[Ovmsdev] Crashing on restart
Tamás Kovács kommykt at gmail.com
Thu Jan 9 02:42:44 HKT 2025
Now i use after send to me, i restarted the modul many times and no
problem.
Michael Balzer via OvmsDev <ovmsdev at lists.openvehicles.com> ezt írta
(időpont: 2025. jan. 8., Sze, 8:29):
> Everyone,
> I've just checked in my changes, so this is now included in the edge build
> (3.3.004-331-g4a7b966d, already available on dexters-web).
> I had no issues with my modules, but depending on the vehicle &
> configuration, we may need to raise the new default queue size beyond 100.
> Please test & report. If the queue is too small, the module will crash
> with a "queue overflow" log entry.
> Am 06.01.25 um 20:49 schrieb Michael Balzer via OvmsDev:
> Tamás,
> I've got a test build that should fix your reboot issue, if my diagnosis
> was correct. Can you please test this firmware image?
> http://ovms.dexters-web.de/f/firmware/test/ovms3.bin
> The build works in my test & live module. The changes are not yet checked
> in, patch attached. This consists of a) delegating registry changes to the
> event task and b) invalidating callbacks in the list on deregistration
> before actually deleting them, so the list processing cannot run into
> deleted entries, when deregistration is done from within a callback
> execution.
> The changes need another mutex and a larger event queue. I had queue size
> 40 before, minimum now is 80, build uses 100 to be on the safe side. That
> means another 720 bytes of 8-bit RAM are used for the queue unfortunately,
> but that shouldn't be a problem yet.
> I also again needed to power off my module for the reboot, but with the
> new firmware, the reboot works. So chances are, this issue is now hit more
> often than before, probably because of more stuff going on in the shutdown.
> Am 02.01.25 um 15:25 schrieb Michael Balzer via OvmsDev:
> The log shows it actually crashes during the shutdown process -- but
> @Michael, I'm pretty sure this is an old issue, turning up now only by
> chance.
> This looks like a race condition between event handler invocation and
> deregistration:
> Guru Meditation Error: Core  1 panic'ed (InstrFetchProhibited). Exception
> was unhandled.
>> Backtrace: 0x41000000:0x3ffc8c30 0x401208ed:0x3ffc8c60
> 0x401209d4:0x3ffc8cc0 0x40120a5d:0x3ffc8d00
> → Crash at *0x41000000* (invalid address), called from:
> 0x401208ed is in OvmsEvents::HandleQueueSignalEvent(event_queue_t*)
> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:310).
> 305           {
> 306           for (EventCallbackList::iterator itc=el->begin();
> itc!=el->end(); ++itc)
> 307             {
> 308             m_current_started = monotonictime;
> 309             m_current_callback = *itc;
> *310             m_current_callback->m_callback(m_current_event,
> msg->body.signal.data);*
> 311             m_current_callback = NULL;
> 312             }
> 313           }
> 314         }
> From there it then enters a crash loop from the crash handler somehow
> running into an illegal address when trying to access the RTC boot_data
> object (?).
> I think, when introducing the separate event handling task, we missed
> adding a lock to make manipulations & accesses to the event handler list
> atomic.
> The log shows, the event queue grew significantly due to duktape/scripts
> lagging during shutdown (as seen in the log), so the task was quite busy.
> So probably a `DeregisterEvent()` call from the shutdown process came in,
> invalidating a callback entry just while the event task was processing that
> callback list.
> Solving this may need some additional thoughts & measures: locking the
> whole event registry with handlers lagging like this could lead to a
> deadlock… probably at least the Duktape component needs to cleanly
> abort/reject all pending events before/while deregistering.
> Michael, if you'd like to have a look at this, go ahead.
> Am 01.01.25 um 11:47 schrieb Tamás Kovács via OvmsDev:
> Now i change the sd card to a smaller, and formatted to fat32 (16Gb), but
> on reboot is crashing.
> Now connect a computer to the usb port, and create a log in verbose,
> attached to the email.
> Üdvözlettel:
> Kovács Tamás
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
> Fon 02330 9104094 * Handy 0176 20698926
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250108/a24aabc0/attachment-0001.htm>
