[Ovmsdev] Crashing on restart
Wed Jan 8 15:29:02 HKT 2025
Everyone,
I've just checked in my changes, so this is now included in the edge
build (3.3.004-331-g4a7b966d, already available on dexters-web).
I had no issues with my modules, but depending on the vehicle &
configuration, we may need to raise the new default queue size beyond 100.
Please test & report. If the queue is too small, the module will crash
with a "queue overflow" log entry.
Am 06.01.25 um 20:49 schrieb Michael Balzer via OvmsDev:
> Tamás,
> I've got a test build that should fix your reboot issue, if my
> diagnosis was correct. Can you please test this firmware image?
> http://ovms.dexters-web.de/f/firmware/test/ovms3.bin
> The build works in my test & live module. The changes are not yet
> checked in, patch attached. This consists of a) delegating registry
> changes to the event task and b) invalidating callbacks in the list on
> deregistration before actually deleting them, so the list processing
> cannot run into deleted entries, when deregistration is done from
> within a callback execution.
> The changes need another mutex and a larger event queue. I had queue
> size 40 before, minimum now is 80, build uses 100 to be on the safe
> side. That means another 720 bytes of 8-bit RAM are used for the queue
> unfortunately, but that shouldn't be a problem yet.
> I also again needed to power off my module for the reboot, but with
> the new firmware, the reboot works. So chances are, this issue is now
> hit more often than before, probably because of more stuff going on in
> the shutdown.
> Am 02.01.25 um 15:25 schrieb Michael Balzer via OvmsDev:
>> The log shows it actually crashes during the shutdown process -- but
>> @Michael, I'm pretty sure this is an old issue, turning up now only
>> by chance.
>> This looks like a race condition between event handler invocation and
>> deregistration:
>> Guru Meditation Error: Core  1 panic'ed
>> (InstrFetchProhibited).Exception was unhandled.
>>>> Backtrace: 0x41000000:0x3ffc8c30 0x401208ed:0x3ffc8c60
>> 0x401209d4:0x3ffc8cc0 0x40120a5d:0x3ffc8d00
>> → Crash at *0x41000000* (invalid address), called from:
>> 0x401208ed is in OvmsEvents::HandleQueueSignalEvent(event_queue_t*)
>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:310).
>> 305           {
>> 306           for (EventCallbackList::iterator itc=el->begin();
>> itc!=el->end(); ++itc)
>> 307             {
>> 308             m_current_started = monotonictime;
>> 309             m_current_callback = *itc;
>> *310 m_current_callback->m_callback(m_current_event,
>> msg->body.signal.data);*
>> 311             m_current_callback = NULL;
>> 312             }
>> 313           }
>> 314         }
>> From there it then enters a crash loop from the crash handler somehow
>> running into an illegal address when trying to access the RTC
>> boot_data object (?).
>> I think, when introducing the separate event handling task, we missed
>> adding a lock to make manipulations & accesses to the event handler
>> list atomic.
>> The log shows, the event queue grew significantly due to
>> duktape/scripts lagging during shutdown (as seen in the log), so the
>> task was quite busy.
>> So probably a `DeregisterEvent()` call from the shutdown process came
>> in, invalidating a callback entry just while the event task was
>> processing that callback list.
>> Solving this may need some additional thoughts & measures: locking
>> the whole event registry with handlers lagging like this could lead
>> to a deadlock… probably at least the Duktape component needs to
>> cleanly abort/reject all pending events before/while deregistering.
>> Michael, if you'd like to have a look at this, go ahead.
>> Am 01.01.25 um 11:47 schrieb Tamás Kovács via OvmsDev:
>>> Now i change the sd card to a smaller, and formatted to fat32
>>> (16Gb), but on reboot is crashing.
>>> Now connect a computer to the usb port, and create a log in verbose,
>>> attached to the email.
>>> Üdvözlettel:
>>> Kovács Tamás
>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250108/7766466c/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250108/7766466c/attachment.sig>
