    Sat Feb  8 19:25:11 HKT 2025
Chris,
Am 04.02.25 um 23:49 schrieb Chris Box:
>> Am 15.01.25 um 11:11 schrieb Michael Balzer via OvmsDev:
>>> Speaking of the Leaf, the code there actually does something fishy
>>> in `CommandWakeup()`:
>>>   unsigned char data = 0;
>>>   m_can1->WriteStandard(0x5C0, *_8_*, &data); //Wakes up the VCM (by
>>> spoofing empty battery request heating)
> I agree that is dodgy. It's going to write 8 bytes of data onto the
> bus, but only the first byte's contents are known. The other 7 are
> nondeterministic - just whatever happened to be on the stack at that
> time. This doesn't seem like a recipe for predictable operation.
I'd say that seems like a recipe for an occasional car fault condition.
If the message needs to be 8 bytes long, I'd expect the car to normally
also process all 8 bytes.
> The commit was
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/09c58a2feda13c32f79c6599fdcb6a7512cf1a48
> by dalathegreat.
> Unfortunately my CAN knowledge is close to zero so I can't comment on
> the messages themselves.
You could try if the 8 is the error here by replacing that by 1, and if
that then no longer works, you could try making data a deterministic 8
null bytes frame.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250208/922dcf09/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250208/922dcf09/attachment.sig>
