming, that all hardware versions use the PWRKEY procedure for
>>>>>> powering, I streamlined the code and moved the corresponding
>>>>>> functions into separate files (simcom_powering.cpp and
>>>>>> simcom_powering.h). This avoids the duplication of the code.
>>>>>> All this leads to substantial changes in ovms_cellular and
>>>>>> ovms_cellular_modem_driver as well.
>>>>>> The code works now perfectly for the 7670, but testing is
>>>>>> required for all other models.
>>>>>> If my assumptions about the OVMS HW versions are not correct, or
>>>>>> the modems do not work as documented, some modifications might be
>>>>>> needed.
>>>>>> GNSS Location
>>>>>> The 7670 no longer accepts the currently used AT commands to
>>>>>> obtain the location as a GRMC sentence. So, I added code to the
>>>>>> new 7670 class to request the location via the AT+CGNSSINFO command.
>>>>>> Since this has to be send explicitly again and again, I
>>>>>> implemented a corresponding call in the StatusPoller of the 7670.
>>>>>> All the NMEA related code has been adapted to handle the
>>>>>> corresponding CGNSSINFO response.
>>>>>> In conclusion, before doing a pull request, it would make sense
>>>>>> that the code is tested with the other hardware and modem models.
>>>>>> So, tell me what you think and if the general strategy of the
>>>>>> mods make sense to you.
>>>>>> Best regards
>>>>>> Christian
>>>>>> OvmsDev mailing list
>>>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>>>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250330/2dba53aa/attachment-0001.htm>
I (1192) psram: This chip is ESP32-D0WD
I (1193) spiram: Found 32MBit SPI RAM device
I (1193) spiram: SPI RAM mode: flash 40m sram 40m
I (1196) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (1203) cpu_start: Pro cpu up.
I (1207) cpu_start: Application information:
I (1212) cpu_start: Project name: ovms3
I (1217) cpu_start: App version: 3.3.004-429-g629e5b8b
I (1223) cpu_start: Compile time: Mar 30 2025 13:28:23
I (1229) cpu_start: ELF file SHA256: 8ba7ed1fff95ef4c...
I (1235) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b
I (1242) cpu_start: Starting app cpu, entry point is 0x400818e0
I (0) cpu_start: App cpu up.
I (2127) spiram: SPI SRAM memory test OK
I (2127) heap_init: Initializing. RAM available for dynamic allocation:
I (2127) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (2133) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM
I (2140) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (2146) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (2153) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM
I (2159) cpu_start: Pro cpu start user code
I (2164) spiram: Adding pool of 4096K of external SPI memory to heap allocator
I (214) ovms_main: Set default logging level for * to INFO
I (215) ovms_main: WATCHDOG already initialized...
I (215) ovms-duktape: Initialising DUKTAPE Registry (1000)
I (222) command: Initialising COMMAND (1010)
I (228) command: Expanding DUKTAPE javascript engine
I (232) boot: Initialising BOOT (1100)
I (237) boot: Power cycle reset detected
I (242) events: Initialising EVENTS (1200)
I (247) config: Initialising CONFIG (1400)
I (252) time: Initialising TIME (1500)
I (256) script: Initialising SCRIPTS (1600)
I (260) ovms-duk-http: Installing DUKTAPE HTTP (1710)
I (266) ovms-duk-util: Installing DUKTAPE Utilities (1710)
I (272) ovms-duk-vfs: Installing DUKTAPE VFS (1710)
I (277) metrics: Initialising METRICS (1810)
I (283) metrics: Expanding DUKTAPE javascript engine
I (288) metrics: Persistent metrics serial 1 using 820 bytes, 0/100 slots used
I (310) notify: Initialising NOTIFICATIONS (1820)
I (312) notify: Registered notification type info
I (312) notify: Registered notification type error
I (316) notify: Registered notification type alert
I (321) notify: Registered notification type data
I (326) notify: Registered notification type stream
I (332) notify: Expanding DUKTAPE javascript engine
I (338) location: Initialising LOCATIONS (1900)
I (346) location: Expanding DUKTAPE javascript engine
I (349) vehicle: Initialising VEHICLE Factory (2000)
I (360) tls: Initialising TLS (3000)
I (361) pcp: Initialising POWER (4000)
I (363) max7317: Initialising MAX7317 EGPIO (4200)
I (369) sdcard: Initialising SD CARD (4400)
I (374) ota: Initialising OTA (4400)
I (380) canformat: Initialising CAN Format Factory (4500)
I (383) canformat-cs11: Registering CAN Format: CS11 (4505)
I (390) canformat-crtd: Registering CAN Format: CRTD (4505)
I (396) canformat-gvret: Registering CAN Format: GVRET (4505)
I (402) canformat-lawicel: Registering CAN Format: LAWICEL (4505)
I (409) canformat-panda: Registering CAN Format: PANDA (4505)
I (416) canformat-pcap: Registering CAN Format: PCAP (4505)
I (422) canformat-raw: Registering CAN Format: RAW (4505)
I (428) can: Initialising CAN (4510)
I (439) dbc-app: Initialising DBC (4520)
I (443) canlog: Initialising CAN logging (4550)
I (444) canlog-monitor: Initialising CAN logging to MONITOR (4560)
I (450) canlog-tcpclient: Initialising CAN logging as TCP client (4560)
I (459) canlog-tcpserver: Initialising CAN logging as TCP server (4560)
I (467) canlog-udpclient: Initialising CAN logging as UDP client (4560)
I (472) canlog-udpserver: Initialising CAN logging as UDP server (4560)
I (481) canlog-vfs: Initialising CAN logging to VFS (4560)
I (485) canplay: Initialising CAN play framework (4570)
I (491) canplay-vfs: Initialising CAN playing from VFS (4580)
I (497) cellular: Initialising CELLULAR (4600)
I (504) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601)
I (509) cellular-modem-auto: Registering auto-detect modem driver (4650)
I (517) SIM5360: Registering SIM5360 modem driver (4650)
I (523) SIM7000: Registering SIM7000 modem driver (4650)
I (529) SIM7600: Registering SIM7600 modem driver (4650)
I (535) SIM7670: Registering Simcom A7670E modem driver (4660)
I (541) tpms: Initialising TPMS (4700)
I (546) test: Initialising TEST (5000)
I (551) module: Initialising MODULE (5100)
I (556) vfs: Initialising VFS (5200)
I (560) ovms-server: Initialising OVMS Server (6000)
I (565) ovms-server-v2: Initialising OVMS V2 Server (6100)
I (572) ovms-server-v3: Initialising OVMS V3 Server (6200)
I (578) vehicle-poll: Initialising Poller (7000)
I (585) obd2ecu: Initialising OBD2ECU (7000)
I (589) canopen: Initialising CANopen (7000)
I (597) pluginstore: Initialising PLUGINS (7100)
I (599) esp32wifi: Initialising ESP32WIFI (8000)
I (604) ovms-mdns: Initialising MDNS (8100)
I (608) webserver: Initialising WEBSERVER (8200)
I (616) ssh: Initialising SSH (8300)
I (618) powermgmt: Initialising POWERMGMT (8500)
I (623) re: Initialising RE Tools (8800)
I (630) pushover: Initialising Pushover client (8800)
I (635) netmanager: Initialising NETMANAGER (8999)
I (642) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000)
I (645) v-zeva: Registering Vehicle: ZEVA (9000)
I (650) v-vweup: Registering Vehicle: VW e-Up (9000)
I (656) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000)
I (663) v-track: Registering Vehicle: TRACK (9000)
I (669) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000)
I (676) v-thinkcity: Registering Vehicle: THINK CITY (9000)
I (682) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000)
I (689) v-teslamodels: Registering Vehicle: Tesla Model S (9000)
I (696) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000)
I (702) v-smarteq: Registering Vehicle: SMART EQ (9000)
I (708) v-smarted: Registering Vehicle: SMART ED (9000)
I (714) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000)
I (721) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000)
I (728) v-twizy: Registering Vehicle: Renault Twizy (9000)
I (734) v-obdii: Registering Vehicle: OBDII (9000)
I (739) v-none: Registering Vehicle: NONE (9000)
I (745) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000)
I (751) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000)
I (761) v-minise: Registering Vehicle: Mini Cooper SE (9000)
I (767) v-mgev4: Registering Vehicle: MG4 (9000)
I (772) v-mgev: Registering Vehicle: MG5 (9000)
I (777) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000)
I (784) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000)
I (790) v-mgev: Registering Vehicle: MG ZS EV (2023-)
I (796) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000)
I (802) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000)
I (808) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000)
I (815) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000)
I (821) v-maple60s: Registering Vehicle: Maple 60S (9000)
I (827) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000)
I (834) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000)
I (841) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000)
I (848) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000)
I (855) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000)
I (862) v-fiat500e: Registering Vehicle: FIAT 500e (9000)
I (868) v-energica: Registering Vehicle: Energica (9000)
I (874) v-demo: Registering Vehicle: DEMO (9000)
I (879) v-dbc: Registering Vehicle: DBC based vehicle (9000)
I (886) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000)
I (894) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000)
I (901) v-atto3: Registering Vehicle: BYD Atto3 (9000)
I (907) v-boltev: Registering Vehicle: Bolt EV (9000)
I (913) v-bmwi3: Registering Vehicle: BMW i3 (9000)
I (918) version: Initialising Versioning (9900)
I (928) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
I (30) ovms-duktape: Duktape: Scripting task is running
I (999) ovms_main: Executing on CPU core 0
I (1009) ovms_main: Mounting CONFIG...
I (1119) ovms_main: Configure logging...
W (1129) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount
I (1129) ovms_main: Registering default configs...
I (1129) ovms_main: Starting HOUSEKEEPING...
I (1139) housekeeping: Initialising HOUSEKEEPING Framework...
I (1139) tls: Built trusted CA cache (5 entries, 8101 bytes)
D (1619) events: Signal(housekeeping.init)
I (1619) housekeeping: Executing on CPU core 1
I (1619) housekeeping: reset_reason: cpu0=1, cpu1=14
I (1619) housekeeping: Starting PERIPHERALS...
I (1629) peripherals: Initialising OVMS Peripherals...
I (1629) peripherals: TCP/IP Adaptor
I (1639) peripherals: ESP32 system
I (1639) peripherals: SPI bus
I (1649) peripherals: MAX7317 I/O Expander
I (1649) peripherals: ESP32 CAN
I (1659) peripherals: ESP32 WIFI
I (1659) peripherals: ESP32 ADC
I (1659) peripherals: MCP2515 CAN 1/2
I (1669) mcp2515: can2: SetPowerMode off
I (1749) peripherals: MCP2515 CAN 2/2
I (1749) mcp2515: can3: SetPowerMode off
I (1829) peripherals: SD CARD
I (1829) peripherals: CELLULAR MODEM
I (1829) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1839) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
V (1849) cellular: Starting modem task
I (1849) uart: queue free spaces: 50
I (1849) ext12v: Powering off external 12V devices
I (1859) housekeeping: Auto init max7317 (free: 160848 bytes)
I (1869) housekeeping: Auto init ext12v (free: 160848 bytes)
I (1869) housekeeping: Auto init dbc (free: 160848 bytes)
I (1879) housekeeping: Auto init wifi (free: 160848 bytes)
I (1899) wifi:wifi driver task: 3ffd9a04, prio:23, stack:3584, core=0
I (1899) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (1909) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (1939) wifi:wifi firmware version: 30f9e79
I (1939) wifi:config NVS flash: enabled
I (1939) wifi:config nano formating: disabled
I (1939) wifi:Init data frame dynamic rx buffer num: 16
I (1939) wifi:Init management frame dynamic rx buffer num: 16
I (1949) wifi:Init management short buffer num: 32
I (1949) wifi:Init dynamic tx buffer num: 16
I (1949) wifi:Init static rx buffer size: 2212
I (1959) wifi:Init static rx buffer num: 16
I (1959) wifi:Init dynamic rx buffer num: 16
I (2739) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
I (2739) wifi:mode : sta (30:ae:a4:43:87:ec) + softAP (30:ae:a4:43:87:ed)
I (2739) wifi:Total power save buffer number: 8
I (2739) wifi:Init max length of beacon: 752/752
I (2749) wifi:Init max length of beacon: 752/752
I (2749) housekeeping: Auto init modem (free: 115428 bytes)
I (2759) housekeeping: Auto init Pollers (free: 115008 bytes)
I (2759) cellular: Set modem driver to 'auto'
I (2759) housekeeping: Auto init vehicle (free: 115008 bytes)
I (2769) cellular: State: Enter PowerOffOn state
I (2779) v-twizy: Renault Twizy vehicle module
I (2779) cellular-modem-auto: Power Cycle
I (2789) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
I (2789) v-twizy: battmon subsystem init
I (2809) v-twizy: pwrmon subsystem init
I (2809) v-twizy: charge subsystem init
I (2809) canopen: Worker started on can1
I (2819) v-twizy: sevcon subsystem init
I (2829) v-twizy: obd subsystem init
I (2829) housekeeping: Auto init obd2ecu (free: 81752 bytes)
I (2829) housekeeping: Auto init server v2 (free: 81752 bytes)
I (2839) ovms-server-v2: OVMS Server V2 registered metric modifier is #2
I (2839) ovms-server-v2: Status: Server has been started
I (2849) ovms-server-v2: OVMS Server v2 running
I (2859) housekeeping: Auto init server v3 (free: 81200 bytes)
I (2859) housekeeping: Auto init javascript (free: 81200 bytes)
I (2869) housekeeping: Auto init done (free: 81160 bytes)
I (2879) housekeeping: Starting USB console...
I (2879) uart: queue free spaces: 100
D (2889) events: Signal(egpio.output.1.low)
D (2899) events: Signal(system.event)
D (2899) events: Signal(system.wifi.sta.start)
D (2909) events: Signal(system.wifi.ap.start)
I (2909) netmanager: WIFI access point is up
D (2919) events: Signal(power.cellular.on)
D (2919) events: Signal(system.modem.stop)
D (2919) events: Signal(vehicle.valet.on)
D (2919) events: Signal(notify.info.valet.enabled)
D (2929) events: Signal(egpio.output.0.low)
D (2929) events: Signal(egpio.output.0.high)
D (2939) events: Signal(power.can1.on)
D (2939) events: Signal(egpio.output.2.low)
D (2949) events: Signal(canopen.worker.start)
D (2949) events: Signal(vehicle.drivemode.33882626)
D (2959) events: Signal(vehicle.type.set)
D (2959) events: Signal(server.v2.waitnetwork)
D (2969) events: Signal(system.start)
I (2969) ovms-mdns: Starting MDNS
D (2969) netmanager: MongooseTask starting
I (2969) ovms-duktape: Duktape: Creating heap (size: 524288 bytes)
Firmware: 3.3.004-429-g629e5b8b/factory/edge
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
D (2989) events: Signal(network.interface.change)
D (2999) events: Signal(network.mgr.init)
I (3019) ssh: Launching SSH Server
OVMS> I (3149) ovms-duktape: Duktape: Initialising module system
D (3169) ovms-duktape: Duktape: Pre-Registered function assert
D (3169) ovms-duktape: Duktape: Pre-Registered function meminfo
D (3169) ovms-duktape: Duktape: Pre-Registered function print
D (3169) ovms-duktape: Duktape: Pre-Registered function write
D (3169) ovms-duktape: Duktape: Pre-Registered object HTTP
D (3169) ovms-duktape: Duktape: Pre-Registered object HTTP function Request
D (3169) ovms-duktape: Duktape: Pre-Registered object HTTP function request
D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsCommand
D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec
D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register
D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig
D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Delete
D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Get
D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function GetValues
D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances
D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params
D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set
D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues
D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsEvents
D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise
D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsLocation
D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status
D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics
D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Age
D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsFloat
D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsJSON
D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues
D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function HasValue
D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsFresh
D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsStale
D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value
D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsNotify
D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsNotify function Raise
D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller
D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetPaused
D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetTraceStatus
D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetUserPaused
D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Pause
D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Resume
D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Trace
D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStarted
D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStatus
D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Reset
D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Start
D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Stop
D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle
D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ClimateControl
D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Homelink
D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Lock
D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ObdRequest
D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent
D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode
D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer
D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge
D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown
D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge
D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown
D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Type
D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unlock
D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unvalet
D (3219) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Valet
D (3219) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup
D (3219) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Disable
D (3219) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Enable
D (3219) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Status
D (3219) ovms-duktape: Duktape: Pre-Registered object VFS
D (3219) ovms-duktape: Duktape: Pre-Registered object VFS function Load
D (3219) ovms-duktape: Duktape: Pre-Registered object VFS function Save
D (3219) ovms-duktape: Duktape: Pre-Registered module JSON
D (3239) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js'
D (3239) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes)
D (3239) ovms-duktape: Duktape: module load: int/JSON.js
D (3329) ovms-duktape: Duktape: Pre-Registered module PubSub
D (3349) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js'
D (3349) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes)
D (3349) ovms-duktape: Duktape: module load: int/PubSub.js
I (3559) ovms-duktape: Duktape: Executing ovmsmain.js
D (3559) ovms-duktape: Duktape: module load: ovmsmain.js
D (3579) ovms-duktape: Duktape: module unload: ovmsmain.js
D (3619) events: Signal(vehicle.charge.mode)
OVMS> D (4619) events: Signal(vehicle.aux.12v.normal)
OVMS> D (5299) events: Signal(egpio.output.0.low)
D (5359) events: Signal(system.event)
D (5359) events: Signal(system.wifi.scan.done)
I (5489) wifi:ap channel adjust o:1,0 n:11,0
I (5489) wifi:new:<11,0>, old:<1,0>, ap:<11,0>, sta:<11,0>, prof:1
OVMS> I (6169) wifi:state: init -> auth (b0)
I (6189) wifi:state: auth -> assoc (0)
I (6199) wifi:state: assoc -> run (10)
I (6219) wifi:connected with LeonsLair, aid = 2, channel 11, BW20, bssid = d4:24:dd:88:1e:85
I (6219) wifi:security type: 3, phy: bgn, rssi: -55
I (6219) wifi:pm start, type: 1
D (6229) events: Signal(system.event)
D (6229) events: Signal(system.wifi.sta.connected)
D (6229) netmanager: send cmd 3 from 0x0
D (6229) netmanager: done cmd 3 from 0x0
I (6249) event: sta ip: 192.168.178.33, mask: 255.255.255.0, gw: 192.168.178.1
D (6249) events: Signal(system.event)
D (6249) events: Signal(network.interface.up)
D (6259) events: Signal(system.wifi.sta.gotip)
I (6259) netmanager: WIFI client got IP
D (6259) netmanager: Saved DNS#0 192.168.178.1
D (6259) netmanager: Saved DNS#1 0.0.0.0
D (6259) netmanager: Saved DNS#2 0.0.0.0
D (6259) netmanager: send cmd 3 from 0x0
D (6259) netmanager: done cmd 3 from 0x0
I (6269) wifi:AP's beacon interval = 102400 us, DTIM period = 1
D (6249) netmanager: MongooseTask: got cmd 3 from 0x0
D (6289) netmanager: MongooseTask: done cmd 3 from 0x0
D (6289) netmanager: MongooseTask: got cmd 3 from 0x0
D (6299) netmanager: MongooseTask: done cmd 3 from 0x0
OVMS> D (7619) events: Signal(network.wifi.sta.good)
I (7619) netmanager: WIFI client has good signal quality (-85.3 dBm); connect
I (7619) netmanager: Interface priority is st1 (192.168.178.33/255.255.255.0 gateway 192.168.178.1)
I (7619) netmanager: Set DNS#1 0.0.0.0
I (7619) netmanager: Set DNS#2 0.0.0.0
I (7619) netmanager: WIFI client up (with MODEM down): starting network with WIFI client
D (7629) events: Signal(network.wifi.up)
D (7629) events: Signal(network.up)
I (7629) ovms-server-v2: Status: Network is up, so attempt network connection
D (7629) events: Signal(network.interface.change)
D (7639) events: Signal(server.v2.connectwait)
OVMS> I (9619) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1
I (9619) ovms-server-v2: Status: Connecting...
D (9649) events: Signal(server.v2.connecting)
OVMS> D (10299) events: Signal(egpio.output.0.high)
D (10499) events: Signal(egpio.output.0.low)
OVMS> D (10999) cellular: State timeout PowerOffOn => PoweringOn
I (10999) cellular: State: Enter PoweringOn state
I (10999) cellular-modem-auto: Power Cycle
D (10999) events: Signal(system.modem.poweringon)
I (10999) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
D (10999) events: Signal(egpio.output.0.high)
OVMS> I (13149) ovms-server-v2: Connection successful
I (13149) ovms-server-v2: Status: Logging in...
D (13159) events: Signal(server.v2.authenticating)
I (13159) ovms-server-v2: Sending server login: MP-C 0 6EQPbaYviEeaaOE9kzsLyB //LWT79yBsM6Vei+A2HG9g== TEST1
I (13199) ovms-server-v2: Got server response: MP-S 0 I1mn1eqQv2tTW7A2RwHQ7r jTMnTslUVDNXFmkeBECwAA==
I (13199) ovms-server-v2: Server token is I1mn1eqQv2tTW7A2RwHQ7r and digest is jTMnTslUVDNXFmkeBECwAA==
I (13209) ovms-server-v2: Status: Server authentication ok. Now priming crypto.
I (13209) ovms-server-v2: Shared secret key is I1mn1eqQv2tTW7A2RwHQ7r6EQPbaYviEeaaOE9kzsLyB (44 bytes)
I (13209) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
D (13209) events: Signal(server.v2.connected)
I (13239) ovms-server-v2: Incoming Msg: MP-0 Z0
OVMS> D (13499) events: Signal(egpio.output.0.low)
I (13619) ovms-server-v2: Send MP-0 S0,K,0,0.00,,standard,50,50,15,0,0,0,0,0,0,0,0,0,92.98,0,0,56,21,-1,0,0,0,0,0,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.0,0.0,0.0,0.0,-1
I (13629) ovms-server-v2: Send MP-0 D0,16,5,0,0,0,0,0,0,10,0,0,1,1,12.33,0,12.6,0,0,0,0
I (13629) ovms-server-v2: Send MP-0 L0,0,0,0,0,0,0,0,2050202,0,0.000,0.000,0,0,,0,0,0,0
I (13629) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1
I (13629) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1
I (13629) ovms-server-v2: Send MP-0 F3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),,27,0,RT,LeonsLair,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/1,
OVMS> D (18499) events: Signal(egpio.output.0.high)
D (18699) events: Signal(egpio.output.0.low)
I (18799) cellular: State: Enter Identify state
D (18899) cellular: tx-cmd: AT+CGMM
I (18909) cellular: Identified cellular modem: SIM5360/SIMCOM SIM5360 (include US and EU variants)
D (18909) cellular: Remove old 'auto' modem driver
I (18909) cellular: Set modem driver to 'SIM5360'
I (18909) cellular: State: Enter PoweredOn state
D (18909) events: Signal(system.modem.installed)
D (18919) events: Signal(system.modem.poweredon)
D (19019) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (19809) cellular: mux-rx-line #0 (12/32): +CPIN: READY
D (19809) cellular: mux-rx-line #0 (12/16): OPL UPDATING
D (19809) cellular: mux-rx-line #0 (12/0): PNN UPDATING
OVMS> D (20539) cellular: mux-rx-line #0 (8/0): SMS DONE
OVMS> D (21139) cellular: mux-rx-line #0 (10/11): CALL READY
D (21139) cellular: mux-rx-line #0 (7/0): PB DONE
OVMS> D (26619) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
D (26639) cellular: mux-rx-line #0 (106/0): AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
D (26679) cellular: mux-rx-line #0 (12/20): +CPIN: READY
D (26679) cellular: mux-rx-line #0 (10/6): +CSQ: 23,0
D (26679) cellular: Signal Quality is: 23 (-67 dBm)
D (26679) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (28059) cellular: mux-rx-line #0 (26/0): +CTZV: 8,25/03/30,11:31:00
OVMS> D (28619) cellular: tx-cmd: AT+CGMR;+ICCID
D (28629) cellular: mux-rx-line #0 (23/37): +CGMR: 35316B11SIM5360E
D (28629) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389
D (28629) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (32339) cellular: mux-rx-line #0 (11/0): +CSQ: 23,99
OVMS> D (32619) cellular: tx-cmd: AT+CMUXSRVPORT=3,1
D (32629) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (33619) cellular: tx-cmd: AT+CMUXSRVPORT=2,1
D (33629) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (34619) cellular: tx-cmd: AT+CMUXSRVPORT=1,1
D (34629) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (35619) cellular: tx-cmd: AT+CMUXSRVPORT=0,5
D (35629) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (36619) cellular: tx-cmd: AT+CMUX=0;+CATR=6
D (36629) cellular: mux-rx-line #0 (2/0): OK
I (36629) cellular: State: Enter MuxStart state
V (36629) cellular: Starting MUX
D (36629) events: Signal(system.modem.muxstart)
I (36629) gsm-mux: Start MUX
I (36629) gsm-mux: Channel #0 is open
I (36639) gsm-mux: Channel #1 is open
I (36639) gsm-mux: Channel #2 is open
I (36649) gsm-mux: Channel #3 is open
I (36659) gsm-mux: Channel #4 is open
OVMS> D (37619) cellular: State transition MuxStart => NetWait
I (37619) cellular: State: Enter NetWait state
V (37619) cellular: Starting NMEA
I (37619) gsm-nmea: Startup
D (37619) cellular: mux-tx #4: AT+CGPSNMEA=66;+CGPS=1,1
D (37619) events: Signal(system.modem.netwait)
D (37629) events: Signal(system.modem.gpsstart)
D (37709) cellular: mux-rx-line #4 (2/0): OK
OVMS> I (45629) ovms-server-v2: Send MP-0 h1,0,RT-BAT-P,1,86400,1,1,0,10000,0,0,1000,0,-40,200,-40,0,0,0,0,0,0,0,0
I (45629) ovms-server-v2: Send MP-0 h2,0,RT-BAT-C,1,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45629) ovms-server-v2: Send MP-0 h3,0,RT-BAT-C,2,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45629) ovms-server-v2: Send MP-0 h4,0,RT-BAT-C,3,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45629) ovms-server-v2: Send MP-0 h5,0,RT-BAT-C,4,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45779) ovms-server-v2: Incoming Msg: MP-0 h1
I (45779) ovms-server-v2: Incoming Msg: MP-0 h2
I (45779) ovms-server-v2: Incoming Msg: MP-0 h3
I (45789) ovms-server-v2: Incoming Msg: MP-0 h4
I (45789) ovms-server-v2: Incoming Msg: MP-0 h5
OVMS> I (46619) ovms-server-v2: Send MP-0 h6,-1,RT-BAT-C,5,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46619) ovms-server-v2: Send MP-0 h7,-1,RT-BAT-C,6,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46619) ovms-server-v2: Send MP-0 h8,-1,RT-BAT-C,7,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46619) ovms-server-v2: Send MP-0 h9,-1,RT-BAT-C,8,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46629) ovms-server-v2: Send MP-0 h10,-1,RT-BAT-C,9,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46829) ovms-server-v2: Incoming Msg: MP-0 h6
I (46829) ovms-server-v2: Incoming Msg: MP-0 h7
I (46829) ovms-server-v2: Incoming Msg: MP-0 h8
I (46829) ovms-server-v2: Incoming Msg: MP-0 h9
I (46839) ovms-server-v2: Incoming Msg: MP-0 h10
OVMS> D (47619) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
I (47619) ovms-server-v2: Send MP-0 h11,-2,RT-BAT-C,10,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47619) ovms-server-v2: Send MP-0 h12,-1,RT-BAT-C,11,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47619) ovms-server-v2: Send MP-0 h13,-1,RT-BAT-C,12,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47619) ovms-server-v2: Send MP-0 h14,-1,RT-BAT-C,13,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47629) ovms-server-v2: Send MP-0 h15,-2,RT-BAT-C,14,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
D (47649) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
I (47649) cellular: Network Registration status: RegisteredRoaming
D (47649) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:31:19+08"
D (47649) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99
D (47649) cellular: mux-rx-line #3 (2/0): OK
I (47869) ovms-server-v2: Incoming Msg: MP-0 h11
I (47869) ovms-server-v2: Incoming Msg: MP-0 h12
I (47869) ovms-server-v2: Incoming Msg: MP-0 h13
I (47869) ovms-server-v2: Incoming Msg: MP-0 h14
I (47879) ovms-server-v2: Incoming Msg: MP-0 h15
OVMS> D (48619) cellular: mux-tx #3: AT+CPSI?
D (48619) cellular: State transition NetWait => NetStart
I (48619) cellular: State: Enter NetStart state
D (48619) events: Signal(system.modem.netstart)
D (48629) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-68,0,39-39
I (48629) cellular: Network Mode: GSM,Online
D (48629) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (49619) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
D (49649) cellular: mux-rx-line #2 (14/0): CONNECT 115200
I (49649) cellular: PPP Connection is ready to start
OVMS> D (50619) cellular: State transition NetStart => NetMode
I (50619) cellular: State: Enter NetMode state
V (50619) cellular: Launching PPP
V (50619) cellular: Starting PPP
I (50619) gsm-ppp: Initialising...
D (50629) events: Signal(system.modem.netmode)
OVMS> I (51469) gsm-ppp: StatusCallBack: None
I (51469) gsm-ppp: status_cb: Connected
I (51469) gsm-ppp: our_ipaddr = 10.170.195.13
I (51469) gsm-ppp: his_ipaddr = 10.64.64.64
I (51469) gsm-ppp: netmask = 255.255.255.255
I (51469) gsm-ppp: DNS#0 = 8.8.8.8
I (51469) gsm-ppp: DNS#1 = 8.8.4.4
I (51469) gsm-ppp: our6_ipaddr = ::
D (51469) events: Signal(network.interface.up)
D (51479) events: Signal(system.modem.gotip)
D (51479) netmanager: Saved DNS#0 8.8.8.8
D (51479) netmanager: Saved DNS#1 8.8.4.4
D (51479) netmanager: Saved DNS#2 0.0.0.0
I (51479) netmanager: Set DNS#1 0.0.0.0
I (51479) netmanager: Set DNS#2 0.0.0.0
I (51479) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority
D (51479) events: Signal(network.modem.up)
D (51479) events: Signal(network.interface.change)
OVMS> D (51889) events: Signal(gps.lock.acquired)
D (51889) events: Signal(system.modem.gotgps)
OVMS> I (52619) ovms-server-v2: Send MP-0 h16,0,RT-GPS-Log,0,86400,51.403725,7.440220,158,0,0,1,0,-60,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (52679) ovms-server-v2: Incoming Msg: MP-0 h16
OVMS> D (53339) cellular: mux-rx-line #3 (10/0): +CSQ: 23,0
OVMS> D (56339) cellular: mux-rx-line #3 (11/0): +CSQ: 23,99
OVMS> D (62679) ovms-duktape: Duktape: Compacting DukTape memory done in 50 ms
OVMS> D (80619) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
D (80639) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
D (80639) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:31:52+08"
D (80639) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99
D (80639) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (81619) cellular: mux-tx #3: AT+CPSI?
D (81629) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38
D (81629) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (82619) cellular: mux-tx #3: AT+COPS?
D (82629) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0
I (82629) cellular: Network Provider is: vodafone.de Hologram
D (82629) cellular: mux-rx-line #3 (2/0): OK
OVMS> I (84619) ovms-server-v2: Send MP-0 h17,0,RT-GPS-Log,0,86400,51.403793,7.440117,159,0,0,1,0,-56,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (84829) ovms-server-v2: Incoming Msg: MP-0 h17
OVMS> D (110619) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
D (110629) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
D (110629) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:32:22+08"
D (110629) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99
D (110639) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (111619) cellular: mux-tx #3: AT+CPSI?
D (111629) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-68,0,39-39
D (111629) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (112619) cellular: mux-tx #3: AT+COPS?
D (112629) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0
D (112629) cellular: mux-rx-line #3 (2/0): OK
OVMS> I (122629) housekeeping: System considered stable (RAM: 8b=45708-48964 32b=12128 SPI=3203128-3218504)
D (122679) ovms-duktape: Duktape: Compacting DukTape memory done in 30 ms
OVMS> D (140619) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
D (140629) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
D (140639) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:32:52+08"
D (140639) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99
D (140639) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (141619) cellular: mux-tx #3: AT+CPSI?
D (141629) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-68,0,39-39
D (141629) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (142619) cellular: mux-tx #3: AT+COPS?
D (142629) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0
D (142629) cellular: mux-rx-line #3 (2/0): OK
OVMS> I (144619) ovms-server-v2: Send MP-0 h18,0,RT-GPS-Log,0,86400,51.403797,7.440110,158,0,0,1,0,-57,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
OVMS> I (144829) ovms-server-v2: Incoming Msg: MP-0 h18
OVMS> enable
Password:
Secure mode
OVMS# module reset
Resetting system...
OVMS# I (168689) boot: Shutting down for Restart...
D (168689) events: Signal(system.shuttingdown)
W (168689) boot: Shutdown: vehicle pending, 1 total
I (168699) v-twizy: Shutdown Renault Twizy vehicle module
I (168699) v-twizy: obd subsystem shutdown
I (168699) v-twizy: sevcon subsystem shutdown
I (168699) v-twizy: charge subsystem shutdown
I (168699) v-twizy: pwrmon subsystem shutdown
I (168709) v-twizy: battmon subsystem shutdown
W (168709) boot: Shutdown: vehicle-poll pending, 2 total
I (168719) wifi:state: run -> init (0)
I (168719) wifi:pm stop, total sleep time: 152092279 us / 162499490 us
I (168719) wifi:new:<11,0>, old:<11,0>, ap:<11,0>, sta:<11,0>, prof:1
I (168729) wifi:flush txq
I (168729) wifi:stop sw txq
E (168729) mongoose: mg_ssl_if_mbed_err 0x3f864380 SSL error: -1
I (168729) wifi:lmac stop hw txq
I (168739) wifi:Deinit lldesc rx mblock:16
E (168739) event: system_event_ap_stop_handle_default 223 esp_wifi_internal_reg_rxcb ret=0x3001
E (168739) ovms-server-v2: Status: Connection lost, reconnecting
W (168749) boot: Shutdown: cellular pending, 3 total
I (168749) cellular: State: Enter PoweringOff state
W (168749) boot: Shutdown: ovms-duktape pending, 4 total
V (168749) cellular: Stopping PPP
W (168749) boot: Shutdown: webserver pending, 5 total
I (168749) gsm-ppp: Shutting down (hard)...
I (168749) gsm-ppp: StatusCallBack: User Interrupt
I (168759) gsm-ppp: PPP is shutdown
V (168759) cellular: Stopping NMEA
D (168759) cellular: mux-tx #4: AT+CGPSNMEA=0
D (168759) events: Signal(power.can1.off)
D (168759) events: Signal(egpio.output.2.high)
D (168769) events: Signal(system.wifi.down)
I (168769) netmanager: WIFI client stop
I (168769) netmanager: Interface priority is pp3 (0.0.0.0/255.255.255.255 gateway 0.0.0.0)
I (168769) netmanager: Set DNS#2 0.0.0.0
I (168769) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority
D (168769) netmanager: send cmd 3 from 0x0
D (168769) netmanager: done cmd 3 from 0x0
D (168769) events: Signal(system.event)
D (168769) events: Signal(system.wifi.sta.disconnected)
D (168779) events: Signal(system.event)
D (168779) events: Signal(network.wifi.sta.bad)
D (168779) events: Signal(system.wifi.sta.stop)
I (168779) netmanager: Set DNS#2 0.0.0.0
D (168779) netmanager: send cmd 3 from 0x0
D (168779) netmanager: done cmd 3 from 0x0
D (168789) events: Signal(system.event)
D (168789) events: Signal(system.wifi.ap.stop)
I (168789) netmanager: Set DNS#2 0.0.0.0
I (168789) netmanager: WIFI access point is down
W (168789) ovms-duktape: EventScript: event 'system.wifi.ap.stop' delayed, queued at position 11/40
D (168789) events: Signal(server.v2.waitreconnect)
W (168789) ovms-duktape: EventScript: event 'server.v2.waitreconnect' delayed, queued at position 12/40
D (168789) events: Signal(system.modem.down)
I (168799) netmanager: MODEM down (with WIFI client down): network connectivity has been lost
W (168799) ovms-duktape: EventScript: event 'system.modem.down' delayed, queued at position 13/40
D (168799) events: Signal(network.wifi.down)
W (168799) ovms-duktape: EventScript: event 'network.wifi.down' delayed, queued at position 14/40
D (168799) events: Signal(network.reconfigured)
I (168799) ovms-server-v2: Status: Network was reconfigured: disconnect and reconnect
W (168799) ovms-duktape: EventScript: event 'network.reconfigured' delayed, queued at position 15/40
D (168799) events: Signal(network.interface.change)
W (168809) ovms-duktape: EventScript: event 'network.interface.change' delayed, queued at position 16/40
D (168809) events: Signal(network.interface.change)
W (168809) ovms-duktape: EventScript: event 'network.interface.change' delayed, queued at position 17/40
D (168809) events: Signal(network.modem.down)
W (168809) ovms-duktape: EventScript: event 'network.modem.down' delayed, queued at position 18/40
D (168809) events: Signal(network.down)
W (168809) ovms-duktape: EventScript: event 'network.down' delayed, queued at position 19/40
D (168819) events: Signal(network.interface.change)
W (168819) ovms-duktape: EventScript: event 'network.interface.change' delayed, queued at position 20/40
D (168819) events: Signal(server.v2.connectwait)
W (168819) ovms-duktape: EventScript: event 'server.v2.connectwait' delayed, queued at position 21/40
D (168829) ovms-duktape: Duktape: module unload all
I (168829) ovms-duktape: Duktape: Clearing existing context
D (168859) cellular: mux-tx #4: AT+CGPS=0
I (168859) gsm-nmea: Shutdown (direct)
D (168859) events: Signal(gps.lock.lost)
I (168859) cellular-modem-auto: Power Off - timing: 2500 ms
W (168859) ovms-duktape: EventScript: event 'gps.lock.lost' delayed, queued at position 22/40
I (168859) Simcom: Power Off - 2500 ms
D (168859) events: Signal(system.modem.lostgps)
W (168859) ovms-duktape: EventScript: event 'system.modem.lostgps' delayed, queued at position 23/40
D (168869) events: Signal(system.modem.gpsstop)
W (168869) ovms-duktape: EventScript: event 'system.modem.gpsstop' delayed, queued at position 24/40
D (168869) events: Signal(egpio.output.3.low)
W (168869) ovms-duktape: EventScript: event 'egpio.output.3.low' delayed, queued at position 25/40
D (168869) events: Signal(egpio.output.0.high)
W (168869) ovms-duktape: EventScript: event 'egpio.output.0.high' delayed, queued at position 26/40
D (168989) netmanager: MongooseTask: got cmd 3 from 0x0
D (168989) netmanager: MongooseTask: done cmd 3 from 0x0
D (168989) netmanager: MongooseTask stopping
D (168989) events: Signal(network.mgr.stop)
I (168989) ssh: Stopping SSH Server
OVMS# I (169619) ovms-server-v2: Status: Server is ready to start
I (169619) boot: Shutdown: vehicle ready, 4 pending
I (169619) boot: Shutdown: vehicle-poll ready, 3 pending
I (169619) boot: Shutdown: ovms-duktape ready, 2 pending
D (169619) events: Signal(server.v2.waitnetwork)
OVMS# D (171359) events: Signal(egpio.output.0.low)
OVMS# I (171619) boot: Shutdown: webserver ready, 1 pending
OVMS# I (173619) boot: Restart in 65 seconds (1 pending)...
OVMS# D (176359) events: Signal(system.modem.stop)
OVMS# I (178619) boot: Restart in 60 seconds (1 pending)...
OVMS# I (183619) boot: Restart in 55 seconds (1 pending)...
OVMS# I (188619) boot: Restart in 50 seconds (1 pending)...
D (188619) cellular: State timeout PoweringOff => CheckPowerOff
I (188619) cellular: State: Enter CheckPowerOff state
OVMS# D (191619) cellular: tx-cmd: AT
OVMS# I (193619) boot: Restart in 45 seconds (1 pending)...
OVMS# D (194619) cellular: tx-cmd: AT
OVMS# D (197619) cellular: tx-cmd: AT
OVMS# I (198619) boot: Restart in 40 seconds (1 pending)...
OVMS# D (200619) cellular: tx-cmd: AT
OVMS# D (203619) cellular: tx-cmd: AT
I (203619) boot: Restart in 35 seconds (1 pending)...
D (203619) cellular: State timeout CheckPowerOff => PoweredOff
I (203619) cellular: State: Enter PoweredOff state
V (203619) cellular: Stopping MUX
I (203619) gsm-mux: Stop MUX
D (203619) events: Signal(system.modem.poweredoff)
D (203619) cellular: UART shutdown
I (203619) boot: Shutdown: cellular ready, 0 pending
OVMS# I (204619) boot: Restart now
OVMS# D (205619) events: Signal(system.shutdown)ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5328
ho 0 tail 12 room 4
load:0x40078000,len:11332
load:0x40080400,len:6204
entry 0x400806cc
I (1192) spiram: Found 32MBit SPI RAM device
I (1233) cpu_start: App cpu up.
I (215) ovms_main: Set default logging level for * to INFO
I (237) boot: Boot #1 reasons for CPU0=12 and CPU1=12
I (242) boot: Soft reset by user
I (247) events: Initialising EVENTS (1200)
I (252) config: Initialising CONFIG (1400)
I (257) time: Initialising TIME (1500)
I (261) script: Initialising SCRIPTS (1600)
I (265) ovms-duk-http: Installing DUKTAPE HTTP (1710)
I (271) ovms-duk-util: Installing DUKTAPE Utilities (1710)
I (277) ovms-duk-vfs: Installing DUKTAPE VFS (1710)
I (283) metrics: Initialising METRICS (1810)
I (288) metrics: Expanding DUKTAPE javascript engine
I (293) metrics: Persistent metrics serial 2 using 820 bytes, 68/100 slots used
I (303) metrics: persist v.b.cac = 92.9772Ah
I (307) metrics: persist v.b.range.est = 50km
I (311) metrics: persist v.b.12v.voltage = 12.59V
I (317) metrics: persist v.b.12v.voltage.ref = 12.6V
I (323) metrics: persist v.c.climit = 15A
I (328) metrics: persist v.c.limit.range = 56km
I (332) metrics: persist v.c.limit.soc = 21%
I (341) metrics: persist v.e.drivemode = 33882626
I (343) metrics: persist v.e.valet = yes
I (347) metrics: persist v.e.parktime = 165Sec
I (354) metrics: persist v.p.latitude = 51.4038
I (358) metrics: persist v.p.longitude = 7.44011
I (363) metrics: persist v.p.altitude = 158.5m
I (370) notify: Initialising NOTIFICATIONS (1820)
I (374) notify: Registered notification type info
I (378) notify: Registered notification type error
I (384) notify: Registered notification type alert
I (389) notify: Registered notification type data
I (395) notify: Registered notification type stream
I (400) notify: Expanding DUKTAPE javascript engine
I (406) location: Initialising LOCATIONS (1900)
I (414) location: Expanding DUKTAPE javascript engine
I (417) vehicle: Initialising VEHICLE Factory (2000)
I (428) tls: Initialising TLS (3000)
I (429) pcp: Initialising POWER (4000)
I (431) max7317: Initialising MAX7317 EGPIO (4200)
I (437) sdcard: Initialising SD CARD (4400)
I (442) ota: Initialising OTA (4400)
I (448) canformat: Initialising CAN Format Factory (4500)
I (452) canformat-cs11: Registering CAN Format: CS11 (4505)
I (458) canformat-crtd: Registering CAN Format: CRTD (4505)
I (464) canformat-gvret: Registering CAN Format: GVRET (4505)
I (471) canformat-lawicel: Registering CAN Format: LAWICEL (4505)
I (477) canformat-panda: Registering CAN Format: PANDA (4505)
I (484) canformat-pcap: Registering CAN Format: PCAP (4505)
I (490) canformat-raw: Registering CAN Format: RAW (4505)
I (496) can: Initialising CAN (4510)
I (508) dbc-app: Initialising DBC (4520)
I (511) canlog: Initialising CAN logging (4550)
I (512) canlog-monitor: Initialising CAN logging to MONITOR (4560)
I (518) canlog-tcpclient: Initialising CAN logging as TCP client (4560)
I (528) canlog-tcpserver: Initialising CAN logging as TCP server (4560)
I (535) canlog-udpclient: Initialising CAN logging as UDP client (4560)
I (541) canlog-udpserver: Initialising CAN logging as UDP server (4560)
I (550) canlog-vfs: Initialising CAN logging to VFS (4560)
I (554) canplay: Initialising CAN play framework (4570)
I (559) canplay-vfs: Initialising CAN playing from VFS (4580)
I (566) cellular: Initialising CELLULAR (4600)
I (572) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601)
I (577) cellular-modem-auto: Registering auto-detect modem driver (4650)
I (585) SIM5360: Registering SIM5360 modem driver (4650)
I (591) SIM7000: Registering SIM7000 modem driver (4650)
I (597) SIM7600: Registering SIM7600 modem driver (4650)
I (603) SIM7670: Registering Simcom A7670E modem driver (4660)
I (609) tpms: Initialising TPMS (4700)
I (615) test: Initialising TEST (5000)
I (620) module: Initialising MODULE (5100)
I (625) vfs: Initialising VFS (5200)
I (629) ovms-server: Initialising OVMS Server (6000)
I (633) ovms-server-v2: Initialising OVMS V2 Server (6100)
I (640) ovms-server-v3: Initialising OVMS V3 Server (6200)
I (646) vehicle-poll: Initialising Poller (7000)
I (654) obd2ecu: Initialising OBD2ECU (7000)
I (657) canopen: Initialising CANopen (7000)
I (665) pluginstore: Initialising PLUGINS (7100)
I (668) esp32wifi: Initialising ESP32WIFI (8000)
I (672) ovms-mdns: Initialising MDNS (8100)
I (676) webserver: Initialising WEBSERVER (8200)
I (684) ssh: Initialising SSH (8300)
I (686) powermgmt: Initialising POWERMGMT (8500)
I (692) re: Initialising RE Tools (8800)
I (698) pushover: Initialising Pushover client (8800)
I (703) netmanager: Initialising NETMANAGER (8999)
I (710) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000)
I (713) v-zeva: Registering Vehicle: ZEVA (9000)
I (719) v-vweup: Registering Vehicle: VW e-Up (9000)
I (724) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000)
I (732) v-track: Registering Vehicle: TRACK (9000)
I (737) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000)
I (744) v-thinkcity: Registering Vehicle: THINK CITY (9000)
I (750) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000)
I (757) v-teslamodels: Registering Vehicle: Tesla Model S (9000)
I (764) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000)
I (770) v-smarteq: Registering Vehicle: SMART EQ (9000)
I (776) v-smarted: Registering Vehicle: SMART ED (9000)
I (782) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000)
I (790) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000)
I (796) v-twizy: Registering Vehicle: Renault Twizy (9000)
I (802) v-obdii: Registering Vehicle: OBDII (9000)
I (808) v-none: Registering Vehicle: NONE (9000)
I (813) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000)
I (819) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000)
I (829) v-minise: Registering Vehicle: Mini Cooper SE (9000)
I (835) v-mgev4: Registering Vehicle: MG4 (9000)
I (840) v-mgev: Registering Vehicle: MG5 (9000)
I (846) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000)
I (852) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000)
I (858) v-mgev: Registering Vehicle: MG ZS EV (2023-)
I (864) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000)
I (870) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000)
I (877) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000)
I (883) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000)
I (889) v-maple60s: Registering Vehicle: Maple 60S (9000)
I (895) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000)
I (902) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000)
I (909) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000)
I (916) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000)
I (923) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000)
I (930) v-fiat500e: Registering Vehicle: FIAT 500e (9000)
I (936) v-energica: Registering Vehicle: Energica (9000)
I (942) v-demo: Registering Vehicle: DEMO (9000)
I (948) v-dbc: Registering Vehicle: DBC based vehicle (9000)
I (954) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000)
I (962) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000)
I (970) v-atto3: Registering Vehicle: BYD Atto3 (9000)
I (975) v-boltev: Registering Vehicle: Bolt EV (9000)
I (981) v-bmwi3: Registering Vehicle: BMW i3 (9000)
I (987) version: Initialising Versioning (9900)
I (995) cpu_start: Starting scheduler on PRO CPU.
I (1067) ovms_main: Executing on CPU core 0
I (1077) ovms_main: Mounting CONFIG...
I (1187) ovms_main: Configure logging...
W (1197) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount
I (1197) ovms_main: Registering default configs...
I (1197) ovms_main: Starting HOUSEKEEPING...
I (1207) housekeeping: Initialising HOUSEKEEPING Framework...
I (1207) tls: Built trusted CA cache (5 entries, 8101 bytes)
D (1687) events: Signal(housekeeping.init)
I (1687) housekeeping: Executing on CPU core 1
I (1687) housekeeping: reset_reason: cpu0=12, cpu1=12
I (1687) housekeeping: Starting PERIPHERALS...
I (1697) peripherals: Initialising OVMS Peripherals...
I (1697) peripherals: TCP/IP Adaptor
I (1707) peripherals: ESP32 system
I (1707) peripherals: SPI bus
I (1717) peripherals: MAX7317 I/O Expander
I (1717) peripherals: ESP32 CAN
I (1727) peripherals: ESP32 WIFI
I (1727) peripherals: ESP32 ADC
I (1727) peripherals: MCP2515 CAN 1/2
I (1737) mcp2515: can2: SetPowerMode off
I (1817) peripherals: MCP2515 CAN 2/2
I (1817) mcp2515: can3: SetPowerMode off
I (1897) peripherals: SD CARD
I (1897) peripherals: CELLULAR MODEM
I (1897) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1907) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
V (1917) cellular: Starting modem task
I (1917) uart: queue free spaces: 50
I (1917) ext12v: Powering off external 12V devices
I (1927) housekeeping: Auto init max7317 (free: 160572 bytes)
I (1937) housekeeping: Auto init ext12v (free: 160572 bytes)
I (1937) housekeeping: Auto init dbc (free: 160572 bytes)
I (1947) housekeeping: Auto init wifi (free: 160572 bytes)
I (1967) wifi:wifi driver task: 3ffd9afc, prio:23, stack:3584, core=0
I (1967) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (1977) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (1997) wifi:wifi firmware version: 30f9e79
I (2007) wifi:config NVS flash: enabled
I (2007) wifi:config nano formating: disabled
I (2007) wifi:Init data frame dynamic rx buffer num: 16
I (2007) wifi:Init management frame dynamic rx buffer num: 16
I (2017) wifi:Init management short buffer num: 32
I (2017) wifi:Init dynamic tx buffer num: 16
I (2017) wifi:Init static rx buffer size: 2212
I (2027) wifi:Init static rx buffer num: 16
I (2027) wifi:Init dynamic rx buffer num: 16
I (2807) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
I (2807) wifi:mode : sta (30:ae:a4:43:87:ec) + softAP (30:ae:a4:43:87:ed)
I (2807) wifi:Total power save buffer number: 8
I (2807) wifi:Init max length of beacon: 752/752
I (2817) wifi:Init max length of beacon: 752/752
I (2817) housekeeping: Auto init modem (free: 115148 bytes)
I (2827) housekeeping: Auto init Pollers (free: 114728 bytes)
I (2827) cellular: Set modem driver to 'auto'
I (2837) housekeeping: Auto init vehicle (free: 114728 bytes)
I (2837) cellular: State: Enter PowerOffOn state
I (2847) v-twizy: Renault Twizy vehicle module
I (2847) cellular-modem-auto: Power Cycle
I (2857) v-twizy: battmon subsystem init
I (2857) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
I (2867) v-twizy: pwrmon subsystem init
I (2877) v-twizy: charge subsystem init
I (2877) canopen: Worker started on can1
I (2887) v-twizy: sevcon subsystem init
I (2897) v-twizy: obd subsystem init
I (2897) housekeeping: Auto init obd2ecu (free: 81464 bytes)
I (2897) housekeeping: Auto init server v2 (free: 81464 bytes)
I (2907) ovms-server-v2: OVMS Server V2 registered metric modifier is #2
I (2917) ovms-server-v2: Status: Server has been started
I (2917) ovms-server-v2: OVMS Server v2 running
I (2927) housekeeping: Auto init server v3 (free: 80912 bytes)
I (2927) housekeeping: Auto init javascript (free: 80912 bytes)
I (2937) housekeeping: Auto init done (free: 80872 bytes)
I (2947) housekeeping: Starting USB console...
I (2947) uart: queue free spaces: 100
D (2957) events: Signal(egpio.output.1.low)
D (2967) events: Signal(system.event)
D (2967) events: Signal(system.wifi.sta.start)
D (2977) events: Signal(system.event)
D (2977) events: Signal(system.wifi.ap.start)
I (2977) netmanager: WIFI access point is up
D (2987) events: Signal(power.cellular.on)
D (2987) events: Signal(system.modem.stop)
D (2987) events: Signal(egpio.output.0.low)
D (2997) events: Signal(egpio.output.0.high)
D (2997) events: Signal(power.can1.on)
D (2997) events: Signal(egpio.output.2.low)
D (3007) events: Signal(canopen.worker.start)
D (3007) events: Signal(vehicle.type.set)
D (3017) events: Signal(server.v2.waitnetwork)
D (3017) events: Signal(system.start)
I (3017) ovms-mdns: Starting MDNS
D (3027) netmanager: MongooseTask starting
I (3027) ovms-duktape: Duktape: Creating heap (size: 524288 bytes)
D (3047) events: Signal(network.interface.change)
D (3057) events: Signal(network.mgr.init)
I (3077) ssh: Launching SSH Server
OVMS> I (3197) ovms-duktape: Duktape: Initialising module system
D (3217) ovms-duktape: Duktape: Pre-Registered function assert
D (3217) ovms-duktape: Duktape: Pre-Registered function meminfo
D (3217) ovms-duktape: Duktape: Pre-Registered function print
D (3227) ovms-duktape: Duktape: Pre-Registered function write
D (3227) ovms-duktape: Duktape: Pre-Registered object HTTP
D (3227) ovms-duktape: Duktape: Pre-Registered object HTTP function Request
D (3227) ovms-duktape: Duktape: Pre-Registered object HTTP function request
D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsCommand
D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec
D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register
D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig
D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Delete
D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Get
D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function GetValues
D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances
D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params
D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set
D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues
D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsEvents
D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise
D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsLocation
D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status
D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics
D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Age
D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsFloat
D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsJSON
D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues
D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function HasValue
D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsFresh
D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsStale
D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value
D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsNotify
D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsNotify function Raise
D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsPoller
D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetPaused
D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetTraceStatus
D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetUserPaused
D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Pause
D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Resume
D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Trace
D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStarted
D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStatus
D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Reset
D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Start
D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Stop
D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle
D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ClimateControl
D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Homelink
D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Lock
D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ObdRequest
D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent
D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode
D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer
D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge
D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown
D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge
D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown
D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Type
D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unlock
D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unvalet
D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Valet
D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup
D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Disable
D (3277) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Enable
D (3277) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Status
D (3277) ovms-duktape: Duktape: Pre-Registered object VFS
D (3277) ovms-duktape: Duktape: Pre-Registered object VFS function Load
D (3277) ovms-duktape: Duktape: Pre-Registered object VFS function Save
D (3277) ovms-duktape: Duktape: Pre-Registered module JSON
D (3287) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js'
D (3297) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes)
D (3297) ovms-duktape: Duktape: module load: int/JSON.js
D (3377) ovms-duktape: Duktape: Pre-Registered module PubSub
D (3387) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js'
D (3387) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes)
D (3387) ovms-duktape: Duktape: module load: int/PubSub.js
I (3617) ovms-duktape: Duktape: Executing ovmsmain.js
D (3617) ovms-duktape: Duktape: module load: ovmsmain.js
D (3627) ovms-duktape: Duktape: module unload: ovmsmain.js
D (3687) events: Signal(vehicle.charge.mode)
OVMS> D (4687) events: Signal(vehicle.aux.12v.normal)
OVMS> D (5367) events: Signal(egpio.output.0.low)
D (5427) events: Signal(system.event)
D (5437) events: Signal(system.wifi.scan.done)
I (5557) wifi:ap channel adjust o:1,0 n:11,0
I (5557) wifi:new:<11,0>, old:<1,0>, ap:<11,0>, sta:<11,0>, prof:1
OVMS> I (6247) wifi:state: init -> auth (b0)
I (6257) wifi:state: auth -> assoc (0)
I (6267) wifi:state: assoc -> run (10)
I (6287) wifi:connected with LeonsLair, aid = 2, channel 11, BW20, bssid = d4:24:dd:88:1e:85
I (6287) wifi:security type: 3, phy: bgn, rssi: -60
I (6287) wifi:pm start, type: 1
D (6297) events: Signal(system.event)
D (6297) events: Signal(system.wifi.sta.connected)
D (6297) netmanager: send cmd 3 from 0x0
D (6297) netmanager: done cmd 3 from 0x0
I (6317) wifi:AP's beacon interval = 102400 us, DTIM period = 1
D (6317) netmanager: MongooseTask: got cmd 3 from 0x0
D (6317) netmanager: MongooseTask: done cmd 3 from 0x0
OVMS> I (6777) event: sta ip: 192.168.178.33, mask: 255.255.255.0, gw: 192.168.178.1
D (6777) events: Signal(system.event)
D (6777) events: Signal(network.interface.up)
D (6777) events: Signal(system.wifi.sta.gotip)
I (6777) netmanager: WIFI client got IP
D (6777) netmanager: Saved DNS#0 192.168.178.1
D (6777) netmanager: Saved DNS#1 0.0.0.0
D (6777) netmanager: Saved DNS#2 0.0.0.0
D (6777) netmanager: send cmd 3 from 0x0
D (6777) netmanager: done cmd 3 from 0x0
D (6817) netmanager: MongooseTask: got cmd 3 from 0x0
D (6817) netmanager: MongooseTask: done cmd 3 from 0x0
OVMS> D (8687) events: Signal(network.wifi.sta.good)
I (8687) netmanager: WIFI client has good signal quality (-81.1 dBm); connect
I (8687) netmanager: Interface priority is st1 (192.168.178.33/255.255.255.0 gateway 192.168.178.1)
I (8687) netmanager: Set DNS#1 0.0.0.0
I (8687) netmanager: Set DNS#2 0.0.0.0
I (8687) netmanager: WIFI client up (with MODEM down): starting network with WIFI client
D (8697) events: Signal(network.wifi.up)
D (8697) events: Signal(network.up)
I (8697) ovms-server-v2: Status: Network is up, so attempt network connection
D (8697) events: Signal(network.interface.change)
D (8707) events: Signal(server.v2.connectwait)
OVMS> D (10367) events: Signal(egpio.output.0.high)
D (10567) events: Signal(egpio.output.0.low)
D (10567) cellular: State timeout PowerOffOn => PoweringOn
I (10567) cellular: State: Enter PoweringOn state
I (10567) cellular-modem-auto: Power Cycle
I (10567) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
D (10567) events: Signal(system.modem.poweringon)
D (10567) events: Signal(egpio.output.0.high)
I (10687) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1
I (10687) ovms-server-v2: Status: Connecting...
D (10717) events: Signal(server.v2.connecting)
OVMS> D (13067) events: Signal(egpio.output.0.low)
OVMS> I (14257) ovms-server-v2: Connection successful
I (14257) ovms-server-v2: Status: Logging in...
D (14257) events: Signal(server.v2.authenticating)
I (14257) ovms-server-v2: Sending server login: MP-C 0 tEGwdgWRdMbD8SwvQncceo lMrakF68LqYE1rEyfixHFg== TEST1
I (14297) ovms-server-v2: Got server response: MP-S 0 OGiiwunTBubdgRsYK5CM6n AtfoPKZ4WkKmQqYVVbWJjw==
I (14297) ovms-server-v2: Server token is OGiiwunTBubdgRsYK5CM6n and digest is AtfoPKZ4WkKmQqYVVbWJjw==
I (14297) ovms-server-v2: Status: Server authentication ok. Now priming crypto.
I (14297) ovms-server-v2: Shared secret key is OGiiwunTBubdgRsYK5CM6ntEGwdgWRdMbD8SwvQncceo (44 bytes)
I (14297) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
D (14297) events: Signal(server.v2.connected)
I (14327) ovms-server-v2: Incoming Msg: MP-0 Z0
OVMS> I (14687) ovms-server-v2: Send MP-0 S0,K,0,0.00,,standard,50,50,15,0,0,0,0,0,0,0,0,0,92.98,0,0,56,21,-1,0,0,0,0,0,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.0,0.0,0.0,0.0,-1
I (14697) ovms-server-v2: Send MP-0 D0,16,5,0,0,0,0,0,0,176,0,0,1,1,12.35,0,12.6,0,0,0,0
I (14697) ovms-server-v2: Send MP-0 L51.403797,7.440107,0,158.5,0,0,0,0,2050202,0,0.000,0.000,0,0,,0,0,0,0
I (14697) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1
I (14697) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1
I (14697) ovms-server-v2: Send MP-0 F3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),,25,0,RT,LeonsLair,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/1,
OVMS> D (18067) events: Signal(egpio.output.0.high)
D (18267) events: Signal(egpio.output.0.low)
D (18267) cellular: tx-cmd: AT
I (18367) cellular: State: Enter Identify state
D (18367) cellular: tx-cmd: AT+CGMM
OVMS> D (18687) cellular: tx-cmd: AT+CGMM
OVMS> D (19687) cellular: tx-cmd: AT+CGMM
OVMS> D (20687) cellular: tx-cmd: AT+CGMM
OVMS> D (21687) cellular: tx-cmd: AT+CGMM
OVMS> D (22687) cellular: tx-cmd: AT+CGMM
OVMS> D (23687) cellular: tx-cmd: AT+CGMM
OVMS> D (24687) cellular: tx-cmd: AT+CGMM
I (24687) ovms-server-v2: Send MP-0 h1,0,RT-GPS-Log,0,86400,51.403797,7.440107,158,0,0,0,0,-62,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (24697) cellular: Identified cellular modem: SIM5360/SIMCOM SIM5360 (include US and EU variants)
D (24697) cellular: Remove old 'auto' modem driver
I (24697) cellular: Set modem driver to 'SIM5360'
I (24697) cellular: State: Enter PoweredOn state
D (24697) events: Signal(system.modem.installed)
D (24697) events: Signal(system.modem.poweredon)
I (24857) ovms-server-v2: Incoming Msg: MP-0 h1
OVMS> D (27057) cellular: mux-rx-line #0 (2/48): OK
D (27057) cellular: mux-rx-line #0 (12/32): +CPIN: READY
D (27057) cellular: mux-rx-line #0 (12/16): OPL UPDATING
D (27057) cellular: mux-rx-line #0 (12/0): PNN UPDATING
OVMS> D (27677) cellular: mux-rx-line #0 (8/0): SMS DONE
OVMS> D (28267) cellular: mux-rx-line #0 (10/11): CALL READY
D (28267) cellular: mux-rx-line #0 (7/0): PB DONE
OVMS> D (34687) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
D (34707) cellular: mux-rx-line #0 (106/0): AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
D (34737) cellular: mux-rx-line #0 (12/20): +CPIN: READY
D (34737) cellular: mux-rx-line #0 (10/6): +CSQ: 23,0
D (34737) cellular: Signal Quality is: 23 (-67 dBm)
D (34747) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (36687) cellular: tx-cmd: AT+CGMR;+ICCID
D (36697) cellular: mux-rx-line #0 (23/37): +CGMR: 35316B11SIM5360E
D (36697) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389
D (36697) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (39287) cellular: mux-rx-line #0 (11/0): +CSQ: 23,99
OVMS> D (40687) cellular: tx-cmd: AT+CMUXSRVPORT=3,1
D (40697) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (41687) cellular: tx-cmd: AT+CMUXSRVPORT=2,1
D (41697) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (42687) cellular: tx-cmd: AT+CMUXSRVPORT=1,1
D (42697) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (43687) cellular: tx-cmd: AT+CMUXSRVPORT=0,5
D (43697) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (44687) cellular: tx-cmd: AT+CMUX=0;+CATR=6
D (44697) cellular: mux-rx-line #0 (2/0): OK
I (44697) cellular: State: Enter MuxStart state
V (44697) cellular: Starting MUX
D (44697) events: Signal(system.modem.muxstart)
I (44697) gsm-mux: Start MUX
I (44697) gsm-mux: Channel #0 is open
I (44707) gsm-mux: Channel #1 is open
I (44717) gsm-mux: Channel #2 is open
I (44717) gsm-mux: Channel #3 is open
I (44727) gsm-mux: Channel #4 is open
OVMS> D (45687) cellular: State transition MuxStart => NetWait
I (45687) cellular: State: Enter NetWait state
V (45687) cellular: Starting NMEA
I (45687) gsm-nmea: Startup
D (45687) cellular: mux-tx #4: AT+CGPSNMEA=66;+CGPS=1,1
I (45697) ovms-server-v2: Send MP-0 h2,0,RT-BAT-P,1,86400,1,1,0,10000,0,0,1000,0,-40,200,-40,0,0,0,0,0,0,0,0
I (45697) ovms-server-v2: Send MP-0 h3,0,RT-BAT-C,1,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45697) ovms-server-v2: Send MP-0 h4,0,RT-BAT-C,2,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45697) ovms-server-v2: Send MP-0 h5,0,RT-BAT-C,3,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45707) ovms-server-v2: Send MP-0 h6,0,RT-BAT-C,4,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
D (45707) events: Signal(system.modem.netwait)
D (45707) events: Signal(system.modem.gpsstart)
D (45787) cellular: mux-rx-line #4 (2/0): OK
I (45887) ovms-server-v2: Incoming Msg: MP-0 h2
I (45887) ovms-server-v2: Incoming Msg: MP-0 h3
I (45887) ovms-server-v2: Incoming Msg: MP-0 h4
I (45897) ovms-server-v2: Incoming Msg: MP-0 h5
I (45897) ovms-server-v2: Incoming Msg: MP-0 h6
OVMS> I (46687) ovms-server-v2: Send MP-0 h7,-1,RT-BAT-C,5,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46687) ovms-server-v2: Send MP-0 h8,-1,RT-BAT-C,6,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46687) ovms-server-v2: Send MP-0 h9,-1,RT-BAT-C,7,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46687) ovms-server-v2: Send MP-0 h10,-1,RT-BAT-C,8,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46697) ovms-server-v2: Send MP-0 h11,0,RT-BAT-C,9,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
OVMS> I (46937) ovms-server-v2: Incoming Msg: MP-0 h7
I (46937) ovms-server-v2: Incoming Msg: MP-0 h8
I (46937) ovms-server-v2: Incoming Msg: MP-0 h9
I (46947) ovms-server-v2: Incoming Msg: MP-0 h10
I (46947) ovms-server-v2: Incoming Msg: MP-0 h11
OVMS> I (47687) ovms-server-v2: Send MP-0 h12,-1,RT-BAT-C,10,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47687) ovms-server-v2: Send MP-0 h13,-1,RT-BAT-C,11,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47687) ovms-server-v2: Send MP-0 h14,-1,RT-BAT-C,12,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47687) ovms-server-v2: Send MP-0 h15,-1,RT-BAT-C,13,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47697) ovms-server-v2: Send MP-0 h16,-2,RT-BAT-C,14,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47747) ovms-server-v2: Incoming Msg: MP-0 h12
I (47747) ovms-server-v2: Incoming Msg: MP-0 h13
I (47747) ovms-server-v2: Incoming Msg: MP-0 h14
I (47757) ovms-server-v2: Incoming Msg: MP-0 h15
I (47757) ovms-server-v2: Incoming Msg: MP-0 h16
OVMS> D (51147) events: Signal(gps.lock.acquired)
D (51157) events: Signal(system.modem.gotgps)
OVMS> I (51687) ovms-server-v2: Send MP-0 h17,0,RT-GPS-Log,0,86400,51.404251,7.439373,159,132,0,1,0,-61,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (51797) ovms-server-v2: Incoming Msg: MP-0 h17
OVMS> D (55687) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
D (55717) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
I (55717) cellular: Network Registration status: RegisteredRoaming
D (55717) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:34:55+08"
D (55717) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99
D (55717) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (56687) cellular: mux-tx #3: AT+CPSI?
D (56687) cellular: State transition NetWait => NetStart
I (56687) cellular: State: Enter NetStart state
D (56687) events: Signal(system.modem.netstart)
D (56697) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-70,0,37-37
I (56697) cellular: Network Mode: GSM,Online
D (56697) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (57687) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
D (57727) cellular: mux-rx-line #2 (14/0): CONNECT 115200
I (57727) cellular: PPP Connection is ready to start
OVMS> D (58687) cellular: State transition NetStart => NetMode
I (58687) cellular: State: Enter NetMode state
V (58687) cellular: Launching PPP
V (58687) cellular: Starting PPP
I (58687) gsm-ppp: Initialising...
D (58697) events: Signal(system.modem.netmode)
OVMS> I (59737) gsm-ppp: StatusCallBack: None
I (59737) gsm-ppp: status_cb: Connected
I (59737) gsm-ppp: our_ipaddr = 10.170.195.13
I (59737) gsm-ppp: his_ipaddr = 10.64.64.64
I (59737) gsm-ppp: netmask = 255.255.255.255
I (59737) gsm-ppp: DNS#0 = 8.8.8.8
I (59737) gsm-ppp: DNS#1 = 8.8.4.4
I (59737) gsm-ppp: our6_ipaddr = ::
D (59737) events: Signal(network.interface.up)
D (59737) events: Signal(system.modem.gotip)
D (59737) netmanager: Saved DNS#0 8.8.8.8
D (59737) netmanager: Saved DNS#1 8.8.4.4
D (59737) netmanager: Saved DNS#2 0.0.0.0
I (59747) netmanager: Set DNS#1 0.0.0.0
I (59747) netmanager: Set DNS#2 0.0.0.0
I (59747) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority
D (59747) events: Signal(network.modem.up)
D (59747) events: Signal(network.interface.change)
OVMS> D (60287) cellular: mux-rx-line #3 (10/0): +CSQ: 23,0
OVMS> D (62767) ovms-duktape: Duktape: Compacting DukTape memory done in 70 ms
OVMS> D (66287) cellular: mux-rx-line #3 (11/0): +CSQ: 23,99
OVMS> I (84687) ovms-server-v2: Send MP-0 h18,0,RT-GPS-Log,0,86400,51.404083,7.439659,152,132,0,1,0,-62,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (84787) ovms-server-v2: Incoming Msg: MP-0 h18
OVMS> D (88687) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
D (88707) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
D (88707) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:35:28+08"
D (88707) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99
D (88707) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (89687) cellular: mux-tx #3: AT+CPSI?
D (89697) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38
D (89697) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (90687) cellular: mux-tx #3: AT+COPS?
D (90697) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0
I (90697) cellular: Network Provider is: vodafone.de Hologram
D (90697) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (118687) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
D (118697) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
D (118697) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:35:58+08"
D (118697) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99
D (118697) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (119687) cellular: mux-tx #3: AT+CPSI?
D (119697) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-70,0,37-37
D (119697) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (120687) cellular: mux-tx #3: AT+COPS?
D (120697) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0
D (120697) cellular: mux-rx-line #3 (2/0): OK
OVMS> I (122697) housekeeping: System considered stable (RAM: 8b=47812-48588 32b=12128 SPI=3202892-3218508)
D (122767) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms
OVMS> enable
Password:
Secure mode
OVMS# module fault I (144687) ovms-server-v2: Send MP-0 h19,0,RT-GPS-Log,0,86400,51.404083,7.439662,152,132,0,1,0,-62,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (144787) ovms-server-v2: Incoming Msg: MP-0 h19
OVMS# module fault powD (148687) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
D (148697) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
D (148697) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:36:28+08"
D (148697) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99
D (148707) cellular: mux-rx-line #3 (2/0): OK
OVMS# power celD (149687) cellular: mux-tx #3: AT+CPSI?
D (149697) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38
D (149697) cellular: mux-rx-line #3 (2/0): OK
OVMS# power cellular oD (150687) cellular: mux-tx #3: AT+COPS?
D (150697) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0
D (150697) cellular: mux-rx-line #3 (2/0): OK
OVMS# power cellular off
Power mode of cellular is now off
OVMS# D (151287) events: Signal(power.cellular.off)
I (151287) cellular: State: Enter PoweringOff state
V (151297) cellular: Stopping PPP
I (151297) gsm-ppp: Shutting down (hard)...
I (151297) gsm-ppp: StatusCallBack: User Interrupt
I (151297) gsm-ppp: PPP is shutdown
D (151297) events: Signal(system.modem.down)
V (151297) cellular: Stopping NMEA
D (151297) cellular: mux-tx #4: AT+CGPSNMEA=0
I (151297) netmanager: Set DNS#1 0.0.0.0
I (151297) netmanager: Set DNS#2 0.0.0.0
I (151297) netmanager: MODEM down (with WIFI client up): staying with WIFI client priority
D (151297) netmanager: send cmd 3 from 0x0
D (151297) netmanager: done cmd 3 from 0x0
D (151297) events: Signal(network.modem.down)
D (151307) events: Signal(network.interface.change)
D (151397) cellular: mux-tx #4: AT+CGPS=0
I (151397) gsm-nmea: Shutdown (direct)
D (151397) events: Signal(gps.lock.lost)
I (151397) cellular-modem-auto: Power Off - timing: 2500 ms
I (151397) Simcom: Power Off - 2500 ms
D (151397) events: Signal(system.modem.lostgps)
D (151397) events: Signal(system.modem.gpsstop)
D (151407) events: Signal(egpio.output.3.low)
D (151407) events: Signal(egpio.output.0.high)
D (151537) netmanager: MongooseTask: got cmd 3 from 0x0
D (151537) netmanager: CleanupConnections: conn 3f8e4ef4 -> iface st1
D (151537) netmanager: MongooseTask: done cmd 3 from 0x0
OVMS# D (153897) events: Signal(egpio.output.0.low)
OVMS# D (158897) events: Signal(system.modem.stop)
I (158897) netmanager: Set DNS#1 0.0.0.0
I (158897) netmanager: Set DNS#2 0.0.0.0
D (158897) netmanager: send cmd 3 from 0x0
D (158897) netmanager: done cmd 3 from 0x0
D (159047) netmanager: MongooseTask: got cmd 3 from 0x0
D (159047) netmanager: CleanupConnections: conn 3f8e4ef4 -> iface st1
D (159047) netmanager: MongooseTask: done cmd 3 from 0x0
OVMS# D (170687) cellular: State timeout PoweringOff => CheckPowerOff
I (170687) cellular: State: Enter CheckPowerOff state
OVMS# D (173687) cellular: tx-cmd: AT
OVMS# D (176687) cellular: tx-cmd: AT
OVMS# D (179687) cellular: tx-cmd: AT
OVMS# D (182687) cellular: tx-cmd: AT
D (182757) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms
OVMS# D (185687) cellular: tx-cmd: AT
D (185687) cellular: State timeout CheckPowerOff => PoweredOff
I (185687) cellular: State: Enter PoweredOff state
V (185687) cellular: Stopping MUX
I (185687) gsm-mux: Stop MUX
D (185687) events: Signal(system.modem.poweredoff)
OVMS# power cellular off n
Power mode of cellular is now on
OVMS# D (196647) events: Signal(power.cellular.on)
I (196657) cellular: Set modem driver to 'auto'
I (196657) cellular: State: Enter PowerOffOn state
V (196657) cellular: Stopping PPP
I (196657) gsm-ppp: Shutting down (hard)...
I (196657) gsm-ppp: StatusCallBack: User Interrupt
I (196657) gsm-ppp: PPP is shutdown
D (196657) events: Signal(system.modem.down)
I (196657) cellular-modem-auto: Power Cycle
I (196657) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
I (196657) netmanager: Set DNS#1 0.0.0.0
I (196657) netmanager: Set DNS#2 0.0.0.0
D (196657) netmanager: send cmd 3 from 0x0
D (196657) netmanager: done cmd 3 from 0x0
D (196667) events: Signal(system.modem.stop)
I (196667) netmanager: Set DNS#1 0.0.0.0
I (196667) netmanager: Set DNS#2 0.0.0.0
D (196667) netmanager: send cmd 3 from 0x0
D (196667) netmanager: done cmd 3 from 0x0
D (196667) events: Signal(egpio.output.0.high)
D (196757) netmanager: MongooseTask: got cmd 3 from 0x0
D (196757) netmanager: CleanupConnections: conn 3f8e4ef4 -> iface st1
D (196757) netmanager: MongooseTask: done cmd 3 from 0x0
D (196767) netmanager: MongooseTask: got cmd 3 from 0x0
D (196777) netmanager: CleanupConnections: conn 3f8e4ef4 -> iface st1
D (196777) netmanager: MongooseTask: done cmd 3 from 0x0
OVMS# D (199157) events: Signal(egpio.output.0.low)
OVMS# D (204157) events: Signal(egpio.output.0.high)
D (204357) cellular: State timeout PowerOffOn => PoweringOn
D (204357) events: Signal(egpio.output.0.low)
I (204357) cellular: State: Enter PoweringOn state
I (204357) cellular-modem-auto: Power Cycle
I (204357) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
D (204357) events: Signal(system.modem.poweringon)
D (204357) events: Signal(egpio.output.0.high)
OVMS# I (204687) ovms-server-v2: Send MP-0 h20,0,RT-GPS-Log,0,86400,51.404083,7.439664,152,132,0,0,0,-62,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (204807) ovms-server-v2: Incoming Msg: MP-0 h20
OVMS# D (206857) events: Signal(egpio.output.0.low)
OVMS# D (211857) events: Signal(egpio.output.0.high)
D (212057) cellular: tx-cmd: AT
D (212057) events: Signal(egpio.output.0.low)
I (212157) cellular: State: Enter Identify state
D (212157) cellular: tx-cmd: AT+CGMM
OVMS# D (212687) cellular: tx-cmd: AT+CGMM
OVMS# D (213687) cellular: tx-cmd: AT+CGMM
OVMS# D (214687) cellular: tx-cmd: AT+CGMM
OVMS# D (215687) cellular: tx-cmd: AT+CGMM
OVMS# D (216687) cellular: tx-cmd: AT+CGMM
OVMS# D (217687) cellular: tx-cmd: AT+CGMM
OVMS# D (218687) cellular: tx-cmd: AT+CGMM
I (218697) cellular: Identified cellular modem: SIM5360/SIMCOM SIM5360 (include US and EU variants)
D (218697) cellular: Remove old 'auto' modem driver
I (218697) cellular: Set modem driver to 'SIM5360'
I (218697) cellular: State: Enter PoweredOn state
D (218697) events: Signal(system.modem.installed)
D (218697) events: Signal(system.modem.poweredon)
OVMS# D (221037) cellular: mux-rx-line #0 (2/48): OK
D (221037) cellular: mux-rx-line #0 (12/32): +CPIN: READY
D (221037) cellular: mux-rx-line #0 (12/16): OPL UPDATING
D (221037) cellular: mux-rx-line #0 (12/0): PNN UPDATING
OVMS# D (221677) cellular: mux-rx-line #0 (8/0): SMS DONE
OVMS# D (222227) cellular: mux-rx-line #0 (10/11): CALL READY
D (222227) cellular: mux-rx-line #0 (7/0): PB DONE
OVMS# D (228687) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
D (228707) cellular: mux-rx-line #0 (106/0): AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
D (228737) cellular: mux-rx-line #0 (12/20): +CPIN: READY
D (228737) cellular: mux-rx-line #0 (10/6): +CSQ: 23,0
D (228737) cellular: Signal Quality is: 23 (-67 dBm)
D (228737) cellular: mux-rx-line #0 (2/0): OK
OVMS# D (230687) cellular: tx-cmd: AT+CGMR;+ICCID
D (230697) cellular: mux-rx-line #0 (23/37): +CGMR: 35316B11SIM5360E
D (230697) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389
D (230697) cellular: mux-rx-line #0 (2/0): OK
OVMS# D (233237) cellular: mux-rx-line #0 (11/0): +CSQ: 23,99
OVMS# D (234687) cellular: tx-cmd: AT+CMUXSRVPORT=3,1
D (234697) cellular: mux-rx-line #0 (2/0): OK
OVMS# D (235687) cellular: tx-cmd: AT+CMUXSRVPORT=2,1
D (235697) cellular: mux-rx-line #0 (2/0): OK
OVMS# D (236687) cellular: tx-cmd: AT+CMUXSRVPORT=1,1
D (236697) cellular: mux-rx-line #0 (2/0): OK
OVMS# D (237687) cellular: tx-cmd: AT+CMUXSRVPORT=0,5
D (237707) cellular: mux-rx-line #0 (2/0): OK
OVMS# D (238687) cellular: tx-cmd: AT+CMUX=0;+CATR=6
D (238697) cellular: mux-rx-line #0 (2/0): OK
I (238697) cellular: State: Enter MuxStart state
V (238697) cellular: Starting MUX
I (238697) gsm-mux: Start MUX
D (238697) events: Signal(system.modem.muxstart)
I (238697) gsm-mux: Channel #0 is open
I (238707) gsm-mux: Channel #1 is open
I (238707) gsm-mux: Channel #2 is open
I (238717) gsm-mux: Channel #3 is open
I (238727) gsm-mux: Channel #4 is open
OVMS# D (239687) cellular: State transition MuxStart => NetWait
I (239687) cellular: State: Enter NetWait state
V (239687) cellular: Starting NMEA
I (239687) gsm-nmea: Startup
D (239687) cellular: mux-tx #4: AT+CGPSNMEA=66;+CGPS=1,1
D (239687) events: Signal(system.modem.netwait)
D (239697) events: Signal(system.modem.gpsstart)
D (239777) cellular: mux-rx-line #4 (2/0): OK
OVMS# D (242757) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms
OVMS# D (248937) events: Signal(gps.lock.acquired)
D (248947) events: Signal(system.modem.gotgps)
OVMS# D (249687) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
I (249687) ovms-server-v2: Send MP-0 h21,0,RT-GPS-Log,0,86400,51.403915,7.439944,160,132,0,1,0,-63,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
D (249717) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
I (249717) cellular: Network Registration status: RegisteredRoaming
D (249717) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:38:08+08"
D (249727) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99
D (249727) cellular: mux-rx-line #3 (2/0): OK
I (249787) ovms-server-v2: Incoming Msg: MP-0 h21
OVMS# D (250687) cellular: mux-tx #3: AT+CPSI?
D (250687) cellular: State transition NetWait => NetStart
I (250687) cellular: State: Enter NetStart state
D (250687) events: Signal(system.modem.netstart)
D (250697) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38
D (250697) cellular: mux-rx-line #3 (2/0): OK
OVMS# D (251687) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
D (251717) cellular: mux-rx-line #2 (14/0): CONNECT 115200
I (251717) cellular: PPP Connection is ready to start
OVMS# D (252687) cellular: State transition NetStart => NetMode
I (252687) cellular: State: Enter NetMode state
V (252687) cellular: Starting PPP
I (252687) gsm-ppp: Initialising...
D (252697) events: Signal(system.modem.netmode)
OVMS# I (253487) gsm-ppp: StatusCallBack: None
I (253487) gsm-ppp: status_cb: Connected
I (253487) gsm-ppp: our_ipaddr = 10.170.195.13
I (253487) gsm-ppp: his_ipaddr = 10.64.64.64
I (253487) gsm-ppp: netmask = 255.255.255.255
I (253487) gsm-ppp: DNS#0 = 8.8.8.8
I (253487) gsm-ppp: DNS#1 = 8.8.4.4
I (253487) gsm-ppp: our6_ipaddr = ::
D (253487) events: Signal(network.interface.up)
D (253497) events: Signal(system.modem.gotip)
D (253497) netmanager: Saved DNS#0 8.8.8.8
D (253497) netmanager: Saved DNS#1 8.8.4.4
D (253497) netmanager: Saved DNS#2 0.0.0.0
I (253497) netmanager: Set DNS#1 0.0.0.0
I (253497) netmanager: Set DNS#2 0.0.0.0
I (253497) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority
D (253497) events: Signal(network.modem.up)
D (253497) events: Signal(network.interface.change)
OVMS# D (254247) cellular: mux-rx-line #3 (10/0): +CSQ: 23,0
OVMS# D (257247) cellular: mux-rx-line #3 (11/0): +CSQ: 23,99
OVMS# I (264687) ovms-server-v2: Send MP-0 h22,0,RT-GPS-Log,0,86400,51.403980,7.439810,159,132,0,1,0,-63,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (264817) ovms-server-v2: Incoming Msg: MP-0 h22
OVMS# module fault
abort() was called at PC 0x401184a3 on core 1
ELF file SHA256: 8ba7ed1fff95ef4c
Backtrace: 0x4008ddae:0x3ffef190 0x4008e049:0x3ffef1b0 0x401184a3:0x3ffef1d0 0x4032e70b:0x3ffef1f0 0x40127862:0x3ffef210 0x40127909:0x3ffef270 0x40127909:0x3ffef2d0 0x401279af:0x3ffef330 0x401138b7:0x3ffef350 0x40130427:0x3ffef370 0x401305de:0x3ffef3d0 0x401138e7:0x3ffef470 0x4032f76a:0x3ffef490 0x4012d559:0x3ffef4b0 0x40122885:0x3ffef4e0 0x40122a5d:0x3ffef510 0x4012d401:0x3ffef530 0x4012d410:0x3ffef550 0x4010c3eb:0x3ffef570
[OVMS] Current tasks: IDLE0|OVMS Console
Rebooting...
ho 0 tail 12 room 4
entry 0x400806cc
I (1192) psram: This chip is ESP32-D0WD
I (1193) spiram: Found 32MBit SPI RAM device
I (1193) spiram: SPI RAM mode: flash 40m sram 40m
I (1196) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (1203) cpu_start: Pro cpu up.
I (1207) cpu_start: Application information:
I (1212) cpu_start: Project name: ovms3
I (1217) cpu_start: App version: 3.3.004-429-g629e5b8b
I (1223) cpu_start: Compile time: Mar 30 2025 13:28:23
I (1229) cpu_start: ELF file SHA256: 8ba7ed1fff95ef4c...
I (1235) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b
I (1242) cpu_start: Starting app cpu, entry point is 0x400818e0
I (2127) spiram: SPI SRAM memory test OK
I (2127) heap_init: Initializing. RAM available for dynamic allocation:
I (2128) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (2134) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM
I (2140) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (2146) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (2153) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM
I (2159) cpu_start: Pro cpu start user code
I (2164) spiram: Adding pool of 4096K of external SPI memory to heap allocator
I (215) ovms_main: WATCHDOG already initialized...
I (216) ovms-duktape: Initialising DUKTAPE Registry (1000)
I (222) command: Initialising COMMAND (1010)
I (228) command: Expanding DUKTAPE javascript engine
I (232) boot: Initialising BOOT (1100)
I (237) boot: Boot #2 reasons for CPU0=12 and CPU1=12
E (242) boot: Crash #1 detected
I (246) boot: Reset reason Exception/panic (4)
I (252) events: Initialising EVENTS (1200)
I (257) config: Initialising CONFIG (1400)
I (262) time: Initialising TIME (1500)
I (266) script: Initialising SCRIPTS (1600)
I (271) ovms-duk-http: Installing DUKTAPE HTTP (1710)
I (276) ovms-duk-util: Installing DUKTAPE Utilities (1710)
I (282) ovms-duk-vfs: Installing DUKTAPE VFS (1710)
I (288) metrics: Initialising METRICS (1810)
I (293) metrics: Expanding DUKTAPE javascript engine
I (299) metrics: Persistent metrics serial 3 using 820 bytes, 68/100 slots used
I (308) metrics: persist v.b.cac = 92.9772Ah
I (312) metrics: persist v.b.range.est = 50km
I (317) metrics: persist v.b.12v.voltage = 12.34V
I (322) metrics: persist v.b.12v.voltage.ref = 12.6V
I (328) metrics: persist v.c.climit = 15A
I (333) metrics: persist v.c.limit.range = 56km
I (337) metrics: persist v.c.limit.soc = 21%
I (346) metrics: persist v.e.drivemode = 33882626
I (348) metrics: persist v.e.valet = yes
I (352) metrics: persist v.e.parktime = 442Sec
I (359) metrics: persist v.p.latitude = 51.404
I (363) metrics: persist v.p.longitude = 7.43981
I (368) metrics: persist v.p.altitude = 158.8m
I (375) notify: Initialising NOTIFICATIONS (1820)
I (380) notify: Registered notification type info
I (384) notify: Registered notification type error
I (389) notify: Registered notification type alert
I (394) notify: Registered notification type data
I (400) notify: Registered notification type stream
I (405) notify: Expanding DUKTAPE javascript engine
I (411) location: Initialising LOCATIONS (1900)
I (419) location: Expanding DUKTAPE javascript engine
I (422) vehicle: Initialising VEHICLE Factory (2000)
I (433) tls: Initialising TLS (3000)
I (434) pcp: Initialising POWER (4000)
I (436) max7317: Initialising MAX7317 EGPIO (4200)
I (443) sdcard: Initialising SD CARD (4400)
I (447) ota: Initialising OTA (4400)
I (453) canformat: Initialising CAN Format Factory (4500)
I (457) canformat-cs11: Registering CAN Format: CS11 (4505)
I (463) canformat-crtd: Registering CAN Format: CRTD (4505)
I (469) canformat-gvret: Registering CAN Format: GVRET (4505)
I (476) canformat-lawicel: Registering CAN Format: LAWICEL (4505)
I (483) canformat-panda: Registering CAN Format: PANDA (4505)
I (489) canformat-pcap: Registering CAN Format: PCAP (4505)
I (495) canformat-raw: Registering CAN Format: RAW (4505)
I (501) can: Initialising CAN (4510)
I (513) dbc-app: Initialising DBC (4520)
I (516) canlog: Initialising CAN logging (4550)
I (517) canlog-monitor: Initialising CAN logging to MONITOR (4560)
I (523) canlog-tcpclient: Initialising CAN logging as TCP client (4560)
I (533) canlog-tcpserver: Initialising CAN logging as TCP server (4560)
I (540) canlog-udpclient: Initialising CAN logging as UDP client (4560)
I (546) canlog-udpserver: Initialising CAN logging as UDP server (4560)
I (555) canlog-vfs: Initialising CAN logging to VFS (4560)
I (559) canplay: Initialising CAN play framework (4570)
I (564) canplay-vfs: Initialising CAN playing from VFS (4580)
I (571) cellular: Initialising CELLULAR (4600)
I (578) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601)
I (583) cellular-modem-auto: Registering auto-detect modem driver (4650)
I (590) SIM5360: Registering SIM5360 modem driver (4650)
I (596) SIM7000: Registering SIM7000 modem driver (4650)
I (602) SIM7600: Registering SIM7600 modem driver (4650)
I (608) SIM7670: Registering Simcom A7670E modem driver (4660)
I (614) tpms: Initialising TPMS (4700)
I (620) test: Initialising TEST (5000)
I (625) module: Initialising MODULE (5100)
I (630) vfs: Initialising VFS (5200)
I (634) ovms-server: Initialising OVMS Server (6000)
I (638) ovms-server-v2: Initialising OVMS V2 Server (6100)
I (645) ovms-server-v3: Initialising OVMS V3 Server (6200)
I (651) vehicle-poll: Initialising Poller (7000)
I (659) obd2ecu: Initialising OBD2ECU (7000)
I (662) canopen: Initialising CANopen (7000)
I (670) pluginstore: Initialising PLUGINS (7100)
I (673) esp32wifi: Initialising ESP32WIFI (8000)
I (678) ovms-mdns: Initialising MDNS (8100)
I (681) webserver: Initialising WEBSERVER (8200)
I (689) ssh: Initialising SSH (8300)
I (691) powermgmt: Initialising POWERMGMT (8500)
I (697) re: Initialising RE Tools (8800)
I (703) pushover: Initialising Pushover client (8800)
I (708) netmanager: Initialising NETMANAGER (8999)
I (715) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000)
I (718) v-zeva: Registering Vehicle: ZEVA (9000)
I (724) v-vweup: Registering Vehicle: VW e-Up (9000)
I (729) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000)
I (737) v-track: Registering Vehicle: TRACK (9000)
I (742) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000)
I (749) v-thinkcity: Registering Vehicle: THINK CITY (9000)
I (755) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000)
I (762) v-teslamodels: Registering Vehicle: Tesla Model S (9000)
I (769) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000)
I (776) v-smarteq: Registering Vehicle: SMART EQ (9000)
I (781) v-smarted: Registering Vehicle: SMART ED (9000)
I (787) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000)
I (795) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000)
I (801) v-twizy: Registering Vehicle: Renault Twizy (9000)
I (807) v-obdii: Registering Vehicle: OBDII (9000)
I (813) v-none: Registering Vehicle: NONE (9000)
I (818) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000)
I (825) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000)
I (834) v-minise: Registering Vehicle: Mini Cooper SE (9000)
I (840) v-mgev4: Registering Vehicle: MG4 (9000)
I (846) v-mgev: Registering Vehicle: MG5 (9000)
I (851) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000)
I (857) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000)
I (863) v-mgev: Registering Vehicle: MG ZS EV (2023-)
I (869) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000)
I (875) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000)
I (882) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000)
I (888) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000)
I (894) v-maple60s: Registering Vehicle: Maple 60S (9000)
I (901) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000)
I (907) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000)
I (915) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000)
I (921) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000)
I (928) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000)
I (935) v-fiat500e: Registering Vehicle: FIAT 500e (9000)
I (942) v-energica: Registering Vehicle: Energica (9000)
I (948) v-demo: Registering Vehicle: DEMO (9000)
I (953) v-dbc: Registering Vehicle: DBC based vehicle (9000)
I (959) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000)
I (967) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000)
I (975) v-atto3: Registering Vehicle: BYD Atto3 (9000)
I (980) v-boltev: Registering Vehicle: Bolt EV (9000)
I (986) v-bmwi3: Registering Vehicle: BMW i3 (9000)
I (992) version: Initialising Versioning (9900)
I (1000) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
I (30) ovms-duktape: Duktape: Scripting task is running
I (1072) ovms_main: Executing on CPU core 0
I (1082) ovms_main: Mounting CONFIG...
I (1192) ovms_main: Configure logging...
W (1202) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount
I (1202) ovms_main: Registering default configs...
I (1202) ovms_main: Starting HOUSEKEEPING...
I (1212) housekeeping: Initialising HOUSEKEEPING Framework...
I (1212) tls: Built trusted CA cache (5 entries, 8101 bytes)
D (1682) events: Signal(housekeeping.init)
I (1682) housekeeping: Executing on CPU core 1
I (1682) housekeeping: reset_reason: cpu0=12, cpu1=12
I (1682) housekeeping: Starting PERIPHERALS...
I (1692) peripherals: Initialising OVMS Peripherals...
I (1692) peripherals: TCP/IP Adaptor
I (1702) peripherals: ESP32 system
I (1702) peripherals: SPI bus
I (1712) peripherals: MAX7317 I/O Expander
I (1712) peripherals: ESP32 CAN
I (1722) peripherals: ESP32 WIFI
I (1722) peripherals: ESP32 ADC
I (1722) peripherals: MCP2515 CAN 1/2
I (1732) mcp2515: can2: SetPowerMode off
I (1812) peripherals: MCP2515 CAN 2/2
I (1812) mcp2515: can3: SetPowerMode off
I (1892) peripherals: SD CARD
I (1892) peripherals: CELLULAR MODEM
I (1892) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1902) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
V (1912) cellular: Starting modem task
I (1912) uart: queue free spaces: 50
I (1912) ext12v: Powering off external 12V devices
I (1922) housekeeping: Auto init max7317 (free: 160572 bytes)
I (1932) housekeeping: Auto init ext12v (free: 160572 bytes)
I (1932) housekeeping: Auto init dbc (free: 160572 bytes)
I (1942) housekeeping: Auto init wifi (free: 160572 bytes)
I (1962) wifi:wifi driver task: 3ffd9afc, prio:23, stack:3584, core=0
I (1962) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (1972) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (1992) wifi:wifi firmware version: 30f9e79
I (2002) wifi:config NVS flash: enabled
I (2002) wifi:config nano formating: disabled
I (2002) wifi:Init data frame dynamic rx buffer num: 16
I (2002) wifi:Init management frame dynamic rx buffer num: 16
I (2012) wifi:Init management short buffer num: 32
I (2012) wifi:Init dynamic tx buffer num: 16
I (2012) wifi:Init static rx buffer size: 2212
I (2022) wifi:Init static rx buffer num: 16
I (2022) wifi:Init dynamic rx buffer num: 16
I (2802) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
I (2802) wifi:mode : sta (30:ae:a4:43:87:ec) + softAP (30:ae:a4:43:87:ed)
I (2802) wifi:Total power save buffer number: 8
I (2802) wifi:Init max length of beacon: 752/752
I (2812) wifi:Init max length of beacon: 752/752
I (2812) housekeeping: Auto init modem (free: 115408 bytes)
I (2822) housekeeping: Auto init Pollers (free: 114728 bytes)
I (2822) housekeeping: Auto init vehicle (free: 114728 bytes)
I (2842) v-twizy: Renault Twizy vehicle module
I (2842) v-twizy: battmon subsystem init
I (2852) v-twizy: pwrmon subsystem init
I (2852) v-twizy: charge subsystem init
I (2852) canopen: Worker started on can1
I (2852) v-twizy: sevcon subsystem init
I (2872) v-twizy: obd subsystem init
I (2872) housekeeping: Auto init obd2ecu (free: 81496 bytes)
I (2872) housekeeping: Auto init server v2 (free: 81496 bytes)
I (2882) ovms-server-v2: OVMS Server V2 registered metric modifier is #2
I (2882) ovms-server-v2: Status: Server has been started
I (2892) ovms-server-v2: OVMS Server v2 running
I (2902) housekeeping: Auto init server v3 (free: 80944 bytes)
I (2902) housekeeping: Auto init javascript (free: 80944 bytes)
I (2912) cellular: Set modem driver to 'auto'
I (2912) housekeeping: Auto init done (free: 80904 bytes)
I (2912) cellular: State: Enter PowerOffOn state
I (2922) housekeeping: Starting USB console...
I (2932) cellular-modem-auto: Power Cycle
I (2932) uart: queue free spaces: 100
I (2932) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
D (2942) events: Signal(egpio.output.1.low)
D (2952) events: Signal(system.event)
D (2962) events: Signal(system.wifi.sta.start)
D (2962) events: Signal(system.event)
D (2972) events: Signal(system.wifi.ap.start)
I (2972) netmanager: WIFI access point is up
D (2982) events: Signal(power.cellular.on)
D (2982) events: Signal(power.can1.on)
D (2992) events: Signal(egpio.output.2.low)
D (2992) events: Signal(canopen.worker.start)
D (3002) events: Signal(vehicle.type.set)
D (3002) events: Signal(server.v2.waitnetwork)
D (3012) events: Signal(system.modem.stop)
D (3012) events: Signal(system.start)
I (3012) ovms-mdns: Starting MDNS
D (3022) netmanager: MongooseTask starting
Firmware: 3.3.004-429-g629e5b8b/factory/edge
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
I (2912) ovms-duktape: Duktape: Creating heap (size: 524288 bytes)
OVMS> D (3042) events: Signal(egpio.output.0.low)
D (3052) events: Signal(egpio.output.0.high)
D (3052) events: Signal(network.interface.change)
D (3052) events: Signal(network.mgr.init)
I (3072) ssh: Launching SSH Server
I (3202) ovms-duktape: Duktape: Initialising module system
D (3222) ovms-duktape: Duktape: Pre-Registered function assert
D (3222) ovms-duktape: Duktape: Pre-Registered function meminfo
D (3222) ovms-duktape: Duktape: Pre-Registered function print
D (3222) ovms-duktape: Duktape: Pre-Registered function write
D (3222) ovms-duktape: Duktape: Pre-Registered object HTTP
D (3222) ovms-duktape: Duktape: Pre-Registered object HTTP function Request
D (3222) ovms-duktape: Duktape: Pre-Registered object HTTP function request
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsCommand
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Delete
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Get
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function GetValues
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsEvents
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsLocation
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Age
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsFloat
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsJSON
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function HasValue
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsFresh
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsStale
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsNotify
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsNotify function Raise
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetPaused
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetTraceStatus
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetUserPaused
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Pause
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Resume
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Trace
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStarted
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStatus
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Reset
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Start
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Stop
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ClimateControl
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Homelink
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Lock
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ObdRequest
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Type
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unlock
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unvalet
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Valet
D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup
D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Disable
D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Enable
D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Status
D (3272) ovms-duktape: Duktape: Pre-Registered object VFS
D (3272) ovms-duktape: Duktape: Pre-Registered object VFS function Load
D (3272) ovms-duktape: Duktape: Pre-Registered object VFS function Save
D (3272) ovms-duktape: Duktape: Pre-Registered module JSON
D (3292) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js'
D (3292) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes)
D (3292) ovms-duktape: Duktape: module load: int/JSON.js
D (3382) ovms-duktape: Duktape: Pre-Registered module PubSub
D (3402) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js'
D (3402) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes)
D (3402) ovms-duktape: Duktape: module load: int/PubSub.js
I (3612) ovms-duktape: Duktape: Executing ovmsmain.js
D (3612) ovms-duktape: Duktape: module load: ovmsmain.js
D (3632) ovms-duktape: Duktape: module unload: ovmsmain.js
D (3682) events: Signal(vehicle.charge.mode)
OVMS> D (4682) events: Signal(vehicle.aux.12v.normal)
OVMS> D (5422) events: Signal(system.event)
D (5422) events: Signal(system.wifi.scan.done)
D (5452) events: Signal(egpio.output.0.low)
I (5542) wifi:ap channel adjust o:1,0 n:11,0
I (5552) wifi:new:<11,0>, old:<1,0>, ap:<11,0>, sta:<11,0>, prof:1
OVMS> I (6232) wifi:state: init -> auth (b0)
I (6252) wifi:state: auth -> assoc (0)
I (6262) wifi:state: assoc -> run (10)
I (6292) wifi:connected with LeonsLair, aid = 2, channel 11, BW20, bssid = d4:24:dd:88:1e:85
I (6302) wifi:security type: 3, phy: bgn, rssi: -61
I (6302) wifi:pm start, type: 1
D (6302) events: Signal(system.event)
D (6302) events: Signal(system.wifi.sta.connected)
D (6302) netmanager: send cmd 3 from 0x0
D (6302) netmanager: done cmd 3 from 0x0
I (6312) wifi:AP's beacon interval = 102400 us, DTIM period = 1
I (6332) event: sta ip: 192.168.178.33, mask: 255.255.255.0, gw: 192.168.178.1
D (6332) events: Signal(system.event)
D (6332) events: Signal(network.interface.up)
D (6332) events: Signal(system.wifi.sta.gotip)
I (6332) netmanager: WIFI client got IP
D (6332) netmanager: Saved DNS#0 192.168.178.1
D (6332) netmanager: Saved DNS#1 0.0.0.0
D (6332) netmanager: Saved DNS#2 0.0.0.0
D (6342) netmanager: send cmd 3 from 0x0
D (6342) netmanager: done cmd 3 from 0x0
D (6542) netmanager: MongooseTask: got cmd 3 from 0x0
D (6542) netmanager: MongooseTask: done cmd 3 from 0x0
D (6552) netmanager: MongooseTask: done cmd 3 from 0x0
OVMS> D (8682) events: Signal(network.wifi.sta.good)
I (8682) netmanager: WIFI client has good signal quality (-81.8 dBm); connect
I (8682) netmanager: Interface priority is st1 (192.168.178.33/255.255.255.0 gateway 192.168.178.1)
I (8682) netmanager: Set DNS#1 0.0.0.0
I (8682) netmanager: Set DNS#2 0.0.0.0
I (8682) netmanager: WIFI client up (with MODEM down): starting network with WIFI client
D (8692) events: Signal(network.wifi.up)
D (8692) events: Signal(network.up)
I (8692) ovms-server-v2: Status: Network is up, so attempt network connection
D (8692) events: Signal(network.interface.change)
D (8702) events: Signal(server.v2.connectwait)
OVMS> D (10452) events: Signal(egpio.output.0.high)
D (10652) events: Signal(egpio.output.0.low)
I (10682) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1
I (10682) ovms-server-v2: Status: Connecting...
D (10712) events: Signal(server.v2.connecting)
D (10852) cellular: State timeout PowerOffOn => PoweringOn
I (10852) cellular: State: Enter PoweringOn state
I (10852) cellular-modem-auto: Power Cycle
D (10852) events: Signal(system.modem.poweringon)
I (10852) Simcom: Power Cycle - T_off 2500 ms - T_on 1000 ms
D (10852) events: Signal(egpio.output.0.high)
OVMS> D (13352) events: Signal(egpio.output.0.low)
OVMS> I (14122) ovms-server-v2: Connection successful
I (14122) ovms-server-v2: Status: Logging in...
D (14122) events: Signal(server.v2.authenticating)
I (14122) ovms-server-v2: Sending server login: MP-C 0 BgLNQXHKd5z1eSqrZeF24F kvQAZSHdib2kENsZ3O2ypw== TEST1
I (14152) ovms-server-v2: Got server response: MP-S 0 qDyZ4KO8ERt1Zk7nEfgJaF atF5mJrBMXDG2fydaH6dwQ==
I (14152) ovms-server-v2: Server token is qDyZ4KO8ERt1Zk7nEfgJaF and digest is atF5mJrBMXDG2fydaH6dwQ==
I (14162) ovms-server-v2: Status: Server authentication ok. Now priming crypto.
I (14162) ovms-server-v2: Shared secret key is qDyZ4KO8ERt1Zk7nEfgJaFBgLNQXHKd5z1eSqrZeF24F (44 bytes)
I (14162) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
D (14162) events: Signal(server.v2.connected)
I (14192) ovms-server-v2: Incoming Msg: MP-0 Z0
OVMS> I (14682) ovms-server-v2: Send MP-0 S0,K,0,0.00,,standard,50,50,15,0,0,0,0,0,0,0,0,0,92.98,0,0,56,21,-1,0,0,0,0,0,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.0,0.0,0.0,0.0,-1
I (14692) ovms-server-v2: Send MP-0 D0,16,5,0,0,0,0,0,0,453,0,0,1,1,12.34,0,12.6,0,0,0,0
I (14692) ovms-server-v2: Send MP-0 L51.403984,7.439806,0,158.8,0,0,0,0,2050202,0,0.000,0.000,0,0,,0,0,0,0
I (14692) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1
I (14692) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1
I (14692) ovms-server-v2: Send MP-0 F3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),,24,0,RT,LeonsLair,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/1,
OVMS> D (18352) events: Signal(egpio.output.0.high)
OVMS> D (19352) events: Signal(egpio.output.0.low)
I (19452) cellular: State: Enter Identify state
D (19552) cellular: tx-cmd: AT+CGMM
D (19652) cellular: tx-cmd: AT+CGMM
D (19682) cellular: tx-cmd: AT+CGMM
OVMS> D (20682) cellular: tx-cmd: AT+CGMM
OVMS> D (21682) cellular: tx-cmd: AT+CGMM
OVMS> D (22682) cellular: tx-cmd: AT+CGMM
OVMS> D (23682) cellular: tx-cmd: AT+CGMM
OVMS> D (24682) cellular: tx-cmd: AT+CGMM
I (24682) ovms-server-v2: Send MP-0 h1,0,RT-GPS-Log,0,86400,51.403984,7.439806,159,0,0,0,0,-60,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (24742) ovms-server-v2: Incoming Msg: MP-0 h1
OVMS> D (25682) cellular: tx-cmd: AT+CGMM
OVMS> D (26682) cellular: tx-cmd: AT+CGMM
OVMS> D (27682) cellular: tx-cmd: AT+CGMM
OVMS> D (28682) cellular: tx-cmd: AT+CGMM
OVMS> D (29682) cellular: tx-cmd: AT+CGMM
OVMS> D (30682) cellular: tx-cmd: AT+CGMM
OVMS> D (31682) cellular: tx-cmd: AT+CGMM
OVMS> D (32682) cellular: tx-cmd: AT+CGMM
OVMS> D (33682) cellular: tx-cmd: AT+CGMM
OVMS> D (34682) cellular: tx-cmd: AT+CGMM
OVMS> D (35682) cellular: tx-cmd: AT+CGMM
D (35682) cellular: State timeout Identify => PowerOffOn
I (35682) cellular: State: Enter PowerOffOn state
I (35682) cellular-modem-auto: Power Cycle
I (35682) Simcom: Power Cycle - T_off 2500 ms - T_on 1126913089 ms
D (35682) events: Signal(system.modem.stop)
I (35692) netmanager: Set DNS#1 0.0.0.0
I (35692) netmanager: Set DNS#2 0.0.0.0
D (35692) netmanager: send cmd 3 from 0x0
D (35692) netmanager: done cmd 3 from 0x0
D (35692) events: Signal(egpio.output.0.high)
D (35742) netmanager: MongooseTask: got cmd 3 from 0x0
D (35742) netmanager: CleanupConnections: conn 3f8e4028 -> iface st1
D (35752) netmanager: MongooseTask: done cmd 3 from 0x0
OVMS> D (38182) events: Signal(egpio.output.0.low)
OVMS> D (43182) events: Signal(egpio.output.0.high)
OVMS> I (45692) ovms-server-v2: Send MP-0 h2,0,RT-BAT-P,1,86400,1,1,0,10000,0,0,1000,0,-40,200,-40,0,0,0,0,0,0,0,0
I (45692) ovms-server-v2: Send MP-0 h3,0,RT-BAT-C,1,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45692) ovms-server-v2: Send MP-0 h4,0,RT-BAT-C,2,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45692) ovms-server-v2: Send MP-0 h5,0,RT-BAT-C,3,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45692) ovms-server-v2: Send MP-0 h6,0,RT-BAT-C,4,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45782) ovms-server-v2: Incoming Msg: MP-0 h2
I (45782) ovms-server-v2: Incoming Msg: MP-0 h3
I (45802) ovms-server-v2: Incoming Msg: MP-0 h4
I (45802) ovms-server-v2: Incoming Msg: MP-0 h5
I (45802) ovms-server-v2: Incoming Msg: MP-0 h6
OVMS> I (46682) ovms-server-v2: Send MP-0 h7,-1,RT-BAT-C,5,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46682) ovms-server-v2: Send MP-0 h8,-1,RT-BAT-C,6,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46682) ovms-server-v2: Send MP-0 h9,-1,RT-BAT-C,7,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46682) ovms-server-v2: Send MP-0 h10,-1,RT-BAT-C,8,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46682) ovms-server-v2: Send MP-0 h11,-1,RT-BAT-C,9,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46832) ovms-server-v2: Incoming Msg: MP-0 h7
I (46832) ovms-server-v2: Incoming Msg: MP-0 h8
I (46832) ovms-server-v2: Incoming Msg: MP-0 h9
I (46832) ovms-server-v2: Incoming Msg: MP-0 h10
I (46852) ovms-server-v2: Incoming Msg: MP-0 h11
OVMS> I (47682) ovms-server-v2: Send MP-0 h12,-2,RT-BAT-C,10,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47682) ovms-server-v2: Send MP-0 h13,-2,RT-BAT-C,11,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47682) ovms-server-v2: Send MP-0 h14,-1,RT-BAT-C,12,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47682) ovms-server-v2: Send MP-0 h15,-1,RT-BAT-C,13,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47692) ovms-server-v2: Send MP-0 h16,-2,RT-BAT-C,14,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47882) ovms-server-v2: Incoming Msg: MP-0 h12
I (47882) ovms-server-v2: Incoming Msg: MP-0 h13
I (47882) ovms-server-v2: Incoming Msg: MP-0 h14
I (47892) ovms-server-v2: Incoming Msg: MP-0 h15
I (47892) ovms-server-v2: Incoming Msg: MP-0 h16
OVMS> D (62752) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms
OVMS> enable
Password:
Secure mode
OVMS# cellular sza tatus debug
MODEM Status
Model: auto
Network Registration: Unknown
Provider:
Signal: 0 dBm
Mode:
State: PowerOffOn
Ticker: 0
User Data: 0
UART:
FIFO overflows: 0
Buffer overflows: 0
Parity errors: 0
Frame errors: 0
Driver Buffer overflows: 0
Mux: Not running
PPP: Not running
GPS: Not running
OVMS# I (122692) housekeeping: System considered stable (RAM: 8b=49404-49560 32b=12128 SPI=3208412-3234380)
D (122762) ovms-duktape: Duktape: Compacting DukTape memory done in 50 ms
OVMS# I (123682) ovms-server-v2: Send MP-0 h17,0,*-OVM-DebugCrash,0,2592000,3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),2,Crash,12,12,1,0,abort(),1,,0x4008ddae 0x4008e049 0x401184a3 0x4032e70b 0x40127862 0x40127909 0x40127909 0x401279af 0x401138b7 0x40130427 0x401305de 0x401138e7 0x4032f76a 0x4012d559 0x40122885 0x40122a5d 0x4012d401 0x4012d410 0x4010c3eb ,4,Exception/panic,,,0,,OVMS WIFI BLE BT cores=2 rev=ESP32/1,,IDLE0,524,OVMS Console,3416
I (123892) ovms-server-v2: Incoming Msg: MP-0 h17
OVMS# echo "modem led on"
modem led on
OVMS# cellular tx ATI
OVMS# D (159502) cellular: tx-cmd: ATI
OVMS# D (182742) ovms-duktape: Duktape: Compacting DukTape memory done in 50 ms
OVMS#
module fault
Backtrace: 0x4008ddae:0x3ffef1a0 0x4008e049:0x3ffef1c0 0x401184a3:0x3ffef1e0 0x4032e70b:0x3ffef200 0x40127862:0x3ffef220 0x40127909:0x3ffef280 0x40127909:0x3ffef2e0 0x401279af:0x3ffef340 0x401138b7:0x3ffef360 0x40130427:0x3ffef380 0x401305de:0x3ffef3e0 0x401138e7:0x3ffef480 0x4032f76a:0x3ffef4a0 0x4012d559:0x3ffef4c0 0x40122885:0x3ffef4f0 0x40122a5d:0x3ffef520 0x4012d401:0x3ffef540 0x4012d410:0x3ffef560 0x4010c3eb:0x3ffef580
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5328
ho 0 tail 12 room 4
load:0x40078000,len:11332
load:0x40080400,len:6204
entry 0x400806cc
I (1233) cpu_start: App cpu up.
I (2127) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (215) ovms_main: Set default logging level for * to INFO
I (215) ovms-duktape: Initialising DUKTAPE Registry (1000)
I (237) boot: Boot #3 reasons for CPU0=12 and CPU1=12
E (242) boot: Crash #2 detected
I (298) metrics: Persistent metrics serial 4 using 820 bytes, 68/100 slots used
I (316) metrics: persist v.b.12v.voltage = 12.3V
I (352) metrics: persist v.e.parktime = 642Sec
I (379) notify: Registered notification type info
I (383) notify: Registered notification type error
I (442) sdcard: Initialising SD CARD (4400)
I (482) canformat-panda: Registering CAN Format: PANDA (4505)
I (545) canlog-udpserver: Initialising CAN logging as UDP server (4560)
I (558) canplay: Initialising CAN play framework (4570)
I (577) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601)
I (582) cellular-modem-auto: Registering auto-detect modem driver (4650)
I (677) ovms-mdns: Initialising MDNS (8100)
I (696) re: Initialising RE Tools (8800)
I (736) v-track: Registering Vehicle: TRACK (9000)
I (775) v-smarteq: Registering Vehicle: SMART EQ (9000)
I (824) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000)
I (845) v-mgev: Registering Vehicle: MG5 (9000)
I (881) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000)
I (900) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000)
I (914) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000)
I (941) v-energica: Registering Vehicle: Energica (9000)
I (947) v-demo: Registering Vehicle: DEMO (9000)
I (974) v-atto3: Registering Vehicle: BYD Atto3 (9000)
D (1672) events: Signal(housekeeping.init)
I (1672) housekeeping: Executing on CPU core 1
I (1672) housekeeping: reset_reason: cpu0=12, cpu1=12
I (1672) housekeeping: Starting PERIPHERALS...
I (1682) peripherals: Initialising OVMS Peripherals...
I (1682) peripherals: TCP/IP Adaptor
I (1692) peripherals: ESP32 system
I (1692) peripherals: SPI bus
I (1702) peripherals: MAX7317 I/O Expander
I (1702) peripherals: ESP32 CAN
I (1712) peripherals: ESP32 WIFI
I (1712) peripherals: ESP32 ADC
I (1712) peripherals: MCP2515 CAN 1/2
I (1722) mcp2515: can2: SetPowerMode off
I (1802) peripherals: MCP2515 CAN 2/2
I (1802) mcp2515: can3: SetPowerMode off
I (1882) peripherals: SD CARD
I (1882) peripherals: CELLULAR MODEM
I (1882) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1892) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
V (1902) cellular: Starting modem task
I (1902) uart: queue free spaces: 50
I (1902) ext12v: Powering off external 12V devices
I (1912) housekeeping: Auto init max7317 (free: 160572 bytes)
I (1922) housekeeping: Auto init ext12v (free: 160572 bytes)
I (1922) housekeeping: Auto init dbc (free: 160572 bytes)
I (1932) housekeeping: Auto init wifi (free: 160572 bytes)
I (1952) wifi:wifi driver task: 3ffd9afc, prio:23, stack:3584, core=0
I (1952) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (1982) wifi:wifi firmware version: 30f9e79
I (1992) wifi:config NVS flash: enabled
I (1992) wifi:config nano formating: disabled
I (1992) wifi:Init data frame dynamic rx buffer num: 16
I (1992) wifi:Init management frame dynamic rx buffer num: 16
I (2002) wifi:Init management short buffer num: 32
I (2002) wifi:Init dynamic tx buffer num: 16
I (2002) wifi:Init static rx buffer size: 2212
I (2012) wifi:Init static rx buffer num: 16
I (2012) wifi:Init dynamic rx buffer num: 16
I (2792) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
I (2792) wifi:mode : sta (30:ae:a4:43:87:ec) + softAP (30:ae:a4:43:87:ed)
I (2792) wifi:Total power save buffer number: 8
I (2792) wifi:Init max length of beacon: 752/752
I (2802) housekeeping: Auto init modem (free: 115148 bytes)
I (2812) housekeeping: Auto init Pollers (free: 114728 bytes)
I (2812) cellular: Set modem driver to 'auto'
I (2812) housekeeping: Auto init vehicle (free: 114728 bytes)
I (2822) cellular: State: Enter PowerOffOn state
I (2832) v-twizy: Renault Twizy vehicle module
I (2832) cellular-modem-auto: Power Cycle
I (2842) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
I (2862) v-twizy: charge subsystem init
I (2862) canopen: Worker started on can1
I (2862) v-twizy: sevcon subsystem init
I (2882) v-twizy: obd subsystem init
I (2882) housekeeping: Auto init obd2ecu (free: 81464 bytes)
I (2882) housekeeping: Auto init server v2 (free: 81464 bytes)
I (2892) ovms-server-v2: OVMS Server V2 registered metric modifier is #2
I (2892) ovms-server-v2: Status: Server has been started
I (2902) ovms-server-v2: OVMS Server v2 running
I (2912) housekeeping: Auto init server v3 (free: 80912 bytes)
I (2912) housekeeping: Auto init javascript (free: 80912 bytes)
I (2922) housekeeping: Auto init done (free: 80872 bytes)
D (2942) events: Signal(system.event)
D (2952) events: Signal(system.wifi.sta.start)
D (2962) events: Signal(system.wifi.ap.start)
I (2962) netmanager: WIFI access point is up
D (2972) events: Signal(power.cellular.on)
D (2972) events: Signal(system.modem.stop)
D (2982) events: Signal(egpio.output.0.low)
D (2982) events: Signal(egpio.output.0.high)
D (3012) netmanager: MongooseTask starting
I (3022) ovms-duktape: Duktape: Creating heap (size: 524288 bytes)
D (3032) events: Signal(network.interface.change)
D (3042) events: Signal(network.mgr.init)
I (3062) ssh: Launching SSH Server
OVMS> I (3192) ovms-duktape: Duktape: Initialising module system
D (3202) ovms-duktape: Duktape: Pre-Registered function assert
D (3202) ovms-duktape: Duktape: Pre-Registered function meminfo
D (3202) ovms-duktape: Duktape: Pre-Registered function print
D (3212) ovms-duktape: Duktape: Pre-Registered function write
D (3212) ovms-duktape: Duktape: Pre-Registered object HTTP
D (3212) ovms-duktape: Duktape: Pre-Registered object HTTP function Request
D (3212) ovms-duktape: Duktape: Pre-Registered object HTTP function request
D (3212) ovms-duktape: Duktape: Pre-Registered object OvmsCommand
D (3212) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec
D (3212) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsEvents
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsLocation
D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function HasValue
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsFresh
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsStale
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsNotify
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Resume
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Trace
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStarted
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStatus
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Reset
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Start
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Stop
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Disable
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Enable
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Status
D (3262) ovms-duktape: Duktape: Pre-Registered object VFS
D (3262) ovms-duktape: Duktape: Pre-Registered object VFS function Load
D (3282) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js'
D (3282) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes)
D (3372) ovms-duktape: Duktape: Pre-Registered module PubSub
D (3382) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js'
D (3382) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes)
D (3392) ovms-duktape: Duktape: module load: int/PubSub.js
I (3602) ovms-duktape: Duktape: Executing ovmsmain.js
D (3602) ovms-duktape: Duktape: module load: ovmsmain.js
D (3612) ovms-duktape: Duktape: module unload: ovmsmain.js
D (3672) events: Signal(vehicle.charge.mode)
OVMS> D (4672) events: Signal(vehicle.aux.12v.normal)
OVMS> D (5352) events: Signal(egpio.output.0.low)
D (5412) events: Signal(system.event)
D (5412) events: Signal(system.wifi.scan.done)
I (5532) wifi:ap channel adjust o:1,0 n:11,0
I (5542) wifi:new:<11,0>, old:<1,0>, ap:<11,0>, sta:<11,0>, prof:1
OVMS> I (6222) wifi:state: init -> auth (b0)
I (6232) wifi:state: auth -> assoc (0)
I (6242) wifi:state: assoc -> run (10)
I (6262) wifi:connected with LeonsLair, aid = 17, channel 11, BW20, bssid = d4:24:dd:88:64:46
I (6262) wifi:security type: 3, phy: bgn, rssi: -68
I (6262) wifi:pm start, type: 1
D (6272) events: Signal(system.event)
D (6272) events: Signal(system.wifi.sta.connected)
D (6272) netmanager: send cmd 3 from 0x0
D (6272) netmanager: done cmd 3 from 0x0
I (6282) event: sta ip: 192.168.178.33, mask: 255.255.255.0, gw: 192.168.178.1
D (6282) events: Signal(system.event)
D (6292) events: Signal(network.interface.up)
D (6292) events: Signal(system.wifi.sta.gotip)
I (6292) netmanager: WIFI client got IP
D (6292) netmanager: Saved DNS#0 192.168.178.1
D (6292) netmanager: Saved DNS#1 0.0.0.0
D (6292) netmanager: Saved DNS#2 0.0.0.0
D (6292) netmanager: send cmd 3 from 0x0
D (6292) netmanager: done cmd 3 from 0x0
D (6292) netmanager: MongooseTask: got cmd 3 from 0x0
D (6312) netmanager: MongooseTask: done cmd 3 from 0x0
D (6312) netmanager: MongooseTask: got cmd 3 from 0x0
D (6322) netmanager: MongooseTask: done cmd 3 from 0x0
I (6352) wifi:AP's beacon interval = 102400 us, DTIM period = 1
OVMS> D (9672) events: Signal(network.wifi.sta.good)
I (9672) netmanager: WIFI client has good signal quality (-84.5 dBm); connect
I (9672) netmanager: Interface priority is st1 (192.168.178.33/255.255.255.0 gateway 192.168.178.1)
I (9672) netmanager: Set DNS#1 0.0.0.0
I (9672) netmanager: Set DNS#2 0.0.0.0
I (9682) netmanager: WIFI client up (with MODEM down): starting network with WIFI client
D (9682) events: Signal(network.wifi.up)
D (9682) events: Signal(network.up)
I (9682) ovms-server-v2: Status: Network is up, so attempt network connection
D (9692) events: Signal(network.interface.change)
D (9692) events: Signal(server.v2.connectwait)
OVMS> D (10352) events: Signal(egpio.output.0.high)
D (10552) events: Signal(egpio.output.0.low)
D (10552) cellular: State timeout PowerOffOn => PoweringOn
I (10552) cellular: State: Enter PoweringOn state
I (10552) cellular-modem-auto: Power Cycle
I (10552) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
D (10552) events: Signal(system.modem.poweringon)
D (10552) events: Signal(egpio.output.0.high)
OVMS> I (11672) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1
I (11672) ovms-server-v2: Status: Connecting...
D (11702) events: Signal(server.v2.connecting)
OVMS> D (13052) events: Signal(egpio.output.0.low)
OVMS> I (15032) ovms-server-v2: Connection successful
I (15032) ovms-server-v2: Status: Logging in...
D (15032) events: Signal(server.v2.authenticating)
I (15032) ovms-server-v2: Sending server login: MP-C 0 Cj2s2/OScrzgXugZLPyWeV 3CuKR76wTwPzTHQX73sT/Q== TEST1
I (15062) ovms-server-v2: Got server response: MP-S 0 MNhAzzc2XB52e4MTRB0Ffp 0l1TcI9RwCWy1XLKJEgtVg==
I (15062) ovms-server-v2: Server token is MNhAzzc2XB52e4MTRB0Ffp and digest is 0l1TcI9RwCWy1XLKJEgtVg==
I (15072) ovms-server-v2: Status: Server authentication ok. Now priming crypto.
I (15082) ovms-server-v2: Shared secret key is MNhAzzc2XB52e4MTRB0FfpCj2s2/OScrzgXugZLPyWeV (44 bytes)
I (15082) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
D (15082) events: Signal(server.v2.connected)
I (15102) ovms-server-v2: Incoming Msg: MP-0 Z0
OVMS> I (15672) ovms-server-v2: Send MP-0 S0,K,0,0.00,,standard,50,50,15,0,0,0,0,0,0,0,0,0,92.98,0,0,56,21,-1,0,0,0,0,0,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.0,0.0,0.0,0.0,-1
I (15682) ovms-server-v2: Send MP-0 D0,16,5,0,0,0,0,0,0,654,0,0,1,1,12.34,0,12.6,0,0,0,0
I (15682) ovms-server-v2: Send MP-0 L51.403984,7.439806,0,158.8,0,0,0,0,2050202,0,0.000,0.000,0,0,,0,0,0,0
I (15682) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1
I (15682) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1
I (15682) ovms-server-v2: Send MP-0 F3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),,20,0,RT,LeonsLair,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/1,
OVMS> D (18052) events: Signal(egpio.output.0.high)
D (18252) events: Signal(egpio.output.0.low)
D (18252) cellular: tx-cmd: AT
I (18352) cellular: State: Enter Identify state
D (18352) cellular: tx-cmd: AT+CGMM
OVMS> D (18672) cellular: tx-cmd: AT+CGMM
OVMS> D (19672) cellular: tx-cmd: AT+CGMM
OVMS> D (20672) cellular: tx-cmd: AT+CGMM
OVMS> D (21672) cellular: tx-cmd: AT+CGMM
OVMS> D (22672) cellular: tx-cmd: AT+CGMM
OVMS> D (23672) cellular: tx-cmd: AT+CGMM
OVMS> D (24672) cellular: tx-cmd: AT+CGMM
I (24672) ovms-server-v2: Send MP-0 h1,0,RT-GPS-Log,0,86400,51.403984,7.439806,159,0,0,0,0,-71,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (24682) cellular: Identified cellular modem: SIM5360/SIMCOM SIM5360 (include US and EU variants)
D (24682) cellular: Remove old 'auto' modem driver
I (24682) cellular: Set modem driver to 'SIM5360'
I (24682) cellular: State: Enter PoweredOn state
D (24682) events: Signal(system.modem.installed)
D (24692) events: Signal(system.modem.poweredon)
I (24882) ovms-server-v2: Incoming Msg: MP-0 h1
OVMS> D (27612) cellular: mux-rx-line #0 (2/48): OK
D (27612) cellular: mux-rx-line #0 (12/32): +CPIN: READY
D (27612) cellular: mux-rx-line #0 (12/16): OPL UPDATING
D (27612) cellular: mux-rx-line #0 (12/0): PNN UPDATING
OVMS> D (28362) cellular: mux-rx-line #0 (8/0): SMS DONE
OVMS> D (28962) cellular: mux-rx-line #0 (10/11): CALL READY
D (28962) cellular: mux-rx-line #0 (7/0): PB DONE
OVMS> D (34672) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
D (34692) cellular: mux-rx-line #0 (106/0): AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
D (34722) cellular: mux-rx-line #0 (12/20): +CPIN: READY
D (34722) cellular: mux-rx-line #0 (10/6): +CSQ: 22,0
D (34722) cellular: Signal Quality is: 22 (-69 dBm)
D (34722) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (36102) cellular: mux-rx-line #0 (26/0): +CTZV: 8,25/03/30,11:42:45
OVMS> D (36672) cellular: tx-cmd: AT+CGMR;+ICCID
D (36682) cellular: mux-rx-line #0 (23/37): +CGMR: 35316B11SIM5360E
D (36682) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389
D (36682) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (40412) cellular: mux-rx-line #0 (11/0): +CSQ: 22,99
OVMS> D (40672) cellular: tx-cmd: AT+CMUXSRVPORT=3,1
D (40682) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (41672) cellular: tx-cmd: AT+CMUXSRVPORT=2,1
D (41682) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (42672) cellular: tx-cmd: AT+CMUXSRVPORT=1,1
D (42682) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (43672) cellular: tx-cmd: AT+CMUXSRVPORT=0,5
D (43702) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (44672) cellular: tx-cmd: AT+CMUX=0;+CATR=6
D (44672) cellular: mux-rx-line #0 (2/0): OK
I (44682) cellular: State: Enter MuxStart state
V (44682) cellular: Starting MUX
D (44682) events: Signal(system.modem.muxstart)
I (44682) gsm-mux: Start MUX
I (44682) gsm-mux: Channel #0 is open
I (44692) gsm-mux: Channel #1 is open
I (44692) gsm-mux: Channel #2 is open
I (44702) gsm-mux: Channel #3 is open
I (44702) gsm-mux: Channel #4 is open
OVMS> D (45672) cellular: State transition MuxStart => NetWait
I (45672) cellular: State: Enter NetWait state
V (45672) cellular: Starting NMEA
I (45672) gsm-nmea: Startup
D (45672) cellular: mux-tx #4: AT+CGPSNMEA=66;+CGPS=1,1
I (45682) ovms-server-v2: Send MP-0 h2,0,RT-BAT-P,1,86400,1,1,0,10000,0,0,1000,0,-40,200,-40,0,0,0,0,0,0,0,0
I (45682) ovms-server-v2: Send MP-0 h3,0,RT-BAT-C,1,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45682) ovms-server-v2: Send MP-0 h4,0,RT-BAT-C,2,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
D (45692) events: Signal(system.modem.netwait)
D (45692) events: Signal(system.modem.gpsstart)
D (45762) cellular: mux-rx-line #4 (2/0): OK
I (45922) ovms-server-v2: Incoming Msg: MP-0 h2
I (45932) ovms-server-v2: Incoming Msg: MP-0 h3
I (45932) ovms-server-v2: Incoming Msg: MP-0 h4
I (45932) ovms-server-v2: Incoming Msg: MP-0 h5
I (45942) ovms-server-v2: Incoming Msg: MP-0 h6
OVMS> I (46672) ovms-server-v2: Send MP-0 h7,-1,RT-BAT-C,5,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46672) ovms-server-v2: Send MP-0 h8,0,RT-BAT-C,6,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46672) ovms-server-v2: Send MP-0 h9,0,RT-BAT-C,7,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46672) ovms-server-v2: Send MP-0 h10,0,RT-BAT-C,8,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46682) ovms-server-v2: Send MP-0 h11,0,RT-BAT-C,9,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46732) ovms-server-v2: Incoming Msg: MP-0 h7
I (46732) ovms-server-v2: Incoming Msg: MP-0 h8
I (46732) ovms-server-v2: Incoming Msg: MP-0 h9
I (46732) ovms-server-v2: Incoming Msg: MP-0 h10
I (46742) ovms-server-v2: Incoming Msg: MP-0 h11
OVMS> I (47672) ovms-server-v2: Send MP-0 h12,-1,RT-BAT-C,10,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47672) ovms-server-v2: Send MP-0 h13,-1,RT-BAT-C,11,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47672) ovms-server-v2: Send MP-0 h14,-1,RT-BAT-C,12,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47672) ovms-server-v2: Send MP-0 h15,-1,RT-BAT-C,13,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47682) ovms-server-v2: Send MP-0 h16,-1,RT-BAT-C,14,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47772) ovms-server-v2: Incoming Msg: MP-0 h12
I (47772) ovms-server-v2: Incoming Msg: MP-0 h13
I (47772) ovms-server-v2: Incoming Msg: MP-0 h14
I (47772) ovms-server-v2: Incoming Msg: MP-0 h15
I (47782) ovms-server-v2: Incoming Msg: MP-0 h16
OVMS> D (55672) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
D (55702) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
I (55702) cellular: Network Registration status: RegisteredRoaming
D (55702) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:43:04+08"
D (55702) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99
D (55702) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (56672) cellular: mux-tx #3: AT+CPSI?
D (56672) cellular: State transition NetWait => NetStart
I (56672) cellular: State: Enter NetStart state
D (56672) events: Signal(system.modem.netstart)
D (56682) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38
I (56682) cellular: Network Mode: GSM,Online
D (56682) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (57672) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
D (57702) cellular: mux-rx-line #2 (14/0): CONNECT 115200
I (57702) cellular: PPP Connection is ready to start
OVMS> D (58672) cellular: State transition NetStart => NetMode
I (58672) cellular: State: Enter NetMode state
V (58672) cellular: Launching PPP
V (58672) cellular: Starting PPP
I (58672) gsm-ppp: Initialising...
D (58682) events: Signal(system.modem.netmode)
OVMS> I (59422) gsm-ppp: StatusCallBack: None
I (59422) gsm-ppp: status_cb: Connected
I (59422) gsm-ppp: our_ipaddr = 10.170.195.13
I (59422) gsm-ppp: his_ipaddr = 10.64.64.64
I (59422) gsm-ppp: netmask = 255.255.255.255
I (59422) gsm-ppp: DNS#0 = 8.8.8.8
I (59422) gsm-ppp: DNS#1 = 8.8.4.4
I (59422) gsm-ppp: our6_ipaddr = ::
D (59422) events: Signal(network.interface.up)
D (59422) events: Signal(system.modem.gotip)
D (59422) netmanager: Saved DNS#0 8.8.8.8
D (59422) netmanager: Saved DNS#1 8.8.4.4
D (59422) netmanager: Saved DNS#2 0.0.0.0
I (59432) netmanager: Set DNS#1 0.0.0.0
I (59432) netmanager: Set DNS#2 0.0.0.0
I (59432) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority
D (59432) events: Signal(network.modem.up)
D (59432) events: Signal(network.interface.change)
OVMS> D (59752) events: Signal(gps.lock.acquired)
D (59762) events: Signal(system.modem.gotgps)
OVMS> I (60672) ovms-server-v2: Send MP-0 h17,0,RT-GPS-Log,0,86400,51.404034,7.439826,155,0,0,1,0,-71,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (60812) ovms-server-v2: Incoming Msg: MP-0 h17
OVMS> D (61422) cellular: mux-rx-line #3 (10/0): +CSQ: 22,0
OVMS> D (62732) ovms-duktape: Duktape: Compacting DukTape memory done in 50 ms
OVMS> D (64422) cellular: mux-rx-line #3 (11/0): +CSQ: 22,99
OVMS> enable
Password:
Secure mode
OVMS# module fault
Rebooting...
ho 0 tail 12 room 4
entry 0x400806cc
I (1192) spiram: Found 32MBit SPI RAM device
I (2133) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM
I (214) ovms_main: Set default logging level for * to INFO
I (237) boot: Boot #4 reasons for CPU0=12 and CPU1=12
E (242) boot: Early crash #1 detected
I (247) boot: Reset reason Exception/panic (4)
I (283) ovms-duk-vfs: Installing DUKTAPE VFS (1710)
I (294) metrics: Expanding DUKTAPE javascript engine
I (299) metrics: Persistent metrics serial 5 using 820 bytes, 68/100 slots used
I (313) metrics: persist v.b.range.est = 50km
I (317) metrics: persist v.b.12v.voltage = 12.32V
I (329) metrics: persist v.c.climit = 15A
I (334) metrics: persist v.c.limit.range = 56km
I (338) metrics: persist v.c.limit.soc = 21%
I (347) metrics: persist v.e.drivemode = 33882626
I (349) metrics: persist v.e.valet = yes
I (353) metrics: persist v.e.parktime = 715Sec
I (359) metrics: persist v.p.latitude = 51.4041
I (363) metrics: persist v.p.longitude = 7.43977
I (369) metrics: persist v.p.altitude = 153.7m
I (376) notify: Initialising NOTIFICATIONS (1820)
I (395) notify: Registered notification type data
I (406) notify: Expanding DUKTAPE javascript engine
I (412) location: Initialising LOCATIONS (1900)
I (420) location: Expanding DUKTAPE javascript engine
I (435) pcp: Initialising POWER (4000)
I (437) max7317: Initialising MAX7317 EGPIO (4200)
I (464) canformat-crtd: Registering CAN Format: CRTD (4505)
I (470) canformat-gvret: Registering CAN Format: GVRET (4505)
I (496) canformat-raw: Registering CAN Format: RAW (4505)
I (502) can: Initialising CAN (4510)
I (517) canlog: Initialising CAN logging (4550)
I (524) canlog-tcpclient: Initialising CAN logging as TCP client (4560)
I (615) tpms: Initialising TPMS (4700)
I (652) vehicle-poll: Initialising Poller (7000)
I (671) pluginstore: Initialising PLUGINS (7100)
I (682) webserver: Initialising WEBSERVER (8200)
I (690) ssh: Initialising SSH (8300)
I (692) powermgmt: Initialising POWERMGMT (8500)
I (709) netmanager: Initialising NETMANAGER (8999)
I (719) v-zeva: Registering Vehicle: ZEVA (9000)
I (730) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000)
I (743) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000)
I (756) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000)
I (763) v-teslamodels: Registering Vehicle: Tesla Model S (9000)
I (782) v-smarted: Registering Vehicle: SMART ED (9000)
I (788) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000)
I (802) v-twizy: Registering Vehicle: Renault Twizy (9000)
I (808) v-obdii: Registering Vehicle: OBDII (9000)
I (841) v-mgev4: Registering Vehicle: MG4 (9000)
I (864) v-mgev: Registering Vehicle: MG ZS EV (2023-)
I (870) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000)
I (876) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000)
I (895) v-maple60s: Registering Vehicle: Maple 60S (9000)
I (922) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000)
I (936) v-fiat500e: Registering Vehicle: FIAT 500e (9000)
I (960) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000)
I (968) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000)
I (981) v-boltev: Registering Vehicle: Bolt EV (9000)
I (987) v-bmwi3: Registering Vehicle: BMW i3 (9000)
I (1001) cpu_start: Starting scheduler on PRO CPU.
I (1073) ovms_main: Executing on CPU core 0
I (1083) ovms_main: Mounting CONFIG...
I (1193) ovms_main: Configure logging...
W (1203) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount
I (1203) ovms_main: Registering default configs...
I (1203) ovms_main: Starting HOUSEKEEPING...
I (1213) housekeeping: Initialising HOUSEKEEPING Framework...
I (1213) tls: Built trusted CA cache (5 entries, 8101 bytes)
D (1693) events: Signal(housekeeping.init)
I (1693) housekeeping: Executing on CPU core 1
I (1693) housekeeping: reset_reason: cpu0=12, cpu1=12
I (1693) housekeeping: Starting PERIPHERALS...
I (1703) peripherals: Initialising OVMS Peripherals...
I (1703) peripherals: TCP/IP Adaptor
I (1713) peripherals: ESP32 system
I (1713) peripherals: SPI bus
I (1723) peripherals: MAX7317 I/O Expander
I (1723) peripherals: ESP32 CAN
I (1733) peripherals: ESP32 WIFI
I (1733) peripherals: ESP32 ADC
I (1733) peripherals: MCP2515 CAN 1/2
I (1743) mcp2515: can2: SetPowerMode off
I (1823) peripherals: MCP2515 CAN 2/2
I (1823) mcp2515: can3: SetPowerMode off
I (1903) peripherals: SD CARD
I (1903) peripherals: CELLULAR MODEM
I (1903) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1913) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
V (1923) cellular: Starting modem task
I (1923) uart: queue free spaces: 50
I (1923) ext12v: Powering off external 12V devices
I (1933) housekeeping: Auto init max7317 (free: 160572 bytes)
I (1943) housekeeping: Auto init ext12v (free: 160572 bytes)
I (1943) housekeeping: Auto init dbc (free: 160572 bytes)
I (1953) housekeeping: Auto init wifi (free: 160572 bytes)
I (1973) wifi:wifi driver task: 3ffd9afc, prio:23, stack:3584, core=0
I (1973) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (1983) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (2003) wifi:wifi firmware version: 30f9e79
I (2013) wifi:config NVS flash: enabled
I (2013) wifi:config nano formating: disabled
I (2013) wifi:Init data frame dynamic rx buffer num: 16
I (2013) wifi:Init management frame dynamic rx buffer num: 16
I (2023) wifi:Init management short buffer num: 32
I (2023) wifi:Init dynamic tx buffer num: 16
I (2023) wifi:Init static rx buffer size: 2212
I (2033) wifi:Init static rx buffer num: 16
I (2033) wifi:Init dynamic rx buffer num: 16
I (2813) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
I (2813) wifi:mode : sta (30:ae:a4:43:87:ec) + softAP (30:ae:a4:43:87:ed)
I (2813) wifi:Total power save buffer number: 8
I (2813) wifi:Init max length of beacon: 752/752
I (2823) wifi:Init max length of beacon: 752/752
I (2823) housekeeping: Auto init modem (free: 115408 bytes)
I (2833) housekeeping: Auto init Pollers (free: 114728 bytes)
I (2843) housekeeping: Auto init vehicle (free: 114728 bytes)
I (2853) v-twizy: Renault Twizy vehicle module
I (2853) v-twizy: battmon subsystem init
I (2863) v-twizy: pwrmon subsystem init
I (2863) v-twizy: charge subsystem init
I (2863) canopen: Worker started on can1
I (2873) v-twizy: sevcon subsystem init
I (2883) v-twizy: obd subsystem init
I (2883) housekeeping: Auto init obd2ecu (free: 81496 bytes)
I (2883) housekeeping: Auto init server v2 (free: 81496 bytes)
I (2893) ovms-server-v2: OVMS Server V2 registered metric modifier is #2
I (2893) ovms-server-v2: Status: Server has been started
I (2903) ovms-server-v2: OVMS Server v2 running
I (2913) housekeeping: Auto init server v3 (free: 80944 bytes)
I (2913) housekeeping: Auto init javascript (free: 80944 bytes)
I (2923) cellular: Set modem driver to 'auto'
I (2923) housekeeping: Auto init done (free: 80904 bytes)
I (2923) cellular: State: Enter PowerOffOn state
I (2933) housekeeping: Starting USB console...
I (2943) cellular-modem-auto: Power Cycle
I (2943) uart: queue free spaces: 100
I (2943) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
D (2963) events: Signal(egpio.output.1.low)
D (2963) events: Signal(system.event)
D (2973) events: Signal(system.wifi.sta.start)
D (2973) events: Signal(system.event)
D (2983) events: Signal(system.wifi.ap.start)
I (2983) netmanager: WIFI access point is up
D (2993) events: Signal(power.cellular.on)
D (2993) events: Signal(power.can1.on)
D (3003) events: Signal(egpio.output.2.low)
D (3003) events: Signal(canopen.worker.start)
D (3013) events: Signal(vehicle.type.set)
D (3013) events: Signal(server.v2.waitnetwork)
D (3023) events: Signal(system.modem.stop)
D (3023) events: Signal(system.start)
I (3023) ovms-mdns: Starting MDNS
D (3033) netmanager: MongooseTask starting
I (2923) ovms-duktape: Duktape: Creating heap (size: 524288 bytes)
OVMS> D (3053) events: Signal(egpio.output.0.low)
D (3063) events: Signal(egpio.output.0.high)
D (3063) events: Signal(network.interface.change)
D (3063) events: Signal(network.mgr.init)
I (3083) ssh: Launching SSH Server
I (3213) ovms-duktape: Duktape: Initialising module system
D (3233) ovms-duktape: Duktape: Pre-Registered function assert
D (3233) ovms-duktape: Duktape: Pre-Registered function meminfo
D (3233) ovms-duktape: Duktape: Pre-Registered function print
D (3243) ovms-duktape: Duktape: Pre-Registered function write
D (3243) ovms-duktape: Duktape: Pre-Registered object HTTP
D (3243) ovms-duktape: Duktape: Pre-Registered object HTTP function Request
D (3243) ovms-duktape: Duktape: Pre-Registered object HTTP function request
D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsCommand
D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec
D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register
D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig
D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Delete
D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Get
D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function GetValues
D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances
D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params
D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set
D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues
D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsEvents
D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise
D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsLocation
D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status
D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics
D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Age
D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsFloat
D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsJSON
D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues
D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function HasValue
D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsFresh
D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsStale
D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value
D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsNotify
D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsNotify function Raise
D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsPoller
D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetPaused
D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetTraceStatus
D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetUserPaused
D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Pause
D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Resume
D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Trace
D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStarted
D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStatus
D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Reset
D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Start
D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Stop
D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle
D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ClimateControl
D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Homelink
D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Lock
D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ObdRequest
D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent
D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode
D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer
D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge
D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown
D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge
D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown
D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Type
D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unlock
D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unvalet
D (3293) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Valet
D (3293) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup
D (3293) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Disable
D (3293) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Enable
D (3293) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Status
D (3293) ovms-duktape: Duktape: Pre-Registered object VFS
D (3293) ovms-duktape: Duktape: Pre-Registered object VFS function Load
D (3293) ovms-duktape: Duktape: Pre-Registered object VFS function Save
D (3293) ovms-duktape: Duktape: Pre-Registered module JSON
D (3303) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js'
D (3303) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes)
D (3303) ovms-duktape: Duktape: module load: int/JSON.js
D (3393) ovms-duktape: Duktape: Pre-Registered module PubSub
D (3403) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js'
D (3403) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes)
D (3403) ovms-duktape: Duktape: module load: int/PubSub.js
I (3623) ovms-duktape: Duktape: Executing ovmsmain.js
D (3623) ovms-duktape: Duktape: module load: ovmsmain.js
D (3633) ovms-duktape: Duktape: module unload: ovmsmain.js
D (3693) events: Signal(vehicle.charge.mode)
OVMS> D (4693) events: Signal(vehicle.aux.12v.normal)
OVMS> D (5433) events: Signal(system.event)
D (5433) events: Signal(system.wifi.scan.done)
D (5463) events: Signal(egpio.output.0.low)
I (5553) wifi:ap channel adjust o:1,0 n:11,0
I (5563) wifi:new:<11,0>, old:<1,0>, ap:<11,0>, sta:<11,0>, prof:1
OVMS> I (6243) wifi:state: init -> auth (b0)
I (6263) wifi:state: auth -> assoc (0)
I (6273) wifi:state: assoc -> run (10)
I (6313) wifi:connected with LeonsLair, aid = 20, channel 11, BW20, bssid = d4:24:dd:88:64:46
I (6313) wifi:security type: 3, phy: bgn, rssi: -68
I (6313) wifi:pm start, type: 1
D (6313) events: Signal(system.event)
D (6323) events: Signal(system.wifi.sta.connected)
D (6323) netmanager: send cmd 3 from 0x0
D (6323) netmanager: done cmd 3 from 0x0
I (6323) event: sta ip: 192.168.178.33, mask: 255.255.255.0, gw: 192.168.178.1
D (6323) events: Signal(system.event)
D (6333) events: Signal(network.interface.up)
D (6333) events: Signal(system.wifi.sta.gotip)
I (6333) netmanager: WIFI client got IP
D (6333) netmanager: Saved DNS#0 192.168.178.1
D (6333) netmanager: Saved DNS#1 0.0.0.0
D (6333) netmanager: Saved DNS#2 0.0.0.0
D (6333) netmanager: send cmd 3 from 0x0
D (6333) netmanager: done cmd 3 from 0x0
I (6373) wifi:AP's beacon interval = 102400 us, DTIM period = 1
D (6553) netmanager: MongooseTask: got cmd 3 from 0x0
D (6553) netmanager: MongooseTask: done cmd 3 from 0x0
D (6563) netmanager: MongooseTask: done cmd 3 from 0x0
OVMS> D (9693) events: Signal(network.wifi.sta.good)
I (9693) netmanager: WIFI client has good signal quality (-84.5 dBm); connect
I (9693) netmanager: Interface priority is st1 (192.168.178.33/255.255.255.0 gateway 192.168.178.1)
I (9693) netmanager: Set DNS#1 0.0.0.0
I (9693) netmanager: Set DNS#2 0.0.0.0
I (9693) netmanager: WIFI client up (with MODEM down): starting network with WIFI client
D (9703) events: Signal(network.wifi.up)
D (9703) events: Signal(network.up)
I (9703) ovms-server-v2: Status: Network is up, so attempt network connection
D (9703) events: Signal(network.interface.change)
D (9713) events: Signal(server.v2.connectwait)
OVMS> D (10463) events: Signal(egpio.output.0.high)
D (10663) events: Signal(egpio.output.0.low)
OVMS> D (11063) cellular: State timeout PowerOffOn => PoweringOn
I (11063) cellular: State: Enter PoweringOn state
I (11063) cellular-modem-auto: Power Cycle
D (11063) events: Signal(system.modem.poweringon)
I (11063) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
D (11063) events: Signal(egpio.output.0.high)
OVMS> I (11693) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1
I (11693) ovms-server-v2: Status: Connecting...
D (11723) events: Signal(server.v2.connecting)
OVMS> D (13563) events: Signal(egpio.output.0.low)
OVMS> I (15313) ovms-server-v2: Connection successful
I (15313) ovms-server-v2: Status: Logging in...
D (15313) events: Signal(server.v2.authenticating)
I (15313) ovms-server-v2: Sending server login: MP-C 0 nojf4vVho/sveBK1aQuyV8 U9sbCREBp8+8uL8s7smHjg== TEST1
I (15343) ovms-server-v2: Got server response: MP-S 0 5fp6dF41wlI69FsJC5uEla Vqkc/9GA6H+dbFlGSPLihg==
I (15343) ovms-server-v2: Server token is 5fp6dF41wlI69FsJC5uEla and digest is Vqkc/9GA6H+dbFlGSPLihg==
I (15353) ovms-server-v2: Status: Server authentication ok. Now priming crypto.
I (15353) ovms-server-v2: Shared secret key is 5fp6dF41wlI69FsJC5uElanojf4vVho/sveBK1aQuyV8 (44 bytes)
I (15353) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
D (15353) events: Signal(server.v2.connected)
I (15383) ovms-server-v2: Incoming Msg: MP-0 Z0
OVMS> I (15693) ovms-server-v2: Send MP-0 S0,K,0,0.00,,standard,50,50,15,0,0,0,0,0,0,0,0,0,92.98,0,0,56,21,-1,0,0,0,0,0,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.0,0.0,0.0,0.0,-1
I (15703) ovms-server-v2: Send MP-0 D0,16,5,0,0,0,0,0,0,727,0,0,1,1,12.34,0,12.6,0,0,0,0
I (15703) ovms-server-v2: Send MP-0 L51.404079,7.439766,0,153.7,0,0,0,0,2050202,0,0.000,0.000,0,0,,0,0,0,0
I (15703) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1
I (15703) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1
I (15703) ovms-server-v2: Send MP-0 F3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),,20,0,RT,LeonsLair,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/1,
OVMS> D (18563) events: Signal(egpio.output.0.high)
D (18763) events: Signal(egpio.output.0.low)
I (18863) cellular: State: Enter Identify state
D (19063) cellular: tx-cmd: AT+CGMM
I (19073) cellular: Identified cellular modem: SIM5360/SIMCOM SIM5360 (include US and EU variants)
D (19073) cellular: Remove old 'auto' modem driver
I (19073) cellular: Set modem driver to 'SIM5360'
I (19073) cellular: State: Enter PoweredOn state
D (19073) events: Signal(system.modem.installed)
D (19083) events: Signal(system.modem.poweredon)
D (19183) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (20193) cellular: mux-rx-line #0 (12/32): +CPIN: READY
D (20193) cellular: mux-rx-line #0 (12/16): OPL UPDATING
D (20193) cellular: mux-rx-line #0 (12/0): PNN UPDATING
OVMS> D (20813) cellular: mux-rx-line #0 (8/0): SMS DONE
OVMS> D (21363) cellular: mux-rx-line #0 (10/11): CALL READY
D (21363) cellular: mux-rx-line #0 (7/0): PB DONE
OVMS> I (24693) ovms-server-v2: Send MP-0 h1,0,RT-GPS-Log,0,86400,51.404079,7.439766,154,0,0,0,0,-72,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
OVMS> I (24903) ovms-server-v2: Incoming Msg: MP-0 h1
OVMS> D (26693) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
D (26723) cellular: mux-rx-line #0 (106/0): AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
D (26753) cellular: mux-rx-line #0 (12/20): +CPIN: READY
D (26753) cellular: mux-rx-line #0 (10/6): +CSQ: 22,0
D (26753) cellular: Signal Quality is: 22 (-69 dBm)
D (26753) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (27603) cellular: mux-rx-line #0 (26/0): +CTZV: 8,25/03/30,11:43:56
OVMS> D (28693) cellular: tx-cmd: AT+CGMR;+ICCID
D (28703) cellular: mux-rx-line #0 (23/37): +CGMR: 35316B11SIM5360E
D (28703) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389
D (28703) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (32523) cellular: mux-rx-line #0 (11/0): +CSQ: 22,99
D (32693) cellular: tx-cmd: AT+CMUXSRVPORT=3,1
D (32703) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (33693) cellular: tx-cmd: AT+CMUXSRVPORT=2,1
D (33703) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (34693) cellular: tx-cmd: AT+CMUXSRVPORT=1,1
D (34703) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (35693) cellular: tx-cmd: AT+CMUXSRVPORT=0,5
D (35703) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (36693) cellular: tx-cmd: AT+CMUX=0;+CATR=6
D (36703) cellular: mux-rx-line #0 (2/0): OK
I (36703) cellular: State: Enter MuxStart state
V (36703) cellular: Starting MUX
I (36703) gsm-mux: Start MUX
D (36703) events: Signal(system.modem.muxstart)
I (36703) gsm-mux: Channel #0 is open
I (36713) gsm-mux: Channel #1 is open
I (36723) gsm-mux: Channel #2 is open
I (36723) gsm-mux: Channel #3 is open
I (36733) gsm-mux: Channel #4 is open
OVMS> D (37693) cellular: State transition MuxStart => NetWait
I (37693) cellular: State: Enter NetWait state
V (37693) cellular: Starting NMEA
I (37693) gsm-nmea: Startup
D (37693) cellular: mux-tx #4: AT+CGPSNMEA=66;+CGPS=1,1
D (37693) events: Signal(system.modem.netwait)
D (37703) events: Signal(system.modem.gpsstart)
D (37793) cellular: mux-rx-line #4 (2/0): OK
OVMS> I (45703) ovms-server-v2: Send MP-0 h2,0,RT-BAT-P,1,86400,1,1,0,10000,0,0,1000,0,-40,200,-40,0,0,0,0,0,0,0,0
I (45703) ovms-server-v2: Send MP-0 h3,0,RT-BAT-C,1,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45703) ovms-server-v2: Send MP-0 h4,0,RT-BAT-C,2,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45703) ovms-server-v2: Send MP-0 h5,0,RT-BAT-C,3,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45713) ovms-server-v2: Send MP-0 h6,0,RT-BAT-C,4,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45943) ovms-server-v2: Incoming Msg: MP-0 h2
I (45943) ovms-server-v2: Incoming Msg: MP-0 h3
I (45943) ovms-server-v2: Incoming Msg: MP-0 h4
I (45943) ovms-server-v2: Incoming Msg: MP-0 h5
I (45953) ovms-server-v2: Incoming Msg: MP-0 h6
OVMS> D (46313) events: Signal(gps.lock.acquired)
D (46313) events: Signal(system.modem.gotgps)
OVMS> I (46693) ovms-server-v2: Send MP-0 h7,-1,RT-BAT-C,5,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46693) ovms-server-v2: Send MP-0 h8,-1,RT-BAT-C,6,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46703) ovms-server-v2: Send MP-0 h9,-1,RT-BAT-C,7,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46703) ovms-server-v2: Send MP-0 h10,-1,RT-BAT-C,8,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46703) ovms-server-v2: Send MP-0 h11,-1,RT-BAT-C,9,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46743) ovms-server-v2: Incoming Msg: MP-0 h7
I (46753) ovms-server-v2: Incoming Msg: MP-0 h8
I (46763) ovms-server-v2: Incoming Msg: MP-0 h9
I (46763) ovms-server-v2: Incoming Msg: MP-0 h10
I (46773) ovms-server-v2: Incoming Msg: MP-0 h11
OVMS> D (47693) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
I (47693) ovms-server-v2: Send MP-0 h12,-1,RT-BAT-C,10,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47693) ovms-server-v2: Send MP-0 h13,-1,RT-BAT-C,11,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47693) ovms-server-v2: Send MP-0 h14,-1,RT-BAT-C,12,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47693) ovms-server-v2: Send MP-0 h15,-1,RT-BAT-C,13,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47703) ovms-server-v2: Send MP-0 h16,-2,RT-BAT-C,14,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
D (47723) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
I (47723) cellular: Network Registration status: RegisteredRoaming
D (47723) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:44:16+08"
D (47723) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99
D (47723) cellular: mux-rx-line #3 (2/0): OK
I (47803) ovms-server-v2: Incoming Msg: MP-0 h12
I (47803) ovms-server-v2: Incoming Msg: MP-0 h13
I (47813) ovms-server-v2: Incoming Msg: MP-0 h14
I (47813) ovms-server-v2: Incoming Msg: MP-0 h15
I (47823) ovms-server-v2: Incoming Msg: MP-0 h16
OVMS> D (48693) cellular: mux-tx #3: AT+CPSI?
D (48693) cellular: State transition NetWait => NetStart
I (48693) cellular: State: Enter NetStart state
I (48693) ovms-server-v2: Send MP-0 h17,-2,RT-GPS-Log,0,86400,51.404243,7.439665,137,0,0,1,0,-72,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
D (48703) events: Signal(system.modem.netstart)
D (48703) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38
I (48703) cellular: Network Mode: GSM,Online
D (48703) cellular: mux-rx-line #3 (2/0): OK
I (48843) ovms-server-v2: Incoming Msg: MP-0 h17
OVMS> D (49693) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
D (49733) cellular: mux-rx-line #2 (14/0): CONNECT 115200
I (49733) cellular: PPP Connection is ready to start
OVMS> D (50693) cellular: State transition NetStart => NetMode
I (50693) cellular: State: Enter NetMode state
V (50693) cellular: Launching PPP
V (50693) cellular: Starting PPP
I (50693) gsm-ppp: Initialising...
D (50703) events: Signal(system.modem.netmode)
OVMS> I (51573) gsm-ppp: StatusCallBack: None
I (51583) gsm-ppp: status_cb: Connected
I (51583) gsm-ppp: our_ipaddr = 10.170.195.13
I (51583) gsm-ppp: his_ipaddr = 10.64.64.64
I (51583) gsm-ppp: netmask = 255.255.255.255
I (51583) gsm-ppp: DNS#0 = 8.8.8.8
I (51583) gsm-ppp: DNS#1 = 8.8.4.4
I (51583) gsm-ppp: our6_ipaddr = ::
D (51583) events: Signal(network.interface.up)
D (51583) events: Signal(system.modem.gotip)
D (51583) netmanager: Saved DNS#0 8.8.8.8
D (51583) netmanager: Saved DNS#1 8.8.4.4
D (51583) netmanager: Saved DNS#2 0.0.0.0
I (51583) netmanager: Set DNS#1 0.0.0.0
I (51583) netmanager: Set DNS#2 0.0.0.0
I (51583) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority
D (51593) events: Signal(network.modem.up)
D (51593) events: Signal(network.interface.change)
OVMS> D (62763) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms
OVMS> D (80693) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
D (80703) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
D (80713) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:44:49+08"
D (80713) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99
D (80713) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (81693) cellular: mux-tx #3: AT+CPSI?
D (81703) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38
D (81703) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (82693) cellular: mux-tx #3: AT+COPS?
D (82703) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0
I (82703) cellular: Network Provider is: vodafone.de Hologram
D (82703) cellular: mux-rx-line #3 (2/0): OK
OVMS> I (84693) ovms-server-v2: Send MP-0 h18,0,RT-GPS-Log,0,86400,51.404110,7.439844,142,0,0,1,0,-71,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (84873) ovms-server-v2: Incoming Msg: MP-0 h18
OVMS> D (110693) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
D (110703) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
D (110703) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:45:19+08"
D (110703) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99
D (110703) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (111693) cellular: mux-tx #3: AT+CPSI?
D (111703) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38
D (111703) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (112693) cellular: mux-tx #3: AT+COPS?
D (112703) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0
D (112703) cellular: mux-rx-line #3 (2/0): OK
OVMS> I (122693) housekeeping: System considered stable (RAM: 8b=47972-48676 32b=12128 SPI=3205136-3218336)
D (122763) ovms-duktape: Duktape: Compacting DukTape memory done in 40 ms
OVMS> I (123693) ovms-server-v2: Send MP-0 h19,0,*-OVM-DebugCrash,0,2592000,3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),4,EarlyCrash,12,12,3,1,abort(),1,,0x4008ddae 0x4008e049 0x401184a3 0x4032e70b 0x40127862 0x40127909 0x40127909 0x401279af 0x401138b7 0x40130427 0x401305de 0x401138e7 0x4032f76a 0x4012d559 0x40122885 0x40122a5d 0x4012d401 0x4012d410 0x4010c3eb ,4,Exception/panic,,,0,,OVMS WIFI BLE BT cores=2 rev=ESP32/1; MODEM SIM5360,,IDLE0,524,OVMS Console,3464
I (123873) ovms-server-v2: Incoming Msg: MP-0 h19
OVMS> enable
Password:
Secure mode
OVMS# module faD (140693) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
D (140703) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
D (140703) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:45:49+08"
D (140703) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99
D (140713) cellular: mux-rx-line #3 (2/0): OK
OVMS# module fault D (141693) cellular: mux-tx #3: AT+CPSI?
D (141703) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38
D (141703) cellular: mux-rx-line #3 (2/0): OK
OVMS# module fault
abort() was called at PC 0x401184a3 on core 1
ELF file SHA256: 8ba7ed1fff95ef4c
[OVMS] Current tasks: IDLE0|OVMS Console
Rebooting...
ho 0 tail 12 room 4
entry 0x400806cc
I (1192) psram: This chip is ESP32-D0WD
I (1193) spiram: Found 32MBit SPI RAM device
I (1193) spiram: SPI RAM mode: flash 40m sram 40m
I (1196) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (1203) cpu_start: Pro cpu up.
I (1207) cpu_start: Application information:
I (1212) cpu_start: Project name: ovms3
I (1217) cpu_start: App version: 3.3.004-429-g629e5b8b
I (1223) cpu_start: Compile time: Mar 30 2025 13:28:23
I (1229) cpu_start: ELF file SHA256: 8ba7ed1fff95ef4c...
I (1235) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b
I (1242) cpu_start: Starting app cpu, entry point is 0x400818e0
I (2127) spiram: SPI SRAM memory test OK
I (2127) heap_init: Initializing. RAM available for dynamic allocation:
I (2134) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM
I (2140) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (2146) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (2153) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM
I (2159) cpu_start: Pro cpu start user code
I (2164) spiram: Adding pool of 4096K of external SPI memory to heap allocator
I (215) ovms_main: WATCHDOG already initialized...
I (222) command: Initialising COMMAND (1010)
I (228) command: Expanding DUKTAPE javascript engine
I (232) boot: Initialising BOOT (1100)
I (237) boot: Boot #5 reasons for CPU0=12 and CPU1=12
E (242) boot: Crash #4 detected
I (246) boot: Reset reason Exception/panic (4)
I (252) events: Initialising EVENTS (1200)
I (257) config: Initialising CONFIG (1400)
I (262) time: Initialising TIME (1500)
I (266) script: Initialising SCRIPTS (1600)
I (271) ovms-duk-http: Installing DUKTAPE HTTP (1710)
I (276) ovms-duk-util: Installing DUKTAPE Utilities (1710)
I (282) ovms-duk-vfs: Installing DUKTAPE VFS (1710)
I (288) metrics: Initialising METRICS (1810)
I (293) metrics: Expanding DUKTAPE javascript engine
I (298) metrics: Persistent metrics serial 6 using 820 bytes, 68/100 slots used
I (308) metrics: persist v.b.cac = 92.9772Ah
I (312) metrics: persist v.b.range.est = 50km
I (322) metrics: persist v.b.12v.voltage.ref = 12.6V
I (328) metrics: persist v.c.climit = 15A
I (333) metrics: persist v.c.limit.range = 56km
I (337) metrics: persist v.c.limit.soc = 21%
I (346) metrics: persist v.e.drivemode = 33882626
I (348) metrics: persist v.e.valet = yes
I (352) metrics: persist v.e.parktime = 853Sec
I (363) metrics: persist v.p.longitude = 7.43985
I (368) metrics: persist v.p.altitude = 142.3m
I (375) notify: Initialising NOTIFICATIONS (1820)
I (389) notify: Registered notification type alert
I (394) notify: Registered notification type data
I (400) notify: Registered notification type stream
I (405) notify: Expanding DUKTAPE javascript engine
I (411) location: Initialising LOCATIONS (1900)
I (419) location: Expanding DUKTAPE javascript engine
I (422) vehicle: Initialising VEHICLE Factory (2000)
I (433) tls: Initialising TLS (3000)
I (434) pcp: Initialising POWER (4000)
I (436) max7317: Initialising MAX7317 EGPIO (4200)
I (443) sdcard: Initialising SD CARD (4400)
I (447) ota: Initialising OTA (4400)
I (453) canformat: Initialising CAN Format Factory (4500)
I (457) canformat-cs11: Registering CAN Format: CS11 (4505)
I (463) canformat-crtd: Registering CAN Format: CRTD (4505)
I (469) canformat-gvret: Registering CAN Format: GVRET (4505)
I (476) canformat-lawicel: Registering CAN Format: LAWICEL (4505)
I (489) canformat-pcap: Registering CAN Format: PCAP (4505)
I (495) canformat-raw: Registering CAN Format: RAW (4505)
I (501) can: Initialising CAN (4510)
I (513) dbc-app: Initialising DBC (4520)
I (516) canlog: Initialising CAN logging (4550)
I (517) canlog-monitor: Initialising CAN logging to MONITOR (4560)
I (523) canlog-tcpclient: Initialising CAN logging as TCP client (4560)
I (533) canlog-tcpserver: Initialising CAN logging as TCP server (4560)
I (540) canlog-udpclient: Initialising CAN logging as UDP client (4560)
I (546) canlog-udpserver: Initialising CAN logging as UDP server (4560)
I (555) canlog-vfs: Initialising CAN logging to VFS (4560)
I (559) canplay: Initialising CAN play framework (4570)
I (564) canplay-vfs: Initialising CAN playing from VFS (4580)
I (571) cellular: Initialising CELLULAR (4600)
I (578) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601)
I (590) SIM5360: Registering SIM5360 modem driver (4650)
I (596) SIM7000: Registering SIM7000 modem driver (4650)
I (602) SIM7600: Registering SIM7600 modem driver (4650)
I (608) SIM7670: Registering Simcom A7670E modem driver (4660)
I (614) tpms: Initialising TPMS (4700)
I (620) test: Initialising TEST (5000)
I (625) module: Initialising MODULE (5100)
I (630) vfs: Initialising VFS (5200)
I (634) ovms-server: Initialising OVMS Server (6000)
I (638) ovms-server-v2: Initialising OVMS V2 Server (6100)
I (645) ovms-server-v3: Initialising OVMS V3 Server (6200)
I (651) vehicle-poll: Initialising Poller (7000)
I (659) obd2ecu: Initialising OBD2ECU (7000)
I (662) canopen: Initialising CANopen (7000)
I (670) pluginstore: Initialising PLUGINS (7100)
I (673) esp32wifi: Initialising ESP32WIFI (8000)
I (681) webserver: Initialising WEBSERVER (8200)
I (689) ssh: Initialising SSH (8300)
I (691) powermgmt: Initialising POWERMGMT (8500)
I (697) re: Initialising RE Tools (8800)
I (703) pushover: Initialising Pushover client (8800)
I (708) netmanager: Initialising NETMANAGER (8999)
I (715) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000)
I (718) v-zeva: Registering Vehicle: ZEVA (9000)
I (724) v-vweup: Registering Vehicle: VW e-Up (9000)
I (729) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000)
I (737) v-track: Registering Vehicle: TRACK (9000)
I (742) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000)
I (749) v-thinkcity: Registering Vehicle: THINK CITY (9000)
I (755) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000)
I (762) v-teslamodels: Registering Vehicle: Tesla Model S (9000)
I (769) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000)
I (781) v-smarted: Registering Vehicle: SMART ED (9000)
I (787) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000)
I (795) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000)
I (801) v-twizy: Registering Vehicle: Renault Twizy (9000)
I (807) v-obdii: Registering Vehicle: OBDII (9000)
I (813) v-none: Registering Vehicle: NONE (9000)
I (818) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000)
I (834) v-minise: Registering Vehicle: Mini Cooper SE (9000)
I (840) v-mgev4: Registering Vehicle: MG4 (9000)
I (851) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000)
I (857) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000)
I (863) v-mgev: Registering Vehicle: MG ZS EV (2023-)
I (869) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000)
I (875) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000)
I (882) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000)
I (888) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000)
I (894) v-maple60s: Registering Vehicle: Maple 60S (9000)
I (907) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000)
I (921) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000)
I (928) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000)
I (935) v-fiat500e: Registering Vehicle: FIAT 500e (9000)
I (953) v-dbc: Registering Vehicle: DBC based vehicle (9000)
I (959) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000)
I (967) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000)
I (975) v-atto3: Registering Vehicle: BYD Atto3 (9000)
I (980) v-boltev: Registering Vehicle: Bolt EV (9000)
I (986) v-bmwi3: Registering Vehicle: BMW i3 (9000)
I (992) version: Initialising Versioning (9900)
I (1000) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
I (30) ovms-duktape: Duktape: Scripting task is running
I (1072) ovms_main: Executing on CPU core 0
I (1082) ovms_main: Mounting CONFIG...
I (1192) ovms_main: Configure logging...
W (1202) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount
I (1202) ovms_main: Registering default configs...
I (1202) ovms_main: Starting HOUSEKEEPING...
I (1212) housekeeping: Initialising HOUSEKEEPING Framework...
I (1212) tls: Built trusted CA cache (5 entries, 8101 bytes)
D (1682) events: Signal(housekeeping.init)
I (1682) housekeeping: Executing on CPU core 1
I (1682) housekeeping: reset_reason: cpu0=12, cpu1=12
I (1682) housekeeping: Starting PERIPHERALS...
I (1692) peripherals: Initialising OVMS Peripherals...
I (1692) peripherals: TCP/IP Adaptor
I (1702) peripherals: ESP32 system
I (1702) peripherals: SPI bus
I (1712) peripherals: MAX7317 I/O Expander
I (1712) peripherals: ESP32 CAN
I (1722) peripherals: ESP32 WIFI
I (1722) peripherals: ESP32 ADC
I (1722) peripherals: MCP2515 CAN 1/2
I (1732) mcp2515: can2: SetPowerMode off
I (1812) peripherals: MCP2515 CAN 2/2
I (1812) mcp2515: can3: SetPowerMode off
I (1892) peripherals: SD CARD
I (1892) peripherals: CELLULAR MODEM
I (1892) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1902) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
V (1912) cellular: Starting modem task
I (1912) uart: queue free spaces: 50
I (1912) ext12v: Powering off external 12V devices
I (1922) housekeeping: Auto init max7317 (free: 160572 bytes)
I (1932) housekeeping: Auto init ext12v (free: 160572 bytes)
I (1932) housekeeping: Auto init dbc (free: 160572 bytes)
I (1942) housekeeping: Auto init wifi (free: 160572 bytes)
I (1962) wifi:wifi driver task: 3ffd9afc, prio:23, stack:3584, core=0
I (1962) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (1972) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (1992) wifi:wifi firmware version: 30f9e79
I (2002) wifi:config NVS flash: enabled
I (2002) wifi:config nano formating: disabled
I (2002) wifi:Init data frame dynamic rx buffer num: 16
I (2002) wifi:Init management frame dynamic rx buffer num: 16
I (2012) wifi:Init management short buffer num: 32
I (2012) wifi:Init dynamic tx buffer num: 16
I (2012) wifi:Init static rx buffer size: 2212
I (2022) wifi:Init static rx buffer num: 16
I (2022) wifi:Init dynamic rx buffer num: 16
I (2802) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
I (2802) wifi:mode : sta (30:ae:a4:43:87:ec) + softAP (30:ae:a4:43:87:ed)
I (2802) wifi:Total power save buffer number: 8
I (2812) wifi:Init max length of beacon: 752/752
I (2822) housekeeping: Auto init modem (free: 115148 bytes)
I (2822) housekeeping: Auto init Pollers (free: 114728 bytes)
I (2822) cellular: Set modem driver to 'auto'
I (2832) housekeeping: Auto init vehicle (free: 114728 bytes)
I (2832) cellular: State: Enter PowerOffOn state
I (2842) v-twizy: Renault Twizy vehicle module
I (2842) cellular-modem-auto: Power Cycle
I (2852) v-twizy: battmon subsystem init
I (2852) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
I (2862) v-twizy: pwrmon subsystem init
I (2872) v-twizy: charge subsystem init
I (2882) canopen: Worker started on can1
I (2882) v-twizy: sevcon subsystem init
I (2892) v-twizy: obd subsystem init
I (2892) housekeeping: Auto init obd2ecu (free: 81464 bytes)
I (2902) housekeeping: Auto init server v2 (free: 81464 bytes)
I (2902) ovms-server-v2: OVMS Server V2 registered metric modifier is #2
I (2912) ovms-server-v2: Status: Server has been started
I (2912) ovms-server-v2: OVMS Server v2 running
I (2922) housekeeping: Auto init server v3 (free: 80912 bytes)
I (2922) housekeeping: Auto init javascript (free: 80912 bytes)
I (2932) housekeeping: Auto init done (free: 80872 bytes)
I (2942) housekeeping: Starting USB console...
I (2942) uart: queue free spaces: 100
D (2952) events: Signal(egpio.output.1.low)
D (2962) events: Signal(system.event)
D (2962) events: Signal(system.wifi.sta.start)
D (2972) events: Signal(system.event)
D (2972) events: Signal(system.wifi.ap.start)
I (2972) netmanager: WIFI access point is up
D (2982) events: Signal(power.cellular.on)
D (2982) events: Signal(system.modem.stop)
D (2992) events: Signal(egpio.output.0.high)
D (2992) events: Signal(power.can1.on)
D (2992) events: Signal(egpio.output.2.low)
D (3002) events: Signal(canopen.worker.start)
D (3002) events: Signal(vehicle.type.set)
D (3012) events: Signal(server.v2.waitnetwork)
D (3012) events: Signal(system.start)
I (3012) ovms-mdns: Starting MDNS
D (3022) netmanager: MongooseTask starting
Firmware: 3.3.004-429-g629e5b8b/factory/edge
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
D (3042) events: Signal(network.interface.change)
D (3052) events: Signal(network.mgr.init)
I (3072) ssh: Launching SSH Server
OVMS> I (3202) ovms-duktape: Duktape: Initialising module system
D (3222) ovms-duktape: Duktape: Pre-Registered function assert
D (3222) ovms-duktape: Duktape: Pre-Registered function meminfo
D (3222) ovms-duktape: Duktape: Pre-Registered function print
D (3232) ovms-duktape: Duktape: Pre-Registered function write
D (3232) ovms-duktape: Duktape: Pre-Registered object HTTP
D (3232) ovms-duktape: Duktape: Pre-Registered object HTTP function Request
D (3232) ovms-duktape: Duktape: Pre-Registered object HTTP function request
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsCommand
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Delete
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Get
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function GetValues
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params
D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsEvents
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsLocation
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Age
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsFloat
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsJSON
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function HasValue
D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsFresh
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsStale
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsNotify
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsNotify function Raise
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetPaused
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetTraceStatus
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetUserPaused
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Pause
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Resume
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Trace
D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStarted
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStatus
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Reset
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Start
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Stop
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ClimateControl
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Homelink
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Lock
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ObdRequest
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode
D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer
D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge
D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown
D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge
D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown
D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Type
D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unlock
D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unvalet
D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Valet
D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup
D (3282) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Disable
D (3282) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Enable
D (3282) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Status
D (3282) ovms-duktape: Duktape: Pre-Registered object VFS
D (3282) ovms-duktape: Duktape: Pre-Registered object VFS function Load
D (3282) ovms-duktape: Duktape: Pre-Registered object VFS function Save
D (3282) ovms-duktape: Duktape: Pre-Registered module JSON
D (3292) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js'
D (3292) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes)
D (3292) ovms-duktape: Duktape: module load: int/JSON.js
D (3372) ovms-duktape: Duktape: Pre-Registered module PubSub
D (3392) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js'
D (3392) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes)
D (3392) ovms-duktape: Duktape: module load: int/PubSub.js
I (3612) ovms-duktape: Duktape: Executing ovmsmain.js
D (3622) ovms-duktape: Duktape: module load: ovmsmain.js
D (3632) ovms-duktape: Duktape: module unload: ovmsmain.js
D (3682) events: Signal(vehicle.charge.mode)
OVMS> D (4682) events: Signal(vehicle.aux.12v.normal)
OVMS> D (5372) events: Signal(egpio.output.0.low)
D (5422) events: Signal(system.event)
D (5422) events: Signal(system.wifi.scan.done)
I (5552) wifi:ap channel adjust o:1,0 n:11,0
I (5552) wifi:new:<11,0>, old:<1,0>, ap:<11,0>, sta:<11,0>, prof:1
OVMS> I (6232) wifi:state: init -> auth (b0)
I (6252) wifi:state: auth -> assoc (0)
I (6262) wifi:state: assoc -> run (10)
I (6282) wifi:connected with LeonsLair, aid = 2, channel 11, BW20, bssid = d4:24:dd:88:1e:85
I (6282) wifi:security type: 3, phy: bgn, rssi: -62
I (6282) wifi:pm start, type: 1
D (6282) events: Signal(system.event)
D (6292) events: Signal(system.wifi.sta.connected)
D (6292) netmanager: send cmd 3 from 0x0
D (6292) netmanager: done cmd 3 from 0x0
D (6292) netmanager: MongooseTask: got cmd 3 from 0x0
I (6302) event: sta ip: 192.168.178.33, mask: 255.255.255.0, gw: 192.168.178.1
D (6302) events: Signal(system.event)
D (6312) events: Signal(network.interface.up)
D (6312) events: Signal(system.wifi.sta.gotip)
I (6312) netmanager: WIFI client got IP
D (6312) netmanager: Saved DNS#0 192.168.178.1
D (6312) netmanager: Saved DNS#1 0.0.0.0
D (6312) netmanager: Saved DNS#2 0.0.0.0
D (6312) netmanager: send cmd 3 from 0x0
D (6312) netmanager: done cmd 3 from 0x0
D (6302) netmanager: MongooseTask: done cmd 3 from 0x0
D (6322) netmanager: MongooseTask: got cmd 3 from 0x0
D (6352) netmanager: MongooseTask: done cmd 3 from 0x0
I (6372) wifi:AP's beacon interval = 102400 us, DTIM period = 1
OVMS> D (8682) events: Signal(network.wifi.sta.good)
I (8682) netmanager: WIFI client has good signal quality (-83.0 dBm); connect
I (8682) netmanager: Interface priority is st1 (192.168.178.33/255.255.255.0 gateway 192.168.178.1)
I (8682) netmanager: Set DNS#1 0.0.0.0
I (8682) netmanager: Set DNS#2 0.0.0.0
I (8682) netmanager: WIFI client up (with MODEM down): starting network with WIFI client
D (8692) events: Signal(network.wifi.up)
D (8692) events: Signal(network.up)
I (8692) ovms-server-v2: Status: Network is up, so attempt network connection
D (8692) events: Signal(network.interface.change)
D (8702) events: Signal(server.v2.connectwait)
OVMS> D (10372) events: Signal(egpio.output.0.high)
D (10572) events: Signal(egpio.output.0.low)
I (10682) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1
I (10682) ovms-server-v2: Status: Connecting...
D (10712) events: Signal(server.v2.connecting)
OVMS> D (10972) cellular: State timeout PowerOffOn => PoweringOn
I (10972) cellular: State: Enter PoweringOn state
I (10972) cellular-modem-auto: Power Cycle
D (10972) events: Signal(system.modem.poweringon)
I (10972) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
D (10972) events: Signal(egpio.output.0.high)
OVMS> D (13472) events: Signal(egpio.output.0.low)
OVMS> I (14252) ovms-server-v2: Connection successful
I (14252) ovms-server-v2: Status: Logging in...
D (14252) events: Signal(server.v2.authenticating)
I (14262) ovms-server-v2: Sending server login: MP-C 0 Yu8DEPRjRT8QKnIu9282gr Kfkv9DBfw7ITt4ffMXbZmg== TEST1
OVMS> I (15982) ovms-server-v2: Got server response: MP-S 0 yjqUlH9NVyAICzYzodUz+t fNsMgt8ZUaouC+Em3X/FNg==
I (15982) ovms-server-v2: Server token is yjqUlH9NVyAICzYzodUz+t and digest is fNsMgt8ZUaouC+Em3X/FNg==
I (15992) ovms-server-v2: Status: Server authentication ok. Now priming crypto.
I (15992) ovms-server-v2: Shared secret key is yjqUlH9NVyAICzYzodUz+tYu8DEPRjRT8QKnIu9282gr (44 bytes)
I (15992) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
D (15992) events: Signal(server.v2.connected)
I (16022) ovms-server-v2: Incoming Msg: MP-0 Z0
OVMS> I (16682) ovms-server-v2: Send MP-0 S0,K,0,0.00,,standard,50,50,15,0,0,0,0,0,0,0,0,0,92.98,0,0,56,21,-1,0,0,0,0,0,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.0,0.0,0.0,0.0,-1
I (16692) ovms-server-v2: Send MP-0 D0,16,5,0,0,0,0,0,0,866,0,0,1,1,12.31,0,12.6,0,0,0,0
I (16692) ovms-server-v2: Send MP-0 L51.404099,7.439854,0,142.3,0,0,0,0,2050202,0,0.000,0.000,0,0,,0,0,0,0
I (16692) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1
I (16692) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1
I (16692) ovms-server-v2: Send MP-0 F3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),,25,0,RT,LeonsLair,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/1,
OVMS> D (18472) events: Signal(egpio.output.0.high)
D (18672) events: Signal(egpio.output.0.low)
I (18772) cellular: State: Enter Identify state
D (18872) cellular: tx-cmd: AT+CGMM
I (18882) cellular: Identified cellular modem: SIM5360/SIMCOM SIM5360 (include US and EU variants)
D (18882) cellular: Remove old 'auto' modem driver
I (18882) cellular: Set modem driver to 'SIM5360'
I (18882) cellular: State: Enter PoweredOn state
D (18882) events: Signal(system.modem.installed)
D (18892) events: Signal(system.modem.poweredon)
D (18992) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (19762) cellular: mux-rx-line #0 (12/32): +CPIN: READY
D (19772) cellular: mux-rx-line #0 (12/16): OPL UPDATING
D (19772) cellular: mux-rx-line #0 (12/0): PNN UPDATING
OVMS> D (20482) cellular: mux-rx-line #0 (8/0): SMS DONE
OVMS> D (21052) cellular: mux-rx-line #0 (10/11): CALL READY
D (21062) cellular: mux-rx-line #0 (7/0): PB DONE
OVMS> I (24682) ovms-server-v2: Send MP-0 h1,0,RT-GPS-Log,0,86400,51.404099,7.439854,142,0,0,0,0,-61,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (24802) ovms-server-v2: Incoming Msg: MP-0 h1
OVMS> D (26682) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
D (26702) cellular: mux-rx-line #0 (106/0): AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
D (26742) cellular: mux-rx-line #0 (12/20): +CPIN: READY
D (26742) cellular: mux-rx-line #0 (10/6): +CSQ: 22,0
D (26742) cellular: Signal Quality is: 22 (-69 dBm)
D (26742) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (27362) cellular: mux-rx-line #0 (26/0): +CTZV: 8,25/03/30,11:46:20
OVMS> D (28682) cellular: tx-cmd: AT+CGMR;+ICCID
D (28692) cellular: mux-rx-line #0 (23/37): +CGMR: 35316B11SIM5360E
D (28692) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389
D (28692) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (32222) cellular: mux-rx-line #0 (11/0): +CSQ: 22,99
OVMS> D (32682) cellular: tx-cmd: AT+CMUXSRVPORT=3,1
D (32692) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (33682) cellular: tx-cmd: AT+CMUXSRVPORT=2,1
D (33692) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (34682) cellular: tx-cmd: AT+CMUXSRVPORT=1,1
D (34692) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (35682) cellular: tx-cmd: AT+CMUXSRVPORT=0,5
D (35692) cellular: mux-rx-line #0 (2/0): OK
OVMS> D (36682) cellular: tx-cmd: AT+CMUX=0;+CATR=6
D (36692) cellular: mux-rx-line #0 (2/0): OK
I (36692) cellular: State: Enter MuxStart state
V (36692) cellular: Starting MUX
D (36692) events: Signal(system.modem.muxstart)
I (36692) gsm-mux: Start MUX
I (36702) gsm-mux: Channel #0 is open
I (36702) gsm-mux: Channel #1 is open
I (36712) gsm-mux: Channel #2 is open
I (36712) gsm-mux: Channel #3 is open
I (36722) gsm-mux: Channel #4 is open
OVMS> D (37682) cellular: State transition MuxStart => NetWait
I (37682) cellular: State: Enter NetWait state
V (37682) cellular: Starting NMEA
I (37682) gsm-nmea: Startup
D (37682) cellular: mux-tx #4: AT+CGPSNMEA=66;+CGPS=1,1
D (37682) events: Signal(system.modem.netwait)
D (37692) events: Signal(system.modem.gpsstart)
D (37772) cellular: mux-rx-line #4 (2/0): OK
OVMS> I (45692) ovms-server-v2: Send MP-0 h2,0,RT-BAT-P,1,86400,1,1,0,10000,0,0,1000,0,-40,200,-40,0,0,0,0,0,0,0,0
I (45692) ovms-server-v2: Send MP-0 h3,0,RT-BAT-C,1,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45692) ovms-server-v2: Send MP-0 h4,0,RT-BAT-C,2,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45692) ovms-server-v2: Send MP-0 h5,0,RT-BAT-C,3,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45702) ovms-server-v2: Send MP-0 h6,0,RT-BAT-C,4,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (45832) ovms-server-v2: Incoming Msg: MP-0 h2
I (45832) ovms-server-v2: Incoming Msg: MP-0 h3
I (45832) ovms-server-v2: Incoming Msg: MP-0 h4
I (45842) ovms-server-v2: Incoming Msg: MP-0 h5
I (45852) ovms-server-v2: Incoming Msg: MP-0 h6
OVMS> I (46682) ovms-server-v2: Send MP-0 h7,-1,RT-BAT-C,5,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46682) ovms-server-v2: Send MP-0 h8,-1,RT-BAT-C,6,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46682) ovms-server-v2: Send MP-0 h9,-1,RT-BAT-C,7,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46682) ovms-server-v2: Send MP-0 h10,-1,RT-BAT-C,8,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46692) ovms-server-v2: Send MP-0 h11,-1,RT-BAT-C,9,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (46882) ovms-server-v2: Incoming Msg: MP-0 h7
I (46882) ovms-server-v2: Incoming Msg: MP-0 h8
I (46882) ovms-server-v2: Incoming Msg: MP-0 h9
I (46892) ovms-server-v2: Incoming Msg: MP-0 h10
I (46892) ovms-server-v2: Incoming Msg: MP-0 h11
OVMS> D (47682) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
I (47682) ovms-server-v2: Send MP-0 h12,-2,RT-BAT-C,10,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47682) ovms-server-v2: Send MP-0 h13,-1,RT-BAT-C,11,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47682) ovms-server-v2: Send MP-0 h14,-1,RT-BAT-C,12,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47692) ovms-server-v2: Send MP-0 h15,-1,RT-BAT-C,13,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
I (47692) ovms-server-v2: Send MP-0 h16,-2,RT-BAT-C,14,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0
D (47712) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
I (47712) cellular: Network Registration status: RegisteredRoaming
D (47712) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:46:40+08"
D (47712) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99
D (47712) cellular: mux-rx-line #3 (2/0): OK
I (47932) ovms-server-v2: Incoming Msg: MP-0 h12
I (47932) ovms-server-v2: Incoming Msg: MP-0 h13
I (47932) ovms-server-v2: Incoming Msg: MP-0 h14
I (47942) ovms-server-v2: Incoming Msg: MP-0 h15
I (47942) ovms-server-v2: Incoming Msg: MP-0 h16
OVMS> D (48682) cellular: mux-tx #3: AT+CPSI?
D (48682) cellular: State transition NetWait => NetStart
I (48682) cellular: State: Enter NetStart state
D (48682) events: Signal(system.modem.netstart)
D (48692) cellular: mux-rx-line #3 (59/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-72,0,35-35
I (48692) cellular: Network Mode: GSM,Online
D (48692) cellular: mux-rx-line #3 (2/0): OK
D (48892) events: Signal(gps.lock.acquired)
D (48902) events: Signal(system.modem.gotgps)
OVMS> D (49682) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
I (49692) ovms-server-v2: Send MP-0 h17,0,RT-GPS-Log,0,86400,51.403904,7.439991,155,0,0,1,0,-60,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (49742) ovms-server-v2: Incoming Msg: MP-0 h17
D (49742) cellular: mux-rx-line #2 (14/0): CONNECT 115200
I (49742) cellular: PPP Connection is ready to start
OVMS> D (50682) cellular: State transition NetStart => NetMode
I (50682) cellular: State: Enter NetMode state
V (50682) cellular: Launching PPP
V (50682) cellular: Starting PPP
I (50682) gsm-ppp: Initialising...
D (50692) events: Signal(system.modem.netmode)
OVMS> I (51512) gsm-ppp: StatusCallBack: None
I (51512) gsm-ppp: status_cb: Connected
I (51512) gsm-ppp: our_ipaddr = 10.170.195.13
I (51512) gsm-ppp: his_ipaddr = 10.64.64.64
I (51522) gsm-ppp: netmask = 255.255.255.255
I (51522) gsm-ppp: DNS#0 = 8.8.8.8
I (51522) gsm-ppp: DNS#1 = 8.8.4.4
I (51522) gsm-ppp: our6_ipaddr = ::
D (51522) events: Signal(network.interface.up)
D (51522) events: Signal(system.modem.gotip)
D (51522) netmanager: Saved DNS#0 8.8.8.8
D (51522) netmanager: Saved DNS#1 8.8.4.4
D (51522) netmanager: Saved DNS#2 0.0.0.0
I (51522) netmanager: Set DNS#1 0.0.0.0
I (51522) netmanager: Set DNS#2 0.0.0.0
I (51522) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority
D (51532) events: Signal(network.modem.up)
D (51532) events: Signal(network.interface.change)
OVMS> D (53232) cellular: mux-rx-line #3 (10/0): +CSQ: 22,0
OVMS> D (56232) cellular: mux-rx-line #3 (11/0): +CSQ: 22,99
OVMS> D (62762) ovms-duktape: Duktape: Compacting DukTape memory done in 70 ms
OVMS> D (80682) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
D (80702) cellular: mux-rx-line #3 (10/54): +CREG: 1,5
D (80702) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:47:13+08"
D (80702) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99
D (80702) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (81682) cellular: mux-tx #3: AT+CPSI?
D (81692) cellular: mux-rx-line #3 (59/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-72,0,35-35
D (81692) cellular: mux-rx-line #3 (2/0): OK
OVMS> D (82682) cellular: mux-tx #3: AT+COPS?
D (82692) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0
I (82692) cellular: Network Provider is: vodafone.de Hologram
D (82692) cellular: mux-rx-line #3 (2/0): OK
OVMS> I (84682) ovms-server-v2: Send MP-0 h18,0,RT-GPS-Log,0,86400,51.403942,7.439952,153,0,0,1,0,-60,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (84732) ovms-server-v2: Incoming Msg: MP-0 h18
OVMS>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250330/2dba53aa/attachment-0001.sig>
