[Ovmsdev] Nissan Leaf ZE1 - Total loss of power
Sat Apr 12 15:29:48 HKT 2025
Chris, Wayne,
you can help by testing switching off the SN65:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/980#issuecomment-2715850440
As Richard wrote, he could not reproduce the issue in his Leaf by that,
but on his bench. If that's the culprit, there still is the Housekeeping
SN65 switch-off to address, but there is probably little we can do about
cold boots.
Regarding floating voltages, see Richards followup post.
Also I suggest asking Richard how you can help in narrowing this down.
Am 11.04.25 um 23:18 schrieb Wayne Love via OvmsDev:
>> Rather than the crash, it could be the subsequent boot that causes the problem.
>> Previously I've caused the 2016 car to throw dashboard errors by typing "module reset" over SSH while charging was in progress. I assume this is an orderly shutdown, and hence it's the boot process that disturbs the CAN bus of an active car.
>> Chris
> My thinking is that the issue is caused when the module goes down. The reason that I say this is that in my instances when the module crashes it does not come back up again, you need to power cycle it for it to restart.
> Is there a chance that we are seeing floating voltages on the CAN connectors when they are not actively controlled by the cpu?
> Cheers
> Wayne
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250412/0efb6278/attachment.sig>
