[Ovmsdev] Crashing on restart
Thu Jan 9 03:04:11 HKT 2025
I compiled and installed 3.3.004-331-g4a7b966d
The initial reboot after the update crashed (as expected). Now
rebooting works again.
Thanx!
Chris
Am Mittwoch, dem 08.01.2025 um 19:42 +0100 schrieb Tamás Kovács via
OvmsDev:
> Now i use after send to me, i restarted the modul many times and no
> problem.
> Michael Balzer via OvmsDev <ovmsdev at lists.openvehicles.com> ezt írta
> (időpont: 2025. jan. 8., Sze, 8:29):
> > Everyone,
> > I've just checked in my changes, so this is now included in the
> > edge build (3.3.004-331-g4a7b966d, already available on dexters-
> > web).
> > I had no issues with my modules, but depending on the vehicle &
> > configuration, we may need to raise the new default queue size
> > beyond 100.
> > Please test & report. If the queue is too small, the module will
> > crash with a "queue overflow" log entry.
> > Regards,
> > Michael
> > Am 06.01.25 um 20:49 schrieb Michael Balzer via OvmsDev:
> > > Tamás,
> > > I've got a test build that should fix your reboot issue, if my
> > > diagnosis was correct. Can you please test this firmware image?
> > > http://ovms.dexters-web.de/f/firmware/test/ovms3.bin
> > > The build works in my test & live module. The changes are not yet
> > > checked in, patch attached. This consists of a) delegating
> > > registry changes to the event task and b) invalidating callbacks
> > > in the list on deregistration before actually deleting them, so
> > > the list processing cannot run into deleted entries, when
> > > deregistration is done from within a callback execution.
> > > The changes need another mutex and a larger event queue. I had
> > > queue size 40 before, minimum now is 80, build uses 100 to be on
> > > the safe side. That means another 720 bytes of 8-bit RAM are used
> > > for the queue unfortunately, but that shouldn't be a problem yet.
> > > I also again needed to power off my module for the reboot, but
> > > with the new firmware, the reboot works. So chances are, this
> > > issue is now hit more often than before, probably because of more
> > > stuff going on in the shutdown.
> > > Regards,
> > > Michael
> > > Am 02.01.25 um 15:25 schrieb Michael Balzer via OvmsDev:
> > > > The log shows it actually crashes during the shutdown process -
> > > > - but @Michael, I'm pretty sure this is an old issue, turning
> > > > up now only by chance.
> > > > This looks like a race condition between event handler
> > > > invocation and deregistration:
> > > > Guru Meditation Error: Core  1 panic'ed (InstrFetchProhibited).
> > > > Exception was unhandled.
> > > > Backtrace: 0x41000000:0x3ffc8c30 0x401208ed:0x3ffc8c60
> > > > 0x401209d4:0x3ffc8cc0 0x40120a5d:0x3ffc8d00
> > > > → Crash at 0x41000000 (invalid address), called from:
> > > > 0x401208ed is in
> > > > OvmsEvents::HandleQueueSignalEvent(event_queue_t*)
> > > > (/home/balzer/esp/Open-Vehicle-Monitoring-System-
> > > > 3/vehicle/OVMS.V3/main/ovms_events.cpp:310).
> > > > 305           {
> > > > 306           for (EventCallbackList::iterator itc=el->begin();
> > > > itc!=el->end(); ++itc)
> > > > 307             {
> > > > 308             m_current_started = monotonictime;
> > > > 309             m_current_callback = *itc;
> > > > 310             m_current_callback->m_callback(m_current_event,
> > > > msg->body.signal.data);
> > > > 311             m_current_callback = NULL;
> > > > 312             }
> > > > 313           }
> > > > 314         }
> > > > From there it then enters a crash loop from the crash handler
> > > > somehow running into an illegal address when trying to access
> > > > the RTC boot_data object (?).
> > > > I think, when introducing the separate event handling task, we
> > > > missed adding a lock to make manipulations & accesses to the
> > > > event handler list atomic.
> > > > The log shows, the event queue grew significantly due to
> > > > duktape/scripts lagging during shutdown (as seen in the log),
> > > > so the task was quite busy.
> > > > So probably a `DeregisterEvent()` call from the shutdown
> > > > process came in, invalidating a callback entry just while the
> > > > event task was processing that callback list.
> > > > Solving this may need some additional thoughts & measures:
> > > > locking the whole event registry with handlers lagging like
> > > > this could lead to a deadlock… probably at least the Duktape
> > > > component needs to cleanly abort/reject all pending events
> > > > before/while deregistering.
> > > > Michael, if you'd like to have a look at this, go ahead.
> > > > Regards,
> > > > Michael
> > > > Am 01.01.25 um 11:47 schrieb Tamás Kovács via OvmsDev:
> > > > > Now i change the sd card to a smaller, and formatted to fat32
> > > > > (16Gb), but on reboot is crashing.
> > > > > Now connect a computer to the usb port, and create a log in
> > > > > verbose, attached to the email.
> > > > > Üdvözlettel:
> > > > > Kovács Tamás
> > > > > _______________________________________________
> > > > > OvmsDev mailing list
> > > > > OvmsDev at lists.openvehicles.com
> > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> > > > Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
> > > > Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250108/31d87203/attachment.htm>
