[Ovmsdev] Another incident
Chris Box chris8086 at ee.eclipse1.net
Tue Feb 11 02:02:33 HKT 2025
On 2025-02-08 22:22, Dan Edwards wrote:
> If you google I-key system error , you'll find posts on issues with the
> BCM, which have been resolved with cleaning contacts on bcm (if there's
> been moisture issues), and others replacing 12v acc battery.
Thanks for the pointer. I drove the car for a year without OVMS and
didn't have an i-key error then.  Did you experience switching to
neutral while driving?
> Check your DTCs with leafspy, if it shows a bunch of DTCs including a
> B2604 BCM Shift PN diag, then likely low 12v, try a 24 hr charge or
> replace it.
I've now ordered a dongle to work with Leaf Spy.
On 2025-02-09 09:23, Michael Balzer via OvmsDev wrote:
> IOW, Chris, you should look for "dip" log entries well within a parking
> / driving / charging phase, when the 12V level should be more or less
> constant.
I've checked the logs for the 7th, and below is the one such dip I can
see. It occurs towards the end of the drive home.
2025-02-07 13:51:03.584 GMT D (468184) events: Signal(vehicle.awake)
2025-02-07 13:51:05.424 GMT D (470024) vehicle-poll: Pollers: Queue
SetState()
PollState(1)
2025-02-07 13:51:05.424 GMT D (470024) events: Signal(vehicle.on)
2025-02-07 13:51:06.464 GMT D (471064) events:
Signal(vehicle.charge.12v.start)
2025-02-07 13:51:08.384 GMT D (472984) events:
Signal(vehicle.aux.12v.blip)
2025-02-07 13:51:11.114 GMT D (475714) vehicle-poll: Pollers: Queue
SetState()
2025-02-07 13:51:11.124 GMT D (475724) vehicle-poll: Pollers:
PollState(2)
2025-02-07 13:51:11.124 GMT D (475724) events:
Signal(vehicle.gear.forward)
2025-02-07 13:51:16.394 GMT D (480994) events:
Signal(vehicle.aux.12v.charging.blip)
2025-02-07 13:51:56.394 GMT D (520994) events:
Signal(vehicle.aux.12v.charging)
2025-02-07 13:56:50.754 GMT D (815354) events:
Signal(vehicle.headlights.on)
2025-02-07 13:56:56.904 GMT D (821504) events:
Signal(vehicle.headlights.off)
2025-02-07 13:56:58.964 GMT D (823564) events:
2025-02-07 13:57:05.164 GMT D (829764) events:
2025-02-07 14:01:54.384 GMT D (1118984) events:
Signal(vehicle.aux.12v.charging.dip)
2025-02-07 14:02:00.384 GMT D (1124984) events:
Signal(vehicle.aux.12v.dip)
2025-02-07 14:02:30.384 GMT D (1154984) events:
Signal(vehicle.aux.12v.normal)
2025-02-07 14:03:36.394 GMT D (1220994) events:
Signal(vehicle.charge.12v.stop)
2025-02-07 14:03:46.394 GMT D (1230994) events:
2025-02-07 14:04:06.394 GMT D (1250994) events:
2025-02-07 14:04:09.954 GMT D (1254554) events:
Signal(vehicle.gear.reverse)
2025-02-07 14:04:16.394 GMT D (1260994) events:
2025-02-07 14:04:28.064 GMT D (1272664) events:
At 14:04:29 I connected to home wifi.
> You should also have a look at the general 12V level behaviour, e.g.
> using the 12V chart plugin or creating a chart from the MQTT metric.
I recorded the attached 12v profile on the 7th via MQTT. It was 12.2 at
13:17, and briefly 11.4 at 13:43. The 14:02 dip is not visible. My
battery was new in November 2023.
> When using V2/MQTT, consider raising the update interval to get a
> higher time resolution.
What interval is sufficiently frequent? This is what I have set.
   updatetime.charging: 60
   updatetime.connected: 300
   updatetime.idle: 600
   updatetime.keepalive: 1780
   updatetime.on: 120
> Btw, also consider shortening the file logging sync period, 30 seconds
> is rather high.
I've now set log flush to 1 second.
> On the 12V shutdown: even with 30 seconds log flushing, you would have
> seen the log entries for a shutdown condition, unless you configured
> the shutdown delay to 0 (default is 2 minutes).
I have no specific values set in vehicle.12v.*, so I'm using default
behaviour. Which I think disables auto-shutdown.
> That is, if the 12V level wasn't suddenly getting drastically low, i.e.
> too low within seconds to keep the ESP32 in operation. That could
> explain the freeze. Not sure how low that would need to have been. I'd
> check for another potential source of such a sudden voltage drop: a
> mechanical/electrical issue with the OBD connector or cable.
How would the V3.3 hardware react when power is completely removed (12V
goes to zero) and then restored (back to 12V)? I would hope it treats it
as a cold start, and begins to boot up. But I didn't see that in the
log. This also raises the question of capacitance to ride out brief
interruptions. It appears there is 470uF between 12V/5V and GND, if I'm
reading it right. I'm not sure what time period that could supply power
for.
> If for example there is a lose wire in the connection, that
> occasionally causes a short circuit, that would both explain the module
> freeze and the car fault.
It would. In the Leaf the OBD port is plastic mounted on plastic, and
not particularly robust. I haven't seen inside the cable.
Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250210/03228977/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250210/03228977/attachment-0001.png>
