[Ovmsdev] High hologram usage
Craig Leres leres at xse.com
Fri Apr 18 03:20:15 HKT 2025
On 4/17/25 00:50, Michael Balzer via OvmsDev wrote:
> if (?) you're running a server v3 instance with the shown "example.net"
> config, the keepalive is not your main issue, as it will keep retrying
> to connect indefinitely. But it would have done so all the time already.
> Regarding wifi/cellular, did you check your logs yet for unexpected
> switches?
I'm not sure how to do that.
What logging level should I be using for this?
I'll attach some logs for a 24 hour period when I was running
3.3.004-313-g78a49a59
FYI, I'm going to have to stop investigating for a bit so don't think
I've forgotten about it if you don't hear from me for a few weeks...
		Craig
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250417/569aadc1/attachment-0001.png>
Type: application/gzip
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250417/569aadc1/attachment-0001.gz>
