[Ovmsdev] Firmware release 3.3.005 / CAN SAE timing
Thu Jul 17 08:06:53 HKT 2025
Michael,
No objection from me. I think we’re 1,264 commits past 3.3.003.
Let me know what you need from me.
> On 13 Jul 2025, at 4:31 PM, Michael Balzer via OvmsDev <ovmsdev at lists.openvehicles.com> wrote:
> Signed PGP part
> Mark, everyone,
> as we don't make any progress on the CAN issues (affecting only few users), and "main" users struggle with bugs that have long been fixed in "edge", I'd say we release 3.3.005 now.
> Am 12.04.25 um 09:37 schrieb Michael Balzer via OvmsDev:
>> Chris,
>> as you changed two parameters at once, you cannot currently tell which helped.
>> I suggest keeping the improved 12V level and returning to the old CAN timing to see if that makes a difference.
>> Reviewing your report & findings, I'd say your issue was caused by the 12V dips.
>> Am 11.04.25 um 20:01 schrieb Chris Box:
>>> On 2025-04-06 11:03, Michael Balzer via OvmsDev wrote:
>>>> Did the changed CAN timing to better follow the SAE recommendations actually have any benefits?
>>> I haven't experienced any Leaf errors using the SAE timing over the past month. As a result my intention is to continue with this new timing, although I can't prove the timing is the reason for the lack of issues. I also improved 12 volt levels.
>>> If you're looking for hard data, please advise what I should do to gather that data. It's not particularly clear to me, because I understand that "normal" can bus statistics for the Leaf include some expected errors.
>>> Thanks
>>> Chris
>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250717/6bad3141/attachment.htm>
