[Ovmsdev] High hologram usage
Craig Leres
leres at xse.com
Sat Apr 19 03:57:36 HKT 2025
On 4/18/25 00:03, Michael Balzer via OvmsDev wrote:
> As you're looking for a network issue, setting level debug for
> netmanager, cellular and esp32wifi might help.
Ok, I'll report back later after turning those on.
> Your log shows you actually do use server-v3 with your own server at
> xse.com, and your log shows there are wifi reconnects to the same
> network every four minutes.
> With the running v3 client, each reconnect means a full retransmission
> of all metrics, as also logged. If that 4 minute period also occurs
> while on cellular, that's your culprit.
I'm still not understanding what changed in 3.3.004-313-g78a49a59 to
increase cellular usage by 10X.
My AP is a ruckus R710. I checked and the "inactivity timeout" is not
enabled for the ssid used.
It looks to me as if the wifi goes to sleep and the module switches to
cellular instead of re-connecting to wifi. Maybe it takes longer for the
wifi to re-connect than the code is willing to wait before switching to
celluar?
Craig
