[Ovmsdev] Another incident
    Sun Feb  9 20:37:19 HKT 2025
Michael,
Am 09.02.25 um 11:34 schrieb Michael Geddes:
> A dip/blip is designed simply to say something is going on.  It's not
> saying that there's a condition  of any sort.. so it's not a false
> alarm.. as it's not really anything.
Thanks for the clarification.
I misinterpreted the dip/blip events as detecting unexpected/irregular
pulse deviations, like the one here at 17:00:
But it's really just about detecting any significant sudden change.
In case there are others misinterpreting these (are there?), we can add
some clarification to the manual.
> The low voltage level is different but not going on here.
> //.ichael
> On Sun, 9 Feb 2025, 17:24 Michael Balzer via OvmsDev,
> <ovmsdev at lists.openvehicles.com> wrote:
>     I'd consider the "dips" logged here as false positives.
>     Michael, correct me if I'm wrong: your new 12V monitor doesn't yet
>     implement a calmdown phase after charging. The voltage decline
>     after the DC converter switches off is logarithmic, so can easily
>     trigger the "dip" detection in the beginning. That fits these log
>     entries:
>     13:17:50.184 (vehicle.off)               assumption: DCDC off
>     13:17:51.144 (vehicle.aux.12v.charging.dip) [12vmon] 12v > 14.0 &&
>     < 0.09 under avg
>     13:17:53.144 (vehicle.aux.12v.dip)              [12vmon] 12v <=
>     14.0 && < 0.25 under avg
>     13:17:56.754 (vehicle.locked)
>     13:18:09.144 (vehicle.charge.12v.stop)          [leaf] 12v <= 12.8
>     13:18:33.174 (vehicle.aux.12v.normal)
>     13:19:59.174 (vehicle.asleep)                   [leaf] off since
>     120-130 seconds (awake stale)
>     Generally I think all aux.12v log entries shortly after a
>     vehicle.off should currently be ignored with regards to 12V
>     diagnosis. (@Michael: check `m_12v_ticker` for my calmdown
>     implementation for the reference voltage measurement)
>     The same may apply to the start of a 12V charging phase, depending
>     on the way the vehicle detects that state.
>     IOW, Chris, you should look for "dip" log entries well within a
>     parking / driving / charging phase, when the 12V level should be
>     more or less constant.
>     You should also have a look at the general 12V level behaviour,
>     e.g. using the 12V chart plugin or creating a chart from the MQTT
>     metric. The V2 Android App also has a 12V chart, if you use V2.
>     When using V2/MQTT, consider raising the update interval to get a
>     higher time resolution.
>     Btw, also consider shortening the file logging sync period, 30
>     seconds is rather high.
>     On the 12V shutdown: even with 30 seconds log flushing, you would
>     have seen the log entries for a shutdown condition, unless you
>     configured the shutdown delay to 0 (default is 2 minutes).
>     That is, if the 12V level wasn't suddenly getting drastically low,
>     i.e. too low within seconds to keep the ESP32 in operation. That
>     could explain the freeze. Not sure how low that would need to have
>     been.
>     I'd check for another potential source of such a sudden voltage
>     drop: a mechanical/electrical issue with the OBD connector or cable.
>     If for example there is a lose wire in the connection, that
>     occasionally causes a short circuit, that would both explain the
>     module freeze and the car fault.
>     Regards,
>     Michael
>     Am 09.02.25 um 04:45 schrieb Michael Geddes via OvmsDev:
>>     Just fyi a 'dip' is 12v voltage decreasing momentarily. A blip is
>>     the reverse.  Charging.dip is dipping while charging.
>>     There's a separate low voltage state for the 12v monitor.
>>     //.ichael
>>     On Sun, 9 Feb 2025, 06:35 Dan Edwards via OvmsDev,
>>         Hi Chris,
>>         Not sure if you’ve investigated the I-key system error , but
>>         thought I’d add my experience here.
>>         I have been receiving the same I-key system error in my 2012
>>         leaf, with all the same symptoms and resolution as yours.
>>         This leaf doesn’t have OVMS installed at the moment, so maybe
>>         your issue is not due to OVMS.
>>         If you google I-key system error , you’ll find posts on
>>         issues with the BCM, which have been resolved with cleaning
>>         contacts on bcm (if there’s been moisture issues), and others
>>         replacing 12v acc battery.
>>         I’m pretty sure I’ve narrowed it down to 12v battery issues
>>         in my case, after inspecting BCM behind glove box in RHD
>>         edition, finding no issue, recharging 12v, and removing any
>>         known 12v drain like OVMS or odb dongle, just waiting for a
>>         recurrence to confirm.
>>         Check your DTCs with leafspy, if it shows a bunch of DTCs
>>         including a B2604 BCM Shift PN diag, then likely low 12v, try
>>         a 24 hr charge or replace it.
>>         The OVMS log also shows 12v dip around the same time as your
>>         issue. This may explain OVMS shutdown as well if you’ve got
>>         it set to shut down due to  low 12v battery, although I
>>         though that might be more graceful.
>>         Cheers Dan
>>>         On 9 Feb 2025, at 8:35 am, Chris Box via OvmsDev
>>>         Hi,
>>>         It's happened again. Yesterday while driving the Leaf lost
>>>         drive mode, forcing pulling over. I couldn't reengage gear
>>>         until I had disconnected the 12v battery.
>>>         Looking at the evidence today, the incident can't be
>>>         explained by writing random bytes in CommandWakeup(), nor by
>>>         having the wrong timing. It actually suggests that OVMS
>>>         locked up ten minutes before the car was impacted.
>>>         Here's what happened.
>>>         13:15 to 13:17 I drove off from home, but forgot an item so
>>>         quickly returned back there.
>>>         The sd log records this activity just fine, and the last
>>>         entries before the suspected hang were these:
>>>         2025-02-07 13:19:59.174 GMT D (93751944) events:
>>>         Signal(vehicle.asleep)
>>>         2025-02-07 13:22:29.184 GMT I (93901954) housekeeping:
>>>         2025-02-07 13:22:28 GMT (RAM: 8b=79028-81980 32b=12560
>>>         SPI=3262992-3285432)
>>>         There should have been the next housekeeping message at
>>>         13:27:29 but none was recorded on the sd. Log flushes are
>>>         configured to occur after 30 seconds.
>>>         The last MQTT metric update my server received was around
>>>         13:27:50. This showed it was connected to home wifi.
>>>         At 13:28 I unlocked the car, started it and drove off
>>>         without noticing anything unusual. None of this activity
>>>         appears in the log.
>>>         During the drive there should have been a connection via
>>>         Hologram to my server, but none was received.
>>>         Ten minutes later at 13:38 I was driving when a yellow
>>>         warning light came on and the car moved to neutral.
>>>         Essentially the same symptoms as in January: turning off and
>>>         on would not clear the fault; it couldn't detect brake
>>>         status meaning it told me to press brake pedal when I
>>>         already was. Also showed I-key system error.
>>>         As I was stranded I used the only option I knew of to clear
>>>         the fault, and I disconnected the 12v battery. On restoring
>>>         power and dismissing the fault notice, it was happy to drive.
>>>         The log shows this cold start SNTP was at 13:44. On
>>>         returning home, unfortunately 'boot status' says nothing
>>>         about a crash, presumably because any information was lost
>>>         when I pulled power.
>>>         So it seems there is some mechanism by which OVMS can lock
>>>         up, without watchdog oversight. And that ten minutes later
>>>         it can do something that becomes a critical issue for the
>>>         car systems.
>>>         Chris
>>>         Relevant log entries below, all part of the same file. 1970
>>>         follows immediately after 13:22:29.184.
>>>         2025-02-07 13:17:50.184 GMT D (93622984) vehicle-poll:
>>>         Pollers: Queue SetState()
>>>         Pollers: PollState(0)
>>>         2025-02-07 13:17:50.184 GMT D (93622984) events:
>>>         Signal(vehicle.off)
>>>         2025-02-07 13:17:51.144 GMT D (93623944) events:
>>>         Signal(vehicle.aux.12v.charging.dip)
>>>         2025-02-07 13:17:53.144 GMT D (93625944) events:
>>>         Signal(vehicle.aux.12v.dip)
>>>         2025-02-07 13:17:54.824 GMT E (93627624) can: can2:
>>>         intr=15711227 rxpkt=15730955 txpkt=100 errflags=0x22401c02
>>>         rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0
>>>         wdgreset=0 errreset=0 txqueue=0
>>>         2025-02-07 13:17:56.754 GMT D (93629554) events:
>>>         Signal(vehicle.locked)
>>>         2025-02-07 13:17:59.744 GMT E (93632544) can: can2:
>>>         intr=15716706 rxpkt=15736447 txpkt=100 errflags=0x23401c01
>>>         2025-02-07 13:18:09.144 GMT D (93641944) events:
>>>         Signal(vehicle.charge.12v.stop)
>>>         2025-02-07 13:18:10.144 GMT I (93642944) powermgmt: No
>>>         longer charging 12V battery..
>>>         2025-02-07 13:18:33.174 GMT D (93665944) events:
>>>         Signal(vehicle.aux.12v.normal)
>>>         2025-02-07 13:18:33.764 GMT E (93666534) can: can2:
>>>         intr=15754521 rxpkt=15774368 txpkt=100 errflags=0x22401c02
>>>         2025-02-07 13:18:45.174 GMT I (93677944) ovms-server-v3:
>>>         Connection is <redacted>
>>>         Status: Connecting...
>>>         2025-02-07 13:18:45.224 GMT D (93677994) events:
>>>         Signal(server.v3.connecting)
>>>         2025-02-07 13:18:48.624 GMT I (93681394) ovms-server-v3:
>>>         Connection successful
>>>         2025-02-07 13:18:48.644 GMT I (93681414) ovms-server-v3:
>>>         Status: OVMS V3 MQTT login successful
>>>         2025-02-07 13:18:48.644 GMT D (93681414) events:
>>>         Signal(server.v3.connected)
>>>         2025-02-07 13:18:49.174 GMT I (93681944) ovms-server-v3:
>>>         Subscribe to MQTT topics
>>>         Transmit all metrics
>>>         2025-02-07 13:18:49.464 GMT I (93682234) ovms-server-v3:
>>>         Subscription acknowledged
>>>         1970-01-01 00:00:08.424 GMT I (7994) command: OpenLogfile:
>>>         now logging to file '/sd/logs/log'
>>>         1970-01-01 00:00:13.474 GMT D (13034) events:
>>>         Signal(system.event)
>>>         Signal(system.wifi.scan.done)
>>>         1970-01-01 00:00:19.424 GMT I (18984) cellular: State: Enter
>>>         Identify state
>>>         1970-01-01 00:00:19.434 GMT I (18994) cellular: Identified
>>>         cellular modem: SIM7600/Experimental support for SIMCOM SIM7600
>>>         1970-01-01 00:00:19.434 GMT I (18994) cellular: Set modem
>>>         driver to 'SIM7600'
>>>         1970-01-01 00:00:19.434 GMT I (18994) cellular: State: Enter
>>>         PoweredOn state
>>>         1970-01-01 00:00:19.424 GMT D (18994) events:
>>>         Signal(system.modem.installed)
>>>         1970-01-01 00:00:19.434 GMT D (19004) events:
>>>         Signal(system.modem.poweredon)
>>>         1970-01-01 00:00:23.474 GMT D (23034) events:
>>>         1970-01-01 00:00:33.474 GMT D (33034) events:
>>>         1970-01-01 00:00:39.434 GMT I (38994) cellular: State: Enter
>>>         MuxStart state
>>>         1970-01-01 00:00:39.444 GMT I (39004) gsm-mux: Start MUX
>>>         1970-01-01 00:00:39.444 GMT D (39004) events:
>>>         Signal(system.modem.muxstart)
>>>         1970-01-01 00:00:39.444 GMT I (39014) gsm-mux: Channel #0 is
>>>         open
>>>         1970-01-01 00:00:39.464 GMT I (39024) gsm-mux: Channel #1 is
>>>         open
>>>         1970-01-01 00:00:39.464 GMT I (39024) gsm-mux: Channel #2 is
>>>         open
>>>         1970-01-01 00:00:39.474 GMT I (39034) gsm-mux: Channel #3 is
>>>         open
>>>         1970-01-01 00:00:39.484 GMT I (39044) gsm-mux: Channel #4 is
>>>         open
>>>         1970-01-01 00:00:40.414 GMT I (39984) cellular: State: Enter
>>>         NetWait state
>>>         1970-01-01 00:00:40.414 GMT D (39984) events:
>>>         Signal(system.modem.netwait)
>>>         1970-01-01 00:00:43.474 GMT D (43034) events:
>>>         1970-01-01 00:00:46.054 GMT D (45624) events:
>>>         Signal(vehicle.awake)
>>>         1970-01-01 00:00:50.444 GMT I (50014) cellular: Network
>>>         Registration status: RegisteredRoaming
>>>         1970-01-01 00:00:51.414 GMT I (50984) cellular: State: Enter
>>>         NetStart state
>>>         1970-01-01 00:00:51.434 GMT D (50994) events:
>>>         Signal(vehicle.aux.12v.blip)
>>>         Signal(system.modem.netstart)
>>>         1970-01-01 00:00:51.444 GMT D (51004) events:
>>>         Signal(vehicle.charge.12v.start)
>>>         1970-01-01 00:00:51.434 GMT I (51004) cellular: Network
>>>         Mode: LTE,Online
>>>         1970-01-01 00:00:52.414 GMT I (51984) powermgmt: Charging
>>>         12V battery..
>>>         1970-01-01 00:00:52.464 GMT I (52034) cellular: PPP
>>>         Connection is ready to start
>>>         1970-01-01 00:00:53.424 GMT I (52984) cellular: State: Enter
>>>         NetMode state
>>>         1970-01-01 00:00:53.424 GMT I (52984) gsm-ppp: Initialising...
>>>         1970-01-01 00:00:53.434 GMT D (52994) events:
>>>         Signal(system.modem.netmode)
>>>         1970-01-01 00:00:53.484 GMT D (53044) events:
>>>         1970-01-01 00:00:53.594 GMT I (53154) gsm-ppp:
>>>         StatusCallBack: None
>>>         1970-01-01 00:00:53.594 GMT I (53154) gsm-ppp: status_cb:
>>>         Connected
>>>         1970-01-01 00:00:53.594 GMT I (53154) gsm-ppp:    our_ipaddr
>>>          = 100.83.212.151
>>>         1970-01-01 00:00:53.594 GMT I (53154) gsm-ppp:    his_ipaddr
>>>          = 10.64.64.64
>>>         1970-01-01 00:00:53.594 GMT I (53154) gsm-ppp:    netmask
>>>           = 255.255.255.255
>>>         1970-01-01 00:00:53.594 GMT I (53154) gsm-ppp:    DNS#0
>>>           = 8.8.8.8
>>>         1970-01-01 00:00:53.584 GMT I (53154) gsm-ppp:    DNS#1
>>>           = 8.8.4.4
>>>          our6_ipaddr = ::
>>>         1970-01-01 00:00:53.594 GMT D (53154) events:
>>>         Signal(network.interface.up)
>>>         1970-01-01 00:00:53.604 GMT D (53164) events:
>>>         Signal(system.modem.gotip)
>>>         1970-01-01 00:00:53.604 GMT I (53164) netmanager: Interface
>>>         priority is pp2 (100.83.212.151/255.255.255.255
>>>         <http://100.83.212.151/255.255.255.255> gateway 10.64.64.64)
>>>         1970-01-01 00:00:53.604 GMT I (53164) netmanager: Set DNS#2
>>>         0.0.0.0
>>>         1970-01-01 00:00:53.594 GMT I (53164) netmanager: MODEM up
>>>         (with WIFI client down): starting network with MODEM
>>>         1970-01-01 00:00:53.594 GMT D (53164) events:
>>>         Signal(network.modem.up)
>>>         1970-01-01 00:00:53.594 GMT D (53164) events: Signal(network.up)
>>>         1970-01-01 00:00:53.604 GMT I (53174) time: Starting SNTP client
>>>         1970-01-01 00:00:53.604 GMT D (53174) events:
>>>         Signal(network.interface.change)
>>>         1970-01-01 00:00:53.614 GMT D (53174) events:
>>>         Signal(network.mgr.init)
>>>         1970-01-01 00:00:53.614 GMT I (53174) webserver: Launching
>>>         Web Server
>>>         2025-02-07 13:44:08.584 GMT I (53184) webserver: Binding to
>>>         port 80 (http)
>>>         2025-02-07 13:44:08.584 GMT I (53184) ssh: Launching SSH Server
>>>         _______________________________________________
>>>         OvmsDev mailing list
>>>         OvmsDev at lists.openvehicles.com
>>>         http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>     Michael Balzer *Am Rahmen 5 * D-58313 Herdecke <https://www.google.com/maps/search/Am+Rahmen+5+*+D-58313+Herdecke?entry=gmail&source=g>
>     Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250209/c66fc458/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250209/c66fc458/attachment-0001.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250209/c66fc458/attachment-0001.sig>
