[Ovmsdev] High hologram usage
Fri Apr 18 15:03:18 HKT 2025
As you're looking for a network issue, setting level debug for
netmanager, cellular and esp32wifi might help.
Your log shows you actually do use server-v3 with your own server at
xse.com, and your log shows there are wifi reconnects to the same
network every four minutes.
With the running v3 client, each reconnect means a full retransmission
of all metrics, as also logged. If that 4 minute period also occurs
while on cellular, that's your culprit.
Am 17.04.25 um 21:20 schrieb Craig Leres:
> On 4/17/25 00:50, Michael Balzer via OvmsDev wrote:
>> if (?) you're running a server v3 instance with the shown
>> "example.net" config, the keepalive is not your main issue, as it
>> will keep retrying to connect indefinitely. But it would have done so
>> all the time already.
>> Regarding wifi/cellular, did you check your logs yet for unexpected
>> switches?
> I'm not sure how to do that.
> What logging level should I be using for this?
> I'll attach some logs for a 24 hour period when I was running
> 3.3.004-313-g78a49a59
> FYI, I'm going to have to stop investigating for a bit so don't think
> I've forgotten about it if you don't hear from me for a few weeks...
>         Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250418/561ecb4f/attachment.sig>
