[Ovmsdev] Firmware release 3.3.005 / CAN SAE timing
Sat Jul 26 01:06:32 HKT 2025
3.3.005-1 is now in "main" on my server.
Am 18.07.25 um 09:15 schrieb Michael Balzer via OvmsDev:
> Mark, everyone,
> I've just tagged the 3.3.005 release, created the maintenance/backport
> branch "release-3.3.005" and published the build as "edge", "pre" and
> "eap" on my server.
> I'll release this as "main" in a week, unless eap/pre users report issues.
> Announcement:
> * German: https://dexters-web.de/firmware-release-3.3.005-text_115.htm
> * English:
> https://dexters-web.de/firmware-release-3.3.005-text_115.en.htm
> Mark, I suggest following up accordingly on your server.
> Am 17.07.25 um 02:06 schrieb Mark Webb-Johnson:
>> Michael,
>> No objection from me. I think we’re 1,264 commits past 3.3.003.
>> Let me know what you need from me.
>>> On 13 Jul 2025, at 4:31 PM, Michael Balzer via OvmsDev
>>> <ovmsdev at lists.openvehicles.com> wrote:
>>> Signed PGP part
>>> Mark, everyone,
>>> as we don't make any progress on the CAN issues (affecting only few
>>> users), and "main" users struggle with bugs that have long been
>>> fixed in "edge", I'd say we release 3.3.005 now.
>>> Am 12.04.25 um 09:37 schrieb Michael Balzer via OvmsDev:
>>>> Chris,
>>>> as you changed two parameters at once, you cannot currently tell
>>>> which helped.
>>>> I suggest keeping the improved 12V level and returning to the old
>>>> CAN timing to see if that makes a difference.
>>>> Reviewing your report & findings, I'd say your issue was caused by
>>>> the 12V dips.
>>>> Regards,
>>>> Michael
>>>> Am 11.04.25 um 20:01 schrieb Chris Box:
>>>>> On 2025-04-06 11:03, Michael Balzer via OvmsDev wrote:
>>>>>> Did the changed CAN timing to better follow the SAE
>>>>>> recommendations actually have any benefits?
>>>>> I haven't experienced any Leaf errors using the SAE timing over
>>>>> the past month. As a result my intention is to continue with this
>>>>> new timing, although I can't prove the timing is the reason for
>>>>> the lack of issues. I also improved 12 volt levels.
>>>>> If you're looking for hard data, please advise what I should do to
>>>>> gather that data. It's not particularly clear to me, because I
>>>>> understand that "normal" can bus statistics for the Leaf include
>>>>> some expected errors.
>>>>> Thanks
>>>>> Chris
>>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>>> Fon 02330 9104094 * Handy 0176 20698926
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250725/0d775e20/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250725/0d775e20/attachment.sig>
