[Ovmsdev] Another incident
    Chris Box
    chris8086 at ee.eclipse1.net
    Sat Feb 22 02:52:06 HKT 2025
>> Check your DTCs with leafspy, if it shows a bunch of DTCs including a
>> B2604 BCM Shift PN diag, then likely low 12v, try a 24 hr charge or
>> replace it.
I did indeed have B2604-00, along with nineteen others. Most of these
mention CAN errors, and it seems plausible that low 12v could be a
common cause.
Do you think this rules out a poor OVMS OBDII connection? I'm thinking
if I have high resistance in that connector, then OVMS will experience
low voltage but the rest of the car modules will have good voltage.
However I see codes that suggest communication errors between Nissan
modules:
C118C-01 ABS Brake: Malfunction is detected in VCM system. Control
module communication issue.
B2064-00 BCM Shift PN Diag CAN: Park-Neutral position switch signal
discrepancy
C1A70-01 BRAKE: Malfunction is detected in ABS actuator control unit
system
U1266-02 MULTI AV: Malfunction is detected between the AV control unit
and TCU
U0428-00 AVM: Invalid data received from steering angle sensor module
So I'm thinking perhaps the whole car briefly had low voltage.
To try to fix this, I cleaned the 12v battery terminals and performed a
long charge. After clearing the codes, I have only two codes that
reappear.
P317E-00 EV/HEV HV Battery System EVC-249 (perhaps caused by #1061 [1])
U1A06-15 TCU Communication incorrect calibration (probably because I've
removed its antenna)
Chris
Links:
[1]
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/1061
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250221/6ffcd343/attachment.htm>
