[Ovmsdev] UI redesign in Android App - Needs beta testing
Sun Feb 2 16:57:15 HKT 2025
Everyone,
I've merged the UI redesign into `master`. I've been using this for 3
weeks now without issues, but I can only test my vehicle (VW e-Up), and
I still can only test the pure OBD installation on that one.
Please install the latest build
(https://github.com/openvehicles/Open-Vehicle-Android/tree/master/latest)
and test for issues with your vehicle types & configurations.
A big "thank you" to DFJ (Developer From Jokela), impressive work!
Am 09.01.25 um 08:33 schrieb Michael Geddes via OvmsDev:
> Looking good!
> No crashes when charging
> Shows as Ioniq 5
> The widget starts the app correctly.
> One thing I found was in the  Push Notifications/ command area:
> Portrait mode:
> Note the really big boxes. This is because the date column is squished
> to a couple of pixels and it is displaying it wrapped downwards.
> Looks fine in landscape mode
> //.ichael
> On Tue, 31 Dec 2024, 15:47 Michael Geddes,
> <frog at bunyip.wheelycreek.net> wrote:
>     Ah, thanks Chris.  Maybe you need to obey that setting when you
>     click on the widget then :)
>     On Tue, 31 Dec 2024 at 15:38, van der Meijden, Chris via OvmsDev
>     <ovmsdev at lists.openvehicles.com> wrote:
>         The apo crashes regardless how I open it.
>         I'm running on LineageOS (based on Android 14) without Google.
>         I don't give the app GPS permissions.
>         @Michael: The old UI is still in the app. You can select it
>         from the gear symbol under "Settings".
>         Regards
>         Chris
>         Am 31. Dezember 2024 03:35:21 MEZ schrieb Michael Geddes via
>         OvmsDev <ovmsdev at lists.openvehicles.com>:
>             Font size looks all fixed, thanks.
>             For some reason when I click on the widget it opens the
>             old look ovms still... is the old look still hidden somewhere?
>             Also if I start charging my car (not through the app),
>             then whenever I switch to or open the app, the app crashes.
>             I'm just doing ac charging from a wallbox.
>             //.ichael.
>             On Tue, 31 Dec 2024, 06:48 Developer From Jokela via
>             OvmsDev, <ovmsdev at lists.openvehicles.com> wrote:
>                 Hi.
>                 New update is released at
>                 https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest.
>                 Brief:
>                 - Quick actions customisable
>                 - Twizy UI fixes
>                 - Font size related issues should be gone (hopefully ;D)
>                 - DFJ
>>                 van der Meijden, Chris <chris at arachnon.de> kirjoitti
>>                 30.12.2024 kello 13.12:
>>                 I like the design of the Mercedes Ne app. Don't need
>>                 a one to one copy, but it has a good mixture between
>>                 info and links, I think.
>>                 Am 30. Dezember 2024 11:29:37 MEZ schrieb Developer
>>                 From Jokela <info at developerfromjokela.com>:
>>                     Hi.
>>                     What info would you like to be shown on main screen?
>>>                     On 30. Dec 2024, at 11.16, Chris van der Meijden
>>>                     <chris at arachnon.de> wrote:
>>>                     Also many thanks for the effort. The new design
>>>                     is not my cup of tea, but that is question of
>>>                     personal liking I suppose. For me the menu is
>>>                     far to present, whereas the information of the
>>>                     vehicle seems barely visible.
>>>                     For the e-Up the climate control throws an
>>>                     error. "Fehler bei der Kommandoausführung".
>>>                     Kind regards
>>>                     Chris
>>>>                     Thanks for the update. In general I like the
>>>>                     new design.
>>>>                     I've attached a screen  shot. The list box
>>>>                     items need to resize for larger fonts to stop
>>>>                     them being all cut off.
>>>>                     Also where does the "Unknown Vehicle model"
>>>>                     come from?
>>>>                     <1000012000.jpg>
>>>>                     I have a slightly larger font setting:
>>>>                     <1000012001.jpg>
>>>>                     Also here:
>>>>                     <1000012002.jpg>
>>>>                     ..where the labels are overlapping due to the
>>>>                     font size.
>>>>                     And the ... here:
>>>>                     <1000012003.jpg>
>>>>                     I'm also getting a crash when opening the
>>>>                     settings on the map. (App disappears. First
>>>>                     time it prompted to clear cache which I did)
>>>>                     Is there a new widget?  If I click on the
>>>>                     widget I see the old UI.
>>>>                     //.ichael
>>>>                     On Mon, 30 Dec 2024, 07:28 Developer From
>>>>                     Jokela via OvmsDev,
>>>>>                     Hi Android users.
>>>>>                     I’ve recently redesigned UI for Android and it
>>>>>                     would need some testing.
>>>>>                     Here is the latest build available for UI
>>>>>                     redesign:
>>>>>                     Please report any issues, improvement
>>>>>                     suggestions, etc.
>>>>>                     Thank you!
>>>>>                     Br, DFJ
>>>>>                     _______________________________________________
>>>>>                     OvmsDev mailing list
>>>>>                     OvmsDev at lists.openvehicles.com
>>>>>                     http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>                 <Screenshot_20241230-115518_Mercedes-Benz_1.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250202/e6059648/attachment-0001.htm>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250202/e6059648/attachment-0002.jpg>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250202/e6059648/attachment-0003.jpg>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250202/e6059648/attachment-0001.sig>
