[Ovmsdev] UI redesign in Android App - Needs beta testing
    Michael Geddes
    Thu Jan  9 15:33:28 HKT 2025
Looking good!
No crashes when charging
Shows as Ioniq 5
The widget starts the app correctly.
One thing I found was in the  Push Notifications/ command area:
Portrait mode:
Note the really big boxes. This is because the date column is squished to a
couple of pixels and it is displaying it wrapped downwards.
Looks fine in landscape mode
//.ichael
On Tue, 31 Dec 2024, 15:47 Michael Geddes, <frog at bunyip.wheelycreek.net>
wrote:
> Ah, thanks Chris.  Maybe you need to obey that setting when you click on
> the widget then :)
> On Tue, 31 Dec 2024 at 15:38, van der Meijden, Chris via OvmsDev <
> ovmsdev at lists.openvehicles.com> wrote:
>> The apo crashes regardless how I open it.
>> I'm running on LineageOS (based on Android 14) without Google. I don't
>> give the app GPS permissions.
>> @Michael: The old UI is still in the app. You can select it from the gear
>> symbol under "Settings".
>> Regards
>> Chris
>> Am 31. Dezember 2024 03:35:21 MEZ schrieb Michael Geddes via OvmsDev <
>> ovmsdev at lists.openvehicles.com>:
>>> Font size looks all fixed, thanks.
>>> For some reason when I click on the widget it opens the old look ovms
>>> still... is the old look still hidden somewhere?
>>> Also if I start charging my car (not through the app),  then whenever I
>>> switch to or open the app, the app crashes.
>>> I'm just doing ac charging from a wallbox.
>>> //.ichael.
>>> On Tue, 31 Dec 2024, 06:48 Developer From Jokela via OvmsDev, <
>>>> Hi.
>>>> New update is released at
>>>> https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest
>>>> Brief:
>>>> - Quick actions customisable
>>>> - Twizy UI fixes
>>>> - Font size related issues should be gone (hopefully ;D)
>>>> - DFJ
>>>> van der Meijden, Chris <chris at arachnon.de> kirjoitti 30.12.2024 kello
>>>> 13.12:
>>>> I like the design of the Mercedes Ne app. Don't need a one to one copy,
>>>> but it has a good mixture between info and links, I think.
>>>> Am 30. Dezember 2024 11:29:37 MEZ schrieb Developer From Jokela <
>>>> info at developerfromjokela.com>:
>>>>> Hi.
>>>>> What info would you like to be shown on main screen?
>>>>> On 30. Dec 2024, at 11.16, Chris van der Meijden <chris at arachnon.de>
>>>>> wrote:
>>>>> Also many thanks for the effort. The new design is not my cup of tea,
>>>>> but that is question of personal liking I suppose. For me the menu is far
>>>>> to present, whereas the information of the vehicle seems barely visible.
>>>>> For the e-Up the climate control throws an error. "Fehler bei der
>>>>> Kommandoausführung".
>>>>> Kind regards
>>>>> Chris
>>>>> Am Montag, dem 30.12.2024 um 15:20 +0800 schrieb Michael Geddes via
>>>>> OvmsDev:
>>>>> Thanks for the update. In general I like the new design.
>>>>> I've attached a screen  shot.  The list box items need to resize for
>>>>> larger fonts to stop them being all cut off.
>>>>> Also where does the "Unknown Vehicle model" come from?
>>>>> <1000012000.jpg>
>>>>> I have a slightly larger font setting:
>>>>> <1000012001.jpg>
>>>>> Also here:
>>>>> <1000012002.jpg>
>>>>> ..where the labels are overlapping due to the font size.
>>>>> And the ... here:
>>>>> <1000012003.jpg>
>>>>> I'm also getting a crash when opening the settings on the map. (App
>>>>> disappears. First time it prompted to clear cache which I did)
>>>>> Is there a new widget?  If I click on the widget I see the old UI.
>>>>> //.ichael
>>>>> On Mon, 30 Dec 2024, 07:28 Developer From Jokela via OvmsDev, <
>>>>> Hi Android users.
>>>>> I’ve recently redesigned UI for Android and it would need some
>>>>> testing.
>>>>> Here is the latest build available for UI redesign:
>>>>> Please report any issues, improvement suggestions, etc.
>>>>> Thank you!
>>>>> Br, DFJ
>>>>> OvmsDev mailing list
>>>>> <Screenshot_20241230-115518_Mercedes-Benz_1.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250109/3de2cbd3/attachment-0001.htm>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250109/3de2cbd3/attachment-0002.jpg>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250109/3de2cbd3/attachment-0003.jpg>
