[Ovmsdev] Firmware release 3.3.005 / CAN SAE timing
Fri Jul 18 15:15:41 HKT 2025
Mark, everyone,
I've just tagged the 3.3.005 release, created the maintenance/backport
branch "release-3.3.005" and published the build as "edge", "pre" and
"eap" on my server.
I'll release this as "main" in a week, unless eap/pre users report issues.
Announcement:
  * German: https://dexters-web.de/firmware-release-3.3.005-text_115.htm
  * English: https://dexters-web.de/firmware-release-3.3.005-text_115.en.htm
Mark, I suggest following up accordingly on your server.
Am 17.07.25 um 02:06 schrieb Mark Webb-Johnson:
> Michael,
> No objection from me. I think we’re 1,264 commits past 3.3.003.
> Let me know what you need from me.
>> On 13 Jul 2025, at 4:31 PM, Michael Balzer via OvmsDev
>> <ovmsdev at lists.openvehicles.com> wrote:
>> Signed PGP part
>> Mark, everyone,
>> as we don't make any progress on the CAN issues (affecting only few
>> users), and "main" users struggle with bugs that have long been fixed
>> in "edge", I'd say we release 3.3.005 now.
>> Am 12.04.25 um 09:37 schrieb Michael Balzer via OvmsDev:
>>> Chris,
>>> as you changed two parameters at once, you cannot currently tell
>>> which helped.
>>> I suggest keeping the improved 12V level and returning to the old
>>> CAN timing to see if that makes a difference.
>>> Reviewing your report & findings, I'd say your issue was caused by
>>> the 12V dips.
>>> Am 11.04.25 um 20:01 schrieb Chris Box:
>>>> On 2025-04-06 11:03, Michael Balzer via OvmsDev wrote:
>>>>> Did the changed CAN timing to better follow the SAE
>>>>> recommendations actually have any benefits?
>>>> I haven't experienced any Leaf errors using the SAE timing over the
>>>> past month. As a result my intention is to continue with this new
>>>> timing, although I can't prove the timing is the reason for the
>>>> lack of issues. I also improved 12 volt levels.
>>>> If you're looking for hard data, please advise what I should do to
>>>> gather that data. It's not particularly clear to me, because I
>>>> understand that "normal" can bus statistics for the Leaf include
>>>> some expected errors.
>>>> Thanks
>>>> Chris
>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250718/3f86ab4e/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250718/3f86ab4e/attachment.sig>
