[Ovmsdev] UI redesign in Android App - Needs beta testing
Sun Feb 2 18:35:16 HKT 2025
Hey Michael,
I installed the new version and things seem basicly to work for me so
far.
Our e-UP is connected via ODB and T26A. Climate control ist working.
What I'm missing is a response that the climate control message is
accepted. The end result with red arrows layer over the car looks nice,
but I would prefer a two step approach. 1. message accepted, 2. result
OK (the red arrows). The situation on the wake up button is simmilar. I
get no visual response, if the wake up is working (like making the text
bold in the old UI).
The two "home link" buttons on the vehicle screen look lost and mess up
the design (the icons look very different). I only have room for 5
buttons on a row and due to the two home link buttons we have six and
therefor a second row with only one button on it. Not that pretty ...
So far my first impressions.
Regards
Chris
Am Sonntag, dem 02.02.2025 um 09:57 +0100 schrieb Michael Balzer via
OvmsDev:
> Everyone,
> I've merged the UI redesign into `master`. I've been using this for 3
> weeks now without issues, but I can only test my vehicle (VW e-Up),
> and I still can only test the pure OBD installation on that one.
> Please install the latest build
> (https://github.com/openvehicles/Open-Vehicle-Android/tree/master/latest
> ) and test for issues with your vehicle types & configurations.
> A big "thank you" to DFJ (Developer From Jokela), impressive work!
> Am 09.01.25 um 08:33 schrieb Michael Geddes via OvmsDev:
> > Looking good!
> > No crashes when charging
> > Shows as Ioniq 5
> > The widget starts the app correctly.
> > One thing I found was in the  Push Notifications/ command area:
> > Portrait mode:
> > Note the really big boxes. This is because the date column is
> > squished to a couple of pixels and it is displaying it wrapped
> > downwards.
> > Looks fine in landscape mode
> > //.ichael
> > On Tue, 31 Dec 2024, 15:47 Michael Geddes,
> > <frog at bunyip.wheelycreek.net> wrote:
> > > Ah, thanks Chris.  Maybe you need to obey that setting when you
> > > click on the widget then :)
> > > On Tue, 31 Dec 2024 at 15:38, van der Meijden, Chris via OvmsDev
> > > <ovmsdev at lists.openvehicles.com> wrote:
> > > > The apo crashes regardless how I open it.
> > > > I'm running on LineageOS (based on Android 14) without Google.
> > > > I don't give the app GPS permissions.
> > > > @Michael: The old UI is still in the app. You can select it
> > > > from the gear symbol under "Settings".
> > > > Regards
> > > > Chris
> > > > Am 31. Dezember 2024 03:35:21 MEZ schrieb Michael Geddes via
> > > > OvmsDev <ovmsdev at lists.openvehicles.com>:
> > > > > Font size looks all fixed, thanks.
> > > > > For some reason when I click on the widget it opens the old
> > > > > look ovms still... is the old look still hidden somewhere?
> > > > > Also if I start charging my car (not through the app),  then
> > > > > whenever I switch to or open the app, the app crashes.
> > > > > I'm just doing ac charging from a wallbox.
> > > > > //.ichael.
> > > > > On Tue, 31 Dec 2024, 06:48 Developer From Jokela via OvmsDev,
> > > > > > Hi.
> > > > > > New update is released at
> > > > > https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest
> > > > > > Brief:
> > > > > > - Quick actions customisable
> > > > > > - Twizy UI fixes
> > > > > > - Font size related issues should be gone (hopefully ;D)
> > > > > > - DFJ
> > > > > > > van der Meijden, Chris <chris at arachnon.de> kirjoitti
> > > > > > > 30.12.2024 kello 13.12:
> > > > > > > I like the design of the Mercedes Ne app. Don't need a
> > > > > > > one to one copy, but it has a good mixture between info
> > > > > > > and links, I think.
> > > > > > > Am 30. Dezember 2024 11:29:37 MEZ schrieb Developer From
> > > > > > > Jokela <info at developerfromjokela.com>:
> > > > > > > > Hi.
> > > > > > > > What info would you like to be shown on main screen?
> > > > > > > > > On 30. Dec 2024, at 11.16, Chris van der Meijden
> > > > > > > > > <chris at arachnon.de> wrote:
> > > > > > > > > Also many thanks for the effort. The new design is
> > > > > > > > > not my cup of tea, but that is question of personal
> > > > > > > > > liking I suppose. For me the menu is far to present,
> > > > > > > > > whereas the information of the vehicle seems barely
> > > > > > > > > visible.
> > > > > > > > > For the e-Up the climate control throws an error.
> > > > > > > > > "Fehler bei der Kommandoausführung".
> > > > > > > > > Kind regards
> > > > > > > > > Chris
> > > > > > > > > > Thanks for the update. In general I like the new
> > > > > > > > > > design.
> > > > > > > > > > I've attached a screen  shot.  The list box items
> > > > > > > > > > need to resize for larger fonts to stop them being
> > > > > > > > > > all cut off.
> > > > > > > > > > Also where does the "Unknown Vehicle model" come
> > > > > > > > > > from?
> > > > > > > > > > <1000012000.jpg>
> > > > > > > > > > I have a slightly larger font setting:
> > > > > > > > > > <1000012001.jpg>
> > > > > > > > > > Also here:
> > > > > > > > > > <1000012002.jpg>
> > > > > > > > > > ..where the labels are overlapping due to the font
> > > > > > > > > > size.
> > > > > > > > > > And the ... here:
> > > > > > > > > > <1000012003.jpg>
> > > > > > > > > > I'm also getting a crash when opening the settings
> > > > > > > > > > on the map. (App disappears. First time it prompted
> > > > > > > > > > to clear cache which I did)
> > > > > > > > > > Is there a new widget?  If I click on the widget I
> > > > > > > > > > see the old UI.
> > > > > > > > > > //.ichael
> > > > > > > > > > On Mon, 30 Dec 2024, 07:28 Developer From Jokela
> > > > > > > > > > via OvmsDev, <ovmsdev at lists.openvehicles.com>
> > > > > > > > > > wrote:
> > > > > > > > > > > Hi Android users.
> > > > > > > > > > > I’ve recently redesigned UI for Android and it
> > > > > > > > > > > would need some testing.
> > > > > > > > > > > Here is the latest build available for UI
> > > > > > > > > > > redesign:
> > > > > > > > > > > Please report any issues, improvement
> > > > > > > > > > > suggestions, etc.
> > > > > > > > > > > Thank you!
> > > > > > > > > > > Br, DFJ
> > > > > > > > > > > _______________________________________________
> > > > > > > > > > > OvmsDev mailing list
> > > > > > > > > > > OvmsDev at lists.openvehicles.com
> > > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> > > > > > > <Screenshot_20241230-115518_Mercedes-Benz_1.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250202/0c2af25d/attachment-0001.htm>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250202/0c2af25d/attachment-0002.jpg>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250202/0c2af25d/attachment-0003.jpg>
